root/radiance/ray/src/cv/rad2mgf.c
Revision: 2.12
Committed: Wed May 10 19:46:05 1995 UTC (29 years, 1 month ago) by greg
Changes since 2.11: +11 -2 lines
added normalization of object names to insure they're legal
1 /* Copyright (c) 1995 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Convert Radiance scene description to MGF
9 */
10
11 #include <stdio.h>
12 #include <math.h>
13 #include <ctype.h>
14 #include <string.h>
15 #include "fvect.h"
16 #include "object.h"
17 #include "color.h"
18 #include "lookup.h"
19
20 #define PI 3.14159265358979323846
21
22 #define C_1SIDEDTHICK 0.005
23
24 int o_face(), o_cone(), o_sphere(), o_ring(), o_cylinder();
25 int o_instance(), o_illum();
26 int o_plastic(), o_metal(), o_glass(), o_dielectric(),
27 o_mirror(), o_trans(), o_light();
28
29 extern void free();
30 extern char *malloc();
31
32 LUTAB rmats = LU_SINIT(free,NULL); /* defined material table */
33
34 LUTAB rdispatch = LU_SINIT(NULL,NULL); /* function dispatch table */
35
36 char curmat[80]; /* current material */
37 char curobj[128] = "Untitled"; /* current object name */
38
39 double unit_mult = 1.; /* units multiplier */
40
41 #define hasmult (unit_mult < .999 || unit_mult > 1.001)
42
43 /*
44 * Stuff for tracking and reusing vertices:
45 */
46
47 char VKFMT[] = "%+16.9e %+16.9e %+16.9e";
48 #define VKLEN 64
49
50 #define mkvkey(k,v) sprintf(k, VKFMT, (v)[0], (v)[1], (v)[2])
51
52 #define NVERTS 256
53
54 long vclock; /* incremented at each vertex request */
55
56 struct vert {
57 long lused; /* when last used (0 if unassigned) */
58 FVECT p; /* track point position only */
59 } vert[NVERTS]; /* our vertex cache */
60
61 LUTAB vertab = LU_SINIT(free,NULL); /* our vertex lookup table */
62
63
64 main(argc, argv)
65 int argc;
66 char **argv;
67 {
68 int i;
69
70 for (i = 1; i < argc && argv[i][0] == '-'; i++)
71 switch (argv[i][1]) {
72 case 'd': /* units */
73 switch (argv[i][2]) {
74 case 'm': /* meters */
75 unit_mult = 1.;
76 break;
77 case 'c': /* centimeters */
78 unit_mult = .01;
79 break;
80 case 'f': /* feet */
81 unit_mult = 12.*.0254;
82 break;
83 case 'i': /* inches */
84 unit_mult = .0254;
85 break;
86 default:
87 goto unkopt;
88 }
89 break;
90 default:
91 goto unkopt;
92 }
93 init();
94 if (i >= argc)
95 rad2mgf(NULL);
96 else
97 for ( ; i < argc; i++)
98 rad2mgf(argv[i]);
99 uninit();
100 exit(0);
101 unkopt:
102 fprintf(stderr, "Usage: %s [-d{m|c|f|i}] file ..\n", argv[0]);
103 exit(1);
104 }
105
106
107 rad2mgf(inp) /* convert a Radiance file to MGF */
108 char *inp;
109 {
110 #define mod buf
111 #define typ (buf+128)
112 #define id (buf+256)
113 #define alias (buf+384)
114 char buf[512];
115 FUNARGS fa;
116 register FILE *fp;
117 register int c;
118
119 if (inp == NULL) {
120 inp = "standard input";
121 fp = stdin;
122 } else if (inp[0] == '!') {
123 if ((fp = popen(inp+1, "r")) == NULL) {
124 fputs(inp, stderr);
125 fputs(": cannot execute\n", stderr);
126 exit(1);
127 }
128 } else if ((fp = fopen(inp, "r")) == NULL) {
129 fputs(inp, stderr);
130 fputs(": cannot open\n", stderr);
131 exit(1);
132 }
133 printf("# Begin conversion from: %s\n", inp);
134 while ((c = getc(fp)) != EOF)
135 switch (c) {
136 case ' ': /* white space */
137 case '\t':
138 case '\n':
139 case '\r':
140 case '\f':
141 break;
142 case '#': /* comment */
143 if (fgets(buf, sizeof(buf), fp) != NULL)
144 printf("# %s", buf);
145 break;
146 case '!': /* inline command */
147 ungetc(c, fp);
148 fgetline(buf, sizeof(buf), fp);
149 rad2mgf(buf);
150 break;
151 default: /* Radiance primitive */
152 ungetc(c, fp);
153 if (fscanf(fp, "%s %s %s", mod, typ, id) != 3) {
154 fputs(inp, stderr);
155 fputs(": unexpected EOF\n", stderr);
156 exit(1);
157 }
158 if (!strcmp(typ, "alias")) {
159 strcpy(alias, "EOF");
160 fscanf(fp, "%s", alias);
161 newmat(id, alias);
162 } else {
163 if (!readfargs(&fa, fp)) {
164 fprintf(stderr,
165 "%s: bad argument syntax for %s \"%s\"\n",
166 inp, typ, id);
167 exit(1);
168 }
169 cvtprim(inp, mod, typ, id, &fa);
170 freefargs(&fa);
171 }
172 break;
173 }
174 printf("# End conversion from: %s\n", inp);
175 if (inp[0] == '!')
