1 |
/* Copyright (c) 1994 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Convert Radiance scene description to MGF |
9 |
10 |
11 |
#include <stdio.h> |
12 |
#include <string.h> |
13 |
#include "fvect.h" |
14 |
#include "object.h" |
15 |
#include "color.h" |
16 |
#include "lookup.h" |
17 |
18 |
int o_face(), o_cone(), o_sphere(), o_ring(), o_cylinder(); |
19 |
int o_instance(), o_source(), o_illum(); |
20 |
int o_plastic(), o_metal(), o_glass(), o_mirror(), o_trans(), o_light(); |
21 |
22 |
extern void free(); |
23 |
extern char *malloc(); |
24 |
25 |
LUTAB rmats = LU_SINIT(free,NULL); /* defined material table */ |
26 |
27 |
LUTAB rdispatch = LU_SINIT(NULL,NULL); /* function dispatch table */ |
28 |
29 |
char curmat[80]; /* current material */ |
30 |
char curobj[128] = "Untitled"; /* current object name */ |
31 |
32 |
double unit_mult = 1.; /* units multiplier */ |
33 |
34 |
#define hasmult (unit_mult < .999 || unit_mult > 1.001) |
35 |
36 |
37 |
main(argc, argv) |
38 |
int argc; |
39 |
char **argv; |
40 |
41 |
int i; |
42 |
43 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
44 |
switch (argv[i][1]) { |
45 |
case 'd': /* units */ |
46 |
switch (argv[i][2]) { |
47 |
case 'm': /* meters */ |
48 |
unit_mult = 1.; |
49 |
break; |
50 |
case 'c': /* centimeters */ |
51 |
unit_mult = .01; |
52 |
break; |
53 |
case 'f': /* feet */ |
54 |
unit_mult = 12.*.0254; |
55 |
break; |
56 |
case 'i': /* inches */ |
57 |
unit_mult = .0254; |
58 |
break; |
59 |
default: |
60 |
goto unkopt; |
61 |
62 |
break; |
63 |
64 |
init(); |
65 |
if (i >= argc) |
66 |
rad2mgf(NULL); |
67 |
else |
68 |
for ( ; i < argc; i++) |
69 |
rad2mgf(argv[i]); |
70 |
uninit(); |
71 |
exit(0); |
72 |
unkopt: |
73 |
fprintf(stderr, "Usage: %s [-d{m|c|f|i}] file ..\n", argv[0]); |
74 |
exit(1); |
75 |
76 |
77 |
78 |
rad2mgf(inp) /* convert a Radiance file to MGF */ |
79 |
char *inp; |
80 |
81 |
#define mod buf |
82 |
#define typ (buf+128) |
83 |
#define id (buf+256) |
84 |
#define alias (buf+384) |
85 |
char buf[512]; |
86 |
FUNARGS fa; |
87 |
register FILE *fp; |
88 |
register int c; |
89 |
90 |
if (inp == NULL) { |
91 |
inp = "standard input"; |
92 |
fp = stdin; |
93 |
} else if (inp[0] == '!') { |
94 |
if ((fp = popen(inp+1, "r")) == NULL) { |
95 |
fputs(inp, stderr); |
96 |
fputs(": cannot execute\n", stderr); |
97 |
exit(1); |
98 |
99 |
} else if ((fp = fopen(inp, "r")) == NULL) { |
100 |
101 |
fputs(": cannot open\n", stderr); |
102 |
exit(1); |
103 |
104 |
printf("# Begin conversion from: %s\n", inp); |
105 |
while ((c = getc(fp)) != EOF) |
106 |
switch (c) { |
107 |
case ' ': /* white space */ |
108 |
case '\t': |
109 |
case '\n': |
110 |
case '\r': |
111 |
case '\f': |
112 |
break; |
113 |
case '#': /* comment */ |
114 |
if (fgets(buf, sizeof(buf), fp) != NULL) |
115 |
printf("# %s", buf); |
116 |
break; |
117 |
case '!': /* inline command */ |
118 |
ungetc(c, fp); |
119 |
fgetline(buf, sizeof(buf), fp); |
120 |
rad2mgf(buf); |
121 |
break; |
122 |
default: /* Radiance primitive */ |
123 |
ungetc(c, fp); |
124 |
