| 1 |
greg |
2.1 |
#ifndef lint
| 2 |
greg |
2.17 |
static const char RCSid[] = "$Id: tmesh2rad.c,v 2.16 2008/11/10 19:08:18 greg Exp $";
| 3 |
greg |
2.1 |
#endif
| 4 |
| 5 |
greg |
2.3 |
* Convert a trianglular mesh into a Radiance description.
| 6 |
greg |
2.1 |
| 7 |
* Unlike most other converters, we have defined a file
| 8 |
greg |
2.3 |
* format for the input ourselves. The format contains eight types,
| 9 |
greg |
2.1 |
* each of which is identified by a single letter. These are:
| 10 |
| 11 |
* # comment = a comment. Continues until end of line.
| 12 |
* v id Px Py Pz = a vertex. The id must be an integer.
| 13 |
* n Nx Ny Nz = a normal. Corresponds to most recent vertex.
| 14 |
* i Iu Iv = an index. Corresponds to most recent vertex.
| 15 |
greg |
2.3 |
* p picture = a picture. Used as a pattern for following.
| 16 |
greg |
2.1 |
* m material = a material name. Used for what follows.
| 17 |
greg |
2.3 |
* o object = an object name. Used for what follows.
| 18 |
greg |
2.1 |
* t id1 id2 id3 = a triangle.
| 19 |
| 20 |
* Only the 't' type results in any output. The others merely set values
| 21 |
* to be used in generating triangles. If no picture or "p -" is given,
| 22 |
* there will be no pattern associated with the geometry. If no material
| 23 |
* or "m -" is given, no material will be associated. (Note that this
| 24 |
* only makes sense for a mesh which is to be put into an octree for
| 25 |
* instancing.) Using a pattern requires that each vertex have an
| 26 |
* associated index value for generating the colorpict primitive.
| 27 |
greg |
2.3 |
* Likewise, an interpolated surface normal also requires that each
| 28 |
* vertex of the triangle have an associated normal vector.
| 29 |
* It is not necessary for the normal vectors to have unit length.
| 30 |
greg |
2.1 |
| 31 |
| 32 |
schorsch |
2.15 |
#include <stdlib.h>
| 33 |
#include <stdio.h>
| 34 |
| 35 |
#include "rtmath.h"
| 36 |
greg |
2.1 |
| 37 |
greg |
2.8 |
#include "tmesh.h"
| 38 |
greg |
2.5 |
| 39 |
greg |
2.3 |
#define VOIDID "void" /* this is defined in object.h */
| 40 |
| 41 |
#define PATNAME "T-pat" /* triangle pattern name (reused) */
| 42 |
#define TEXNAME "T-nor" /* triangle texture name (reused) */
| 43 |
greg |
2.1 |
| 44 |
#define V_DEFINED 01 /* this vertex is defined */
| 45 |
#define V_HASNORM 02 /* vertex has surface normal */
| 46 |
#define V_HASINDX 04 /* vertex has index */
| 47 |
| 48 |
typedef struct {
| 49 |
short flags; /* vertex flags, from above */
| 50 |
FVECT pos; /* location */
| 51 |
FVECT nor; /* normal */
| 52 |
float ndx[2]; /* picture index */
| 53 |
} VERTEX;
| 54 |
| 55 |
VERTEX *vlist = NULL; /* our vertex list */
| 56 |
int nverts = 0; /* number of vertices in our list */
| 57 |
| 58 |
schorsch |
2.14 |
#define novert(i) (((i)<0)|((i)>=nverts) || !(vlist[i].flags&V_DEFINED))
| 59 |
greg |
2.1 |
| 60 |
#define CHUNKSIZ 128 /* vertex allocation chunk size */
| 61 |
| 62 |
extern VERTEX *vnew(); /* allocate a vertex (never freed) */
| 63 |
| 64 |
greg |
2.3 |