176 pclose(fp);
177 else
178 fclose(fp);
179 #undef mod
180 #undef typ
181 #undef id
182 #undef alias
183 }
184
185
186 cvtprim(inp, mod, typ, id, fa) /* process Radiance primitive */
187 char *inp, *mod, *typ, *id;
188 FUNARGS *fa;
189 {
190 int (*df)();
191
192 df = (int (*)())lu_find(&rdispatch, typ)->data;
193 if (df != NULL) { /* convert */
194 if ((*df)(mod, typ, id, fa) < 0) {
195 fprintf(stderr, "%s: bad %s \"%s\"\n", typ, id);
196 exit(1);
197 }
198 } else { /* unsupported */
199 o_unsupported(mod, typ, id, fa);
200 if (lu_find(&rmats, mod)->data != NULL) /* make alias */
201 newmat(id, mod);
202 }
203 }
204
205
206 newmat(id, alias) /* add a modifier to the alias list */
207 char *id;
208 char *alias;
209 {
210 register LUENT *lp, *lpa;
211
212 if (alias != NULL) { /* look up alias */
213 if ((lpa = lu_find(&rmats, alias)) == NULL)
214 goto memerr;
215 if (lpa->data == NULL)
216 alias = NULL; /* doesn't exist! */
217 }
218 if ((lp = lu_find(&rmats, id)) == NULL) /* look up material */
219 goto memerr;
220 if (alias != NULL && lp->data == lpa->key)
221 return; /* alias set already */
222 if (lp->data == NULL) { /* allocate material */
223 if ((lp->key = (char *)malloc(strlen(id)+1)) == NULL)
224 goto memerr;
225 strcpy(lp->key, id);
226 }
227 if (alias == NULL) { /* set this material */
228 lp->data = lp->key;
229 printf("m %s =\n", id);
230 } else { /* set this alias */
231 lp->data = lpa->key;
232 printf("m %s = %s\n", id, alias);
233 }
234 strcpy(curmat, id);
235 return;
236 memerr:
237 fputs("Out of memory in newmat!\n", stderr);
238 exit(1);
239 }
240
241
242 setmat(id) /* set material to this one */
243 char *id;
244 {
245 if (!strcmp(id, curmat)) /* already set? */
246 return;
247 if (!strcmp(id, VOIDID)) /* cannot set */
248 return;
249 printf("m %s\n", id);
250 strcpy(curmat, id);
251 }
252
253
254 setobj(id) /* set object name to this one */
255 char *id;
256 {
257 register char *cp, *cp2;
258 char *end = NULL;
259 int diff = 0;
260 /* use all but final suffix */
261 for (cp = id; *cp; cp++)
262 if (*cp == '.')