if (fscanf(fp, "%s %s %s", mod, typ, id) != 3) { |
125 |
126 |
fputs(": unexpected EOF\n", stderr); |
127 |
exit(1); |
128 |
129 |
if (!strcmp(typ, "alias")) { |
130 |
strcpy(alias, "EOF"); |
131 |
fscanf(fp, "%s", alias); |
132 |
newmat(id, alias); |
133 |
} else { |
134 |
if (!readfargs(&fa, fp)) { |
135 |
fprintf(stderr, |
136 |
"%s: bad argument syntax for %s \"%s\"\n", |
137 |
inp, typ, id); |
138 |
exit(1); |
139 |
140 |
cvtprim(inp, mod, typ, id, &fa); |
141 |
freefargs(&fa); |
142 |
143 |
break; |
144 |
145 |
printf("# End conversion from: %s\n", inp); |
146 |
if (inp[0] == '!') |
147 |
pclose(fp); |
148 |
else |
149 |
fclose(fp); |
150 |
#undef mod |
151 |
#undef typ |
152 |
#undef id |
153 |
#undef alias |
154 |
155 |
156 |
157 |
cvtprim(inp, mod, typ, id, fa) /* process Radiance primitive */ |
158 |
char *inp, *mod, *typ, *id; |
159 |
FUNARGS *fa; |
160 |
161 |
int (*df)(); |
162 |
163 |
df = (int (*)())lu_find(&rdispatch, typ)->data; |
164 |
if (df != NULL) { /* convert */ |
165 |
if ((*df)(mod, typ, id, fa) < 0) { |
166 |
fprintf(stderr, "%s: bad %s \"%s\"\n", typ, id); |
167 |
exit(1); |
168 |
169 |
} else if (lu_find(&rmats, mod)->data != NULL) /* make alias */ |
170 |
newmat(id, mod); |
171 |
172 |
173 |
174 |
newmat(id, alias) /* add a modifier to the alias list */ |
175 |
char *id; |
176 |
char *alias; |
177 |
178 |
register LUENT *lp, *lpa; |
179 |
180 |
if (alias != NULL) { /* look up alias */ |
181 |
if ((lpa = lu_find(&rmats, alias)) == NULL) |
182 |
goto memerr; |
183 |
if (lpa->data == NULL) |
184 |
alias = NULL; /* doesn't exist! */ |
185 |
186 |
if ((lp = lu_find(&rmats, id)) == NULL) /* look up material */ |
187 |
goto memerr; |
188 |
if (alias != NULL && lp->data == lpa->key) |
189 |
return; /* alias set already */ |
190 |
if (lp->data == NULL) { /* allocate material */ |
191 |
if ((lp->key = (char *)malloc(strlen(id)+1)) == NULL) |
192 |
goto memerr; |
193 |
strcpy(lp->key, id); |
194 |
195 |
if (alias == NULL) { /* set this material */ |
196 |
lp->data = lp->key; |
197 |
printf("m %s =\n", id); |
198 |
} else { /* set this alias */ |
199 |
lp->data = lpa->key; |
200 |
printf("m %s = %s\n", id, alias); |
201 |
202 |
strcpy(curmat, id); |
203 |
return; |
204 |
memerr: |
205 |
fputs("Out of memory in newmat!\n", stderr); |
206 |
exit(1); |
207 |
208 |
209 |
210 |
setmat(id) /* set material to this one */ |
211 |
char *id; |
212 |
213 |
if (!strcmp(id, curmat)) /* already set? */ |
214 |
return; |
215 |
if (!strcmp(id, VOIDID)) /* cannot set */ |
216 |
return; |
217 |
printf("m %s\n", id); |
218 |
219 |
220 |
221 |
222 |
setobj(id) /* set object name to this one */ |
223 |
char *id; |
224 |
225 |
register char *cp, *cp2; |
226 |
char *end = NULL; |
227 |
int diff = 0; |
228 |
/* use all but final suffix */ |
229 |
for (cp = id; *cp; cp++) |
230 |
if (*cp == '.') |
231 |
end = cp; |
232 |
if (end == NULL) |
233 |
end = cp; |
234 |
/* copy to current object */ |
235 |
for (cp = id, cp2 = curobj; cp < end; *cp2++ = *cp++) |
236 |
diff += *cp != *cp2; |
237 |
if (!diff && !*cp2) |
