root/radiance/ray/src/cv/rad2mgf.c
Revision: 2.19
Committed: Sat Aug 16 15:54:30 2003 UTC (21 years, 11 months ago) by greg
Added basic mesh primitive support
2 static const char RCSid[] = "$Id: rad2mgf.c,v 2.18 2003/07/27 22:12:02 schorsch Exp $";
5 * Convert Radiance scene description to MGF
6 */
7
8 #include "standard.h"
9 #include <ctype.h>
10 #include <string.h>
11 #include <stdio.h>
12
13 #include "platform.h"
14 #include "object.h"
15 #include "color.h"
16 #include "lookup.h"
17
18 #define C_1SIDEDTHICK 0.005
19
20 int o_face(), o_cone(), o_sphere(), o_ring(), o_cylinder();
21 int o_instance(), o_illum();
22 int o_plastic(), o_metal(), o_glass(), o_dielectric(),
23 o_mirror(), o_trans(), o_light();
24
25 LUTAB rmats = LU_SINIT(free,NULL); /* defined material table */
26
27 LUTAB rdispatch = LU_SINIT(NULL,NULL); /* function dispatch table */
28
29 char curmat[80]; /* current material */
30 char curobj[128] = "Untitled"; /* current object name */
31
32 double unit_mult = 1.; /* units multiplier */
33
34 #define hasmult (unit_mult < .999 || unit_mult > 1.001)
35
36 /*
37 * Stuff for tracking and reusing vertices:
38 */
39
40 char VKFMT[] = "%+16.9e %+16.9e %+16.9e";
41 #define VKLEN 64
42
43 #define mkvkey(k,v) sprintf(k, VKFMT, (v)[0], (v)[1], (v)[2])
44
45 #define NVERTS 256
46
47 long vclock; /* incremented at each vertex request */
48
49 struct vert {
50 long lused; /* when last used (0 if unassigned) */
51 FVECT p; /* track point position only */
52 } vert[NVERTS]; /* our vertex cache */
53
54 LUTAB vertab = LU_SINIT(free,NULL); /* our vertex lookup table */
55
56
57 main(argc, argv)
58 int argc;
59 char **argv;
60 {
61 int i;
62
63 for (i = 1; i < argc && argv[i][0] == '-'; i++)
64 switch (argv[i][1]) {
65 case 'd': /* units */
66 switch (argv[i][2]) {
67 case 'm': /* meters */
68 unit_mult = 1.;
69 break;
70 case 'c': /* centimeters */
71 unit_mult = .01;
72 break;
73 case 'f': /* feet */
74 unit_mult = 12.*.0254;
75 break;
76 case 'i': /* inches */
77 unit_mult = .0254;
78 break;
79 default:
80 goto unkopt;
81 }
82 break;
83 default:
84 goto unkopt;
85 }
86 init();
87 if (i >= argc)
88 rad2mgf(NULL);
89 else
90 for ( ; i < argc; i++)
91 rad2mgf(argv[i]);
92 uninit();
93 exit(0);
94 unkopt:
95 fprintf(stderr, "Usage: %s [-d{m|c|f|i}] file ..\n", argv[0]);
96 exit(1);
97 }
98
99
100 rad2mgf(inp) /* convert a Radiance file to MGF */
101 char *inp;
102 {
103 #define mod buf
104 #define typ (buf+128)
105 #define id (buf+256)
106 #define alias (buf+384)
107 char buf[512];
108 FUNARGS fa;
109 register FILE *fp;
110 register int c;
111
112 if (inp == NULL) {
113 inp = "standard input";
114 fp = stdin;
115 } else if (inp[0] == '!') {
116 if ((fp = popen(inp+1, "r")) == NULL) {
117 fputs(inp, stderr);
118 fputs(": cannot execute\n", stderr);
119 exit(1);
120 }
121 } else if ((fp = fopen(inp, "r")) == NULL) {
122 fputs(inp, stderr);
123 fputs(": cannot open\n", stderr);
124 exit(1);
125 }
126 printf("# Begin conversion from: %s\n", inp);
127 while ((c = getc(fp)) != EOF)
