| 1 |
/* Copyright (c) 1994 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Convert Radiance scene description to MGF
| 9 |
| 10 |
| 11 |
#include <stdio.h>
| 12 |
#include <string.h>
| 13 |
#include "fvect.h"
| 14 |
#include "object.h"
| 15 |
#include "color.h"
| 16 |
#include "lookup.h"
| 17 |
| 18 |
#define PI 3.14159265358979323846
| 19 |
| 20 |
int o_face(), o_cone(), o_sphere(), o_ring(), o_cylinder();
| 21 |
int o_instance(), o_source(), o_illum();
| 22 |
int o_plastic(), o_metal(), o_glass(), o_mirror(), o_trans(), o_light();
| 23 |
| 24 |
extern void free();
| 25 |
extern char *malloc();
| 26 |
| 27 |
LUTAB rmats = LU_SINIT(free,NULL); /* defined material table */
| 28 |
| 29 |
LUTAB rdispatch = LU_SINIT(NULL,NULL); /* function dispatch table */
| 30 |
| 31 |
char curmat[80]; /* current material */
| 32 |
char curobj[128] = "Untitled"; /* current object name */
| 33 |
| 34 |
double unit_mult = 1.; /* units multiplier */
| 35 |
| 36 |
#define hasmult (unit_mult < .999 || unit_mult > 1.001)
| 37 |
| 38 |
| 39 |
* Stuff for tracking and reusing vertices:
| 40 |
| 41 |
| 42 |
char VKFMT[] = "%+1.9e %+1.9e %+1.9e";
| 43 |
#define VKLEN 64
| 44 |
| 45 |
#define mkvkey(k,v) sprintf(k, VKFMT, (v)[0], (v)[1], (v)[2])
| 46 |
| 47 |
#define NVERTS 256
| 48 |
| 49 |
long vclock; /* incremented at each vertex request */
| 50 |
| 51 |
struct vert {
| 52 |
long lused; /* when last used (0 if unassigned) */
| 53 |
FVECT p; /* track point position only */
| 54 |
} vert[NVERTS]; /* our vertex cache */
| 55 |
| 56 |
LUTAB vertab = LU_SINIT(free,NULL); /* our vertex lookup table */
| 57 |
| 58 |
| 59 |
main(argc, argv)
| 60 |
int argc;
| 61 |
char **argv;
| 62 |
| 63 |
int i;
| 64 |
| 65 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 66 |
switch (argv[i][1]) {
| 67 |
case 'd': /* units */
| 68 |
switch (argv[i][2]) {
| 69 |
case 'm': /* meters */
| 70 |
unit_mult = 1.;
| 71 |
break;
| 72 |
case 'c': /* centimeters */
| 73 |
unit_mult = .01;
| 74 |
break;
| 75 |
case 'f': /* feet */
| 76 |
unit_mult = 12.*.0254;
| 77 |
break;
| 78 |
case 'i': /* inches */
| 79 |
unit_mult = .0254;
| 80 |
break;
| 81 |
default:
| 82 |
goto unkopt;
| 83 |
| 84 |
break;
| 85 |
default:
| 86 |
goto unkopt;
| 87 |
| 88 |
init();
| 89 |
if (i >= argc)
| 90 |
rad2mgf(NULL);
| 91 |
else
| 92 |
for ( ; i < argc; i++)
| 93 |
rad2mgf(argv[i]);
| 94 |
uninit();
| 95 |
exit(0);
| 96 |
unkopt:
| 97 |
fprintf(stderr, "Usage: %s [-d{m|c|f|i}] file ..\n", argv[0]);
| 98 |
exit(1);
| 99 |
| 100 |
| 101 |
| 102 |
rad2mgf(inp) /* convert a Radiance file to MGF */
| 103 |
char *inp;
| 104 |
| 105 |
#define mod buf
| 106 |
#define typ (buf+128)
| 107 |
#define id (buf+256)
| 108 |
#define alias (buf+384)
| 109 |
char buf[512];
| 110 |