238 |
return; |
239 |
*cp2 = '\0'; |
240 |
fputs("o\no ", stdout); |
241 |
puts(curobj); |
242 |
243 |
244 |
245 |
init() /* initialize dispatch table and output */ |
246 |
247 |
lu_init(&rdispatch, 22); |
248 |
add2dispatch("polygon", o_face); |
249 |
add2dispatch("cone", o_cone); |
250 |
add2dispatch("cup", o_cone); |
251 |
add2dispatch("sphere", o_sphere); |
252 |
add2dispatch("bubble", o_sphere); |
253 |
add2dispatch("cylinder", o_cylinder); |
254 |
add2dispatch("tube", o_cylinder); |
255 |
add2dispatch("ring", o_ring); |
256 |
add2dispatch("instance", o_instance); |
257 |
add2dispatch("plastic", o_plastic); |
258 |
add2dispatch("plastic2", o_plastic); |
259 |
add2dispatch("metal", o_metal); |
260 |
add2dispatch("metal2", o_metal); |
261 |
add2dispatch("glass", o_glass); |
262 |
add2dispatch("trans", o_trans); |
263 |
add2dispatch("trans2", o_trans); |
264 |
add2dispatch("mirror", o_mirror); |
265 |
add2dispatch("light", o_light); |
266 |
add2dispatch("spotlight", o_light); |
267 |
add2dispatch("glow", o_light); |
268 |
add2dispatch("illum", o_illum); |
269 |
puts("# The following was converted from Radiance scene input"); |
270 |
if (hasmult) |
271 |
printf("xf -s %.4e\n", unit_mult); |
272 |
printf("o %s\n", curobj); |
273 |
274 |
275 |
276 |
uninit() /* mark end of MGF file */ |
277 |
278 |
puts("o"); |
279 |
if (hasmult) |
280 |
puts("xf"); |
281 |
puts("# End of data converted from Radiance scene input"); |
282 |
lu_done(&rdispatch); |
283 |
lu_done(&rmats); |
284 |
285 |
286 |
287 |
add2dispatch(name, func) /* add function to dispatch table */ |
288 |
char *name; |
289 |
int (*func)(); |
290 |
291 |
register LUENT *lp; |
292 |
293 |
lp = lu_find(&rdispatch, name); |
294 |
if (lp->key != NULL) { |
295 |
fputs(name, stderr); |
296 |
fputs(": duplicate dispatch entry!\n", stderr); |
297 |
exit(1); |
298 |
299 |
lp->key = name; |
300 |
lp->data = (char *)func; |
301 |
302 |
303 |
304 |
305 |
* Stuff for tracking and reusing vertices: |
306 |
307 |
308 |
char VKFMT[] = "%+1.9e %+1.9e %+1.9e"; |
309 |
#define VKLEN 64 |
310 |
311 |
#define mkvkey(k,v) sprintf(k, VKFMT, (v)[0], (v)[1], (v)[2]) |
312 |
313 |
#define NVERTS 256 |
314 |
315 |
long clock; /* incremented at each vertex request */ |
316 |
317 |
struct vert { |
318 |
long lused; /* when last used (0 if unassigned) */ |
319 |
FVECT p; /* track point position only */ |
320 |
} vert[NVERTS]; |
321 |
322 |
LUTAB vertab = LU_SINIT(free,NULL); /* our vertex lookup table */ |
323 |
324 |
325 |
char * |
326 |
getvertid(vname, vp) /* get/set vertex ID for this point */ |
327 |
char *vname; |
328 |
FVECT vp; |
329 |
330 |
char vkey[VKLEN]; |
331 |
332 |
register int i, vndx; |
333 |
334 |
if (!vertab.tsiz && !lu_init(&vertab, NVERTS)) |
335 |
goto memerr; |
336 |
clock++; /* increment counter */ |
337 |
mkvkey(vkey, vp); |
338 |
if ((lp = lu_find(&vertab, vkey)) == NULL) |
339 |
goto memerr; |
340 |
if (lp->data == NULL) { /* allocate new vertex entry */ |
341 |
if (lp->key != NULL) /* reclaim deleted entry */ |
342 |
vertab.ndel--; |
343 |
