--- ray/src/cv/rad2mgf.c 1994/07/07 17:30:33 2.1 +++ ray/src/cv/rad2mgf.c 1995/04/11 13:33:10 2.9 @@ -15,6 +15,8 @@ static char SCCSid[] = "$SunId$ LBL"; #include "color.h" #include "lookup.h" +#define PI 3.14159265358979323846 + int o_face(), o_cone(), o_sphere(), o_ring(), o_cylinder(); int o_instance(), o_source(), o_illum(); int o_plastic(), o_metal(), o_glass(), o_mirror(), o_trans(), o_light(); @@ -26,11 +28,34 @@ LUTAB rmats = LU_SINIT(free,NULL); /* defined materia LUTAB rdispatch = LU_SINIT(NULL,NULL); /* function dispatch table */ -char curmat[80]; /* current material */ +char curmat[80]; /* current material */ +char curobj[128] = "Untitled"; /* current object name */ -double unit_mult = 1.; /* units multiplier */ +double unit_mult = 1.; /* units multiplier */ +#define hasmult (unit_mult < .999 || unit_mult > 1.001) +/* + * Stuff for tracking and reusing vertices: + */ + +char VKFMT[] = "%+16.9e %+16.9e %+16.9e"; +#define VKLEN 64 + +#define mkvkey(k,v) sprintf(k, VKFMT, (v)[0], (v)[1], (v)[2]) + +#define NVERTS 256 + +long vclock; /* incremented at each vertex request */ + +struct vert { + long lused; /* when last used (0 if unassigned) */ + FVECT p; /* track point position only */ +} vert[NVERTS]; /* our vertex cache */ + +LUTAB vertab = LU_SINIT(free,NULL); /* our vertex lookup table */ + + main(argc, argv) int argc; char **argv; @@ -57,6 +82,8 @@ char **argv; goto unkopt; } break; + default: + goto unkopt; } init(); if (i >= argc) @@ -85,7 +112,7 @@ char *inp; register int c; if (inp == NULL) { - inp = "the standard input"; + inp = "standard input"; fp = stdin; } else if (inp[0] == '!') { if ((fp = popen(inp+1, "r")) == NULL) { @@ -209,13 +236,39 @@ char *id; { if (!strcmp(id, curmat)) /* already set? */ return; + if (!strcmp(id, VOIDID)) /* cannot set */ + return; printf("m %s\n", id); strcpy(curmat, id); } +setobj(id) /* set object name to this one */ +char *id; +{ + register char *cp, *cp2; + char *end = NULL; + int diff = 0; + /* use all but final suffix */ + for (cp = id; *cp; cp++) + if (*cp == '.') + end = cp; + if (end == NULL) + end = cp; + /* copy to current object */ + for (cp = id, cp2 = curobj; cp < end; *cp2++ = *cp++) + diff += *cp != *cp2; + if (!diff && !*cp2) + return; + *cp2 = '\0'; + fputs("o\no ", stdout); + puts(curobj); +} + + init() /* initialize dispatch table and output */ { + lu_init(&vertab, NVERTS); lu_init(&rdispatch, 22); add2dispatch("polygon", o_face); add2dispatch("cone", o_cone); @@ -239,21 +292,35 @@ init() /* initialize dispatch table and output */ add2dispatch("glow", o_light); add2dispatch("illum", o_illum); puts("# The following was converted from Radiance scene input"); - if (unit_mult < .999 || unit_mult > 1.001) + if (hasmult) printf("xf -s %.4e\n", unit_mult); + printf("o %s\n", curobj); } uninit() /* mark end of MGF file */ { - if (unit_mult < .999 || unit_mult > 1.001) + puts("o"); + if (hasmult) puts("xf"); puts("# End of data converted from Radiance scene input"); lu_done(&rdispatch); lu_done(&rmats); + lu_done(&vertab); } +clrverts() /* clear vertex table */ +{ + register int i; + + lu_done(&vertab); + for (i = 0; i < NVERTS; i++) + vert[i].lused = 0; + lu_init(&vertab, NVERTS); +} + + add2dispatch(name, func) /* add function to dispatch table */ char *name; int (*func)(); @@ -271,35 +338,16 @@ int (*func)(); } -char VKFMT[] = "%+1.9e %+1.9e %+1.9e"; -#define VKLEN 64 - -#define