128 switch (c) {
129 case ' ': /* white space */
130 case '\t':
131 case '\n':
132 case '\r':
133 case '\f':
134 break;
135 case '#': /* comment */
136 if (fgets(buf, sizeof(buf), fp) != NULL)
137 printf("# %s", buf);
138 break;
139 case '!': /* inline command */
140 ungetc(c, fp);
141 fgetline(buf, sizeof(buf), fp);
142 rad2mgf(buf);
143 break;
144 default: /* Radiance primitive */
145 ungetc(c, fp);
146 if (fscanf(fp, "%s %s %s", mod, typ, id) != 3) {
147 fputs(inp, stderr);
148 fputs(": unexpected EOF\n", stderr);
149 exit(1);
150 }
151 if (!strcmp(typ, "alias")) {
152 strcpy(alias, "EOF");
153 fscanf(fp, "%s", alias);
154 newmat(id, alias);
155 } else {
156 if (!readfargs(&fa, fp)) {
157 fprintf(stderr,
158 "%s: bad argument syntax for %s \"%s\"\n",
159 inp, typ, id);
160 exit(1);
161 }
162 cvtprim(inp, mod, typ, id, &fa);
163 freefargs(&fa);
164 }
165 break;
166 }
167 printf("# End conversion from: %s\n", inp);
168 if (inp[0] == '!')
169 pclose(fp);
170 else
171 fclose(fp);
172 #undef mod
173 #undef typ
174 #undef id
175 #undef alias
176 }
177
178
179 cvtprim(inp, mod, typ, id, fa) /* process Radiance primitive */
180 char *inp, *mod, *typ, *id;
181 FUNARGS *fa;
182 {
183 int (*df)();
184
185 df = (int (*)())lu_find(&rdispatch, typ)->data;
186 if (df != NULL) { /* convert */
187 if ((*df)(mod, typ, id, fa) < 0) {
188 fprintf(stderr, "%s: bad %s \"%s\"\n", typ, id);
189 exit(1);
190 }
191 } else { /* unsupported */
192 o_unsupported(mod, typ, id, fa);
193 if (lu_find(&rmats, mod)->data != NULL) /* make alias */
194 newmat(id, mod);
195 }
196 }
197
198
199 newmat(id, alias) /* add a modifier to the alias list */
200 char *id;
201 char *alias;
202 {
203 register LUENT *lp, *lpa;
204
205 if (alias != NULL) { /* look up alias */
206 if ((lpa = lu_find(&rmats, alias)) == NULL)
207 goto memerr;
208 if (lpa->data == NULL)
209 alias = NULL; /* doesn't exist! */
210 }
211 if ((lp = lu_find(&rmats, id)) == NULL) /* look up material */
212 goto memerr;
213 if (alias != NULL && lp->data == lpa->key)
214 return; /* alias set already */
215 if (lp->data == NULL) { /* allocate material */
216 if ((lp->key = (char *)malloc(strlen(id)+1)) == NULL)
217 goto memerr;
218 strcpy(lp->key, id);
219 }
220 if (alias == NULL) { /* set this material */
221 lp->data = lp->key;
222 printf("m %s =\n", id);
223 } else { /* set this alias */
224 lp->data = lpa->key;
225 printf("m %s = %s\n", id, alias);
226 }
227 strcpy(curmat, id);
228 return;
229 memerr:
230 fputs("Out of memory in newmat!\n", stderr);
231 exit(1);
232 }
233
234
235 setmat(id) /* set material to this one */
236 char *id;
237 {
238 if (!strcmp(id, curmat)) /* already set? */
239 return;
240 if (!strcmp(id, VOIDID)) /* cannot set */
241 return;
242 printf("m %s\n", id);
243 strcpy(curmat, id);
244 }
245
246
247 setobj(id) /* set object name to this one */
248 char *id;
249 {
250 register char *cp, *cp2;
251 char *end = NULL;
252 int diff = 0;
253 /* use all but final suffix */
254 for (cp = id; *cp; cp++)
255 if (*cp == '.')
