--- ray/src/cv/tmesh2rad.c 2003/07/27 22:12:02 2.14 +++ ray/src/cv/tmesh2rad.c 2008/11/10 19:08:18 2.16 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: tmesh2rad.c,v 2.14 2003/07/27 22:12:02 schorsch Exp $"; +static const char RCSid[] = "$Id: tmesh2rad.c,v 2.16 2008/11/10 19:08:18 greg Exp $"; #endif /* * Convert a trianglular mesh into a Radiance description. @@ -29,8 +29,11 @@ static const char RCSid[] = "$Id: tmesh2rad.c,v 2.14 2 * It is not necessary for the normal vectors to have unit length. */ -#include "standard.h" +#include +#include +#include "rtmath.h" + #include "tmesh.h" #define VOIDID "void" /* this is defined in object.h */ @@ -62,10 +65,17 @@ char *defmat = VOIDID; /* default (starting) material char *defpat = ""; /* default (starting) picture name */ char *defobj = "T"; /* default (starting) object name */ +void convert(char *fname, FILE *fp); +void triangle(char *pn,char *mod,char *obj, VERTEX *v1,VERTEX *v2,VERTEX *v3); +VERTEX *vnew(int id, double x, double y, double z); +void syntax(char *fn, FILE *fp, char *er); -main(argc, argv) /* read in T-mesh files and convert */ -int argc; -char *argv[]; + +int +main( /* read in T-mesh files and convert */ + int argc, + char *argv[] +) { FILE *fp; int i; @@ -83,7 +93,7 @@ char *argv[]; break; default: fprintf(stderr, - "Usage: %s [-o obj][-m mat][-p pic] [file ..]\n", + "Usage: %s [-o obj][-m mat][-p hdr] [file ..]\n", argv[0]); exit(1); } @@ -102,9 +112,11 @@ char *argv[]; } -convert(fname, fp) /* convert a T-mesh */ -char *fname; -FILE *fp; +void +convert( /* convert a T-mesh */ + char *fname, + FILE *fp +) { char typ[4]; int id[3]; @@ -195,9 +207,15 @@ FILE *fp; } -triangle(pn, mod, obj, v1, v2, v3) /* put out a triangle */ -char *pn, *mod, *obj; -register VERTEX *v1, *v2, *v3; +void +triangle( /* put out a triangle */ + char *pn, + char *mod, + char *obj, + register VERTEX *v1, + register VERTEX *v2, + register VERTEX *v3 +) { static char vfmt[] = "%18.12g %18.12g %18.12g\n"; static int ntri = 0; @@ -258,9 +276,12 @@ register VERTEX *v1, *v2, *v3; VERTEX * -vnew(id, x, y, z) /* create a new vertex */ -register int id; -double x, y, z; +vnew( /* create a new vertex */ + register int id, + double x, + double y, + double z +) { register int i; @@ -290,10 +311,12 @@ double x, y, z; } -syntax(fn, fp, er) /* report syntax error and exit */ -char *fn; -register FILE *fp; -char *er; +void +syntax( /* report syntax error and exit */ + char *fn, + register FILE *fp, + char *er +) { extern long ftell(); register long cpos;
