root/radiance/ray/src/cv/tmesh2rad.c
Revision: 2.4
Committed: Tue Mar 22 08:54:23 1994 UTC (31 years, 2 months ago) by greg
bug fix in vnew()
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Convert a trianglular mesh into a Radiance description.
9 *
10 * Unlike most other converters, we have defined a file
11 * format for the input ourselves. The format contains eight types,
12 * each of which is identified by a single letter. These are:
13 *
14 * # comment = a comment. Continues until end of line.
15 * v id Px Py Pz = a vertex. The id must be an integer.
16 * n Nx Ny Nz = a normal. Corresponds to most recent vertex.
17 * i Iu Iv = an index. Corresponds to most recent vertex.
18 * p picture = a picture. Used as a pattern for following.
19 * m material = a material name. Used for what follows.
20 * o object = an object name. Used for what follows.
21 * t id1 id2 id3 = a triangle.
22 *
23 * Only the 't' type results in any output. The others merely set values
24 * to be used in generating triangles. If no picture or "p -" is given,
25 * there will be no pattern associated with the geometry. If no material
26 * or "m -" is given, no material will be associated. (Note that this
27 * only makes sense for a mesh which is to be put into an octree for
28 * instancing.) Using a pattern requires that each vertex have an
29 * associated index value for generating the colorpict primitive.
30 * Likewise, an interpolated surface normal also requires that each
31 * vertex of the triangle have an associated normal vector.
32 * It is not necessary for the normal vectors to have unit length.
33 */
34
35 #include "standard.h"
36
37 #define VOIDID "void" /* this is defined in object.h */
38
39 #define CALNAME "tmesh.cal" /* the name of our auxiliary file */
40 #define PATNAME "T-pat" /* triangle pattern name (reused) */
41 #define TEXNAME "T-nor" /* triangle texture name (reused) */
42
43 #define V_DEFINED 01 /* this vertex is defined */
44 #define V_HASNORM 02 /* vertex has surface normal */
45 #define V_HASINDX 04 /* vertex has index */
46
47 typedef struct {
48 short flags; /* vertex flags, from above */
49 FVECT pos; /* location */
50 FVECT nor; /* normal */
51 float ndx[2]; /* picture index */
52 } VERTEX;
53
54 VERTEX *vlist = NULL; /* our vertex list */
55 int nverts = 0; /* number of vertices in our list */
56
57 typedef FLOAT BARYCCM[3][4];
58
59 #define novert(i) ((i)<0|(i)>=nverts || !(vlist[i].flags&V_DEFINED))
60
61 #define CHUNKSIZ 128 /* vertex allocation chunk size */
62
63 extern VERTEX *vnew(); /* allocate a vertex (never freed) */
64
65 char *defmat = VOIDID; /* default (starting) material name */
66 char *defpat = ""; /* default (starting) picture name */
67 char *defobj = "T"; /* default (starting) object name */
68
69
70 main(argc, argv) /* read in T-mesh files and convert */
71 int argc;
72 char *argv[];
73 {
74 FILE *fp;
75 int i;
76
77 for (i = 1; i < argc && argv[i][0] == '-'; i++)
78 switch (argv[i][1]) {
79 case 'o': /* object name */
80 defobj = argv[++i];
81 break;
82 case 'm': /* default material */
83 defmat = argv[++i];
84 break;
85 case 'p': /* default picture */
86 defpat = argv[++i];
87 break;
88 default:
89 fprintf(stderr,
90 "Usage: %s [-o obj][-m mat][-p pic] [file ..]\n",
91 argv[0]);
92 exit(1);
93 }
94 if (i >= argc)
95 convert("<stdin>", stdin);
96 else
97 for ( ; i < argc; i++) {