256 end = cp;
257 if (end == NULL)
258 end = cp;
259 /* copy to current object */
260 cp2 = curobj;
261 if (!isalpha(*id)) { /* start with letter */
262 diff = *cp2 != 'O';
263 *cp2++ = 'O';
264 }
265 for (cp = id; cp < end; *cp2++ = *cp++) {
266 if ((*cp < '!') | (*cp > '~')) /* limit to visible chars */
267 *cp = '?';
268 diff += *cp != *cp2;
269 }
270 if (!diff && !*cp2)
271 return;
272 *cp2 = '\0';
273 fputs("o\no ", stdout);
274 puts(curobj);
275 }
276
277
278 init() /* initialize dispatch table and output */
279 {
280 lu_init(&vertab, NVERTS);
281 lu_init(&rdispatch, 22);
282 add2dispatch("polygon", o_face);
283 add2dispatch("cone", o_cone);
284 add2dispatch("cup", o_cone);
285 add2dispatch("sphere", o_sphere);
286 add2dispatch("bubble", o_sphere);
287 add2dispatch("cylinder", o_cylinder);
288 add2dispatch("tube", o_cylinder);
289 add2dispatch("ring", o_ring);
290 add2dispatch("instance", o_instance);
291 add2dispatch("mesh", o_instance);
292 add2dispatch("plastic", o_plastic);
293 add2dispatch("plastic2", o_plastic);
294 add2dispatch("metal", o_metal);
295 add2dispatch("metal2", o_metal);
296 add2dispatch("glass", o_glass);
297 add2dispatch("dielectric", o_dielectric);
298 add2dispatch("trans", o_trans);
299 add2dispatch("trans2", o_trans);
300 add2dispatch("mirror", o_mirror);
301 add2dispatch("light", o_light);
302 add2dispatch("spotlight", o_light);
303 add2dispatch("glow", o_light);
304 add2dispatch("illum", o_illum);
305 puts("# The following was converted from RADIANCE scene input");
306 if (hasmult)
307 printf("xf -s %.4e\n", unit_mult);
308 printf("o %s\n", curobj);
309 }
310
311
312 uninit() /* mark end of MGF file */
313 {
314 puts("o");
315 if (hasmult)
316 puts("xf");
317 puts("# End of data converted from RADIANCE scene input");
318 lu_done(&rdispatch);
319 lu_done(&rmats);
320 lu_done(&vertab);
321 }
322
323
324 clrverts() /* clear vertex table */
325 {
326 register int i;
327
328 lu_done(&vertab);
329 for (i = 0; i < NVERTS; i++)
330 vert[i].lused = 0;
331 lu_init(&vertab, NVERTS);
332 }
333
334
335 add2dispatch(name, func) /* add function to dispatch table */
336 char *name;
337 int (*func)();
338 {
339 register LUENT *lp;
340
341 lp = lu_find(&rdispatch, name);
342 if (lp->key != NULL) {
343 fputs(name, stderr);
344 fputs(": duplicate dispatch entry!\n", stderr);
345 exit(1);
346 }
347 lp->key = name;
348 lp->data = (char *)func;
349 }
350
351
352 char *
353 getvertid(vname, vp) /* get/set vertex ID for this point */
354 char *vname;