char *defmat = VOIDID; /* default (starting) material name */
| 65 |
char *defpat = ""; /* default (starting) picture name */
| 66 |
char *defobj = "T"; /* default (starting) object name */
| 67 |
greg |
2.1 |
| 68 |
schorsch |
2.15 |
void convert(char *fname, FILE *fp);
| 69 |
void triangle(char *pn,char *mod,char *obj, VERTEX *v1,VERTEX *v2,VERTEX *v3);
| 70 |
VERTEX *vnew(int id, double x, double y, double z);
| 71 |
void syntax(char *fn, FILE *fp, char *er);
| 72 |
| 73 |
greg |
2.3 |
| 74 |
schorsch |
2.15 |
int
| 75 |
main( /* read in T-mesh files and convert */
| 76 |
int argc,
| 77 |
char *argv[]
| 78 |
| 79 |
greg |
2.1 |
| 80 |
FILE *fp;
| 81 |
int i;
| 82 |
| 83 |
greg |
2.3 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 84 |
switch (argv[i][1]) {
| 85 |
case 'o': /* object name */
| 86 |
defobj = argv[++i];
| 87 |
break;
| 88 |
case 'm': /* default material */
| 89 |
defmat = argv[++i];
| 90 |
break;
| 91 |
case 'p': /* default picture */
| 92 |
defpat = argv[++i];
| 93 |
break;
| 94 |
default:
| 95 |
fprintf(stderr,
| 96 |
greg |
2.16 |
"Usage: %s [-o obj][-m mat][-p hdr] [file ..]\n",
| 97 |
greg |
2.3 |
argv[0]);
| 98 |
exit(1);
| 99 |
| 100 |
if (i >= argc)
| 101 |
greg |
2.1 |
convert("<stdin>", stdin);
| 102 |
else
| 103 |
greg |
2.3 |
for ( ; i < argc; i++) {
| 104 |
greg |
2.1 |
if ((fp = fopen(argv[i], "r")) == NULL) {
| 105 |
perror(argv[i]);
| 106 |
exit(1);
| 107 |
| 108 |
convert(argv[i], fp);
| 109 |
fclose(fp);
| 110 |
| 111 |
exit(0);
| 112 |
| 113 |
| 114 |
| 115 |
schorsch |
2.15 |
void
| 116 |
convert( /* convert a T-mesh */
| 117 |
char *fname,
| 118 |
FILE *fp
| 119 |
| 120 |
greg |
2.1 |
| 121 |
greg |
2.3 |
char typ[4];
| 122 |
greg |
2.1 |
int id[3];
| 123 |
double vec[3];
| 124 |
char picfile[128];
| 125 |
char matname[64];
| 126 |
greg |
2.3 |
char objname[64];
| 127 |
greg |
2.17 |
int i;
| 128 |
VERTEX *lastv;
| 129 |
greg |
2.3 |
/* start fresh */
| 130 |
i = nverts;
| 131 |
lastv = vlist;
| 132 |
while (i--)
| 133 |
(lastv++)->flags = 0;
| 134 |
lastv = NULL;
| 135 |
strcpy(picfile, defpat);
| 136 |
strcpy(matname, defmat);
| 137 |
strcpy(objname, defobj);
| 138 |
greg |
2.1 |
| 139 |
greg |
2.3 |
printf("\n## T-mesh read from: %s\n", fname);
| 140 |
/* scan until EOF */
| 141 |
greg |
2.1 |
while (fscanf(fp, "%1s", typ) == 1)
| 142 |
switch (typ[0]) {
| 143 |
case 'v': /* vertex */
| 144 |
if (fscanf(fp, "%d %lf %lf %lf", &id[0],
| 145 |
&vec[0], &vec[1], &vec[2]) != 4)
| 146 |
syntax(fname, fp, "Bad vertex");
| 147 |
lastv = vnew(id[0], vec[0], vec[1], vec[2]);
| 148 |
break;
| 149 |
case 't': /* triangle */
| 150 |
if (fscanf(fp, "%d %d %d", &id[0], &id[1], &id[2]) != 3)
| 151 |
syntax(fname, fp, "Bad triangle");
| 152 |
if (novert(id[0]) | novert(id[1]) | novert(id[2]))
| 153 |
syntax(fname, fp, "Undefined triangle vertex");
| 154 |
greg |
2.3 |
triangle(picfile, matname, objname, &vlist[id[0]],
| 155 |
greg |
2.1 |
&vlist[id[1]], &vlist[id[2]]);
| 156 |
break;
| 157 |
case 'n': /* surface normal */
| 158 |
if (lastv == NULL)