FUNARGS fa;
| 111 |
register FILE *fp;
| 112 |
register int c;
| 113 |
| 114 |
if (inp == NULL) {
| 115 |
inp = "standard input";
| 116 |
fp = stdin;
| 117 |
} else if (inp[0] == '!') {
| 118 |
if ((fp = popen(inp+1, "r")) == NULL) {
| 119 |
fputs(inp, stderr);
| 120 |
fputs(": cannot execute\n", stderr);
| 121 |
exit(1);
| 122 |
| 123 |
} else if ((fp = fopen(inp, "r")) == NULL) {
| 124 |
fputs(inp, stderr);
| 125 |
fputs(": cannot open\n", stderr);
| 126 |
exit(1);
| 127 |
| 128 |
printf("# Begin conversion from: %s\n", inp);
| 129 |
while ((c = getc(fp)) != EOF)
| 130 |
switch (c) {
| 131 |
case ' ': /* white space */
| 132 |
case '\t':
| 133 |
case '\n':
| 134 |
case '\r':
| 135 |
case '\f':
| 136 |
break;
| 137 |
case '#': /* comment */
| 138 |
if (fgets(buf, sizeof(buf), fp) != NULL)
| 139 |
printf("# %s", buf);
| 140 |
break;
| 141 |
case '!': /* inline command */
| 142 |
ungetc(c, fp);
| 143 |
fgetline(buf, sizeof(buf), fp);
| 144 |
rad2mgf(buf);
| 145 |
break;
| 146 |
default: /* Radiance primitive */
| 147 |
ungetc(c, fp);
| 148 |
if (fscanf(fp, "%s %s %s", mod, typ, id) != 3) {
| 149 |
fputs(inp, stderr);
| 150 |
fputs(": unexpected EOF\n", stderr);
| 151 |
exit(1);
| 152 |
| 153 |
if (!strcmp(typ, "alias")) {
| 154 |
strcpy(alias, "EOF");
| 155 |
fscanf(fp, "%s", alias);
| 156 |
newmat(id, alias);
| 157 |
} else {
| 158 |
if (!readfargs(&fa, fp)) {
| 159 |
fprintf(stderr,
| 160 |
"%s: bad argument syntax for %s \"%s\"\n",
| 161 |
inp, typ, id);
| 162 |
exit(1);
| 163 |
| 164 |
cvtprim(inp, mod, typ, id, &fa);
| 165 |
freefargs(&fa);
| 166 |
| 167 |
break;
| 168 |
| 169 |
printf("# End conversion from: %s\n", inp);
| 170 |
if (inp[0] == '!')
| 171 |
pclose(fp);
| 172 |
else
| 173 |
fclose(fp);
| 174 |
#undef mod
| 175 |
#undef typ
| 176 |
#undef id
| 177 |
#undef alias
| 178 |
| 179 |
| 180 |
| 181 |
cvtprim(inp, mod, typ, id, fa) /* process Radiance primitive */
| 182 |
char *inp, *mod, *typ, *id;
| 183 |
FUNARGS *fa;
| 184 |
| 185 |
int (*df)();
| 186 |
| 187 |
df = (int (*)())lu_find(&rdispatch, typ)->data;
| 188 |
if (df != NULL) { /* convert */
| 189 |
if ((*df)(mod, typ, id, fa) < 0) {
| 190 |
fprintf(stderr, "%s: bad %s \"%s\"\n", typ, id);
| 191 |
exit(1);
| 192 |
| 193 |
} else if (lu_find(&rmats, mod)->data != NULL) /* make alias */
| 194 |
newmat(id, mod);
| 195 |
| 196 |
| 197 |
| 198 |
newmat(id, alias) /* add a modifier to the alias list */
| 199 |
char *id;
| 200 |
char *alias;
| 201 |
| 202 |
register LUENT *lp, *lpa;
| 203 |
| 204 |
if (alias != NULL) { /* look up alias */
| 205 |
if ((lpa = lu_find(&rmats, alias)) == NULL)
| 206 |
goto memerr;
| 207 |
if (lpa->data == NULL)
| 208 |
alias = NULL; /* doesn't exist! */
| 209 |
| 210 |
if ((lp = lu_find(&rmats, id)) == NULL) /* look up material */