else { |
344 |
if ((lp->key = (char *)malloc(VKLEN)) == NULL) |
345 |
goto memerr; |
346 |
strcpy(lp->key, vkey); |
347 |
348 |
vndx = 0; /* find oldest vertex */ |
349 |
for (i = 1; i < NVERTS; i++) |
350 |
if (vert[i].lused < vert[vndx].lused) |
351 |
vndx = i; |
352 |
if (vert[vndx].lused) { /* free old entry first */ |
353 |
mkvkey(vkey, vert[vndx].p); |
354 |
lu_delete(&vertab, vkey); |
355 |
356 |
vert[vndx].lused = clock; /* assign it */ |
357 |
VCOPY(vert[vndx].p, vp); |
358 |
printf("v v%d =\n\tp %.15g %.15g %.15g\n", /* print it */ |
359 |
vndx, vp[0], vp[1], vp[2]); |
360 |
lp->data = (char *)&vert[vndx]; /* set it */ |
361 |
} else |
362 |
vndx = (struct vert *)lp->data - vert; |
363 |
sprintf(vname, "v%d", vndx); |
364 |
return(vname); |
365 |
memerr: |
366 |
fputs("Out of memory in getvertid!\n", stderr); |
367 |
exit(1); |
368 |
369 |
370 |
371 |
int |
372 |
o_face(mod, typ, id, fa) /* print out a polygon */ |
373 |
char *mod, *typ, *id; |
374 |
FUNARGS *fa; |
375 |
376 |
char entbuf[512]; |
377 |
register char *cp; |
378 |
register int i; |
379 |
380 |
if (fa->nfargs < 9 | fa->nfargs % 3) |
381 |
return(-1); |
382 |
setmat(mod); |
383 |
setobj(id); |
384 |
cp = entbuf; |
385 |
*cp++ = 'f'; |
386 |
for (i = 0; i < fa->nfargs; i += 3) { |
387 |
*cp++ = ' '; |
388 |
getvertid(cp, fa->farg + i); |
389 |
while (*cp) |
390 |
cp++; |
391 |
392 |
puts(entbuf); |
393 |
return(0); |
394 |
395 |
396 |
397 |
int |
398 |
o_cone(mod, typ, id, fa) /* print out a cone */ |
399 |
400 |
register FUNARGS *fa; |
401 |
402 |
char v1[6], v2[6]; |
403 |
404 |
if (fa->nfargs != 8) |
405 |
return(-1); |
406 |
setmat(mod); |
407 |
setobj(id); |
408 |
getvertid(v1, fa->farg); |
409 |
getvertid(v2, fa->farg + 3); |
410 |
if (typ[1] == 'u') /* cup -> inverted cone */ |
411 |
printf("cone %s %.12g %s %.12g\n", |
412 |
v1, -fa->farg[6], v2, -fa->farg[7]); |
413 |
else |
414 |
415 |
v1, fa->farg[6], v2, fa->farg[7]); |
416 |
return(0); |
417 |
418 |
419 |
420 |
int |
421 |
o_sphere(mod, typ, id, fa) /* print out a sphere */ |
422 |
423 |
424 |
425 |
char cent[6]; |
426 |
427 |
if (fa->nfargs != 4) |
428 |
return(-1); |
429 |
setmat(mod); |
430 |
setobj(id); |
431 |
printf("sph %s %.12g\n", getvertid(cent, fa->farg), |
432 |
typ[0]=='b' ? -fa->farg[3] : fa->farg[3]); |
433 |
return(0); |
434 |
435 |
436 |
437 |
int |
438 |
o_cylinder(mod, typ, id, fa) /* print out a cylinder */ |
439 |
440 |
441 |
442 |
443 |
444 |
if (fa->nfargs != 7) |
445 |
return(-1); |
446 |
setmat(mod); |
447 |
setobj(id); |
448 |
449 |
450 |
printf("cyl %s %.12g %s\n", v1, |
451 |
typ[0]=='t' ? -fa->farg[6] : fa->farg[6], v2); |
452 |
return(0); |
453 |
454 |
455 |
456 |
int |
457 |
o_ring(mod, typ, id, fa) /* print out a ring */ |
458 |
459 |
460 |
461 |
462 |
return(-1); |
463 |
setmat(mod); |
464 |
setobj(id); |
465 |
printf("v cent =\n\tp %.12g %.12g %.12g\n", |
466 |
fa->farg[0], fa->farg[1], fa->farg[2]); |
467 |
printf("\tn %.12g %.12g %.12g\n", |
468 |
fa->farg[3], fa->farg[4], fa->farg[5]); |
469 |
if (fa->farg[6] < fa->farg[7]) |
