root/radiance/ray/src/cv/source.cal
Revision: 2.10
Committed: Thu Jan 24 23:15:46 2008 UTC (17 years, 2 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad3R9, rad4R2P1, rad5R3, HEAD
Changes since 2.9: +3 -3 lines
# User Rev Content
1 greg 2.10 { RCSid: $Id: source.cal,v 2.9 2003/02/22 02:07:23 greg Exp $ }
2 greg 1.1 {
3     Source distribution coordinates (degrees).
4
5 greg 2.6 Theta is measured from the negative z-axis.
6     Phi is measured from the positive x-axis (0 degrees)
7 greg 2.10 towards the positive y-axis (90 degrees).
8 greg 1.1
9     srcB_vert and srcB_horiz are angles
10     used in type B photometry.
11
12 greg 2.2 boxcorr function corrects for distribution modeled
13     with a rectangular box. lboxcorr provides a more
14     accurate calculation for nearby surfaces, but requires
15     that the source box be centered at the origin.
16 greg 2.5 The dimensions of the box, which must be aligned with
17     the x,y,z axes, are given in meters regardless of the
18     units being used in the scene file.
19 greg 2.2
20 gregl 2.8 cylcorr function provides the same correction for a
21     cylinder whose central axis is aligned with the Z-axis.
22
23 greg 1.2 A1 - optional multipier
24 greg 2.5 A2,A3,A4 - X,Y,Z dimensions of axis-aligned box (in meters!)
25 gregl 2.8 or
26     A2,A3 - diameter and height of Z-aligned cylinder (meters)
27 greg 1.1 }
28 greg 1.2 { local definitions }
29     boxprojection = abs(Dx)*A3*A4 + abs(Dy)*A2*A4 + abs(Dz)*A2*A3;
30 greg 2.2 lboxprojection = ( noneg(abs(Px-Dx*Ts)-A2/2)*A3*A4 +
31     noneg(abs(Py-Dy*Ts)-A3/2)*A2*A4 +
32     noneg(abs(Pz-Dz*Ts)-A4/2)*A2*A3 ) / Ts;
33 gregl 2.8 cylprojection = A2*A3*sqrt(1-Dz*Dz) + PI/4*A2*A2*abs(Dz);
34 greg 1.1
35     flatcorr(v) = corr(v) / Rdot; { correction for flat sources }
36     corr(v) = if(AC-.5, A1*v, v); { multiplier correction }
37 greg 1.2 boxcorr(v) = A1 * v / boxprojection; { correction for emitting box }
38 greg 2.2 lboxcorr(v) = A1 * v / lboxprojection; { local box correction }
39 gregl 2.8 cylcorr(v) = A1 * v / cylprojection; { cylinder correction }
40 greg 1.1
41     src_theta = Acos(Dz) / DEGREE; { 0-180 }
42 greg 2.10 src_phi = mod( Atan2(-Dy, -Dx) / DEGREE, 360 ); { 0-360 }
43 greg 1.1 { bilateral symmetry }
44     src_phi2 = tri( src_phi, 180 ); { 0-180 }
45     { quadrilateral symmetry }
46     src_phi4 = tri( src_phi, 90 ); { 0-90 }
47
48     { Type B photometry coordinates }
49 greg 2.9 srcB_vert = atan2( -Dx, Dz ) / DEGREE;
50     srcB_horiz = atan2( Dy, Dz ) / DEGREE;
51 greg 2.4 { w/ symmetry }
52     srcB_vert2 = abs( srcB_vert );
53 greg 1.1 srcB_horiz2 = abs( srcB_horiz );
