1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: tmesh2rad.c,v 2.13 2003/06/26 00:58:09 schorsch Exp $"; |
3 |
#endif |
4 |
5 |
* Convert a trianglular mesh into a Radiance description. |
6 |
7 |
* Unlike most other converters, we have defined a file |
8 |
* format for the input ourselves. The format contains eight types, |
9 |
* each of which is identified by a single letter. These are: |
10 |
11 |
* # comment = a comment. Continues until end of line. |
12 |
* v id Px Py Pz = a vertex. The id must be an integer. |
13 |
* n Nx Ny Nz = a normal. Corresponds to most recent vertex. |
14 |
* i Iu Iv = an index. Corresponds to most recent vertex. |
15 |
* p picture = a picture. Used as a pattern for following. |
16 |
* m material = a material name. Used for what follows. |
17 |
* o object = an object name. Used for what follows. |
18 |
* t id1 id2 id3 = a triangle. |
19 |
20 |
* Only the 't' type results in any output. The others merely set values |
21 |
* to be used in generating triangles. If no picture or "p -" is given, |
22 |
* there will be no pattern associated with the geometry. If no material |
23 |
* or "m -" is given, no material will be associated. (Note that this |
24 |
* only makes sense for a mesh which is to be put into an octree for |
25 |
* instancing.) Using a pattern requires that each vertex have an |
26 |
* associated index value for generating the colorpict primitive. |
27 |
* Likewise, an interpolated surface normal also requires that each |
28 |
* vertex of the triangle have an associated normal vector. |
29 |
* It is not necessary for the normal vectors to have unit length. |
30 |
31 |
32 |
#include "standard.h" |
33 |
34 |
#include "tmesh.h" |
35 |
36 |
#define VOIDID "void" /* this is defined in object.h */ |
37 |
38 |
#define PATNAME "T-pat" /* triangle pattern name (reused) */ |
39 |
#define TEXNAME "T-nor" /* triangle texture name (reused) */ |
40 |
41 |
#define V_DEFINED 01 /* this vertex is defined */ |
42 |
#define V_HASNORM 02 /* vertex has surface normal */ |
43 |
#define V_HASINDX 04 /* vertex has index */ |
44 |
45 |
typedef struct { |
46 |
short flags; /* vertex flags, from above */ |
47 |
FVECT pos; /* location */ |
48 |
FVECT nor; /* normal */ |
49 |
float ndx[2]; /* picture index */ |
50 |
} VERTEX; |
51 |
52 |
VERTEX *vlist = NULL; /* our vertex list */ |
53 |
int nverts = 0; /* number of vertices in our list */ |
54 |
55 |
#define novert(i) (((i)<0)|((i)>=nverts) || !(vlist[i].flags&V_DEFINED)) |
56 |
57 |
#define CHUNKSIZ 128 /* vertex allocation chunk size */ |
58 |
59 |
extern VERTEX *vnew(); /* allocate a vertex (never freed) */ |
60 |
61 |
char *defmat = VOIDID; /* default (starting) material name */ |
62 |
char *defpat = ""; /* default (starting) picture name */ |
63 |
char *defobj = "T"; /* default (starting) object name */ |
64 |
65 |
66 |
main(argc, argv) /* read in T-mesh files and convert */ |
67 |
int argc; |
68 |
char *argv[]; |
69 |
70 |
FILE *fp; |
71 |
int i; |
72 |
73 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
74 |
switch (argv[i][1]) { |
75 |
case 'o': /* object name */ |
76 |
defobj = argv[++i]; |
77 |
break; |
78 |
case 'm': /* default material */ |
79 |
defmat = argv[++i]; |
80 |
break; |
81 |
case 'p': /* default picture */ |
82 |
defpat = argv[++i]; |
83 |
break; |
84 |
default: |
85 |
fprintf(stderr, |
86 |
"Usage: %s [-o obj][-m mat][-p pic] [file ..]\n", |