355 FVECT vp;
356 {
357 static char vkey[VKLEN];
358 register LUENT *lp;
359 register int i, vndx;
360
361 vclock++; /* increment counter */
362 mkvkey(vkey, vp);
363 if ((lp = lu_find(&vertab, vkey)) == NULL)
364 goto memerr;
365 if (lp->data == NULL) { /* allocate new vertex entry */
366 if (lp->key != NULL) /* reclaim deleted entry */
367 vertab.ndel--;
368 else {
369 if ((lp->key = (char *)malloc(VKLEN)) == NULL)
370 goto memerr;
371 strcpy(lp->key, vkey);
372 }
373 vndx = 0; /* find oldest vertex */
374 for (i = 1; i < NVERTS; i++)
375 if (vert[i].lused < vert[vndx].lused)
376 vndx = i;
377 if (vert[vndx].lused) { /* free old entry first */
378 mkvkey(vkey, vert[vndx].p);
379 lu_delete(&vertab, vkey);
380 }
381 VCOPY(vert[vndx].p, vp); /* assign it */
382 printf("v v%d =\n\tp %.15g %.15g %.15g\n", /* print it */
383 vndx, vp[0], vp[1], vp[2]);
384 lp->data = (char *)&vert[vndx]; /* set it */
385 } else
386 vndx = (struct vert *)lp->data - vert;
387 vert[vndx].lused = vclock; /* record this use */
388 sprintf(vname, "v%d", vndx);
389 return(vname);
390 memerr:
391 fputs("Out of memory in getvertid!\n", stderr);
392 exit(1);
393 }
394
395
396 int
397 o_unsupported(mod, typ, id, fa) /* mark unsupported primitive */
398 char *mod, *typ, *id;
399 FUNARGS *fa;
400 {
401 register int i;
402
403 fputs("\n# Unsupported RADIANCE primitive:\n", stdout);
404 printf("# %s %s %s", mod, typ, id);
405 printf("\n# %d", fa->nsargs);
406 for (i = 0; i < fa->nsargs; i++)
407 printf(" %s", fa->sarg[i]);
408 #ifdef IARGS
409 printf("\n# %d", fa->niargs);
410 for (i = 0; i < fa->niargs; i++)
411 printf(" %ld", fa->iarg[i]);
412 #else
413 fputs("\n# 0", stdout);
414 #endif
415 printf("\n# %d", fa->nfargs);
416 for (i = 0; i < fa->nfargs; i++)
417 printf(" %g", fa->farg[i]);
418 fputs("\n\n", stdout);
419 return(0);
420 }
421
422
423 int
424 o_face(mod, typ, id, fa) /* print out a polygon */
425 char *mod, *typ, *id;
426 FUNARGS *fa;
427 {
428 char entbuf[2048], *linestart;
429 register char *cp;
430 register int i;
431
432 if ((fa->nfargs < 9) | (fa->nfargs % 3))
433 return(-1);
434 setmat(mod);
435 setobj(id);
436 cp = linestart = entbuf;
437 *cp++ = 'f';
438 for (i = 0; i < fa->nfargs; i += 3) {
439 *cp++ = ' ';
440 if (cp - linestart > 72) {
441 *cp++ = '\\'; *cp++ = '\n';
442 linestart = cp;
443 *cp++ = ' '; *cp++ = ' ';
444 }
445 getvertid(cp, fa->farg + i);
446 while (*cp)
447 cp++;
448 }
449 puts(entbuf);
450 return(0);
451 }
452
453
454 int
