root/radiance/ray/src/cv/tmesh2rad.c
Thu Apr 15 23:51:04 2021 UTC (4 years, 3 months ago) by greg
Diff to previous 2.17 , to selected 2.12
Fri Apr 11 20:27:23 2014 UTC (11 years, 3 months ago) by greg
Changes since 2.16: +12 -12 lines
Made reading of vectors more consistent with FVFORMAT macro
Mon Nov 10 19:08:18 2008 UTC (16 years, 8 months ago) by greg
CVS Tags: rad4R0, rad4R1
Sat Nov 15 17:54:06 2003 UTC (21 years, 8 months ago) by schorsch
Changes since 2.14: +41 -18 lines
Sun Jul 27 22:12:02 2003 UTC (22 years ago) by schorsch
Thu Jun 26 00:58:09 2003 UTC (22 years, 1 month ago) by schorsch
Diff to previous 2.12
Wed Apr 23 00:52:33 2003 UTC (22 years, 3 months ago) by greg
Tue Mar 4 01:42:29 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.10: +20 -7 lines
Fixed problems with normals and orientations that disagree.
Sat Feb 22 02:07:23 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.9: +1 -4 lines
Wed Jul 24 13:07:44 1996 UTC (29 years ago) by greg
added check for flat triangles with normals
Wed Jun 22 12:35:58 1994 UTC (31 years, 1 month ago) by greg
Changes since 2.7: +3 -76 lines
Wed Jun 15 19:06:02 1994 UTC (31 years, 1 month ago) by greg
cosmetic fix to parameters of put_baryc
Wed Jun 15 15:07:06 1994 UTC (31 years, 1 month ago) by greg
Changes since 2.5: +31 -18 lines
further reduced complexity and size of barycentric calculation
Wed Jun 15 12:38:29 1994 UTC (31 years, 1 month ago) by greg
Changes since 2.4: +42 -29 lines
removed gensurf quadrilateral code to make smoothing work better
Tue Mar 22 08:54:23 1994 UTC (31 years, 4 months ago) by greg
bug fix in vnew()
Fri Feb 18 13:11:35 1994 UTC (31 years, 5 months ago) by greg
Changes since 2.2: +70 -30 lines
a few enhancements, a little beautification
Fri Feb 18 09:29:26 1994 UTC (31 years, 5 months ago) by greg
Changes since 2.1: +10 -6 lines
initial bug fixes
Tue Feb 15 15:58:03 1994 UTC (31 years, 5 months ago) by greg
Diff to selected 2.12