87 |
argv[0]); |
88 |
exit(1); |
89 |
90 |
if (i >= argc) |
91 |
convert("<stdin>", stdin); |
92 |
else |
93 |
for ( ; i < argc; i++) { |
94 |
if ((fp = fopen(argv[i], "r")) == NULL) { |
95 |
perror(argv[i]); |
96 |
exit(1); |
97 |
98 |
convert(argv[i], fp); |
99 |
fclose(fp); |
100 |
101 |
exit(0); |
102 |
103 |
104 |
105 |
convert(fname, fp) /* convert a T-mesh */ |
106 |
char *fname; |
107 |
FILE *fp; |
108 |
109 |
char typ[4]; |
110 |
int id[3]; |
111 |
double vec[3]; |
112 |
char picfile[128]; |
113 |
char matname[64]; |
114 |
char objname[64]; |
115 |
register int i; |
116 |
register VERTEX *lastv; |
117 |
/* start fresh */ |
118 |
i = nverts; |
119 |
lastv = vlist; |
120 |
while (i--) |
121 |
(lastv++)->flags = 0; |
122 |
lastv = NULL; |
123 |
strcpy(picfile, defpat); |
124 |
strcpy(matname, defmat); |
125 |
strcpy(objname, defobj); |
126 |
127 |
printf("\n## T-mesh read from: %s\n", fname); |
128 |
/* scan until EOF */ |
129 |
while (fscanf(fp, "%1s", typ) == 1) |
130 |
switch (typ[0]) { |
131 |
case 'v': /* vertex */ |
132 |
if (fscanf(fp, "%d %lf %lf %lf", &id[0], |
133 |
&vec[0], &vec[1], &vec[2]) != 4) |
134 |
syntax(fname, fp, "Bad vertex"); |
135 |
lastv = vnew(id[0], vec[0], vec[1], vec[2]); |
136 |
break; |
137 |
case 't': /* triangle */ |
138 |
if (fscanf(fp, "%d %d %d", &id[0], &id[1], &id[2]) != 3) |
139 |
syntax(fname, fp, "Bad triangle"); |
140 |
if (novert(id[0]) | novert(id[1]) | novert(id[2])) |
141 |
syntax(fname, fp, "Undefined triangle vertex"); |
142 |
triangle(picfile, matname, objname, &vlist[id[0]], |
143 |
&vlist[id[1]], &vlist[id[2]]); |
144 |
break; |
145 |
case 'n': /* surface normal */ |
146 |
if (lastv == NULL) |
147 |
syntax(fname, fp, "No vertex for normal"); |
148 |
if (fscanf(fp, "%lf %lf %lf", |
149 |
&vec[0], &vec[1], &vec[2]) != 3) |
150 |
syntax(fname, fp, "Bad vertex normal"); |
151 |
lastv->nor[0] = vec[0]; |
152 |
lastv->nor[1] = vec[1]; |
153 |
lastv->nor[2] = vec[2]; |
154 |
if (normalize(lastv->nor) == 0.0) |
155 |
syntax(fname, fp, "Zero vertex normal"); |
156 |
lastv->flags |= V_HASNORM; |
157 |
break; |
158 |
case 'i': /* index position */ |
159 |
160 |
syntax(fname, fp, "No vertex for index"); |
161 |
if (fscanf(fp, "%lf %lf", &vec[0], &vec[1]) != 2) |
162 |
syntax(fname, fp, "Bad index"); |
163 |
lastv->ndx[0] = vec[0]; |
164 |
lastv->ndx[1] = vec[1]; |
165 |
lastv->flags |= V_HASINDX; |
166 |
break; |
167 |
168 |
if (fscanf(fp, "%s", objname) != 1) |
169 |
syntax(fname, fp, "Bad object name"); |
170 |
break; |
171 |
case 'm': /* material */ |
172 |
if (fscanf(fp, "%s", matname) != 1) |
173 |
syntax(fname, fp, "Bad material"); |
174 |
if (matname[0] == '-' && !matname[1]) |
175 |
strcpy(matname, VOIDID); |
176 |
break; |
177 |
case 'p': /* picture */ |
178 |
if (fscanf(fp, "%s", picfile) != 1) |
179 |
syntax(fname, fp, "Bad pattern"); |
180 |
if (picfile[0] == '-' && !picfile[1]) |
181 |
picfile[0] = '\0'; |
182 |
break; |
183 |
case '#': /* comment */ |
184 |
fputs("\n#", stdout); |
185 |
while ((i = getc(fp)) != EOF) { |
186 |
putchar(i); |
187 |
if (i == '\n') |
188 |
break; |
189 |
190 |
break; |
191 |
default: |
192 |
syntax(fname, fp, "Unknown type"); |
193 |
break; |
194 |
195 |
196 |
197 |
198 |
triangle(pn, mod, obj, v1, v2, v3) /* put out a triangle */ |
199 |
char *pn, *mod, *obj; |
200 |
register VERTEX *v1, *v2, *v3; |
201 |
202 |
static char vfmt[] = "%18.12g %18.12g %18.12g\n"; |
