1 |
greg |
2.9 |
{ RCSid: $Id$ } |
2 |
greg |
1.1 |
3 |
Source distribution coordinates (degrees). |
4 |
5 |
greg |
2.6 |
Theta is measured from the negative z-axis. |
6 |
Phi is measured from the positive x-axis (0 degrees) |
7 |
towards the negative y-axis (90 degrees). |
8 |
greg |
1.1 |
9 |
srcB_vert and srcB_horiz are angles |
10 |
used in type B photometry. |
11 |
12 |
greg |
2.2 |
boxcorr function corrects for distribution modeled |
13 |
with a rectangular box. lboxcorr provides a more |
14 |
accurate calculation for nearby surfaces, but requires |
15 |
that the source box be centered at the origin. |
16 |
greg |
2.5 |
The dimensions of the box, which must be aligned with |
17 |
the x,y,z axes, are given in meters regardless of the |
18 |
units being used in the scene file. |
19 |
greg |
2.2 |
20 |
gregl |
2.8 |
cylcorr function provides the same correction for a |
21 |
cylinder whose central axis is aligned with the Z-axis. |
22 |
23 |
greg |
1.2 |
A1 - optional multipier |
24 |
greg |
2.5 |
A2,A3,A4 - X,Y,Z dimensions of axis-aligned box (in meters!) |
25 |
gregl |
2.8 |
or |
26 |
A2,A3 - diameter and height of Z-aligned cylinder (meters) |
27 |
greg |
1.1 |
28 |
greg |
1.2 |
{ local definitions } |
29 |
boxprojection = abs(Dx)*A3*A4 + abs(Dy)*A2*A4 + abs(Dz)*A2*A3; |
30 |
greg |
2.2 |
lboxprojection = ( noneg(abs(Px-Dx*Ts)-A2/2)*A3*A4 + |
31 |
noneg(abs(Py-Dy*Ts)-A3/2)*A2*A4 + |
32 |
noneg(abs(Pz-Dz*Ts)-A4/2)*A2*A3 ) / Ts; |
33 |
gregl |
2.8 |
cylprojection = A2*A3*sqrt(1-Dz*Dz) + PI/4*A2*A2*abs(Dz); |
34 |
greg |
1.1 |
35 |
flatcorr(v) = corr(v) / Rdot; { correction for flat sources } |
36 |
corr(v) = if(AC-.5, A1*v, v); { multiplier correction } |
37 |
greg |
1.2 |
boxcorr(v) = A1 * v / boxprojection; { correction for emitting box } |
38 |
greg |
2.2 |
lboxcorr(v) = A1 * v / lboxprojection; { local box correction } |
39 |
gregl |
2.8 |
cylcorr(v) = A1 * v / cylprojection; { cylinder correction } |
40 |
greg |
1.1 |
41 |
src_theta = Acos(Dz) / DEGREE; { 0-180 } |
42 |
greg |
2.7 |
src_phi = mod( Atan2(Dy, -Dx) / DEGREE, 360 ); { 0-360 } |
43 |
greg |
1.1 |
{ bilateral symmetry } |
44 |
src_phi2 = tri( src_phi, 180 ); { 0-180 } |
45 |
{ quadrilateral symmetry } |
46 |
src_phi4 = tri( src_phi, 90 ); { 0-90 } |
47 |
48 |
{ Type B photometry coordinates } |
49 |
greg |
2.9 |
srcB_vert = atan2( -Dx, Dz ) / DEGREE; |
50 |
srcB_horiz = atan2( Dy, Dz ) / DEGREE; |
51 |
greg |
2.4 |
{ w/ symmetry } |
52 |
srcB_vert2 = abs( srcB_vert ); |
53 |
greg |
1.1 |
srcB_horiz2 = abs( srcB_horiz ); |