| 211 |
goto memerr;
| 212 |
if (alias != NULL && lp->data == lpa->key)
| 213 |
return; /* alias set already */
| 214 |
if (lp->data == NULL) { /* allocate material */
| 215 |
if ((lp->key = (char *)malloc(strlen(id)+1)) == NULL)
| 216 |
goto memerr;
| 217 |
strcpy(lp->key, id);
| 218 |
| 219 |
if (alias == NULL) { /* set this material */
| 220 |
lp->data = lp->key;
| 221 |
printf("m %s =\n", id);
| 222 |
} else { /* set this alias */
| 223 |
lp->data = lpa->key;
| 224 |
printf("m %s = %s\n", id, alias);
| 225 |
| 226 |
strcpy(curmat, id);
| 227 |
return;
| 228 |
memerr:
| 229 |
fputs("Out of memory in newmat!\n", stderr);
| 230 |
exit(1);
| 231 |
| 232 |
| 233 |
| 234 |
setmat(id) /* set material to this one */
| 235 |
char *id;
| 236 |
| 237 |
if (!strcmp(id, curmat)) /* already set? */
| 238 |
return;
| 239 |
if (!strcmp(id, VOIDID)) /* cannot set */
| 240 |
return;
| 241 |
printf("m %s\n", id);
| 242 |
strcpy(curmat, id);
| 243 |
| 244 |
| 245 |
| 246 |
setobj(id) /* set object name to this one */
| 247 |
char *id;
| 248 |
| 249 |
register char *cp, *cp2;
| 250 |
char *end = NULL;
| 251 |
int diff = 0;
| 252 |
/* use all but final suffix */
| 253 |
for (cp = id; *cp; cp++)
| 254 |
if (*cp == '.')
| 255 |
end = cp;
| 256 |
if (end == NULL)
| 257 |
end = cp;
| 258 |
/* copy to current object */
| 259 |
for (cp = id, cp2 = curobj; cp < end; *cp2++ = *cp++)
| 260 |
diff += *cp != *cp2;
| 261 |
if (!diff && !*cp2)
| 262 |
return;
| 263 |
*cp2 = '\0';
| 264 |
fputs("o\no ", stdout);
| 265 |
puts(curobj);
| 266 |
| 267 |
| 268 |
| 269 |
init() /* initialize dispatch table and output */
| 270 |
| 271 |
lu_init(&vertab, NVERTS);
| 272 |
lu_init(&rdispatch, 22);
| 273 |
add2dispatch("polygon", o_face);
| 274 |
add2dispatch("cone", o_cone);
| 275 |
add2dispatch("cup", o_cone);
| 276 |
add2dispatch("sphere", o_sphere);
| 277 |
add2dispatch("bubble", o_sphere);
| 278 |
add2dispatch("cylinder", o_cylinder);
| 279 |
add2dispatch("tube", o_cylinder);
| 280 |
add2dispatch("ring", o_ring);
| 281 |
add2dispatch("instance", o_instance);
| 282 |
add2dispatch("plastic", o_plastic);
| 283 |
add2dispatch("plastic2", o_plastic);
| 284 |
add2dispatch("metal", o_metal);
| 285 |
add2dispatch("metal2", o_metal);
| 286 |
add2dispatch("glass", o_glass);
| 287 |
add2dispatch("trans", o_trans);
| 288 |
add2dispatch("trans2", o_trans);
| 289 |
add2dispatch("mirror", o_mirror);
| 290 |
add2dispatch("light", o_light);
| 291 |
add2dispatch("spotlight", o_light);
| 292 |
add2dispatch("glow", o_light);
| 293 |
add2dispatch("illum", o_illum);
| 294 |
puts("# The following was converted from Radiance scene input");
| 295 |
if (hasmult)
| 296 |
printf("xf -s %.4e\n", unit_mult);
| 297 |
printf("o %s\n", curobj);
| 298 |
