| 1 |
{ RCSid: $Id$ }
| 2 |
| 3 |
Source distribution coordinates (degrees).
| 4 |
| 5 |
Theta is measured from the negative z-axis.
| 6 |
Phi is measured from the positive x-axis (0 degrees)
| 7 |
towards the negative y-axis (90 degrees).
| 8 |
| 9 |
srcB_vert and srcB_horiz are angles
| 10 |
used in type B photometry.
| 11 |
| 12 |
boxcorr function corrects for distribution modeled
| 13 |
with a rectangular box. lboxcorr provides a more
| 14 |
accurate calculation for nearby surfaces, but requires
| 15 |
that the source box be centered at the origin.
| 16 |
The dimensions of the box, which must be aligned with
| 17 |
the x,y,z axes, are given in meters regardless of the
| 18 |
units being used in the scene file.
| 19 |
| 20 |
cylcorr function provides the same correction for a
| 21 |
cylinder whose central axis is aligned with the Z-axis.
| 22 |
| 23 |
A1 - optional multipier
| 24 |
A2,A3,A4 - X,Y,Z dimensions of axis-aligned box (in meters!)
| 25 |
or
| 26 |
A2,A3 - diameter and height of Z-aligned cylinder (meters)
| 27 |
| 28 |
{ local definitions }
| 29 |
boxprojection = abs(Dx)*A3*A4 + abs(Dy)*A2*A4 + abs(Dz)*A2*A3;
| 30 |
lboxprojection = ( noneg(abs(Px-Dx*Ts)-A2/2)*A3*A4 +
| 31 |
noneg(abs(Py-Dy*Ts)-A3/2)*A2*A4 +
| 32 |
noneg(abs(Pz-Dz*Ts)-A4/2)*A2*A3 ) / Ts;
| 33 |
cylprojection = A2*A3*sqrt(1-Dz*Dz) + PI/4*A2*A2*abs(Dz);
| 34 |
| 35 |
flatcorr(v) = corr(v) / Rdot; { correction for flat sources }
| 36 |
corr(v) = if(AC-.5, A1*v, v); { multiplier correction }
| 37 |
boxcorr(v) = A1 * v / boxprojection; { correction for emitting box }
| 38 |
lboxcorr(v) = A1 * v / lboxprojection; { local box correction }
| 39 |
cylcorr(v) = A1 * v / cylprojection; { cylinder correction }
| 40 |
| 41 |
src_theta = Acos(Dz) / DEGREE; { 0-180 }
| 42 |
src_phi = mod( Atan2(Dy, -Dx) / DEGREE, 360 ); { 0-360 }
| 43 |
{ bilateral symmetry }
| 44 |
src_phi2 = tri( src_phi, 180 ); { 0-180 }
| 45 |
{ quadrilateral symmetry }
| 46 |
src_phi4 = tri( src_phi, 90 ); { 0-90 }
| 47 |
| 48 |
{ Type B photometry coordinates }
| 49 |
srcB_vert = atan2( -Dx, Dz ) / DEGREE;
| 50 |
srcB_horiz = atan2( Dy, Dz ) / DEGREE;
| 51 |
{ w/ symmetry }
| 52 |
srcB_vert2 = abs( srcB_vert );
| 53 |
srcB_horiz2 = abs( srcB_horiz );