263 end = cp;
264 if (end == NULL)
265 end = cp;
266 /* copy to current object */
267 cp2 = curobj;
268 if (!isalpha(*id)) { /* start with letter */
269 diff = *cp2 != 'O';
270 *cp2++ = 'O';
271 }
272 for (cp = id; cp < end; *cp2++ = *cp++) {
273 if (*cp < '!' | *cp > '~') /* limit to visible chars */
274 *cp = '?';
275 diff += *cp != *cp2;
276 }
277 if (!diff && !*cp2)
278 return;
279 *cp2 = '\0';
280 fputs("o\no ", stdout);
281 puts(curobj);
282 }
283
284
285 init() /* initialize dispatch table and output */
286 {
287 lu_init(&vertab, NVERTS);
288 lu_init(&rdispatch, 22);
289 add2dispatch("polygon", o_face);
290 add2dispatch("cone", o_cone);
291 add2dispatch("cup", o_cone);
292 add2dispatch("sphere", o_sphere);
293 add2dispatch("bubble", o_sphere);
294 add2dispatch("cylinder", o_cylinder);
295 add2dispatch("tube", o_cylinder);
296 add2dispatch("ring", o_ring);
297 add2dispatch("instance", o_instance);
298 add2dispatch("plastic", o_plastic);
299 add2dispatch("plastic2", o_plastic);
300 add2dispatch("metal", o_metal);
301 add2dispatch("metal2", o_metal);
302 add2dispatch("glass", o_glass);
303 add2dispatch("dielectric", o_dielectric);
304 add2dispatch("trans", o_trans);
305 add2dispatch("trans2", o_trans);
306 add2dispatch("mirror", o_mirror);
307 add2dispatch("light", o_light);
308 add2dispatch("spotlight", o_light);
309 add2dispatch("glow", o_light);
310 add2dispatch("illum", o_illum);
311 puts("# The following was converted from RADIANCE scene input");
312 if (hasmult)
313 printf("xf -s %.4e\n", unit_mult);
314 printf("o %s\n", curobj);
315 }
316
317
318 uninit() /* mark end of MGF file */
319 {
320 puts("o");
321 if (hasmult)
322 puts("xf");
323 puts("# End of data converted from RADIANCE scene input");
324 lu_done(&rdispatch);
325 lu_done(&rmats);
326 lu_done(&vertab);
327 }
328
329
330 clrverts() /* clear vertex table */
331 {
332 register int i;
333
334 lu_done(&vertab);
335 for (i = 0; i < NVERTS; i++)
336 vert[i].lused = 0;
337 lu_init(&vertab, NVERTS);
338 }
339
340
341 add2dispatch(name, func) /* add function to dispatch table */
342 char *name;
343 int (*func)();
344 {
345 register LUENT *lp;
346
347 lp = lu_find(&rdispatch, name);
348 if (lp->key != NULL) {
349 fputs(name, stderr);
350 fputs(": duplicate dispatch entry!\n", stderr);
351 exit(1);
352 }
353 lp->key = name;
354 lp->data = (char *)func;
355 }
356
357
358 char *
359 getvertid(vname, vp) /* get/set vertex ID for this point */
360 char *vname;
361 FVECT vp;
362 {
363 static char vkey[VKLEN];
364 register LUENT *lp;
365 register int i, vndx;
366
367 vclock++; /* increment counter */
368 mkvkey(vkey, vp);
369 if ((lp = lu_find(&vertab, vkey)) == NULL)
370 goto memerr;
371 if (lp->data == NULL) { /* allocate new vertex entry */
372 if (lp->key != NULL) /* reclaim deleted entry */
373 vertab.ndel--;
374 else {
375 if ((lp->key = (char *)malloc(VKLEN)) == NULL)
376 goto memerr;
377 strcpy(lp->key, vkey);
378 }
379 vndx = 0; /* find oldest vertex */
380 for (i = 1; i < NVERTS; i++)
381 if (vert[i].lused < vert[vndx].lused)
382 vndx = i;
383 if (vert[vndx].lused) { /* free old entry first */
384 mkvkey(vkey, vert[vndx].p);
385 lu_delete(&vertab, vkey);
386 }
387 VCOPY(vert[vndx].p, vp); /* assign it */
388 printf("v v%d =\n\tp %.15g %.15g %.15g\n", /* print it */
389 vndx, vp[0], vp[1], vp[2]);
390 lp->data = (char *)&vert[vndx]; /* set it */
391 } else
392 vndx = (struct vert *)lp->data - vert;
393 vert[vndx].lused = vclock; /* record this use */
394 sprintf(vname, "v%d", vndx);
395 return(vname);
396 memerr:
397 fputs("Out of memory in getvertid!\n", stderr);
398 exit(1);
399 }
400
401
402 int