| 299 |
| 300 |
| 301 |
uninit() /* mark end of MGF file */
| 302 |
| 303 |
puts("o");
| 304 |
if (hasmult)
| 305 |
puts("xf");
| 306 |
puts("# End of data converted from Radiance scene input");
| 307 |
lu_done(&rdispatch);
| 308 |
lu_done(&rmats);
| 309 |
lu_done(&vertab);
| 310 |
| 311 |
| 312 |
| 313 |
clrverts() /* clear vertex table */
| 314 |
| 315 |
register int i;
| 316 |
| 317 |
lu_done(&vertab);
| 318 |
for (i = 0; i < NVERTS; i++)
| 319 |
vert[i].lused = 0;
| 320 |
| 321 |
| 322 |
| 323 |
| 324 |
add2dispatch(name, func) /* add function to dispatch table */
| 325 |
char *name;
| 326 |
int (*func)();
| 327 |
| 328 |
register LUENT *lp;
| 329 |
| 330 |
lp = lu_find(&rdispatch, name);
| 331 |
if (lp->key != NULL) {
| 332 |
fputs(name, stderr);
| 333 |
fputs(": duplicate dispatch entry!\n", stderr);
| 334 |
exit(1);
| 335 |
| 336 |
lp->key = name;
| 337 |
lp->data = (char *)func;
| 338 |
| 339 |
| 340 |
| 341 |
char *
| 342 |
getvertid(vname, vp) /* get/set vertex ID for this point */
| 343 |
char *vname;
| 344 |
FVECT vp;
| 345 |
| 346 |
char vkey[VKLEN];
| 347 |
register LUENT *lp;
| 348 |
register int i, vndx;
| 349 |
| 350 |
vclock++; /* increment counter */
| 351 |
mkvkey(vkey, vp);
| 352 |
if ((lp = lu_find(&vertab, vkey)) == NULL)
| 353 |
goto memerr;
| 354 |
if (lp->data == NULL) { /* allocate new vertex entry */
| 355 |
if (lp->key != NULL) /* reclaim deleted entry */
| 356 |
vertab.ndel--;
| 357 |
else {
| 358 |
if ((lp->key = (char *)malloc(VKLEN)) == NULL)
| 359 |
goto memerr;
| 360 |
strcpy(lp->key, vkey);
| 361 |
| 362 |
vndx = 0; /* find oldest vertex */
| 363 |
for (i = 1; i < NVERTS; i++)
| 364 |
if (vert[i].lused < vert[vndx].lused)
| 365 |
vndx = i;
| 366 |
if (vert[vndx].lused) { /* free old entry first */
| 367 |
mkvkey(vkey, vert[vndx].p);
| 368 |
lu_delete(&vertab, vkey);
| 369 |
| 370 |
VCOPY(vert[vndx].p, vp); /* assign it */
| 371 |
printf("v v%d =\n\tp %.15g %.15g %.15g\n", /* print it */
| 372 |
vndx, vp[0], vp[1], vp[2]);
| 373 |
lp->data = (char *)&vert[vndx]; /* set it */
| 374 |
} else
| 375 |
vndx = (struct vert *)lp->data - vert;
| 376 |
vert[vndx].lused = vclock; /* record this use */
| 377 |
sprintf(vname, "v%d", vndx);
| 378 |
return(vname);
| 379 |
memerr:
| 380 |
fputs("Out of memory in getvertid!\n", stderr);
| 381 |
exit(1);
| 382 |
| 383 |
| 384 |
| 385 |
int
| 386 |
o_face(mod, typ, id, fa) /* print out a polygon */
| 387 |
char *mod, *typ, *id;
| 388 |
FUNARGS *fa;
| 389 |
| 390 |
char entbuf[512];
| 391 |
register char *cp;
| 392 |
register int i;
| 393 |
| 394 |
if (fa->nfargs < 9 | fa->nfargs % 3)
| 395 |
return(-1);
| 396 |
setmat(mod);
| 397 |
setobj(id);
| 398 |
cp = entbuf;
| 399 |
*cp++ = 'f';
| 400 |
for (i = 0; i < fa->nfargs; i += 3) {
| 401 |
