root/radiance/ray/src/cv/tmesh2rad.c
Fri Apr 11 20:27:23 2014 UTC (10 years ago) by greg
Changes since 2.16: +12 -12 lines
Diff to previous 2.16 , to selected 2.15
Made reading of vectors more consistent with FVFORMAT macro
Mon Nov 10 19:08:18 2008 UTC (15 years, 5 months ago) by greg
CVS Tags: rad4R0, rad4R1
Diff to previous 2.15
Revision 2.15 - (view) (download) (annotate) - [selected]
Sat Nov 15 17:54:06 2003 UTC (20 years, 5 months ago) by schorsch
Changes since 2.14: +41 -18 lines
Diff to previous 2.14
Sun Jul 27 22:12:02 2003 UTC (20 years, 9 months ago) by schorsch
Diff to previous 2.13 , to selected 2.15
Diff to previous 2.12 , to selected 2.15
Diff to previous 2.11 , to selected 2.15
Tue Mar 4 01:42:29 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.10: +20 -7 lines
Diff to previous 2.10 , to selected 2.15
Fixed problems with normals and orientations that disagree.
Changes since 2.9: +1 -4 lines
Diff to previous 2.9 , to selected 2.15
Wed Jul 24 13:07:44 1996 UTC (27 years, 9 months ago) by greg
Diff to previous 2.8 , to selected 2.15
added check for flat triangles with normals
Wed Jun 22 12:35:58 1994 UTC (29 years, 10 months ago) by greg
Changes since 2.7: +3 -76 lines
Diff to previous 2.7 , to selected 2.15
Wed Jun 15 19:06:02 1994 UTC (29 years, 10 months ago) by greg
Diff to previous 2.6 , to selected 2.15
cosmetic fix to parameters of put_baryc
Wed Jun 15 15:07:06 1994 UTC (29 years, 10 months ago) by greg
Changes since 2.5: +31 -18 lines
Diff to previous 2.5 , to selected 2.15
further reduced complexity and size of barycentric calculation
Wed Jun 15 12:38:29 1994 UTC (29 years, 10 months ago) by greg
Changes since 2.4: +42 -29 lines
Diff to previous 2.4 , to selected 2.15
removed gensurf quadrilateral code to make smoothing work better
Tue Mar 22 08:54:23 1994 UTC (30 years, 1 month ago) by greg
Diff to previous 2.3 , to selected 2.15
bug fix in vnew()
Fri Feb 18 13:11:35 1994 UTC (30 years, 2 months ago) by greg
Changes since 2.2: +70 -30 lines
Diff to previous 2.2 , to selected 2.15
a few enhancements, a little beautification
Fri Feb 18 09:29:26 1994 UTC (30 years, 2 months ago) by greg
Changes since 2.1: +10 -6 lines
Diff to previous 2.1 , to selected 2.15
initial bug fixes
Tue Feb 15 15:58:03 1994 UTC (30 years, 2 months ago) by greg
Diff to selected 2.15