| 159 |
syntax(fname, fp, "No vertex for normal");
| 160 |
if (fscanf(fp, "%lf %lf %lf",
| 161 |
&vec[0], &vec[1], &vec[2]) != 3)
| 162 |
syntax(fname, fp, "Bad vertex normal");
| 163 |
lastv->nor[0] = vec[0];
| 164 |
lastv->nor[1] = vec[1];
| 165 |
lastv->nor[2] = vec[2];
| 166 |
if (normalize(lastv->nor) == 0.0)
| 167 |
syntax(fname, fp, "Zero vertex normal");
| 168 |
lastv->flags |= V_HASNORM;
| 169 |
break;
| 170 |
case 'i': /* index position */
| 171 |
if (lastv == NULL)
| 172 |
syntax(fname, fp, "No vertex for index");
| 173 |
if (fscanf(fp, "%lf %lf", &vec[0], &vec[1]) != 2)
| 174 |
syntax(fname, fp, "Bad index");
| 175 |
lastv->ndx[0] = vec[0];
| 176 |
lastv->ndx[1] = vec[1];
| 177 |
lastv->flags |= V_HASINDX;
| 178 |
break;
| 179 |
greg |
2.3 |
| 180 |
if (fscanf(fp, "%s", objname) != 1)
| 181 |
syntax(fname, fp, "Bad object name");
| 182 |
break;
| 183 |
greg |
2.1 |
case 'm': /* material */
| 184 |
if (fscanf(fp, "%s", matname) != 1)
| 185 |
syntax(fname, fp, "Bad material");
| 186 |
if (matname[0] == '-' && !matname[1])
| 187 |
greg |
2.3 |
strcpy(matname, VOIDID);
| 188 |
greg |
2.1 |
break;
| 189 |
case 'p': /* picture */
| 190 |
if (fscanf(fp, "%s", picfile) != 1)
| 191 |
syntax(fname, fp, "Bad pattern");
| 192 |
if (picfile[0] == '-' && !picfile[1])
| 193 |
picfile[0] = '\0';
| 194 |
break;
| 195 |
case '#': /* comment */
| 196 |
greg |
2.3 |
fputs("\n#", stdout);
| 197 |
while ((i = getc(fp)) != EOF) {
| 198 |
putchar(i);
| 199 |
if (i == '\n')
| 200 |
break;
| 201 |
| 202 |
greg |
2.1 |
break;
| 203 |
default:
| 204 |
syntax(fname, fp, "Unknown type");
| 205 |
break;
| 206 |
| 207 |
| 208 |
| 209 |
| 210 |
schorsch |
2.15 |
void
| 211 |
triangle( /* put out a triangle */
| 212 |
char *pn,
| 213 |
char *mod,
| 214 |
char *obj,
| 215 |
greg |
2.17 |
VERTEX *v1,
| 216 |
VERTEX *v2,
| 217 |
VERTEX *v3
| 218 |
schorsch |
2.15 |
| 219 |
greg |
2.1 |
| 220 |
greg |
2.11 |
static char vfmt[] = "%18.12g %18.12g %18.12g\n";
| 221 |
greg |
2.1 |
static int ntri = 0;
| 222 |
greg |
2.11 |
int flatness = ISFLAT;
| 223 |
greg |
2.1 |
BARYCCM bvecs;
| 224 |
schorsch |
2.13 |
RREAL bvm[3][3];
| 225 |
greg |
2.17 |
int i;
| 226 |
greg |
2.1 |
/* compute barycentric coordinates */
| 227 |
if (v1->flags & v2->flags & v3->flags & (V_HASINDX|V_HASNORM))
| 228 |
greg |
2.5 |
if (comp_baryc(&bvecs, v1->pos, v2->pos, v3->pos) < 0)
| 229 |
greg |
2.1 |
return;
| 230 |
greg |
2.11 |
/* check flatness */
| 231 |
if (v1->flags & v2->flags & v3->flags & V_HASNORM) {
| 232 |
flatness = flat_tri(v1->pos, v2->pos, v3->pos,
| 233 |
v1->nor, v2->nor, v3->nor);
| 234 |
if (flatness == DEGEN)
| 235 |
return;
| 236 |
| 237 |
greg |
2.1 |
/* put out texture (if any) */
| 238 |
greg |
2.11 |
if (flatness == ISBENT || flatness == RVBENT) {
| 239 |
greg |
2.1 |
printf("\n%s texfunc %s\n", mod, TEXNAME);
| 240 |
mod = TEXNAME;
| 241 |
greg |
2.8 |
printf("4 dx dy dz %s\n", TCALNAME);
| 242 |
greg |
2.6 |
printf("0\n");
| 243 |
for (i = 0; i < 3; i++) {
| 244 |
bvm[i][0] = v1->nor[i];