455 o_cone(mod, typ, id, fa) /* print out a cone */
456 char *mod, *typ, *id;
457 register FUNARGS *fa;
458 {
459 char v1[6], v2[6];
460
461 if (fa->nfargs != 8)
462 return(-1);
463 setmat(mod);
464 setobj(id);
465 getvertid(v1, fa->farg);
466 getvertid(v2, fa->farg + 3);
467 if (typ[1] == 'u') /* cup -> inverted cone */
468 printf("cone %s %.12g %s %.12g\n",
469 v1, -fa->farg[6], v2, -fa->farg[7]);
470 else
471 printf("cone %s %.12g %s %.12g\n",
472 v1, fa->farg[6], v2, fa->farg[7]);
473 return(0);
474 }
475
476
477 int
478 o_sphere(mod, typ, id, fa) /* print out a sphere */
479 char *mod, *typ, *id;
480 register FUNARGS *fa;
481 {
482 char cent[6];
483
484 if (fa->nfargs != 4)
485 return(-1);
486 setmat(mod);
487 setobj(id);
488 printf("sph %s %.12g\n", getvertid(cent, fa->farg),
489 typ[0]=='b' ? -fa->farg[3] : fa->farg[3]);
490 return(0);
491 }
492
493
494 int
495 o_cylinder(mod, typ, id, fa) /* print out a cylinder */
496 char *mod, *typ, *id;
497 register FUNARGS *fa;
498 {
499 char v1[6], v2[6];
500
501 if (fa->nfargs != 7)
502 return(-1);
503 setmat(mod);
504 setobj(id);
505 getvertid(v1, fa->farg);
506 getvertid(v2, fa->farg + 3);
507 printf("cyl %s %.12g %s\n", v1,
508 typ[0]=='t' ? -fa->farg[6] : fa->farg[6], v2);
509 return(0);
510 }
511
512
513 int
514 o_ring(mod, typ, id, fa) /* print out a ring */
515 char *mod, *typ, *id;
516 register FUNARGS *fa;
517 {
518 if (fa->nfargs != 8)
519 return(-1);
520 setmat(mod);
521 setobj(id);
522 printf("v cent =\n\tp %.12g %.12g %.12g\n",
523 fa->farg[0], fa->farg[1], fa->farg[2]);
524 printf("\tn %.12g %.12g %.12g\n",
525 fa->farg[3], fa->farg[4], fa->farg[5]);
526 if (fa->farg[6] < fa->farg[7])
527 printf("ring cent %.12g %.12g\n",
528 fa->farg[6], fa->farg[7]);
529 else
530 printf("ring cent %.12g %.12g\n",
531 fa->farg[7], fa->farg[6]);
532 return(0);
533 }
534
535
536 int
537 o_instance(mod, typ, id, fa) /* convert an instance (or mesh) */
538 char *mod, *typ, *id;
539 FUNARGS *fa;
540 {
541 register int i;
542 register char *cp;
543 char *start = NULL, *end = NULL;
544 /*
545 * We don't really know how to do this, so we just create
546 * a reference to an undefined MGF file and it's the user's
547 * responsibility to create this file and put the appropriate
548 * stuff into it.
549 */
550 if (fa->nsargs < 1)
551 return(-1);
552 setmat(mod); /* only works if surfaces are void */
553 setobj(id);
554 for (cp = fa->sarg[0]; *cp; cp++) /* construct MGF file name */
555 if (*cp == '/')
556 start = cp+1;
557 else if (*cp == '.')
