1 |
/* Copyright (c) 1994 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Compute and print barycentric coordinates for triangle meshes |
9 |
10 |
11 |
#include <stdio.h> |
12 |
13 |
#include "fvect.h" |
14 |
15 |
#include "tmesh.h" |
16 |
17 |
#define ABS(x) ((x) >= 0 ? (x) : -(x)) |
18 |
19 |
20 |
int |
21 |
comp_baryc(bcm, v1, v2, v3) /* compute barycentric vectors */ |
22 |
register BARYCCM *bcm; |
23 |
FLOAT *v1, *v2, *v3; |
24 |
25 |
FLOAT *vt; |
26 |
FVECT va, vab, vcb; |
27 |
double d; |
28 |
int ax0, ax1; |
29 |
register int i, j; |
30 |
/* compute major axis */ |
31 |
for (i = 0; i < 3; i++) { |
32 |
vab[i] = v1[i] - v2[i]; |
33 |
vcb[i] = v3[i] - v2[i]; |
34 |
35 |
fcross(va, vab, vcb); |
36 |
bcm->ax = ABS(va[0]) > ABS(va[1]) ? 0 : 1; |
37 |
bcm->ax = ABS(va[bcm->ax]) > ABS(va[2]) ? bcm->ax : 2; |
38 |
ax0 = (bcm->ax + 1) % 3; |
39 |
ax1 = (bcm->ax + 2) % 3; |
40 |
for (j = 0; j < 2; j++) { |
41 |
vab[0] = v1[ax0] - v2[ax0]; |
42 |
vcb[0] = v3[ax0] - v2[ax0]; |
43 |
vab[1] = v1[ax1] - v2[ax1]; |
44 |
vcb[1] = v3[ax1] - v2[ax1]; |
45 |
d = vcb[0]*vcb[0] + vcb[1]*vcb[1]; |
46 |
if (d <= FTINY) |
47 |
return(-1); |
48 |
d = (vcb[0]*vab[0]+vcb[1]*vab[1])/d; |
49 |
va[0] = vab[0] - vcb[0]*d; |
50 |
va[1] = vab[1] - vcb[1]*d; |
51 |
d = va[0]*va[0] + va[1]*va[1]; |
52 |
if (d <= FTINY) |
53 |
return(-1); |
54 |
bcm->tm[j][0] = va[0] /= d; |
55 |
bcm->tm[j][1] = va[1] /= d; |
56 |
bcm->tm[j][2] = -(v2[ax0]*va[0]+v2[ax1]*va[1]); |
57 |
/* rotate vertices */ |
58 |
vt = v1; |
59 |
v1 = v2; |
60 |
v2 = v3; |
61 |
v3 = vt; |
62 |
63 |
return(0); |
64 |
65 |
66 |
67 |
put_baryc(bcm, com, n) /* put barycentric coord. vectors */ |
68 |
69 |
register FLOAT com[][3]; |
70 |
int n; |
71 |
72 |
double a, b; |
73 |
74 |
75 |
printf("%d\t%d\n", 1+3*n, bcm->ax); |
76 |
for (i = 0; i < n; i++) { |
77 |
a = com[i][0] - com[i][2]; |
78 |
b = com[i][1] - com[i][2]; |
79 |
printf("%14.8f %14.8f %14.8f\n", |
80 |
bcm->tm[0][0]*a + bcm->tm[1][0]*b, |
81 |
bcm->tm[0][1]*a + bcm->tm[1][1]*b, |
82 |
bcm->tm[0][2]*a + bcm->tm[1][2]*b + com[i][2]); |
83 |
84 |
