root/radiance/ray/src/cv/rad2mgf.c
Sat Dec 28 18:05:14 2019 UTC (5 years, 6 months ago) by greg
CVS Tags: rad5R3, rad5R4
Changes since 2.27: +1 -3 lines
Diff to previous 2.27 , to selected 2.6
Fri Apr 20 15:53:22 2018 UTC (7 years, 2 months ago) by greg
Changes since 2.26: +22 -22 lines
Diff to previous 2.26 , to selected 2.6
Increased precision of cxy output as it makes a big difference to colors
Tue Oct 25 23:23:17 2011 UTC (13 years, 8 months ago) by greg
Diff to previous 2.25 , to selected 2.6
Bug fix in handling of trans2 material
Wed Dec 28 18:39:07 2005 UTC (19 years, 6 months ago) by greg
Changes since 2.24: +2 -1 lines
Diff to previous 2.24 , to selected 2.6
Compile fix in last change -- oops
Wed Dec 28 18:35:42 2005 UTC (19 years, 6 months ago) by greg
Changes since 2.23: +49 -38 lines
Diff to previous 2.23 , to selected 2.6
Sat Nov 15 17:54:06 2003 UTC (21 years, 7 months ago) by schorsch
Changes since 2.22: +4 -3 lines
Diff to previous 2.22 , to selected 2.6
Sat Nov 15 16:29:11 2003 UTC (21 years, 7 months ago) by schorsch
Changes since 2.21: +163 -75 lines
Diff to previous 2.21 , to selected 2.6
ANSIfication, and fixed bad fprintf() call.
Mon Oct 27 10:26:45 2003 UTC (21 years, 8 months ago) by schorsch
Diff to previous 2.20 , to selected 2.6
Various compatibility fixes.
Wed Oct 22 02:06:34 2003 UTC (21 years, 8 months ago) by greg
Diff to previous 2.19 , to selected 2.6
Sat Aug 16 15:54:30 2003 UTC (21 years, 10 months ago) by greg
Diff to previous 2.18 , to selected 2.6
Added basic mesh primitive support
Sun Jul 27 22:12:02 2003 UTC (21 years, 11 months ago) by schorsch
Diff to previous 2.17 , to selected 2.6
Sun Jun 8 12:03:09 2003 UTC (22 years ago) by schorsch
Diff to previous 2.16 , to selected 2.6
Sat Feb 22 02:07:23 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.15: +1 -6 lines
Wed Oct 14 14:48:04 1998 UTC (26 years, 8 months ago) by gwlarson
changed o_face() to put out multiple, escaped lines for big faces
Fri Sep 4 09:09:58 1998 UTC (26 years, 10 months ago) by gwlarson
Changes since 2.13: +2 -7 lines
Mon Nov 20 11:06:21 1995 UTC (29 years, 7 months ago) by greg
increased size of face argument buffer, which ran out on big polys
Wed May 10 19:46:05 1995 UTC (30 years, 1 month ago) by greg
Changes since 2.11: +11 -2 lines
added normalization of object names to insure they're legal
Thu Apr 13 15:33:48 1995 UTC (30 years, 2 months ago) by greg
Changes since 2.10: +36 -15 lines
added commenting of unsupported Radiance primitives
Thu Apr 13 14:43:30 1995 UTC (30 years, 2 months ago) by greg
Changes since 2.9: +37 -1 lines
added MGF index of refraction (ir) and dielectric support
Tue Apr 11 13:33:10 1995 UTC (30 years, 2 months ago) by greg
minor changes
Mon Dec 12 12:09:28 1994 UTC (30 years, 6 months ago) by greg
changed clock to vclock for compatibility reasons
Wed Dec 7 12:44:05 1994 UTC (30 years, 7 months ago) by greg
fixed conversion of emittance
Fri Sep 2 16:21:00 1994 UTC (30 years, 10 months ago) by greg
option parsing error
Mon Aug 15 16:29:22 1994 UTC (30 years, 10 months ago) by greg
Changes since 2.4: +12 -0 lines
fixed bug due to vertices changed in include file (instancing)
Sat Jul 9 09:42:48 1994 UTC (31 years ago) by greg
Changes since 2.3: +22 -23 lines
moved things around a bit
Fri Jul 8 16:39:22 1994 UTC (31 years ago) by greg
fixed updating of vertex last used
Fri Jul 8 16:10:06 1994 UTC (31 years ago) by greg
Changes since 2.1: +142 -78 lines
numerous bug fixes and enhancements
Thu Jul 7 17:30:33 1994 UTC (31 years ago) by greg
Diff to selected 2.6