*cp++ = ' ';
| 402 |
getvertid(cp, fa->farg + i);
| 403 |
while (*cp)
| 404 |
cp++;
| 405 |
| 406 |
puts(entbuf);
| 407 |
return(0);
| 408 |
| 409 |
| 410 |
| 411 |
int
| 412 |
o_cone(mod, typ, id, fa) /* print out a cone */
| 413 |
| 414 |
register FUNARGS *fa;
| 415 |
| 416 |
char v1[6], v2[6];
| 417 |
| 418 |
if (fa->nfargs != 8)
| 419 |
return(-1);
| 420 |
setmat(mod);
| 421 |
setobj(id);
| 422 |
getvertid(v1, fa->farg);
| 423 |
getvertid(v2, fa->farg + 3);
| 424 |
if (typ[1] == 'u') /* cup -> inverted cone */
| 425 |
printf("cone %s %.12g %s %.12g\n",
| 426 |
v1, -fa->farg[6], v2, -fa->farg[7]);
| 427 |
else
| 428 |
| 429 |
v1, fa->farg[6], v2, fa->farg[7]);
| 430 |
return(0);
| 431 |
| 432 |
| 433 |
| 434 |
int
| 435 |
o_sphere(mod, typ, id, fa) /* print out a sphere */
| 436 |
| 437 |
| 438 |
| 439 |
char cent[6];
| 440 |
| 441 |
if (fa->nfargs != 4)
| 442 |
return(-1);
| 443 |
setmat(mod);
| 444 |
setobj(id);
| 445 |
printf("sph %s %.12g\n", getvertid(cent, fa->farg),
| 446 |
typ[0]=='b' ? -fa->farg[3] : fa->farg[3]);
| 447 |
return(0);
| 448 |
| 449 |
| 450 |
| 451 |
int
| 452 |
o_cylinder(mod, typ, id, fa) /* print out a cylinder */
| 453 |
| 454 |
| 455 |
| 456 |
char v1[6], v2[6];
| 457 |
| 458 |
if (fa->nfargs != 7)
| 459 |
return(-1);
| 460 |
setmat(mod);
| 461 |
setobj(id);
| 462 |
| 463 |
| 464 |
printf("cyl %s %.12g %s\n", v1,
| 465 |
typ[0]=='t' ? -fa->farg[6] : fa->farg[6], v2);
| 466 |
return(0);
| 467 |
| 468 |
| 469 |
| 470 |
int
| 471 |
o_ring(mod, typ, id, fa) /* print out a ring */
| 472 |
| 473 |
| 474 |
| 475 |
| 476 |
return(-1);
| 477 |
setmat(mod);
| 478 |
setobj(id);
| 479 |
printf("v cent =\n\tp %.12g %.12g %.12g\n",
| 480 |
fa->farg[0], fa->farg[1], fa->farg[2]);
| 481 |
printf("\tn %.12g %.12g %.12g\n",
| 482 |
fa->farg[3], fa->farg[4], fa->farg[5]);
| 483 |
if (fa->farg[6] < fa->farg[7])
| 484 |
printf("ring cent %.12g %.12g\n",
| 485 |
fa->farg[6], fa->farg[7]);
| 486 |
else
| 487 |
| 488 |
fa->farg[7], fa->farg[6]);
| 489 |
return(0);
| 490 |
| 491 |
| 492 |
| 493 |
int
| 494 |
o_instance(mod, typ, id, fa) /* convert an instance */
| 495 |
| 496 |
FUNARGS *fa;
| 497 |
| 498 |
register int i;
| 499 |
register char *cp;
| 500 |
char *start = NULL, *end = NULL;
| 501 |
| 502 |
* We don't really know how to do this, so we just create
| 503 |
* a reference to an undefined MGF file and it's the user's
| 504 |
* responsibility to create this file and put the appropriate
| 505 |
* stuff into it.
| 506 |
| 507 |
if (fa->nsargs < 1)
| 508 |
return(-1);
| 509 |
setmat(mod); /* only works if surfaces are void */
| 510 |
setobj(id);
| 511 |
for (cp = fa->sarg[0]; *cp; cp++) /* construct MGF file name */
| 512 |
if (*cp == '/')
| 513 |
start = cp+1;
| 514 |
else if (*cp == '.')