mkvkey(k,v) sprintf(k, VKFMT, (v)[0], (v)[1], (v)[2]) - -#define NVERTS 256 - -long clock; /* incremented at each vertex request */ - -struct vert { - long lused; /* when last used (0 if unassigned) */ - FVECT p; /* track point position only */ -} vert[NVERTS]; - -LUTAB vertab = LU_SINIT(free,NULL); /* our vertex lookup table */ - - char * -getvertid(vp) /* get/set vertex ID for this point */ +getvertid(vname, vp) /* get/set vertex ID for this point */ +char *vname; FVECT vp; { - static char vname[6]; - char vkey[VKLEN]; + static char vkey[VKLEN]; register LUENT *lp; register int i, vndx; - if (!vertab.tsiz && !lu_init(&vertab, NVERTS)) - goto memerr; - clock++; /* increment counter */ + vclock++; /* increment counter */ mkvkey(vkey, vp); if ((lp = lu_find(&vertab, vkey)) == NULL) goto memerr; @@ -319,13 +367,13 @@ FVECT vp; mkvkey(vkey, vert[vndx].p); lu_delete(&vertab, vkey); } - vert[vndx].lused = clock; /* assign it */ - VCOPY(vert[vndx].p, vp); - printf("v v%d =\np %.15g %.15g %.15g\n", /* print it */ + VCOPY(vert[vndx].p, vp); /* assign it */ + printf("v v%d =\n\tp %.15g %.15g %.15g\n", /* print it */ vndx, vp[0], vp[1], vp[2]); lp->data = (char *)&vert[vndx]; /* set it */ } else vndx = (struct vert *)lp->data - vert; + vert[vndx].lused = vclock; /* record this use */ sprintf(vname, "v%d", vndx); return(vname); memerr: @@ -340,23 +388,22 @@ char *mod, *typ, *id; FUNARGS *fa; { char entbuf[512]; - register char *cp1, *cp2; + register char *cp; register int i; if (fa->nfargs < 9 | fa->nfargs % 3) return(-1); setmat(mod); - printf("o %s\n", id); - cp1 = entbuf; - *cp1++ = 'f'; + setobj(id); + cp = entbuf; + *cp++ = 'f'; for (i = 0; i < fa->nfargs; i += 3) { - cp2 = getvertid(fa->farg + i); - *cp1++ = ' '; - while ((*cp1 = *cp2++)) - cp1++; + *cp++ = ' '; + getvertid(cp, fa->farg + i); + while (*cp) + cp++; } puts(entbuf); - puts("o"); return(0); } @@ -366,21 +413,20 @@ o_cone(mod, typ, id, fa) /* print out a cone */ char *mod, *typ, *id; register FUNARGS *fa; { + char v1[6], v2[6]; + if (fa->nfargs != 8) return(-1); setmat(mod); - printf("o %s\n", id); - printf("v cv1 =\np %.12g %.12g %.12g\n", - fa->farg[0], fa->farg[1], fa->farg[2]); - printf("v cv2 =\np %.12g %.12g %.12g\n", - fa->farg[3], fa->farg[4], fa->farg[5]); + setobj(id); + getvertid(v1, fa->farg); + getvertid(v2, fa->farg + 3); if (typ[1] == 'u') /* cup -> inverted cone */ - printf("cone cv1 %.12g cv2 %.12g\n", - -fa->farg[6], -fa->farg[7]); + printf("cone %s %.12g %s %.12g\n", + v1, -fa->farg[6], v2, -fa->farg[7]); else - printf("cone cv1 %.12g cv2 %.12g\n", - fa->farg[6], fa->farg[7]); - puts("o"); + printf("cone %s %.12g %s %.12g\n", + v1, fa->farg[6], v2, fa->farg[7]); return(0); } @@ -390,14 +436,14 @@ o_sphere(mod, typ, id, fa) /* print out a sphere */ char *mod, *typ, *id; register FUNARGS *fa; { + char cent[6]; + if (fa->nfargs != 4) return(-1); setmat(mod); - printf("o %s\n", id); - printf("v cent =\np %.12g %.12g %.12g\n", - fa->farg[0], fa->farg[1], fa->farg[2]); - printf("sph cent %.12g\n", typ[0]=='b' ? -fa->farg[3] : fa->farg[3]); - puts("o"); + setobj(id); + printf("sph %s %.12g\n", getvertid(cent, fa->farg), + typ[0]=='b' ? -fa->farg[3] : fa->farg[3]); return(0); } @@ -407,17 +453,16 @@ o_cylinder(mod, typ, id, fa) /* print out a cylinder * char *mod, *typ, *id; register FUNARGS *fa; { + char v1[6], v2[6]; + if (fa->nfargs != 7) return(-1); setmat(mod); - printf("o %s\n", id); - printf("v cv1 =\np %.12g %.12g %.12g\n", - fa->farg[0], fa->farg[1], fa->farg[2]); - printf("v cv2 =\np %.12g %.12g %.12g\n", - fa->farg[3], fa->farg[4], fa->farg[5]); - printf("cyl cv1 %.12g cv2\n", - typ[0]=='t' ? -fa->farg[6] : fa->farg[6]); - puts("o"); + setobj(id); + getvertid(v1, fa->farg); + getvertid(v2, fa->farg + 3); + printf("cyl %s %.12g %s\n", v1, + typ[0]=='t' ? -fa->farg[6] : fa->farg[6], v2); return(0); } @@ -430,10 +475,10 @@ register FUNARGS *fa; if (fa->nfargs != 8) return(-1); setmat(mod); - printf("o %s\n", id); - printf("v cent =\np %.12g %.12g %.12g\n", + setobj(id); + printf("v cent =\n\tp %.12g %.12g %.12g\n", fa->farg[0], fa->farg[1], fa->farg[2]); - printf("n %.12g %.12g %.12g\n", + printf("\tn %.12g %.12g %.12g\n", fa->farg[3], fa->farg[4], fa->farg[5]); if (fa->farg[6] < fa->farg[7]) printf("ring cent %.12g %.12g\n", @@ -441,7 +486,6 @@ register FUNARGS *fa; else printf("ring cent %.12g %.12g\n", fa->farg[7], fa->farg[6]); - puts("o"); return(0); } @@ -451,7 +495,39 @@ o_instance(mod, typ, id, fa) /* convert an instance */ char *mod, *typ, *id; FUNARGS *fa; { - return(0); /* this is too damned difficult! */ + register int i; + register char *cp; + char *start = NULL, *end = NULL; + /* + * We don't really know how to do this, so we just create + * a reference to an undefined MGF file and it's the user's + * responsibility to create this file and put the appropriate + * stuff into it. + */ + if (fa->nsargs < 1) + return(-1); + setmat(mod); /* only works if surfaces are void */ + setobj(id); + for (cp = fa->sarg[0]; *cp; cp++) /* construct MGF file name */ + if (*cp == '/') + start = cp+1; + else if (*cp == '.') + end = cp; + if (start == NULL) + start = fa->sarg[0]; + if (end == NULL || start >= end) + end = cp; + fputs("i ", stdout); /* print include entity */ + for (cp = start; cp < end; cp++) + putchar(*cp); + fputs(".mgf", stdout); /* add MGF suffix */ + for (i = 1; i < fa->nsargs; i++) { /* add transform */ + putchar(' '); + fputs(fa->sarg[i], stdout); + } + putchar('\n'); + clrverts(); /* vertex id's no longer reliable */ + return(0); } @@ -475,7 +551,7 @@ FUNARGS *fa; } /* else create invisible material */ newmat(id, NULL); - puts("ts 1 0"); + puts("\tts 1 0"); return(0); } @@ -493,15 +569,17 @@ register FUNARGS *fa; newmat(id, NULL); rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2]; rgb_cie(cxyz, rrgb); - puts("c"); /* put diffuse component */ + puts("\tc"); /* put diffuse component */ d = cxyz[0] + cxyz[1] + cxyz[2]; if (d > FTINY) - printf("cxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d); - printf("rd %.4f\n", cxyz[1]*(1. - fa->farg[3])); - puts("c"); /* put specular component */ - printf("rs %.4f %.4f\n", fa->farg[3], - typ[7]=='2' ? .5*(fa->farg[4] + fa->farg[5]) : - fa->farg[4]); + printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d); + printf("\trd %.4f\n", cxyz[1]*(1. - fa->farg[3])); + if (fa->farg[3] > FTINY) { /* put specular component */ + puts("\tc"); + printf("\trs %.4f %.4f\n", fa->farg[3], + typ[7]=='2' ? .5*(fa->farg[4] + fa->farg[5]) : + fa->farg[4]); + } return(0); } @@ -519,13 +597,13 @@ register FUNARGS *fa; newmat(id, NULL); rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2]; rgb_cie(cxyz, rrgb); - puts("c"); /* put diffuse component */ + puts("\tc"); /* put diffuse component */ d = cxyz[0] + cxyz[1] + cxyz[2]; if (d > FTINY) - printf("cxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d); - printf("rd %.4f\n", cxyz[1]*(1. - fa->farg[3])); + printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d); + printf("\trd %.4f\n", cxyz[1]*(1. - fa->farg[3])); /* put specular component */ - printf("rs %.4f %.4f\n", cxyz[1]*fa->farg[3], + printf("\trs %.4f %.4f\n", cxyz[1]*fa->farg[3], typ[5]=='2' ? .5*(fa->farg[4] + fa->farg[5]) : fa->farg[4]); return(0); @@ -549,22 +627,23 @@ register FUNARGS *fa; F = (1. - nrfr)/(1. + nrfr); /* use normal incidence */ F *= F; for (i = 0; i < 3; i++) { - rrgb[i] = (1. - F)*(1. - F)/(1. - F*F*fa->farg[i]*fa->farg[i]); - trgb[i] = F * (1. + (1. - 2.*F)*fa->farg[i]) / + trgb[i] = fa->farg[i] * (1. - F)*(1. - F) / (1. - F*F*fa->farg[i]*fa->farg[i]); + rrgb[i] = F * (1. + (1. - 2.*F)*fa->farg[i]) / + (1. - F*F*fa->farg[i]*fa->farg[i]); } rgb_cie(cxyz, rrgb); /* put reflected component */ - puts("c"); + puts("\tc"); d = cxyz[0] + cxyz[1] + cxyz[2]; if (d > FTINY) - printf("cxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d); - printf("rs %.4f 0\n", cxyz[1]); + printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d); + printf("\trs %.4f 0\n", cxyz[1]); rgb_cie(cxyz, trgb); /* put transmitted component */ - puts("c"); + puts("\tc"); d = cxyz[0] + cxyz[1] + cxyz[2]; if (d > FTINY) - printf("cxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d); - printf("ts %.4f 0\n", cxyz[1]); + printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d); + printf("\tts %.4f 0\n", cxyz[1]); return(0); } @@ -586,11 +665,11 @@ register FUNARGS *fa; newmat(id, NULL); rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2]; rgb_cie(cxyz, rrgb); - puts("c"); /* put specular component */ + puts("\tc"); /* put specular component */ d = cxyz[0] + cxyz[1] + cxyz[2]; if (d > FTINY) - printf("cxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d); - printf("rs %.4f 0\n", cxyz[1]); + printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d); + printf("\trs %.4f 0\n", cxyz[1]); return(0); } @@ -619,17 +698,17 @@ register FUNARGS *fa; newmat(id, NULL); rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2]; rgb_cie(cxyz, rrgb); - puts("c"); /* put transmitted diffuse */ + puts("\tc"); /* put transmitted diffuse */ d = cxyz[0] + cxyz[1] + cxyz[2]; if (d > FTINY) - printf("cxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d); - printf("td %.4f\n", cxyz[1]*trans*(1. - fa->farg[3])*(1. - tspec)); + printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d); + printf("\ttd %.4f\n", cxyz[1]*trans*(1. - fa->farg[3])*(1. - tspec)); /* put transmitted specular */ - printf("ts %.4f %.4f\n", cxyz[1]*trans*tspec*(1. - fa->farg[3]), rough); + printf("\tts %.4f %.4f\n", cxyz[1]*trans*tspec*(1. - fa->farg[3]), rough); /* put reflected diffuse */ - printf("rd %.4f\n", cxyz[1]*(1. - fa->farg[3])*(1. - trans)); - puts("c"); /* put reflected specular */ - printf("rs %.4f %.4f\n", fa->farg[3], rough); + printf("\trd %.4f\n", cxyz[1]*(1. - fa->farg[3])*(1. - trans)); + puts("\tc"); /* put reflected specular */ + printf("\trs %.4f %.4f\n", fa->farg[3], rough); return(0); } @@ -648,9 +727,9 @@ register FUNARGS *fa; rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2]; rgb_cie(cxyz, rrgb); d = cxyz[0] + cxyz[1] + cxyz[2]; - puts("c"); + puts("\tc"); if (d > FTINY) - printf("cxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d); - printf("ed %.4g\n", cxyz[1]); + printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d); + printf("\ted %.4g\n", cxyz[1]*(PI*WHTEFFICACY)); return(0); }