403 o_unsupported(mod, typ, id, fa) /* mark unsupported primitive */
404 char *mod, *typ, *id;
405 FUNARGS *fa;
406 {
407 register int i;
408
409 fputs("\n# Unsupported RADIANCE primitive:\n", stdout);
410 printf("# %s %s %s", mod, typ, id);
411 printf("\n# %d", fa->nsargs);
412 for (i = 0; i < fa->nsargs; i++)
413 printf(" %s", fa->sarg[i]);
414 #ifdef IARGS
415 printf("\n# %d", fa->niargs);
416 for (i = 0; i < fa->niargs; i++)
417 printf(" %ld", fa->iarg[i]);
418 #else
419 fputs("\n# 0", stdout);
420 #endif
421 printf("\n# %d", fa->nfargs);
422 for (i = 0; i < fa->nfargs; i++)
423 printf(" %g", fa->farg[i]);
424 fputs("\n\n", stdout);
425 return(0);
426 }
427
428
429 int
430 o_face(mod, typ, id, fa) /* print out a polygon */
431 char *mod, *typ, *id;
432 FUNARGS *fa;
433 {
434 char entbuf[512];
435 register char *cp;
436 register int i;
437
438 if (fa->nfargs < 9 | fa->nfargs % 3)
439 return(-1);
440 setmat(mod);
441 setobj(id);
442 cp = entbuf;
443 *cp++ = 'f';
444 for (i = 0; i < fa->nfargs; i += 3) {
445 *cp++ = ' ';
446 getvertid(cp, fa->farg + i);
447 while (*cp)
448 cp++;
449 }
450 puts(entbuf);
451 return(0);
452 }
453
454
455 int
456 o_cone(mod, typ, id, fa) /* print out a cone */
457 char *mod, *typ, *id;
458 register FUNARGS *fa;
459 {
460 char v1[6], v2[6];
461
462 if (fa->nfargs != 8)
463 return(-1);
464 setmat(mod);
465 setobj(id);
466 getvertid(v1, fa->farg);
467 getvertid(v2, fa->farg + 3);
468 if (typ[1] == 'u') /* cup -> inverted cone */
469 printf("cone %s %.12g %s %.12g\n",
470 v1, -fa->farg[6], v2, -fa->farg[7]);
471 else
472 printf("cone %s %.12g %s %.12g\n",
473 v1, fa->farg[6], v2, fa->farg[7]);
474 return(0);
475 }
476
477
478 int
479 o_sphere(mod, typ, id, fa) /* print out a sphere */
480 char *mod, *typ, *id;
481 register FUNARGS *fa;
482 {
483 char cent[6];
484
485 if (fa->nfargs != 4)
486 return(-1);
487 setmat(mod);
488 setobj(id);
489 printf("sph %s %.12g\n", getvertid(cent, fa->farg),
490 typ[0]=='b' ? -fa->farg[3] : fa->farg[3]);
491 return(0);
492 }
493
494
495 int
496 o_cylinder(mod, typ, id, fa) /* print out a cylinder */
497 char *mod, *typ, *id;
498 register FUNARGS *fa;
499 {
500 char v1[6], v2[6];
501
502 if (fa->nfargs != 7)
503 return(-1);
504 setmat(mod);
505 setobj(id);
506 getvertid(v1, fa->farg);
507 getvertid(v2, fa->farg + 3);
508 printf("cyl %s %.12g %s\n", v1,
509 typ[0]=='t' ? -fa->farg[6] : fa->farg[6], v2);
510 return(0);
511 }
512
513
514 int
515 o_ring(mod, typ, id, fa) /* print out a ring */
516 char *mod, *typ, *id;
517 register FUNARGS *fa;
518 {
519 if (fa->nfargs != 8)
520 return(-1);
521 setmat(mod);
522 setobj(id);
523 printf("v cent =\n\tp %.12g %.12g %.12g\n",
524 fa->farg[0], fa->farg[1], fa->farg[2]);
525 printf("\tn %.12g %.12g %.12g\n",
526 fa->farg[3], fa->farg[4], fa->farg[5]);
527 if (fa->farg[6] < fa->farg[7])
528 printf("ring cent %.12g %.12g\n",
529 fa->farg[6], fa->farg[7]);
530 else
531 printf("ring cent %.12g %.12g\n",
532 fa->farg[7], fa->farg[6]);
533 return(0);
534 }
535
536
537 int
538 o_instance(mod, typ, id, fa) /* convert an instance */
539 char *mod, *typ, *id;
540 FUNARGS *fa;
541 {
542 register int i;
543 register char *cp;
544 char *start = NULL, *end = NULL;
545 /*
546 * We don't really know how to do this, so we just create
547 * a reference to an undefined MGF file and it's the user's
548 * responsibility to create this file and put the appropriate
549 * stuff into it.
550 */
551 if (fa->nsargs < 1)
552 return(-1);
553 setmat(mod); /* only works if surfaces are void */
554 setobj(id);
555 for (cp = fa->sarg[0]; *cp; cp++) /* construct MGF file name */
556 if (*cp == '/')
557 start = cp+1;
558 else if (*cp == '.')