| 245 |
bvm[i][1] = v2->nor[i];
| 246 |
bvm[i][2] = v3->nor[i];
| 247 |
| 248 |
put_baryc(&bvecs, bvm, 3);
| 249 |
greg |
2.1 |
| 250 |
/* put out pattern (if any) */
| 251 |
if (*pn && (v1->flags & v2->flags & v3->flags & V_HASINDX)) {
| 252 |
printf("\n%s colorpict %s\n", mod, PATNAME);
| 253 |
mod = PATNAME;
| 254 |
greg |
2.8 |
printf("7 noneg noneg noneg %s %s u v\n", pn, TCALNAME);
| 255 |
greg |
2.6 |
printf("0\n");
| 256 |
for (i = 0; i < 2; i++) {
| 257 |
bvm[i][0] = v1->ndx[i];
| 258 |
bvm[i][1] = v2->ndx[i];
| 259 |
bvm[i][2] = v3->ndx[i];
| 260 |
| 261 |
put_baryc(&bvecs, bvm, 2);
| 262 |
greg |
2.1 |
| 263 |
greg |
2.11 |
/* put out (reversed) triangle */
| 264 |
greg |
2.3 |
printf("\n%s polygon %s.%d\n", mod, obj, ++ntri);
| 265 |
greg |
2.1 |
printf("0\n0\n9\n");
| 266 |
greg |
2.11 |
if (flatness == RVFLAT || flatness == RVBENT) {
| 267 |
printf(vfmt, v3->pos[0],v3->pos[1],v3->pos[2]);
| 268 |
printf(vfmt, v2->pos[0],v2->pos[1],v2->pos[2]);
| 269 |
printf(vfmt, v1->pos[0],v1->pos[1],v1->pos[2]);
| 270 |
} else {
| 271 |
| 272 |
| 273 |
| 274 |
| 275 |
greg |
2.1 |
| 276 |
| 277 |
| 278 |
VERTEX *
| 279 |
schorsch |
2.15 |
vnew( /* create a new vertex */
| 280 |
greg |
2.17 |
int id,
| 281 |
schorsch |
2.15 |
double x,
| 282 |
double y,
| 283 |
double z
| 284 |
| 285 |
greg |
2.1 |
| 286 |
greg |
2.17 |
int i;
| 287 |
greg |
2.1 |
| 288 |
greg |
2.4 |
if (id >= nverts) { /* get some more */
| 289 |
greg |
2.1 |
i = nverts;
| 290 |
greg |
2.4 |
nverts = CHUNKSIZ*((id/CHUNKSIZ)+1);
| 291 |
greg |
2.1 |
if (vlist == NULL)
| 292 |
vlist = (VERTEX *)malloc(nverts*sizeof(VERTEX));
| 293 |
else
| 294 |
greg |
2.12 |
vlist = (VERTEX *)realloc((void *)vlist,
| 295 |
greg |
2.1 |
| 296 |
if (vlist == NULL) {
| 297 |
fprintf(stderr,
| 298 |
"Out of memory while allocating vertex %d\n", id);
| 299 |
exit(1);
| 300 |
| 301 |
greg |
2.3 |
while (i < nverts) /* clear what's new */
| 302 |
greg |
2.1 |
vlist[i++].flags = 0;
| 303 |
| 304 |
greg |
2.3 |
/* assign new vertex */
| 305 |
greg |
2.1 |
vlist[id].pos[0] = x;
| 306 |
vlist[id].pos[1] = y;
| 307 |
vlist[id].pos[2] = z;
| 308 |
vlist[id].flags = V_DEFINED;
| 309 |
/* return it */
| 310 |
return(&vlist[id]);
| 311 |
| 312 |
| 313 |
| 314 |
schorsch |
2.15 |
void
| 315 |
syntax( /* report syntax error and exit */
| 316 |
char *fn,
| 317 |
greg |
2.17 |
FILE *fp,
| 318 |
schorsch |
2.15 |
char *er
| 319 |
| 320 |
greg |
2.1 |
| 321 |
extern long ftell();
| 322 |
greg |
2.17 |
long cpos;
| 323 |
int c;
| 324 |
greg |
2.1 |
int lineno;
| 325 |
| 326 |
if (fp == stdin)
| 327 |
greg |
2.3 |
fprintf(stderr, "%s: T-mesh format error: %s\n", fn, er);
| 328 |
greg |
2.1 |
else {
| 329 |
cpos = ftell(fp);
| 330 |
fseek(fp, 0L, 0);
| 331 |
lineno = 1;
| 332 |
while (cpos-- > 0) {
| 333 |
if ((c = getc(fp)) == EOF)
| 334 |
break;
| 335 |
if (c == '\n')
| 336 |
lineno++;
| 337 |
| 338 |
greg |
2.3 |
fprintf(stderr, "%s: T-mesh format error at line %d: %s\n",
| 339 |
greg |
2.1 |
fn, lineno, er);
| 340 |
| 341 |
exit(1);
| 342 |
