root/radiance/ray/src/cv/rad2mgf.c
Revision: 2.9
Committed: Tue Apr 11 13:33:10 1995 UTC (29 years, 1 month ago) by greg
minor changes
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Convert Radiance scene description to MGF
9 */
10
11 #include <stdio.h>
12 #include <string.h>
13 #include "fvect.h"
14 #include "object.h"
15 #include "color.h"
16 #include "lookup.h"
17
18 #define PI 3.14159265358979323846
19
20 int o_face(), o_cone(), o_sphere(), o_ring(), o_cylinder();
21 int o_instance(), o_source(), o_illum();
22 int o_plastic(), o_metal(), o_glass(), o_mirror(), o_trans(), o_light();
23
24 extern void free();
25 extern char *malloc();
26
27 LUTAB rmats = LU_SINIT(free,NULL); /* defined material table */
28
29 LUTAB rdispatch = LU_SINIT(NULL,NULL); /* function dispatch table */
30
31 char curmat[80]; /* current material */
32 char curobj[128] = "Untitled"; /* current object name */
33
34 double unit_mult = 1.; /* units multiplier */
35
36 #define hasmult (unit_mult < .999 || unit_mult > 1.001)
37
38 /*
39 * Stuff for tracking and reusing vertices:
40 */
41
42 char VKFMT[] = "%+16.9e %+16.9e %+16.9e";
43 #define VKLEN 64
44
45 #define mkvkey(k,v) sprintf(k, VKFMT, (v)[0], (v)[1], (v)[2])
46
47 #define NVERTS 256
48
49 long vclock; /* incremented at each vertex request */
50
51 struct vert {
52 long lused; /* when last used (0 if unassigned) */
53 FVECT p; /* track point position only */
54 } vert[NVERTS]; /* our vertex cache */
55
56 LUTAB vertab = LU_SINIT(free,NULL); /* our vertex lookup table */
57
58
59 main(argc, argv)
60 int argc;
61 char **argv;
62 {
63 int i;
64
65 for (i = 1; i < argc && argv[i][0] == '-'; i++)
66 switch (argv[i][1]) {
67 case 'd': /* units */
68 switch (argv[i][2]) {
69 case 'm': /* meters */
70 unit_mult = 1.;
71 break;
72 case 'c': /* centimeters */
73 unit_mult = .01;
74 break;
75 case 'f': /* feet */
76 unit_mult = 12.*.0254;
77 break;
78 case 'i': /* inches */
79 unit_mult = .0254;
80 break;
81 default:
82 goto unkopt;
83 }
84 break;
85 default:
86 goto unkopt;
87 }
88 init();
89 if (i >= argc)
90 rad2mgf(NULL);
91 else
92 for ( ; i < argc; i++)
93 rad2mgf(argv[i]);
94 uninit();
95 exit(0);
96 unkopt:
97 fprintf(stderr, "Usage: %s [-d{m|c|f|i}] file ..\n", argv[0]);
98 exit(1);
99 }
100
101
102 rad2mgf(inp) /* convert a Radiance file to MGF */
103 char *inp;
104 {
105 #define mod buf
106 #define typ (buf+128)
107 #define id (buf+256)
108 #define alias (buf+384)
109 char buf[512];
110 FUNARGS fa;
111 register FILE *fp;
112 register int c;
113
114 if (inp == NULL) {
115 inp = "standard input";
116 fp = stdin;
117 } else if (inp[0] == '!') {
118 if ((fp = popen(inp+1, "r")) == NULL) {
119 fputs(inp, stderr);
120 fputs(": cannot execute\n", stderr);
121 exit(1);
122 }
123 } else if ((fp = fopen(inp, "r")) == NULL) {
124 fputs(inp, stderr);
125 fputs(": cannot open\n", stderr);
126 exit(1);
127 }
128 printf("# Begin conversion from: %s\n", inp);
129 while ((c = getc(fp)) != EOF)
130 switch (c) {
131 case ' ': /* white space */
132 case '\t':
133 case '\n':
134 case '\r':
135 case '\f':
136 break;
137 case '#': /* comment */
138 if (fgets(buf, sizeof(buf), fp) != NULL)
139 printf("# %s", buf);
140 break;
141 case '!': /* inline command */
142 ungetc(c, fp);
143 fgetline(buf, sizeof(buf), fp);
144 rad2mgf(buf);
145 break;
146 default: /* Radiance primitive */
147 ungetc(c, fp);
148 if (fscanf(fp, "%s %s %s", mod, typ, id) != 3) {
149 fputs(inp, stderr);
150 fputs(": unexpected EOF\n", stderr);
151 exit(1);
152 }
153 if (!strcmp(typ, "alias")) {
154 strcpy(alias, "EOF");
155 fscanf(fp, "%s", alias);
156 newmat(id, alias);
157 } else {
158 if (!readfargs(&fa, fp)) {
159 fprintf(stderr,
160 "%s: bad argument syntax for %s \"%s\"\n",
161 inp, typ, id);
162 exit(1);
163 }
164 cvtprim(inp, mod, typ, id, &fa);
165 freefargs(&fa);
166 }
167 break;
168 }
169 printf("# End conversion from: %s\n", inp);
170 if (inp[0] == '!')