558 end = cp;
559 if (start == NULL)
560 start = fa->sarg[0];
561 if (end == NULL || start >= end)
562 end = cp;
563 fputs("i ", stdout); /* print include entity */
564 for (cp = start; cp < end; cp++)
565 putchar(*cp);
566 fputs(".mgf", stdout); /* add MGF suffix */
567 for (i = 1; i < fa->nsargs; i++) { /* add transform */
568 putchar(' ');
569 fputs(fa->sarg[i], stdout);
570 }
571 putchar('\n');
572 clrverts(); /* vertex id's no longer reliable */
573 return(0);
574 }
575
576
577 int
578 o_illum(mod, typ, id, fa) /* convert an illum material */
579 char *mod, *typ, *id;
580 FUNARGS *fa;
581 {
582 if (fa->nsargs == 1 && strcmp(fa->sarg[0], VOIDID)) {
583 newmat(id, fa->sarg[0]); /* just create alias */
584 return(0);
585 }
586 /* else create invisible material */
587 newmat(id, NULL);
588 puts("\tts 1 0");
589 return(0);
590 }
591
592
593 int
594 o_plastic(mod, typ, id, fa) /* convert a plastic material */
595 char *mod, *typ, *id;
596 register FUNARGS *fa;
597 {
598 COLOR cxyz, rrgb;
599 double d;
600
601 if (fa->nfargs != (typ[7]=='2' ? 6 : 5))
602 return(-1);
603 newmat(id, NULL);
604 rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2];
605 rgb_cie(cxyz, rrgb);
606 puts("\tc"); /* put diffuse component */
607 d = cxyz[0] + cxyz[1] + cxyz[2];
608 if (d > FTINY)
609 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
610 printf("\trd %.4f\n", cxyz[1]*(1. - fa->farg[3]));
611 if (fa->farg[3] > FTINY) { /* put specular component */
612 puts("\tc");
613 printf("\trs %.4f %.4f\n", fa->farg[3],
614 typ[7]=='2' ? .5*(fa->farg[4] + fa->farg[5]) :
615 fa->farg[4]);
616 }
617 return(0);
618 }
619
620
621 int
622 o_metal(mod, typ, id, fa) /* convert a metal material */
623 char *mod, *typ, *id;
624 register FUNARGS *fa;
625 {
626 COLOR cxyz, rrgb;
627 double d;
628
629 if (fa->nfargs != (typ[5]=='2' ? 6 : 5))
630 return(-1);
631 newmat(id, NULL);
632 rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2];
633 rgb_cie(cxyz, rrgb);
634 puts("\tc"); /* put diffuse component */
635 d = cxyz[0] + cxyz[1] + cxyz[2];
636 if (d > FTINY)
637 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
638 printf("\trd %.4f\n", cxyz[1]*(1. - fa->farg[3]));
639 /* put specular component */
640 printf("\trs %.4f %.4f\n", cxyz[1]*fa->farg[3],
641 typ[5]=='2' ? .5*(fa->farg[4] + fa->farg[5]) :
642 fa->farg[4]);
643 return(0);
644 }
645
646
647 int
648 o_glass(mod, typ, id, fa) /* convert a glass material */
649 char *mod, *typ, *id;
650 register FUNARGS *fa;
651 {
652 COLOR cxyz, rrgb, trgb;
653 double nrfr = 1.52, F, d;
654 register int i;
655
656 if (fa->nfargs != 3 && fa->nfargs != 4)
657 return(-1);
658 newmat(id, NULL);
659 if (fa->nfargs == 4)
660 nrfr = fa->farg[3];
661 printf("\tir %f 0\n", nrfr);
662 F = (1. - nrfr)/(1. + nrfr); /* use normal incidence */
663 F *= F;
664 for (i = 0; i < 3; i++) {
665 trgb[i] = fa->farg[i] * (1. - F)*(1. - F) /
666 (1. - F*F*fa->farg[i]*fa->farg[i]);
667 rrgb[i] = F * (1. + (1. - 2.*F)*fa->farg[i]) /
668 (1. - F*F*fa->farg[i]*fa->farg[i]);
669 }
670 rgb_cie(cxyz, rrgb); /* put reflected component */
671 puts("\tc");
672 d = cxyz[0] + cxyz[1] + cxyz[2];
673 if (d > FTINY)
674 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
675 printf("\trs %.4f 0\n", cxyz[1]);
676 rgb_cie(cxyz, trgb); /* put transmitted component */
677 puts("\tc");
678 d = cxyz[0] + cxyz[1] + cxyz[2];
