root/radiance/ray/src/cv/source.cal
Thu Jan 24 23:15:46 2008 UTC (17 years, 3 months ago) by greg
CVS Tags: HEAD, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.9: +3 -3 lines
Sat Feb 22 02:07:23 2003 UTC (22 years, 2 months ago) by greg
CVS Tags: rad3R5, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8
Changes since 2.8: +3 -4 lines
Fri Jul 25 12:08:06 1997 UTC (27 years, 9 months ago) by gregl
Changes since 2.7: +7 -0 lines
eliminated use of "glow" type and applied boxcorr and new cylcorr
Thu Dec 9 16:58:03 1993 UTC (31 years, 5 months ago) by greg
changed atan2() call to Atan2()
Mon Apr 5 16:40:10 1993 UTC (32 years, 1 month ago) by greg
corrected error in azimuthal angle specification
Wed Feb 24 10:24:58 1993 UTC (32 years, 2 months ago) by greg
added additional comments about the box correction functions
Wed Oct 14 13:21:09 1992 UTC (32 years, 6 months ago) by greg
added symmetric coordinates for type B photometry
Tue Aug 18 13:23:14 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.2: +1 -2 lines
eliminated norm_deg() funtion
Tue Mar 3 15:01:45 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.1: +9 -0 lines
Diff to previous 2.1
added local box correction function
Tue Nov 12 17:02:13 1991 UTC (33 years, 5 months ago) by greg
Diff to previous 1.2
Tue Oct 15 13:09:46 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.1: +6 -3 lines
Diff to previous 1.1
added boxcorr function for parallelopiped sources
Thu Aug 22 08:43:46 1991 UTC (33 years, 8 months ago) by greg