171 pclose(fp);
172 else
173 fclose(fp);
174 #undef mod
175 #undef typ
176 #undef id
177 #undef alias
178 }
179
180
181 cvtprim(inp, mod, typ, id, fa) /* process Radiance primitive */
182 char *inp, *mod, *typ, *id;
183 FUNARGS *fa;
184 {
185 int (*df)();
186
187 df = (int (*)())lu_find(&rdispatch, typ)->data;
188 if (df != NULL) { /* convert */
189 if ((*df)(mod, typ, id, fa) < 0) {
190 fprintf(stderr, "%s: bad %s \"%s\"\n", typ, id);
191 exit(1);
192 }
193 } else if (lu_find(&rmats, mod)->data != NULL) /* make alias */
194 newmat(id, mod);
195 }
196
197
198 newmat(id, alias) /* add a modifier to the alias list */
199 char *id;
200 char *alias;
201 {
202 register LUENT *lp, *lpa;
203
204 if (alias != NULL) { /* look up alias */
205 if ((lpa = lu_find(&rmats, alias)) == NULL)
206 goto memerr;
207 if (lpa->data == NULL)
208 alias = NULL; /* doesn't exist! */
209 }
210 if ((lp = lu_find(&rmats, id)) == NULL) /* look up material */
211 goto memerr;
212 if (alias != NULL && lp->data == lpa->key)
213 return; /* alias set already */
214 if (lp->data == NULL) { /* allocate material */
215 if ((lp->key = (char *)malloc(strlen(id)+1)) == NULL)
216 goto memerr;
217 strcpy(lp->key, id);
218 }
219 if (alias == NULL) { /* set this material */
220 lp->data = lp->key;
221 printf("m %s =\n", id);
222 } else { /* set this alias */
223 lp->data = lpa->key;
224 printf("m %s = %s\n", id, alias);
225 }
226 strcpy(curmat, id);
227 return;
228 memerr:
229 fputs("Out of memory in newmat!\n", stderr);
230 exit(1);
231 }
232
233
234 setmat(id) /* set material to this one */
235 char *id;
236 {
237 if (!strcmp(id, curmat)) /* already set? */
238 return;
239 if (!strcmp(id, VOIDID)) /* cannot set */
240 return;
241 printf("m %s\n", id);
242 strcpy(curmat, id);
243 }
244
245
246 setobj(id) /* set object name to this one */
247 char *id;
248 {
249 register char *cp, *cp2;
250 char *end = NULL;
251 int diff = 0;
252 /* use all but final suffix */
253 for (cp = id; *cp; cp++)
254 if (*cp == '.')