559 end = cp;
560 if (start == NULL)
561 start = fa->sarg[0];
562 if (end == NULL || start >= end)
563 end = cp;
564 fputs("i ", stdout); /* print include entity */
565 for (cp = start; cp < end; cp++)
566 putchar(*cp);
567 fputs(".mgf", stdout); /* add MGF suffix */
568 for (i = 1; i < fa->nsargs; i++) { /* add transform */
569 putchar(' ');
570 fputs(fa->sarg[i], stdout);
571 }
572 putchar('\n');
573 clrverts(); /* vertex id's no longer reliable */
574 return(0);
575 }
576
577
578 int
579 o_illum(mod, typ, id, fa) /* convert an illum material */
580 char *mod, *typ, *id;
581 FUNARGS *fa;
582 {
583 if (fa->nsargs == 1 && strcmp(fa->sarg[0], VOIDID)) {
584 newmat(id, fa->sarg[0]); /* just create alias */
585 return(0);
586 }
587 /* else create invisible material */
588 newmat(id, NULL);
589 puts("\tts 1 0");
590 return(0);
591 }
592
593
594 int
595 o_plastic(mod, typ, id, fa) /* convert a plastic material */
596 char *mod, *typ, *id;
597 register FUNARGS *fa;
598 {
599 COLOR cxyz, rrgb;
600 double d;
601
602 if (fa->nfargs != (typ[7]=='2' ? 6 : 5))
603 return(-1);
604 newmat(id, NULL);
605 rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2];
606 rgb_cie(cxyz, rrgb);
607 puts("\tc"); /* put diffuse component */
608 d = cxyz[0] + cxyz[1] + cxyz[2];
609 if (d > FTINY)
610 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
611 printf("\trd %.4f\n", cxyz[1]*(1. - fa->farg[3]));
612 if (fa->farg[3] > FTINY) { /* put specular component */
613 puts("\tc");
614 printf("\trs %.4f %.4f\n", fa->farg[3],
615 typ[7]=='2' ? .5*(fa->farg[4] + fa->farg[5]) :
616 fa->farg[4]);
617 }
618 return(0);
619 }
620
621
622 int
623 o_metal(mod, typ, id, fa) /* convert a metal material */
624 char *mod, *typ, *id;
625 register FUNARGS *fa;
626 {
627 COLOR cxyz, rrgb;
628 double d;
629
630 if (fa->nfargs != (typ[5]=='2' ? 6 : 5))
631 return(-1);
632 newmat(id, NULL);
633 rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2];
634 rgb_cie(cxyz, rrgb);
635 puts("\tc"); /* put diffuse component */
636 d = cxyz[0] + cxyz[1] + cxyz[2];
637 if (d > FTINY)
638 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
639 printf("\trd %.4f\n", cxyz[1]*(1. - fa->farg[3]));
640 /* put specular component */
641 printf("\trs %.4f %.4f\n", cxyz[1]*fa->farg[3],
642 typ[5]=='2' ? .5*(fa->farg[4] + fa->farg[5]) :
643 fa->farg[4]);
644 return(0);
645 }
646
647
648 int
649 o_glass(mod, typ, id, fa) /* convert a glass material */
650 char *mod, *typ, *id;
651 register FUNARGS *fa;
652 {
653 COLOR cxyz, rrgb, trgb;
654 double nrfr = 1.52, F, d;
655 register int i;
656
657 if (fa->nfargs != 3 && fa->nfargs != 4)
658 return(-1);
659 newmat(id, NULL);
660 if (fa->nfargs == 4)
661 nrfr = fa->farg[3];
662 printf("\tir %f 0\n", nrfr);
663 F = (1. - nrfr)/(1. + nrfr); /* use normal incidence */
664 F *= F;
665 for (i = 0; i < 3; i++) {
666 trgb[i] = fa->farg[i] * (1. - F)*(1. - F) /
667 (1. - F*F*fa->farg[i]*fa->farg[i]);
668 rrgb[i] = F * (1. + (1. - 2.*F)*fa->farg[i]) /
669 (1. - F*F*fa->farg[i]*fa->farg[i]);
670 }
671 rgb_cie(cxyz, rrgb); /* put reflected component */
672 puts("\tc");
673 d = cxyz[0] + cxyz[1] + cxyz[2];
674 if (d > FTINY)
675 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
676 printf("\trs %.4f 0\n", cxyz[1]);
677 rgb_cie(cxyz, trgb); /* put transmitted component */
678 puts("\tc");
679 d = cxyz[0] + cxyz[1] + cxyz[2];