203 |
static int ntri = 0; |
204 |
int flatness = ISFLAT; |
205 |
BARYCCM bvecs; |
206 |
RREAL bvm[3][3]; |
207 |
register int i; |
208 |
/* compute barycentric coordinates */ |
209 |
if (v1->flags & v2->flags & v3->flags & (V_HASINDX|V_HASNORM)) |
210 |
if (comp_baryc(&bvecs, v1->pos, v2->pos, v3->pos) < 0) |
211 |
return; |
212 |
/* check flatness */ |
213 |
if (v1->flags & v2->flags & v3->flags & V_HASNORM) { |
214 |
flatness = flat_tri(v1->pos, v2->pos, v3->pos, |
215 |
v1->nor, v2->nor, v3->nor); |
216 |
if (flatness == DEGEN) |
217 |
return; |
218 |
219 |
/* put out texture (if any) */ |
220 |
if (flatness == ISBENT || flatness == RVBENT) { |
221 |
printf("\n%s texfunc %s\n", mod, TEXNAME); |
222 |
mod = TEXNAME; |
223 |
printf("4 dx dy dz %s\n", TCALNAME); |
224 |
printf("0\n"); |
225 |
for (i = 0; i < 3; i++) { |
226 |
bvm[i][0] = v1->nor[i]; |
227 |
bvm[i][1] = v2->nor[i]; |
228 |
bvm[i][2] = v3->nor[i]; |
229 |
230 |
put_baryc(&bvecs, bvm, 3); |
231 |
232 |
/* put out pattern (if any) */ |
233 |
if (*pn && (v1->flags & v2->flags & v3->flags & V_HASINDX)) { |
234 |
printf("\n%s colorpict %s\n", mod, PATNAME); |
235 |
mod = PATNAME; |
236 |
printf("7 noneg noneg noneg %s %s u v\n", pn, TCALNAME); |
237 |
printf("0\n"); |
238 |
for (i = 0; i < 2; i++) { |
239 |
bvm[i][0] = v1->ndx[i]; |
240 |
bvm[i][1] = v2->ndx[i]; |
241 |
bvm[i][2] = v3->ndx[i]; |
242 |
243 |
put_baryc(&bvecs, bvm, 2); |
244 |
245 |
/* put out (reversed) triangle */ |
246 |
printf("\n%s polygon %s.%d\n", mod, obj, ++ntri); |
247 |
printf("0\n0\n9\n"); |
248 |
if (flatness == RVFLAT || flatness == RVBENT) { |
249 |
printf(vfmt, v3->pos[0],v3->pos[1],v3->pos[2]); |
250 |
printf(vfmt, v2->pos[0],v2->pos[1],v2->pos[2]); |
251 |
printf(vfmt, v1->pos[0],v1->pos[1],v1->pos[2]); |
252 |
} else { |
253 |
254 |
255 |
256 |
257 |
258 |
259 |
260 |
VERTEX * |
261 |
vnew(id, x, y, z) /* create a new vertex */ |
262 |
register int id; |
263 |
double x, y, z; |
264 |
265 |
register int i; |
266 |
267 |
if (id >= nverts) { /* get some more */ |
268 |
i = nverts; |
269 |
nverts = CHUNKSIZ*((id/CHUNKSIZ)+1); |
270 |
if (vlist == NULL) |
271 |
vlist = (VERTEX *)malloc(nverts*sizeof(VERTEX)); |
272 |
else |
273 |
vlist = (VERTEX *)realloc((void *)vlist, |
274 |
275 |
if (vlist == NULL) { |
276 |
fprintf(stderr, |
277 |
"Out of memory while allocating vertex %d\n", id); |
278 |
exit(1); |
279 |
280 |
while (i < nverts) /* clear what's new */ |
281 |
vlist[i++].flags = 0; |
282 |
283 |
/* assign new vertex */ |
284 |
vlist[id].pos[0] = x; |
285 |
vlist[id].pos[1] = y; |
286 |
vlist[id].pos[2] = z; |
287 |
vlist[id].flags = V_DEFINED; |
288 |
/* return it */ |
289 |
return(&vlist[id]); |
290 |
291 |
292 |
293 |
syntax(fn, fp, er) /* report syntax error and exit */ |
294 |
char *fn; |
295 |
register FILE *fp; |
296 |
char *er; |
297 |
298 |
extern long ftell(); |
299 |
register long cpos; |
300 |
register int c; |
301 |
int lineno; |
302 |
303 |
if (fp == stdin) |
304 |
fprintf(stderr, "%s: T-mesh format error: %s\n", fn, er); |
305 |
else { |
306 |
cpos = ftell(fp); |
307 |
fseek(fp, 0L, 0); |
308 |
lineno = 1; |
309 |
while (cpos-- > 0) { |
310 |
if ((c = getc(fp)) == EOF) |
311 |
break; |
312 |
if (c == '\n') |
313 |
lineno++; |
314 |
315 |
fprintf(stderr, "%s: T-mesh format error at line %d: %s\n", |
316 |
fn, lineno, er); |
317 |
318 |
exit(1); |
319 |