470 |
printf("ring cent %.12g %.12g\n", |
471 |
fa->farg[6], fa->farg[7]); |
472 |
else |
473 |
474 |
fa->farg[7], fa->farg[6]); |
475 |
return(0); |
476 |
477 |
478 |
479 |
int |
480 |
o_instance(mod, typ, id, fa) /* convert an instance */ |
481 |
482 |
FUNARGS *fa; |
483 |
484 |
register int i; |
485 |
486 |
char *start = NULL, *end = NULL; |
487 |
488 |
* We don't really know how to do this, so we just create |
489 |
* a reference to an undefined MGF file and it's the user's |
490 |
* responsibility to create this file and put the appropriate |
491 |
* stuff into it. |
492 |
493 |
if (fa->nsargs < 1) |
494 |
return(-1); |
495 |
setmat(mod); /* only works if surfaces are void */ |
496 |
setobj(id); |
497 |
for (cp = fa->sarg[0]; *cp; cp++) /* construct MGF file name */ |
498 |
if (*cp == '/') |
499 |
start = cp+1; |
500 |
else if (*cp == '.') |
501 |
end = cp; |
502 |
if (start == NULL) |
503 |
start = fa->sarg[0]; |
504 |
if (end == NULL || start >= end) |
505 |
end = cp; |
506 |
fputs("i ", stdout); /* print include entity */ |
507 |
for (cp = start; cp < end; cp++) |
508 |
putchar(*cp); |
509 |
fputs(".mgf", stdout); /* add MGF suffix */ |
510 |
for (i = 1; i < fa->nsargs; i++) { /* add transform */ |
511 |
putchar(' '); |
512 |
fputs(fa->sarg[i], stdout); |
513 |
514 |
putchar('\n'); |
515 |
return(0); |
516 |
517 |
518 |
519 |
int |
520 |
o_source(mod, typ, id, fa) /* convert a source */ |
521 |
522 |
FUNARGS *fa; |
523 |
524 |
return(0); /* there is no MGF equivalent! */ |
525 |
526 |
527 |
528 |
int |
529 |
o_illum(mod, typ, id, fa) /* convert an illum material */ |
530 |
531 |
FUNARGS *fa; |
532 |
533 |
if (fa->nsargs == 1 && strcmp(fa->sarg[0], VOIDID)) { |
534 |
newmat(id, fa->sarg[0]); /* just create alias */ |
535 |
return(0); |
536 |
537 |
/* else create invisible material */ |
538 |
newmat(id, NULL); |
539 |
puts("\tts 1 0"); |
540 |
return(0); |
541 |
542 |
543 |
544 |
int |
545 |
o_plastic(mod, typ, id, fa) /* convert a plastic material */ |
546 |
547 |
548 |
549 |
COLOR cxyz, rrgb; |
550 |
double d; |
551 |
552 |
if (fa->nfargs != (typ[7]=='2' ? 6 : 5)) |
553 |
return(-1); |
554 |
newmat(id, NULL); |
555 |
rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2]; |
556 |
rgb_cie(cxyz, rrgb); |
557 |
puts("\tc"); /* put diffuse component */ |
558 |
d = cxyz[0] + cxyz[1] + cxyz[2]; |
559 |
if (d > FTINY) |
560 |
printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d); |
561 |
printf("\trd %.4f\n", cxyz[1]*(1. - fa->farg[3])); |
562 |
if (fa->farg[3] > FTINY) { /* put specular component */ |
563 |
puts("\tc"); |
564 |
printf("\trs %.4f %.4f\n", fa->farg[3], |
565 |
typ[7]=='2' ? .5*(fa->farg[4] + fa->farg[5]) : |
566 |
fa->farg[4]); |
567 |
568 |
return(0); |
569 |
570 |
571 |
572 |
int |
573 |
o_metal(mod, typ, id, fa) /* convert a metal material */ |
574 |
575 |
576 |
577 |
COLOR cxyz, rrgb; |
578 |
double d; |
579 |
580 |
if (fa->nfargs != (typ[5]=='2' ? 6 : 5)) |
581 |
return(-1); |
582 |
newmat(id, NULL); |
583 |
584 |
585 |
586 |
587 |
if (d > FTINY) |
588 |
589 |