680 if (d > FTINY)
681 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
682 printf("\tts %.4f 0\n", cxyz[1]);
683 return(0);
684 }
685
686
687 int
688 o_dielectric(mod, typ, id, fa) /* convert a dielectric material */
689 char *mod, *typ, *id;
690 register FUNARGS *fa;
691 {
692 COLOR cxyz, trgb;
693 double F, d;
694 register int i;
695
696 if (fa->nfargs != 5)
697 return(-1);
698 newmat(id, NULL);
699 F = (1. - fa->farg[3])/(1. + fa->farg[3]); /* normal incidence */
700 F *= F;
701 for (i = 0; i < 3; i++)
702 trgb[i] = (1. - F)*pow(fa->farg[i], C_1SIDEDTHICK/unit_mult);
703 printf("\tir %f 0\n", fa->farg[3]); /* put index of refraction */
704 printf("\tsides 1\n");
705 puts("\tc"); /* put reflected component */
706 printf("\trs %.4f 0\n", F);
707 rgb_cie(cxyz, trgb); /* put transmitted component */
708 puts("\tc");
709 d = cxyz[0] + cxyz[1] + cxyz[2];
710 if (d > FTINY)
711 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
712 printf("\tts %.4f 0\n", cxyz[1]);
713 return(0);
714 }
715
716
717 int
718 o_mirror(mod, typ, id, fa) /* convert a mirror material */
719 char *mod, *typ, *id;
720 register FUNARGS *fa;
721 {
722 COLOR cxyz, rrgb;
723 double d;
724
725 if (fa->nsargs == 1) { /* use alternate material */
726 newmat(id, fa->sarg[0]);
727 return(0);
728 }
729 if (fa->nfargs != 3)
730 return(-1);
731 newmat(id, NULL);
732 rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2];
733 rgb_cie(cxyz, rrgb);
734 puts("\tc"); /* put specular component */
735 d = cxyz[0] + cxyz[1] + cxyz[2];
736 if (d > FTINY)
737 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
738 printf("\trs %.4f 0\n", cxyz[1]);
739 return(0);
740 }
741
742
743 int
744 o_trans(mod, typ, id, fa) /* convert a trans material */
745 char *mod, *typ, *id;
746 register FUNARGS *fa;
747 {
748 COLOR cxyz, rrgb;
749 double rough, trans, tspec, d;
750
751 if (typ[4] == '2') { /* trans2 */
752 if (fa->nfargs != 8)
753 return(-1);
754 rough = .5*(fa->farg[4] + fa->farg[5]);
755 trans = fa->farg[6];
756 tspec = fa->farg[7];
757 } else { /* trans */
758 if (fa->nfargs != 7)
759 return(-1);
760 rough = fa->farg[4];
761 trans = fa->farg[5];
762 tspec = fa->farg[6];
763 }
764 newmat(id, NULL);
765 rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2];
766 rgb_cie(cxyz, rrgb);
767 puts("\tc"); /* put transmitted diffuse */
768 d = cxyz[0] + cxyz[1] + cxyz[2];
769 if (d > FTINY)
770 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
771 printf("\ttd %.4f\n", cxyz[1]*trans*(1. - fa->farg[3])*(1. - tspec));
772 /* put transmitted specular */
773 printf("\tts %.4f %.4f\n", cxyz[1]*trans*tspec*(1. - fa->farg[3]), rough);
774 /* put reflected diffuse */
775 printf("\trd %.4f\n", cxyz[1]*(1. - fa->farg[3])*(1. - trans));
776 puts("\tc"); /* put reflected specular */
777 printf("\trs %.4f %.4f\n", fa->farg[3], rough);
778 return(0);
779 }
780
781
782 int
783 o_light(mod, typ, id, fa) /* convert a light type */
784 char *mod, *typ, *id;
785 register FUNARGS *fa;
786 {
787 COLOR cxyz, rrgb;
788 double d;
789
790 if (fa->nfargs < 3)
791 return(-1);
792 newmat(id, NULL);
793 rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2];
794 rgb_cie(cxyz, rrgb);
795 d = cxyz[0] + cxyz[1] + cxyz[2];
796 puts("\tc");
797 if (d > FTINY)
798 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
799 printf("\ted %.4g\n", cxyz[1]*(PI*WHTEFFICACY));
800 return(0);
801 }