255 end = cp;
256 if (end == NULL)
257 end = cp;
258 /* copy to current object */
259 for (cp = id, cp2 = curobj; cp < end; *cp2++ = *cp++)
260 diff += *cp != *cp2;
261 if (!diff && !*cp2)
262 return;
263 *cp2 = '\0';
264 fputs("o\no ", stdout);
265 puts(curobj);
266 }
267
268
269 init() /* initialize dispatch table and output */
270 {
271 lu_init(&vertab, NVERTS);
272 lu_init(&rdispatch, 22);
273 add2dispatch("polygon", o_face);
274 add2dispatch("cone", o_cone);
275 add2dispatch("cup", o_cone);
276 add2dispatch("sphere", o_sphere);
277 add2dispatch("bubble", o_sphere);
278 add2dispatch("cylinder", o_cylinder);
279 add2dispatch("tube", o_cylinder);
280 add2dispatch("ring", o_ring);
281 add2dispatch("instance", o_instance);
282 add2dispatch("plastic", o_plastic);
283 add2dispatch("plastic2", o_plastic);
284 add2dispatch("metal", o_metal);
285 add2dispatch("metal2", o_metal);
286 add2dispatch("glass", o_glass);
287 add2dispatch("trans", o_trans);
288 add2dispatch("trans2", o_trans);
289 add2dispatch("mirror", o_mirror);
290 add2dispatch("light", o_light);
291 add2dispatch("spotlight", o_light);
292 add2dispatch("glow", o_light);
293 add2dispatch("illum", o_illum);
294 puts("# The following was converted from Radiance scene input");
295 if (hasmult)
296 printf("xf -s %.4e\n", unit_mult);
297 printf("o %s\n", curobj);
298 }
299
300
301 uninit() /* mark end of MGF file */
302 {
303 puts("o");
304 if (hasmult)
305 puts("xf");
306 puts("# End of data converted from Radiance scene input");
307 lu_done(&rdispatch);
308 lu_done(&rmats);
309 lu_done(&vertab);
310 }
311
312
313 clrverts() /* clear vertex table */
314 {
315 register int i;
316
317 lu_done(&vertab);
318 for (i = 0; i < NVERTS; i++)
319 vert[i].lused = 0;
320 lu_init(&vertab, NVERTS);
321 }
322
323
324 add2dispatch(name, func) /* add function to dispatch table */
325 char *name;
326 int (*func)();
327 {
328 register LUENT *lp;
329
330 lp = lu_find(&rdispatch, name);
331 if (lp->key != NULL) {
332 fputs(name, stderr);
333 fputs(": duplicate dispatch entry!\n", stderr);
334 exit(1);
335 }
336 lp->key = name;
337 lp->data = (char *)func;
338 }
339
340
341 char *
342 getvertid(vname, vp) /* get/set vertex ID for this point */
343 char *vname;
344 FVECT vp;
345 {
346 static char vkey[VKLEN];
347 register LUENT *lp;
348 register int i, vndx;
349
350 vclock++; /* increment counter */
351 mkvkey(vkey, vp);
352 if ((lp = lu_find(&vertab, vkey)) == NULL)
353 goto memerr;
354 if (lp->data == NULL) { /* allocate new vertex entry */
355 if (lp->key != NULL) /* reclaim deleted entry */
356 vertab.ndel--;
357 else {
358 if ((lp->key = (char *)malloc(VKLEN)) == NULL)
359 goto memerr;
360 strcpy(lp->key, vkey);
361 }
362 vndx = 0; /* find oldest vertex */
363 for (i = 1; i < NVERTS; i++)
364 if (vert[i].lused < vert[vndx].lused)
365 vndx = i;
366 if (vert[vndx].lused) { /* free old entry first */
367 mkvkey(vkey, vert[vndx].p);
368 lu_delete(&vertab, vkey);
369 }
370 VCOPY(vert[vndx].p, vp); /* assign it */
371 printf("v v%d =\n\tp %.15g %.15g %.15g\n", /* print it */