590 |
591 |
printf("\trs %.4f %.4f\n", cxyz[1]*fa->farg[3], |
592 |
typ[5]=='2' ? .5*(fa->farg[4] + fa->farg[5]) : |
593 |
fa->farg[4]); |
594 |
return(0); |
595 |
596 |
597 |
598 |
int |
599 |
o_glass(mod, typ, id, fa) /* convert a glass material */ |
600 |
601 |
602 |
603 |
COLOR cxyz, rrgb, trgb; |
604 |
double nrfr = 1.52, F, d; |
605 |
register int i; |
606 |
607 |
if (fa->nfargs != 3 && fa->nfargs != 4) |
608 |
return(-1); |
609 |
newmat(id, NULL); |
610 |
if (fa->nfargs == 4) |
611 |
nrfr = fa->farg[3]; |
612 |
F = (1. - nrfr)/(1. + nrfr); /* use normal incidence */ |
613 |
F *= F; |
614 |
for (i = 0; i < 3; i++) { |
615 |
trgb[i] = fa->farg[i] * (1. - F)*(1. - F) / |
616 |
(1. - F*F*fa->farg[i]*fa->farg[i]); |
617 |
rrgb[i] = F * (1. + (1. - 2.*F)*fa->farg[i]) / |
618 |
619 |
620 |
rgb_cie(cxyz, rrgb); /* put reflected component */ |
621 |
puts("\tc"); |
622 |
623 |
if (d > FTINY) |
624 |
625 |
printf("\trs %.4f 0\n", cxyz[1]); |
626 |
rgb_cie(cxyz, trgb); /* put transmitted component */ |
627 |
puts("\tc"); |
628 |
629 |
if (d > FTINY) |
630 |
631 |
printf("\tts %.4f 0\n", cxyz[1]); |
632 |
return(0); |
633 |
634 |
635 |
636 |
int |
637 |
o_mirror(mod, typ, id, fa) /* convert a mirror material */ |
638 |
639 |
640 |
641 |
COLOR cxyz, rrgb; |
642 |
double d; |
643 |
644 |
if (fa->nsargs == 1) { /* use alternate material */ |
645 |
newmat(id, fa->sarg[0]); |
646 |
return(0); |
647 |
648 |
if (fa->nfargs != 3) |
649 |
return(-1); |
650 |
newmat(id, NULL); |
651 |
652 |
653 |
puts("\tc"); /* put specular component */ |
654 |
655 |
if (d > FTINY) |
656 |
657 |
658 |
return(0); |
659 |
660 |
661 |
662 |
int |
663 |
o_trans(mod, typ, id, fa) /* convert a trans material */ |
664 |
665 |
666 |
667 |
COLOR cxyz, rrgb; |
668 |
double rough, trans, tspec, d; |
669 |
670 |
if (typ[4] == '2') { /* trans2 */ |
671 |
672 |
return(-1); |
673 |
rough = .5*(fa->farg[4] + fa->farg[5]); |
674 |
trans = fa->farg[6]; |
675 |
tspec = fa->farg[7]; |
676 |
} else { /* trans */ |
677 |
678 |
return(-1); |
679 |
rough = fa->farg[4]; |
680 |
trans = fa->farg[5]; |
681 |
tspec = fa->farg[6]; |
682 |
683 |
newmat(id, NULL); |
684 |
685 |
686 |
puts("\tc"); /* put transmitted diffuse */ |
687 |
688 |
if (d > FTINY) |
689 |
690 |
printf("\ttd %.4f\n", cxyz[1]*trans*(1. - fa->farg[3])*(1. - tspec)); |
691 |
/* put transmitted specular */ |
692 |
printf("\tts %.4f %.4f\n", cxyz[1]*trans*tspec*(1. - fa->farg[3]), rough); |
693 |
/* put reflected diffuse */ |
694 |
printf("\trd %.4f\n", cxyz[1]*(1. - fa->farg[3])*(1. - trans)); |
695 |
puts("\tc"); /* put reflected specular */ |
696 |
printf("\trs %.4f %.4f\n", fa->farg[3], rough); |
697 |
return(0); |
698 |
699 |
700 |
701 |
int |
702 |
o_light(mod, typ, id, fa) /* convert a light type */ |
703 |
704 |
705 |
706 |
COLOR cxyz, rrgb; |
707 |
double d; |
708 |
709 |
if (fa->nfargs < 3) |
710 |
return(-1); |
711 |
newmat(id, NULL); |
712 |
713 |
714 |
715 |
puts("\tc"); |
716 |
if (d > FTINY) |
717 |
718 |
printf("\ted %.4g\n", cxyz[1]*WHTEFFICACY); |
719 |
return(0); |
720 |