679 if (d > FTINY)
680 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
681 printf("\tts %.4f 0\n", cxyz[1]);
682 return(0);
683 }
684
685
686 int
687 o_dielectric(mod, typ, id, fa) /* convert a dielectric material */
688 char *mod, *typ, *id;
689 register FUNARGS *fa;
690 {
691 COLOR cxyz, trgb;
692 double F, d;
693 register int i;
694
695 if (fa->nfargs != 5)
696 return(-1);
697 newmat(id, NULL);
698 F = (1. - fa->farg[3])/(1. + fa->farg[3]); /* normal incidence */
699 F *= F;
700 for (i = 0; i < 3; i++)
701 trgb[i] = (1. - F)*pow(fa->farg[i], C_1SIDEDTHICK/unit_mult);
702 printf("\tir %f 0\n", fa->farg[3]); /* put index of refraction */
703 printf("\tsides 1\n");
704 puts("\tc"); /* put reflected component */
705 printf("\trs %.4f 0\n", F);
706 rgb_cie(cxyz, trgb); /* put transmitted component */
707 puts("\tc");
708 d = cxyz[0] + cxyz[1] + cxyz[2];
709 if (d > FTINY)
710 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
711 printf("\tts %.4f 0\n", cxyz[1]);
712 return(0);
713 }
714
715
716 int
717 o_mirror(mod, typ, id, fa) /* convert a mirror material */
718 char *mod, *typ, *id;
719 register FUNARGS *fa;
720 {
721 COLOR cxyz, rrgb;
722 double d;
723
724 if (fa->nsargs == 1) { /* use alternate material */
725 newmat(id, fa->sarg[0]);
726 return(0);
727 }
728 if (fa->nfargs != 3)
729 return(-1);
730 newmat(id, NULL);
731 rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2];
732 rgb_cie(cxyz, rrgb);
733 puts("\tc"); /* put specular component */
734 d = cxyz[0] + cxyz[1] + cxyz[2];
735 if (d > FTINY)
736 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
737 printf("\trs %.4f 0\n", cxyz[1]);
738 return(0);
739 }
740
741
742 int
743 o_trans(mod, typ, id, fa) /* convert a trans material */
744 char *mod, *typ, *id;
745 register FUNARGS *fa;
746 {
747 COLOR cxyz, rrgb;
748 double rough, trans, tspec, d;
749
750 if (typ[4] == '2') { /* trans2 */
751 if (fa->nfargs != 8)
752 return(-1);
753 rough = .5*(fa->farg[4] + fa->farg[5]);
754 trans = fa->farg[6];
755 tspec = fa->farg[7];
756 } else { /* trans */
757 if (fa->nfargs != 7)
758 return(-1);
759 rough = fa->farg[4];
760 trans = fa->farg[5];
761 tspec = fa->farg[6];
762 }
763 newmat(id, NULL);
764 rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2];
765 rgb_cie(cxyz, rrgb);
766 puts("\tc"); /* put transmitted diffuse */
767 d = cxyz[0] + cxyz[1] + cxyz[2];
768 if (d > FTINY)
769 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
770 printf("\ttd %.4f\n", cxyz[1]*trans*(1. - fa->farg[3])*(1. - tspec));
771 /* put transmitted specular */
772 printf("\tts %.4f %.4f\n", cxyz[1]*trans*tspec*(1. - fa->farg[3]), rough);
773 /* put reflected diffuse */
774 printf("\trd %.4f\n", cxyz[1]*(1. - fa->farg[3])*(1. - trans));
775 puts("\tc"); /* put reflected specular */
776 printf("\trs %.4f %.4f\n", fa->farg[3], rough);
777 return(0);
778 }
779
780
781 int
782 o_light(mod, typ, id, fa) /* convert a light type */
783 char *mod, *typ, *id;
784 register FUNARGS *fa;
785 {
786 COLOR cxyz, rrgb;
787 double d;
788
789 if (fa->nfargs < 3)
790 return(-1);
791 newmat(id, NULL);
792 rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2];
793 rgb_cie(cxyz, rrgb);
794 d = cxyz[0] + cxyz[1] + cxyz[2];
795 puts("\tc");
796 if (d > FTINY)
797 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
798 printf("\ted %.4g\n", cxyz[1]*(PI*WHTEFFICACY));
799 return(0);
800 }
