root/radiance/ray/src/cv/source.cal
Revision: 1.1
Committed: Thu Aug 22 08:43:46 1991 UTC (33 years, 11 months ago) by greg
1 { SCCSid "$SunId$ LBL" }
2
3 {
4 Source distribution coordinates (degrees).
5
6 Theta is measured from the negative z-axis,
7 phi is measured from the positive x-axis
8 according to the right-hand rule.
9
10 srcB_vert and srcB_horiz are angles
11 used in type B photometry.
12
13 A1 - optional multipier
14 }
15
16 flatcorr(v) = corr(v) / Rdot; { correction for flat sources }
17 corr(v) = if(AC-.5, A1*v, v); { multiplier correction }
18
19 src_theta = Acos(Dz) / DEGREE; { 0-180 }
20 src_phi = norm_deg( atan2(Dy, Dx) / DEGREE ); { 0-360 }
21 { bilateral symmetry }
22 src_phi2 = tri( src_phi, 180 ); { 0-180 }
23 { quadrilateral symmetry }
24 src_phi4 = tri( src_phi, 90 ); { 0-90 }
25
26 norm_deg(d) : if( d, d, d+360 );
27
28 { Type B photometry coordinates }
29 srcB_vert = atan( -Dx/Dz ) / DEGREE;
30 srcB_horiz = Asin(Dy) / DEGREE;
31 { w/ bilateral symmetry }
32 srcB_horiz2 = abs( srcB_horiz );
