--- ray/src/cv/tmesh2rad.c 2008/11/10 19:08:18 2.16 +++ ray/src/cv/tmesh2rad.c 2014/04/11 20:27:23 2.17 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: tmesh2rad.c,v 2.16 2008/11/10 19:08:18 greg Exp $"; +static const char RCSid[] = "$Id: tmesh2rad.c,v 2.17 2014/04/11 20:27:23 greg Exp $"; #endif /* * Convert a trianglular mesh into a Radiance description. @@ -124,8 +124,8 @@ convert( /* convert a T-mesh */ char picfile[128]; char matname[64]; char objname[64]; - register int i; - register VERTEX *lastv; + int i; + VERTEX *lastv; /* start fresh */ i = nverts; lastv = vlist; @@ -212,9 +212,9 @@ triangle( /* put out a triangle */ char *pn, char *mod, char *obj, - register VERTEX *v1, - register VERTEX *v2, - register VERTEX *v3 + VERTEX *v1, + VERTEX *v2, + VERTEX *v3 ) { static char vfmt[] = "%18.12g %18.12g %18.12g\n"; @@ -222,7 +222,7 @@ triangle( /* put out a triangle */ int flatness = ISFLAT; BARYCCM bvecs; RREAL bvm[3][3]; - register int i; + int i; /* compute barycentric coordinates */ if (v1->flags & v2->flags & v3->flags & (V_HASINDX|V_HASNORM)) if (comp_baryc(&bvecs, v1->pos, v2->pos, v3->pos) < 0) @@ -277,13 +277,13 @@ triangle( /* put out a triangle */ VERTEX * vnew( /* create a new vertex */ - register int id, + int id, double x, double y, double z ) { - register int i; + int i; if (id >= nverts) { /* get some more */ i = nverts; @@ -314,13 +314,13 @@ vnew( /* create a new vertex */ void syntax( /* report syntax error and exit */ char *fn, - register FILE *fp, + FILE *fp, char *er ) { extern long ftell(); - register long cpos; - register int c; + long cpos; + int c; int lineno; if (fp == stdin)