| 515 |
end = cp;
| 516 |
if (start == NULL)
| 517 |
start = fa->sarg[0];
| 518 |
if (end == NULL || start >= end)
| 519 |
end = cp;
| 520 |
fputs("i ", stdout); /* print include entity */
| 521 |
for (cp = start; cp < end; cp++)
| 522 |
putchar(*cp);
| 523 |
fputs(".mgf", stdout); /* add MGF suffix */
| 524 |
for (i = 1; i < fa->nsargs; i++) { /* add transform */
| 525 |
putchar(' ');
| 526 |
fputs(fa->sarg[i], stdout);
| 527 |
| 528 |
putchar('\n');
| 529 |
clrverts(); /* vertex id's no longer reliable */
| 530 |
return(0);
| 531 |
| 532 |
| 533 |
| 534 |
int
| 535 |
o_source(mod, typ, id, fa) /* convert a source */
| 536 |
| 537 |
FUNARGS *fa;
| 538 |
| 539 |
return(0); /* there is no MGF equivalent! */
| 540 |
| 541 |
| 542 |
| 543 |
int
| 544 |
o_illum(mod, typ, id, fa) /* convert an illum material */
| 545 |
| 546 |
FUNARGS *fa;
| 547 |
| 548 |
if (fa->nsargs == 1 && strcmp(fa->sarg[0], VOIDID)) {
| 549 |
newmat(id, fa->sarg[0]); /* just create alias */
| 550 |
return(0);
| 551 |
| 552 |
/* else create invisible material */
| 553 |
newmat(id, NULL);
| 554 |
puts("\tts 1 0");
| 555 |
return(0);
| 556 |
| 557 |
| 558 |
| 559 |
int
| 560 |
o_plastic(mod, typ, id, fa) /* convert a plastic material */
| 561 |
| 562 |
| 563 |
| 564 |
COLOR cxyz, rrgb;
| 565 |
double d;
| 566 |
| 567 |
if (fa->nfargs != (typ[7]=='2' ? 6 : 5))
| 568 |
return(-1);
| 569 |
newmat(id, NULL);
| 570 |
rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2];
| 571 |
rgb_cie(cxyz, rrgb);
| 572 |
puts("\tc"); /* put diffuse component */
| 573 |
d = cxyz[0] + cxyz[1] + cxyz[2];
| 574 |
if (d > FTINY)
| 575 |
printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
| 576 |
printf("\trd %.4f\n", cxyz[1]*(1. - fa->farg[3]));
| 577 |
if (fa->farg[3] > FTINY) { /* put specular component */
| 578 |
puts("\tc");
| 579 |
printf("\trs %.4f %.4f\n", fa->farg[3],
| 580 |
typ[7]=='2' ? .5*(fa->farg[4] + fa->farg[5]) :
| 581 |
fa->farg[4]);
| 582 |
| 583 |
return(0);
| 584 |
| 585 |
| 586 |
| 587 |
int
| 588 |
o_metal(mod, typ, id, fa) /* convert a metal material */
| 589 |
| 590 |
| 591 |
| 592 |
COLOR cxyz, rrgb;
| 593 |
double d;
| 594 |
| 595 |
if (fa->nfargs != (typ[5]=='2' ? 6 : 5))
| 596 |
return(-1);
| 597 |
newmat(id, NULL);
| 598 |
| 599 |
| 600 |
| 601 |
| 602 |
if (d > FTINY)
| 603 |
| 604 |
| 605 |
| 606 |
printf("\trs %.4f %.4f\n", cxyz[1]*fa->farg[3],
| 607 |
typ[5]=='2' ? .5*(fa->farg[4] + fa->farg[5]) :
| 608 |
fa->farg[4]);
| 609 |
return(0);
| 610 |
| 611 |
| 612 |
| 613 |
int
| 614 |
o_glass(mod, typ, id, fa) /* convert a glass material */
| 615 |
| 616 |
| 617 |
| 618 |
COLOR cxyz, rrgb, trgb;
| 619 |
double nrfr = 1.52, F, d;
| 620 |
register int i;
| 621 |
| 622 |
if (fa->nfargs != 3 && fa->nfargs != 4)