372 vndx, vp[0], vp[1], vp[2]);
373 lp->data = (char *)&vert[vndx]; /* set it */
374 } else
375 vndx = (struct vert *)lp->data - vert;
376 vert[vndx].lused = vclock; /* record this use */
377 sprintf(vname, "v%d", vndx);
378 return(vname);
379 memerr:
380 fputs("Out of memory in getvertid!\n", stderr);
381 exit(1);
382 }
383
384
385 int
386 o_face(mod, typ, id, fa) /* print out a polygon */
387 char *mod, *typ, *id;
388 FUNARGS *fa;
389 {
390 char entbuf[512];
391 register char *cp;
392 register int i;
393
394 if (fa->nfargs < 9 | fa->nfargs % 3)
395 return(-1);
396 setmat(mod);
397 setobj(id);
398 cp = entbuf;
399 *cp++ = 'f';
400 for (i = 0; i < fa->nfargs; i += 3) {
401 *cp++ = ' ';
402 getvertid(cp, fa->farg + i);
403 while (*cp)
404 cp++;
405 }
406 puts(entbuf);
407 return(0);
408 }
409
410
411 int
412 o_cone(mod, typ, id, fa) /* print out a cone */
413 char *mod, *typ, *id;
414 register FUNARGS *fa;
415 {
416 char v1[6], v2[6];
417
418 if (fa->nfargs != 8)
419 return(-1);
420 setmat(mod);
421 setobj(id);
422 getvertid(v1, fa->farg);
423 getvertid(v2, fa->farg + 3);
424 if (typ[1] == 'u') /* cup -> inverted cone */
425 printf("cone %s %.12g %s %.12g\n",
426 v1, -fa->farg[6], v2, -fa->farg[7]);
427 else
428 printf("cone %s %.12g %s %.12g\n",
429 v1, fa->farg[6], v2, fa->farg[7]);
430 return(0);
431 }
432
433
434 int
435 o_sphere(mod, typ, id, fa) /* print out a sphere */
436 char *mod, *typ, *id;
437 register FUNARGS *fa;
438 {
439 char cent[6];
440
441 if (fa->nfargs != 4)
442 return(-1);
443 setmat(mod);
444 setobj(id);
445 printf("sph %s %.12g\n", getvertid(cent, fa->farg),
446 typ[0]=='b' ? -fa->farg[3] : fa->farg[3]);
447 return(0);
448 }
449
450
451 int
452 o_cylinder(mod, typ, id, fa) /* print out a cylinder */
453 char *mod, *typ, *id;
454 register FUNARGS *fa;
455 {
456 char v1[6], v2[6];
457
458 if (fa->nfargs != 7)
459 return(-1);
460 setmat(mod);
461 setobj(id);
462 getvertid(v1, fa->farg);
463 getvertid(v2, fa->farg + 3);
464 printf("cyl %s %.12g %s\n", v1,
465 typ[0]=='t' ? -fa->farg[6] : fa->farg[6], v2);
466 return(0);
467 }
468
469
470 int
471 o_ring(mod, typ, id, fa) /* print out a ring */
472 char *mod, *typ, *id;
473 register FUNARGS *fa;
474 {
475 if (fa->nfargs != 8)
476 return(-1);
477 setmat(mod);
478 setobj(id);
479 printf("v cent =\n\tp %.12g %.12g %.12g\n",
480 fa->farg[0], fa->farg[1], fa->farg[2]);
481 printf("\tn %.12g %.12g %.12g\n",
482 fa->farg[3], fa->farg[4], fa->farg[5]);
483 if (fa->farg[6] < fa->farg[7])
484 printf("ring cent %.12g %.12g\n",
485 fa->farg[6], fa->farg[7]);
486 else
487 printf("ring cent %.12g %.12g\n",
488 fa->farg[7], fa->farg[6]);
489 return(0);
490 }
491
492
493 int
494 o_instance(mod, typ, id, fa) /* convert an instance */
495 char *mod, *typ, *id;
496 FUNARGS *fa;
497 {
498 register int i;
499 register char *cp;
500 char *start = NULL, *end = NULL;
501 /*
502 * We don't really know how to do this, so we just create
503 * a reference to an undefined MGF file and it's the user's
504 * responsibility to create this file and put the appropriate
505 * stuff into it.