98 if ((fp = fopen(argv[i], "r")) == NULL) {
99 perror(argv[i]);
100 exit(1);
101 }
102 convert(argv[i], fp);
103 fclose(fp);
104 }
105 exit(0);
106 }
107
108
109 convert(fname, fp) /* convert a T-mesh */
110 char *fname;
111 FILE *fp;
112 {
113 char typ[4];
114 int id[3];
115 double vec[3];
116 char picfile[128];
117 char matname[64];
118 char objname[64];
119 register int i;
120 register VERTEX *lastv;
121 /* start fresh */
122 i = nverts;
123 lastv = vlist;
124 while (i--)
125 (lastv++)->flags = 0;
126 lastv = NULL;
127 strcpy(picfile, defpat);
128 strcpy(matname, defmat);
129 strcpy(objname, defobj);
130
131 printf("\n## T-mesh read from: %s\n", fname);
132 /* scan until EOF */
133 while (fscanf(fp, "%1s", typ) == 1)
134 switch (typ[0]) {
135 case 'v': /* vertex */
136 if (fscanf(fp, "%d %lf %lf %lf", &id[0],
137 &vec[0], &vec[1], &vec[2]) != 4)
138 syntax(fname, fp, "Bad vertex");
139 lastv = vnew(id[0], vec[0], vec[1], vec[2]);
140 break;
141 case 't': /* triangle */
142 if (fscanf(fp, "%d %d %d", &id[0], &id[1], &id[2]) != 3)
143 syntax(fname, fp, "Bad triangle");
144 if (novert(id[0]) | novert(id[1]) | novert(id[2]))
145 syntax(fname, fp, "Undefined triangle vertex");
146 triangle(picfile, matname, objname, &vlist[id[0]],
147 &vlist[id[1]], &vlist[id[2]]);
148 break;
149 case 'n': /* surface normal */
150 if (lastv == NULL)
151 syntax(fname, fp, "No vertex for normal");
152 if (fscanf(fp, "%lf %lf %lf",
153 &vec[0], &vec[1], &vec[2]) != 3)
154 syntax(fname, fp, "Bad vertex normal");
155 lastv->nor[0] = vec[0];
156 lastv->nor[1] = vec[1];
157 lastv->nor[2] = vec[2];
158 if (normalize(lastv->nor) == 0.0)
159 syntax(fname, fp, "Zero vertex normal");
160 lastv->flags |= V_HASNORM;
161 break;
162 case 'i': /* index position */
163 if (lastv == NULL)
164 syntax(fname, fp, "No vertex for index");
165 if (fscanf(fp, "%lf %lf", &vec[0], &vec[1]) != 2)
166 syntax(fname, fp, "Bad index");
167 lastv->ndx[0] = vec[0];
168 lastv->ndx[1] = vec[1];
169 lastv->flags |= V_HASINDX;
170 break;
171 case 'o': /* object name */
172 if (fscanf(fp, "%s", objname) != 1)
173 syntax(fname, fp, "Bad object name");
174 break;
175 case 'm': /* material */
176 if (fscanf(fp, "%s", matname) != 1)
177 syntax(fname, fp, "Bad material");
178 if (matname[0] == '-' && !matname[1])
179 strcpy(matname, VOIDID);
180 break;
181 case 'p': /* picture */
182 if (fscanf(fp, "%s", picfile) != 1)
183 syntax(fname, fp, "Bad pattern");
184 if (picfile[0] == '-' && !picfile[1])
185 picfile[0] = '\0';
186 break;
187 case '#': /* comment */
188 fputs("\n#", stdout);
189 while ((i = getc(fp)) != EOF) {
190 putchar(i);
191 if (i == '\n')
192 break;
193 }
194 break;
195 default:
196 syntax(fname, fp, "Unknown type");
197 break;
198 }
199 }
200
201
202 triangle(pn, mod, obj, v1, v2, v3) /* put out a triangle */
203 char *pn, *mod, *obj;
204 register VERTEX *v1, *v2, *v3;
205 {
206 static int ntri = 0;
207 BARYCCM bvecs;
208 /* compute barycentric coordinates */
209 if (v1->flags & v2->flags & v3->flags & (V_HASINDX|V_HASNORM))
210 if (comp_baryc(bvecs, v1->pos, v2->pos, v3->pos) < 0)
211 return;
212 /* put out texture (if any) */
213 if (v1->flags & v2->flags & v3->flags & V_HASNORM) {
214 printf("\n%s texfunc %s\n", mod, TEXNAME);
215 mod = TEXNAME;
216 printf("4 dx dy dz %s\n", CALNAME);
217 printf("0\n21\n");
218 put_baryc(bvecs);