| 623 |
return(-1);
| 624 |
newmat(id, NULL);
| 625 |
if (fa->nfargs == 4)
| 626 |
nrfr = fa->farg[3];
| 627 |
F = (1. - nrfr)/(1. + nrfr); /* use normal incidence */
| 628 |
F *= F;
| 629 |
for (i = 0; i < 3; i++) {
| 630 |
trgb[i] = fa->farg[i] * (1. - F)*(1. - F) /
| 631 |
(1. - F*F*fa->farg[i]*fa->farg[i]);
| 632 |
rrgb[i] = F * (1. + (1. - 2.*F)*fa->farg[i]) /
| 633 |
| 634 |
| 635 |
rgb_cie(cxyz, rrgb); /* put reflected component */
| 636 |
puts("\tc");
| 637 |
| 638 |
if (d > FTINY)
| 639 |
| 640 |
printf("\trs %.4f 0\n", cxyz[1]);
| 641 |
rgb_cie(cxyz, trgb); /* put transmitted component */
| 642 |
puts("\tc");
| 643 |
| 644 |
if (d > FTINY)
| 645 |
| 646 |
printf("\tts %.4f 0\n", cxyz[1]);
| 647 |
return(0);
| 648 |
| 649 |
| 650 |
| 651 |
int
| 652 |
o_mirror(mod, typ, id, fa) /* convert a mirror material */
| 653 |
| 654 |
| 655 |
| 656 |
COLOR cxyz, rrgb;
| 657 |
double d;
| 658 |
| 659 |
if (fa->nsargs == 1) { /* use alternate material */
| 660 |
| 661 |
return(0);
| 662 |
| 663 |
if (fa->nfargs != 3)
| 664 |
return(-1);
| 665 |
newmat(id, NULL);
| 666 |
| 667 |
| 668 |
puts("\tc"); /* put specular component */
| 669 |
| 670 |
if (d > FTINY)
| 671 |
| 672 |
| 673 |
return(0);
| 674 |
| 675 |
| 676 |
| 677 |
int
| 678 |
o_trans(mod, typ, id, fa) /* convert a trans material */
| 679 |
| 680 |
| 681 |
| 682 |
COLOR cxyz, rrgb;
| 683 |
double rough, trans, tspec, d;
| 684 |
| 685 |
if (typ[4] == '2') { /* trans2 */
| 686 |
| 687 |
return(-1);
| 688 |
rough = .5*(fa->farg[4] + fa->farg[5]);
| 689 |
trans = fa->farg[6];
| 690 |
tspec = fa->farg[7];
| 691 |
} else { /* trans */
| 692 |
| 693 |
return(-1);
| 694 |
rough = fa->farg[4];
| 695 |
trans = fa->farg[5];
| 696 |
tspec = fa->farg[6];
| 697 |
| 698 |
newmat(id, NULL);
| 699 |
| 700 |
| 701 |
puts("\tc"); /* put transmitted diffuse */
| 702 |
| 703 |
if (d > FTINY)
| 704 |
| 705 |
printf("\ttd %.4f\n", cxyz[1]*trans*(1. - fa->farg[3])*(1. - tspec));
| 706 |
/* put transmitted specular */
| 707 |
printf("\tts %.4f %.4f\n", cxyz[1]*trans*tspec*(1. - fa->farg[3]), rough);
| 708 |
/* put reflected diffuse */
| 709 |
printf("\trd %.4f\n", cxyz[1]*(1. - fa->farg[3])*(1. - trans));
| 710 |
puts("\tc"); /* put reflected specular */
| 711 |
printf("\trs %.4f %.4f\n", fa->farg[3], rough);
| 712 |
return(0);
| 713 |
| 714 |
| 715 |
| 716 |
int
| 717 |
o_light(mod, typ, id, fa) /* convert a light type */
| 718 |
| 719 |
| 720 |
| 721 |
COLOR cxyz, rrgb;
| 722 |
double d;
| 723 |
| 724 |
if (fa->nfargs < 3)
| 725 |
return(-1);
| 726 |
newmat(id, NULL);
| 727 |
| 728 |
| 729 |
| 730 |
puts("\tc");
| 731 |
if (d > FTINY)
| 732 |
| 733 |
printf("\ted %.4g\n", cxyz[1]*(PI*WHTEFFICACY));
| 734 |
return(0);
| 735 |