506 */
507 if (fa->nsargs < 1)
508 return(-1);
509 setmat(mod); /* only works if surfaces are void */
510 setobj(id);
511 for (cp = fa->sarg[0]; *cp; cp++) /* construct MGF file name */
512 if (*cp == '/')
513 start = cp+1;
514 else if (*cp == '.')
515 end = cp;
516 if (start == NULL)
517 start = fa->sarg[0];
518 if (end == NULL || start >= end)
519 end = cp;
520 fputs("i ", stdout); /* print include entity */
521 for (cp = start; cp < end; cp++)
522 putchar(*cp);
523 fputs(".mgf", stdout); /* add MGF suffix */
524 for (i = 1; i < fa->nsargs; i++) { /* add transform */
525 putchar(' ');
526 fputs(fa->sarg[i], stdout);
527 }
528 putchar('\n');
529 clrverts(); /* vertex id's no longer reliable */
530 return(0);
531 }
532
533
534 int
535 o_source(mod, typ, id, fa) /* convert a source */
536 char *mod, *typ, *id;
537 FUNARGS *fa;
538 {
539 return(0); /* there is no MGF equivalent! */
540 }
541
542
543 int
544 o_illum(mod, typ, id, fa) /* convert an illum material */
545 char *mod, *typ, *id;
546 FUNARGS *fa;
547 {
548 if (fa->nsargs == 1 && strcmp(fa->sarg[0], VOIDID)) {
549 newmat(id, fa->sarg[0]); /* just create alias */
550 return(0);
551 }
552 /* else create invisible material */
553 newmat(id, NULL);
554 puts("\tts 1 0");
555 return(0);
556 }
557
558
559 int
560 o_plastic(mod, typ, id, fa) /* convert a plastic material */
561 char *mod, *typ, *id;
562 register FUNARGS *fa;
563 {
564 COLOR cxyz, rrgb;
565 double d;
566
567 if (fa->nfargs != (typ[7]=='2' ? 6 : 5))
568 return(-1);
569 newmat(id, NULL);
570 rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2];
571 rgb_cie(cxyz, rrgb);
572 puts("\tc"); /* put diffuse component */
573 d = cxyz[0] + cxyz[1] + cxyz[2];
574 if (d > FTINY)
575 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
576 printf("\trd %.4f\n", cxyz[1]*(1. - fa->farg[3]));
577 if (fa->farg[3] > FTINY) { /* put specular component */
578 puts("\tc");
579 printf("\trs %.4f %.4f\n", fa->farg[3],
580 typ[7]=='2' ? .5*(fa->farg[4] + fa->farg[5]) :
581 fa->farg[4]);
582 }
583 return(0);
584 }
585
586
587 int
588 o_metal(mod, typ, id, fa) /* convert a metal material */
589 char *mod, *typ, *id;
590 register FUNARGS *fa;
591 {
592 COLOR cxyz, rrgb;
593 double d;
594
595 if (fa->nfargs != (typ[5]=='2' ? 6 : 5))
596 return(-1);
597 newmat(id, NULL);
598 rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2];
599 rgb_cie(cxyz, rrgb);
600 puts("\tc"); /* put diffuse component */
601 d = cxyz[0] + cxyz[1] + cxyz[2];
602 if (d > FTINY)
603 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
604 printf("\trd %.4f\n", cxyz[1]*(1. - fa->farg[3]));
605 /* put specular component */
606 printf("\trs %.4f %.4f\n", cxyz[1]*fa->farg[3],
607 typ[5]=='2' ? .5*(fa->farg[4] + fa->farg[5]) :
608 fa->farg[4]);
609 return(0);
610 }
611
612
613 int
614 o_glass(mod, typ, id, fa) /* convert a glass material */
615 char *mod, *typ, *id;
616 register FUNARGS *fa;
617 {
618 COLOR cxyz, rrgb, trgb;
619 double nrfr = 1.52, F, d;
620 register int i;
621
622 if (fa->nfargs != 3 && fa->nfargs != 4)
623 return(-1);
624 newmat(id, NULL);
625 if (fa->nfargs == 4)
626 nrfr = fa->farg[3];
