--- ray/src/cv/rad2mgf.c 2003/06/08 12:03:09 2.17 +++ ray/src/cv/rad2mgf.c 2003/11/15 17:54:06 2.23 @@ -1,26 +1,24 @@ #ifndef lint -static const char RCSid[] = "$Id: rad2mgf.c,v 2.17 2003/06/08 12:03:09 schorsch Exp $"; +static const char RCSid[] = "$Id: rad2mgf.c,v 2.23 2003/11/15 17:54:06 schorsch Exp $"; #endif /* * Convert Radiance scene description to MGF */ -#include "standard.h" #include #include #include #include "platform.h" +#include "rtmath.h" +#include "rtio.h" +#include "rtprocess.h" #include "object.h" #include "color.h" #include "lookup.h" #define C_1SIDEDTHICK 0.005 -int o_face(), o_cone(), o_sphere(), o_ring(), o_cylinder(); -int o_instance(), o_illum(); -int o_plastic(), o_metal(), o_glass(), o_dielectric(), - o_mirror(), o_trans(), o_light(); LUTAB rmats = LU_SINIT(free,NULL); /* defined material table */ @@ -53,10 +51,38 @@ struct vert { LUTAB vertab = LU_SINIT(free,NULL); /* our vertex lookup table */ +static void rad2mgf(char *inp); +static void cvtprim(char *inp, char *mod, char *typ, char *id, FUNARGS *fa); +static void newmat(char *id, char *alias); +static void setmat(char *id); +static void setobj(char *id); +static void init(void); +static void uninit(void); +static void clrverts(void); +static void add2dispatch(char *name, int (*func)()); +static char *getvertid(char *vname, FVECT vp); +static int o_unsupported(char *mod, char *typ, char *id, FUNARGS *fa); +static int o_face(char *mod, char *typ, char *id, FUNARGS *fa); +static int o_cone(char *mod, char *typ, char *id, FUNARGS *fa); +static int o_sphere(char *mod, char *typ, char *id, FUNARGS *fa); +static int o_cylinder(char *mod, char *typ, char *id, FUNARGS *fa); +static int o_ring(char *mod, char *typ, char *id, FUNARGS *fa); +static int o_instance(char *mod, char *typ, char *id, FUNARGS *fa); +static int o_illum(char *mod, char *typ, char *id, FUNARGS *fa); +static int o_plastic(char *mod, char *typ, char *id, FUNARGS *fa); +static int o_metal(char *mod, char *typ, char *id, FUNARGS *fa); +static int o_glass(char *mod, char *typ, char *id, FUNARGS *fa); +static int o_dielectric(char *mod, char *typ, char *id, FUNARGS *fa); +static int o_mirror(char *mod, char *typ, char *id, FUNARGS *fa); +static int o_trans(char *mod, char *typ, char *id, FUNARGS *fa); +static int o_light(char *mod, char *typ, char *id, FUNARGS *fa); -main(argc, argv) -int argc; -char **argv; + +int +main( + int argc, + char **argv +) { int i; @@ -97,8 +123,10 @@ unkopt: } -rad2mgf(inp) /* convert a Radiance file to MGF */ -char *inp; +void +rad2mgf( /* convert a Radiance file to MGF */ + char *inp +) { #define mod buf #define typ (buf+128) @@ -176,16 +204,21 @@ char *inp; } -cvtprim(inp, mod, typ, id, fa) /* process Radiance primitive */ -char *inp, *mod, *typ, *id; -FUNARGS *fa; +void +cvtprim( /* process Radiance primitive */ + char *inp, + char *mod, + char *typ, + char *id, + FUNARGS *fa +) { int (*df)(); df = (int (*)())lu_find(&rdispatch, typ)->data; if (df != NULL) { /* convert */ if ((*df)(mod, typ, id, fa) < 0) { - fprintf(stderr, "%s: bad %s \"%s\"\n", typ, id); + fprintf(stderr, "%s: bad %s \"%s\"\n", "rat2mgf", typ, id); exit(1); } } else { /* unsupported */ @@ -196,9 +229,11 @@ FUNARGS *fa; } -newmat(id, alias) /* add a modifier to the alias list */ -char *id; -char *alias; +void +newmat( /* add a modifier to the alias list */ + char *id, + char *alias +) { register LUENT *lp, *lpa; @@ -232,8 +267,10 @@ memerr: } -setmat(id) /* set material to this one */ -char *id; +void +setmat( /* set material to this one */ + char *id +) { if (!strcmp(id, curmat)) /* already set? */ return; @@ -244,8 +281,10 @@ char *id; } -setobj(id) /* set object name to this one */ -char *id; +void +setobj( /* set object name to this one */ + char *id +) { register char *cp, *cp2; char *end = NULL; @@ -263,7 +302,7 @@ char *id; *cp2++ = 'O'; } for (cp = id; cp < end; *cp2++ = *cp++) { - if (*cp < '!' | *cp > '~') /* limit to visible chars */ + if ((*cp < '!') | (*cp > '~')) /* limit to visible chars */ *cp = '?'; diff += *cp != *cp2; } @@ -275,7 +314,8 @@ char *id; } -init() /* initialize dispatch table and output */ +void +init(void) /* initialize dispatch table and output */ { lu_init(&vertab, NVERTS); lu_init(&rdispatch, 22); @@ -288,6 +328,7 @@ init() /* initialize dispatch table and output */ add2dispatch("tube", o_cylinder); add2dispatch("ring", o_ring); add2dispatch("instance", o_instance); + add2dispatch("mesh", o_instance); add2dispatch("plastic", o_plastic); add2dispatch("plastic2", o_plastic); add2dispatch("metal", o_metal); @@ -308,7 +349,8 @@ init() /* initialize dispatch table and output */ } -uninit() /* mark end of MGF file */ +void +uninit(void) /* mark end of MGF file */ { puts("o"); if (hasmult) @@ -320,7 +362,8 @@ uninit() /* mark end of MGF file */ } -clrverts() /* clear vertex table */ +void +clrverts(void) /* clear vertex table */ { register int i; @@ -331,9 +374,11 @@ clrverts() /* clear vertex table */ } -add2dispatch(name, func) /* add function to dispatch table */ -char *name; -int (*func)(); +void +add2dispatch( /* add function to dispatch table */ + char *name, + int (*func)() +) { register LUENT *lp; @@ -349,9 +394,10 @@ int (*func)(); char * -getvertid(vname, vp) /* get/set vertex ID for this point */ -char *vname; -FVECT vp; +getvertid( /* get/set vertex ID for this point */ + char *vname, + FVECT vp +) { static char vkey[VKLEN]; register LUENT *lp; @@ -393,9 +439,12 @@ memerr: int -o_unsupported(mod, typ, id, fa) /* mark unsupported primitive */ -char *mod, *typ, *id; -FUNARGS *fa; +o_unsupported( /* mark unsupported primitive */ + char *mod, + char *typ, + char *id, + FUNARGS *fa +) { register int i; @@ -420,15 +469,18 @@ FUNARGS *fa; int -o_face(mod, typ, id, fa) /* print out a polygon */ -char *mod, *typ, *id; -FUNARGS *fa; +o_face( /* print out a polygon */ + char *mod, + char *typ, + char *id, + FUNARGS *fa +) { char entbuf[2048], *linestart; register char *cp; register int i; - if (fa->nfargs < 9 | fa->nfargs % 3) + if ((fa->nfargs < 9) | (fa->nfargs % 3)) return(-1); setmat(mod); setobj(id); @@ -451,9 +503,12 @@ FUNARGS *fa; int -o_cone(mod, typ, id, fa) /* print out a cone */ -char *mod, *typ, *id; -register FUNARGS *fa; +o_cone( /* print out a cone */ + char *mod, + char *typ, + char *id, + register FUNARGS *fa +) { char v1[6], v2[6]; @@ -474,9 +529,12 @@ register FUNARGS *fa; int -o_sphere(mod, typ, id, fa) /* print out a sphere */ -char *mod, *typ, *id; -register FUNARGS *fa; +o_sphere( /* print out a sphere */ + char *mod, + char *typ, + char *id, + register FUNARGS *fa +) { char cent[6]; @@ -491,9 +549,12 @@ register FUNARGS *fa; int -o_cylinder(mod, typ, id, fa) /* print out a cylinder */ -char *mod, *typ, *id; -register FUNARGS *fa; +o_cylinder( /* print out a cylinder */ + char *mod, + char *typ, + char *id, + register FUNARGS *fa +) { char v1[6], v2[6]; @@ -510,9 +571,12 @@ register FUNARGS *fa; int -o_ring(mod, typ, id, fa) /* print out a ring */ -char *mod, *typ, *id; -register FUNARGS *fa; +o_ring( /* print out a ring */ + char *mod, + char *typ, + char *id, + register FUNARGS *fa +) { if (fa->nfargs != 8) return(-1); @@ -533,9 +597,12 @@ register FUNARGS *fa; int -o_instance(mod, typ, id, fa) /* convert an instance */ -char *mod, *typ, *id; -FUNARGS *fa; +o_instance( /* convert an instance (or mesh) */ + char *mod, + char *typ, + char *id, + FUNARGS *fa +) { register int i; register char *cp; @@ -574,9 +641,12 @@ FUNARGS *fa; int -o_illum(mod, typ, id, fa) /* convert an illum material */ -char *mod, *typ, *id; -FUNARGS *fa; +o_illum( /* convert an illum material */ + char *mod, + char *typ, + char *id, + FUNARGS *fa +) { if (fa->nsargs == 1 && strcmp(fa->sarg[0], VOIDID)) { newmat(id, fa->sarg[0]); /* just create alias */ @@ -590,9 +660,12 @@ FUNARGS *fa; int -o_plastic(mod, typ, id, fa) /* convert a plastic material */ -char *mod, *typ, *id; -register FUNARGS *fa; +o_plastic( /* convert a plastic material */ + char *mod, + char *typ, + char *id, + register FUNARGS *fa +) { COLOR cxyz, rrgb; double d; @@ -618,9 +691,12 @@ register FUNARGS *fa; int -o_metal(mod, typ, id, fa) /* convert a metal material */ -char *mod, *typ, *id; -register FUNARGS *fa; +o_metal( /* convert a metal material */ + char *mod, + char *typ, + char *id, + register FUNARGS *fa +) { COLOR cxyz, rrgb; double d; @@ -644,9 +720,12 @@ register FUNARGS *fa; int -o_glass(mod, typ, id, fa) /* convert a glass material */ -char *mod, *typ, *id; -register FUNARGS *fa; +o_glass( /* convert a glass material */ + char *mod, + char *typ, + char *id, + register FUNARGS *fa +) { COLOR cxyz, rrgb, trgb; double nrfr = 1.52, F, d; @@ -683,9 +762,12 @@ register FUNARGS *fa; int -o_dielectric(mod, typ, id, fa) /* convert a dielectric material */ -char *mod, *typ, *id; -register FUNARGS *fa; +o_dielectric( /* convert a dielectric material */ + char *mod, + char *typ, + char *id, + register FUNARGS *fa +) { COLOR cxyz, trgb; double F, d; @@ -713,9 +795,12 @@ register FUNARGS *fa; int -o_mirror(mod, typ, id, fa) /* convert a mirror material */ -char *mod, *typ, *id; -register FUNARGS *fa; +o_mirror( /* convert a mirror material */ + char *mod, + char *typ, + char *id, + register FUNARGS *fa +) { COLOR cxyz, rrgb; double d; @@ -739,9 +824,12 @@ register FUNARGS *fa; int -o_trans(mod, typ, id, fa) /* convert a trans material */ -char *mod, *typ, *id; -register FUNARGS *fa; +o_trans( /* convert a trans material */ + char *mod, + char *typ, + char *id, + register FUNARGS *fa +) { COLOR cxyz, rrgb; double rough, trans, tspec, d; @@ -778,9 +866,12 @@ register FUNARGS *fa; int -o_light(mod, typ, id, fa) /* convert a light type */ -char *mod, *typ, *id; -register FUNARGS *fa; +o_light( /* convert a light type */ + char *mod, + char *typ, + char *id, + register FUNARGS *fa +) { COLOR cxyz, rrgb; double d;