219 printf("\t%14.12g %14.12g %14.12g\n",
220 v1->nor[0], v2->nor[0], v3->nor[0]);
221 printf("\t%14.12g %14.12g %14.12g\n",
222 v1->nor[1], v2->nor[1], v3->nor[1]);
223 printf("\t%14.12g %14.12g %14.12g\n",
224 v1->nor[2], v2->nor[2], v3->nor[2]);
225 }
226 /* put out pattern (if any) */
227 if (*pn && (v1->flags & v2->flags & v3->flags & V_HASINDX)) {
228 printf("\n%s colorpict %s\n", mod, PATNAME);
229 mod = PATNAME;
230 printf("7 noneg noneg noneg %s %s u v\n", pn, CALNAME);
231 printf("0\n18\n");
232 put_baryc(bvecs);
233 printf("\t%f %f %f\n", v1->ndx[0], v2->ndx[0], v3->ndx[0]);
234 printf("\t%f %f %f\n", v1->ndx[1], v2->ndx[1], v3->ndx[1]);
235 }
236 /* put out triangle */
237 printf("\n%s polygon %s.%d\n", mod, obj, ++ntri);
238 printf("0\n0\n9\n");
239 printf("%18.12g %18.12g %18.12g\n", v1->pos[0],v1->pos[1],v1->pos[2]);
240 printf("%18.12g %18.12g %18.12g\n", v2->pos[0],v2->pos[1],v2->pos[2]);
241 printf("%18.12g %18.12g %18.12g\n", v3->pos[0],v3->pos[1],v3->pos[2]);
242 }
243
244
245 int
246 comp_baryc(bcm, v1, v2, v3) /* compute barycentric vectors */
247 register BARYCCM bcm;
248 FLOAT *v1, *v2, *v3;
249 {
250 FLOAT *vt;
251 FVECT va, vab, vcb;
252 double d;
253 register int i, j;
254
255 for (j = 0; j < 3; j++) {
256 for (i = 0; i < 3; i++) {
257 vab[i] = v1[i] - v2[i];
258 vcb[i] = v3[i] - v2[i];
259 }
260 d = DOT(vcb,vcb);
261 if (d <= FTINY)
262 return(-1);
263 d = DOT(vcb,vab)/d;
264 for (i = 0; i < 3; i++)
265 va[i] = vab[i] - vcb[i]*d;
266 d = DOT(va,va);
267 if (d <= FTINY)
268 return(-1);
269 for (i = 0; i < 3; i++) {
270 va[i] /= d;
271 bcm[j][i] = va[i];
272 }
273 bcm[j][3] = -DOT(v2,va);
274 /* rotate vertices */
275 vt = v1;
276 v1 = v2;
277 v2 = v3;
278 v3 = vt;
279 }
280 return(0);
281 }
282
283
284 put_baryc(bcm) /* put barycentric coord. vectors */
285 register BARYCCM bcm;
286 {
287 register int i;
288
289 for (i = 0; i < 3; i++)
290 printf("%14.8f %14.8f %14.8f %14.8f\n",
291 bcm[i][0], bcm[i][1], bcm[i][2], bcm[i][3]);
292 }
293
294
295 VERTEX *
296 vnew(id, x, y, z) /* create a new vertex */
297 register int id;
298 double x, y, z;
299 {
300 register int i;
301
302 if (id >= nverts) { /* get some more */
303 i = nverts;
304 nverts = CHUNKSIZ*((id/CHUNKSIZ)+1);
305 if (vlist == NULL)
306 vlist = (VERTEX *)malloc(nverts*sizeof(VERTEX));
307 else
308 vlist = (VERTEX *)realloc((char *)vlist,
309 nverts*sizeof(VERTEX));
310 if (vlist == NULL) {
311 fprintf(stderr,
312 "Out of memory while allocating vertex %d\n", id);
313 exit(1);
314 }
315 while (i < nverts) /* clear what's new */
316 vlist[i++].flags = 0;
317 }
318 /* assign new vertex */
319 vlist[id].pos[0] = x;
320 vlist[id].pos[1] = y;
321 vlist[id].pos[2] = z;
322 vlist[id].flags = V_DEFINED;
323 /* return it */
324 return(&vlist[id]);
325 }
326
327
328 syntax(fn, fp, er) /* report syntax error and exit */
329 char *fn;
330 register FILE *fp;
331 char *er;
332 {
333 extern long ftell();
334 register long cpos;
335 register int c;
336 int lineno;
337
338 if (fp == stdin)
339 fprintf(stderr, "%s: T-mesh format error: %s\n", fn, er);
340 else {
341 cpos = ftell(fp);
342 fseek(fp, 0L, 0);
343 lineno = 1;
344 while (cpos-- > 0) {
345 if ((c = getc(fp)) == EOF)
346 break;
347 if (c == '\n')
348 lineno++;
349 }
350 fprintf(stderr, "%s: T-mesh format error at line %d: %s\n",
351 fn, lineno, er);
352 }
353 exit(1);
354 }