627 F = (1. - nrfr)/(1. + nrfr); /* use normal incidence */
628 F *= F;
629 for (i = 0; i < 3; i++) {
630 trgb[i] = fa->farg[i] * (1. - F)*(1. - F) /
631 (1. - F*F*fa->farg[i]*fa->farg[i]);
632 rrgb[i] = F * (1. + (1. - 2.*F)*fa->farg[i]) /
633 (1. - F*F*fa->farg[i]*fa->farg[i]);
634 }
635 rgb_cie(cxyz, rrgb); /* put reflected component */
636 puts("\tc");
637 d = cxyz[0] + cxyz[1] + cxyz[2];
638 if (d > FTINY)
639 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
640 printf("\trs %.4f 0\n", cxyz[1]);
641 rgb_cie(cxyz, trgb); /* put transmitted component */
642 puts("\tc");
643 d = cxyz[0] + cxyz[1] + cxyz[2];
644 if (d > FTINY)
645 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
646 printf("\tts %.4f 0\n", cxyz[1]);
647 return(0);
648 }
649
650
651 int
652 o_mirror(mod, typ, id, fa) /* convert a mirror material */
653 char *mod, *typ, *id;
654 register FUNARGS *fa;
655 {
656 COLOR cxyz, rrgb;
657 double d;
658
659 if (fa->nsargs == 1) { /* use alternate material */
660 newmat(id, fa->sarg[0]);
661 return(0);
662 }
663 if (fa->nfargs != 3)
664 return(-1);
665 newmat(id, NULL);
666 rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2];
667 rgb_cie(cxyz, rrgb);
668 puts("\tc"); /* put specular component */
669 d = cxyz[0] + cxyz[1] + cxyz[2];
670 if (d > FTINY)
671 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
672 printf("\trs %.4f 0\n", cxyz[1]);
673 return(0);
674 }
675
676
677 int
678 o_trans(mod, typ, id, fa) /* convert a trans material */
679 char *mod, *typ, *id;
680 register FUNARGS *fa;
681 {
682 COLOR cxyz, rrgb;
683 double rough, trans, tspec, d;
684
685 if (typ[4] == '2') { /* trans2 */
686 if (fa->nfargs != 8)
687 return(-1);
688 rough = .5*(fa->farg[4] + fa->farg[5]);
689 trans = fa->farg[6];
690 tspec = fa->farg[7];
691 } else { /* trans */
692 if (fa->nfargs != 7)
693 return(-1);
694 rough = fa->farg[4];
695 trans = fa->farg[5];
696 tspec = fa->farg[6];
697 }
698 newmat(id, NULL);
699 rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2];
700 rgb_cie(cxyz, rrgb);
701 puts("\tc"); /* put transmitted diffuse */
702 d = cxyz[0] + cxyz[1] + cxyz[2];
703 if (d > FTINY)
704 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
705 printf("\ttd %.4f\n", cxyz[1]*trans*(1. - fa->farg[3])*(1. - tspec));
706 /* put transmitted specular */
707 printf("\tts %.4f %.4f\n", cxyz[1]*trans*tspec*(1. - fa->farg[3]), rough);
708 /* put reflected diffuse */
709 printf("\trd %.4f\n", cxyz[1]*(1. - fa->farg[3])*(1. - trans));
710 puts("\tc"); /* put reflected specular */
711 printf("\trs %.4f %.4f\n", fa->farg[3], rough);
712 return(0);
713 }
714
715
716 int
717 o_light(mod, typ, id, fa) /* convert a light type */
718 char *mod, *typ, *id;
719 register FUNARGS *fa;
720 {
721 COLOR cxyz, rrgb;
722 double d;
723
724 if (fa->nfargs < 3)
725 return(-1);
726 newmat(id, NULL);
727 rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2];
728 rgb_cie(cxyz, rrgb);
729 d = cxyz[0] + cxyz[1] + cxyz[2];
730 puts("\tc");
731 if (d > FTINY)
732 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
733 printf("\ted %.4g\n", cxyz[1]*(PI*WHTEFFICACY));
734 return(0);
735 }
