root/radiance/ray/src/cv/rad2mgf.c
Revision: 2.25
Committed: Wed Dec 28 18:39:07 2005 UTC (19 years, 7 months ago) by greg
CVS Tags: rad4R0, rad3R8, rad3R9
Changes since 2.24: +2 -1 lines
Compile fix in last change -- oops
2 static const char RCSid[] = "$Id: rad2mgf.c,v 2.24 2005/12/28 18:35:42 greg Exp $";
5 * Convert Radiance scene description to MGF
6 */
7
8 #include <ctype.h>
9 #include <string.h>
10 #include <stdio.h>
11
12 #include "platform.h"
13 #include "rtmath.h"
14 #include "rtio.h"
15 #include "rtprocess.h"
16 #include "object.h"
17 #include "color.h"
18 #include "lookup.h"
19
20 #define C_1SIDEDTHICK 0.005
21
22
23 LUTAB rmats = LU_SINIT(free,NULL); /* defined material table */
24
25 LUTAB rdispatch = LU_SINIT(NULL,NULL); /* function dispatch table */
26
27 char curmat[80]; /* current material */
28 char curobj[128] = "Untitled"; /* current object name */
29
30 double unit_mult = 1.; /* units multiplier */
31
32 #define hasmult (unit_mult < .999 || unit_mult > 1.001)
33
34 /*
35 * Stuff for tracking and reusing vertices:
36 */
37
38 char VKFMT[] = "%+16.9e %+16.9e %+16.9e";
39 #define VKLEN 64
40
41 #define mkvkey(k,v) sprintf(k, VKFMT, (v)[0], (v)[1], (v)[2])
42
43 #define NVERTS 256
44
45 long vclock; /* incremented at each vertex request */
46
47 struct vert {
48 long lused; /* when last used (0 if unassigned) */
49 FVECT p; /* track point position only */
50 } vert[NVERTS]; /* our vertex cache */
51
52 LUTAB vertab = LU_SINIT(free,NULL); /* our vertex lookup table */
53
54 void rad2mgf(char *inp);
55 void cvtprim(char *inp, char *mod, char *typ, char *id, FUNARGS *fa);
56 void newmat(char *id, char *alias);
57 void setmat(char *id);
58 void setobj(char *id);
59 void init(void);
60 void uninit(void);
61 void clrverts(void);
62 void unspace(char *s);
63 void add2dispatch(char *name, int (*func)());
64 char *getvertid(char *vname, FVECT vp);
65 int o_unsupported(char *mod, char *typ, char *id, FUNARGS *fa);
66 int o_face(char *mod, char *typ, char *id, FUNARGS *fa);
67 int o_cone(char *mod, char *typ, char *id, FUNARGS *fa);
68 int o_sphere(char *mod, char *typ, char *id, FUNARGS *fa);
69 int o_cylinder(char *mod, char *typ, char *id, FUNARGS *fa);
70 int o_ring(char *mod, char *typ, char *id, FUNARGS *fa);
71 int o_instance(char *mod, char *typ, char *id, FUNARGS *fa);
72 int o_illum(char *mod, char *typ, char *id, FUNARGS *fa);
73 int o_plastic(char *mod, char *typ, char *id, FUNARGS *fa);
74 int o_metal(char *mod, char *typ, char *id, FUNARGS *fa);
75 int o_glass(char *mod, char *typ, char *id, FUNARGS *fa);
76 int o_dielectric(char *mod, char *typ, char *id, FUNARGS *fa);
77 int o_mirror(char *mod, char *typ, char *id, FUNARGS *fa);
78 int o_trans(char *mod, char *typ, char *id, FUNARGS *fa);
79 int o_light(char *mod, char *typ, char *id, FUNARGS *fa);
80
81
82 int
83 main(
84 int argc,
85 char **argv
86 )
87 {
88 int i;
89
90 for (i = 1; i < argc && argv[i][0] == '-'; i++)
91 switch (argv[i][1]) {
92 case 'd': /* units */
93 switch (argv[i][2]) {
94 case 'm': /* meters */
95 unit_mult = 1.;
96 break;
97 case 'c': /* centimeters */
98 unit_mult = .01;
99 break;
100 case 'f': /* feet */
101 unit_mult = 12.*.0254;
102 break;
103 case 'i': /* inches */
104 unit_mult = .0254;
105 break;
106 default:
107 goto unkopt;
108 }
109 break;
110 default:
111 goto unkopt;
112 }
113 init();
114 if (i >= argc)
115 rad2mgf(NULL);
116 else
117 for ( ; i < argc; i++)
118 rad2mgf(argv[i]);
119 uninit();
120 exit(0);
121 unkopt:
122 fprintf(stderr, "Usage: %s [-d{m|c|f|i}] file ..\n", argv[0]);
123 exit(1);
124 }
125
126
127 void
128 rad2mgf( /* convert a Radiance file to MGF */
129 char *inp
130 )
131 {
132 char buf[512];
133 char mod[128], typ[32], id[128], alias[128];
134 FUNARGS fa;
135 register FILE *fp;
136 register int c;
137
138 if (inp == NULL) {
139 inp = "standard input";
140 fp = stdin;
141 } else if (inp[0] == '!') {
142 if ((fp = popen(inp+1, "r")) == NULL) {
143 fputs(inp, stderr);
144 fputs(": cannot execute\n", stderr);
145 exit(1);
146 }
147 } else if ((fp = fopen(inp, "r")) == NULL) {
148 fputs(inp, stderr);
149 fputs(": cannot open\n", stderr);
150 exit(1);
151 }
152 printf("# Begin conversion from: %s\n", inp);
153 while ((c = getc(fp)) != EOF)
154 switch (c) {
155 case ' ': /* white space */
156 case '\t':
157 case '\n':
158 case '\r':
159 case '\f':
160 break;
161 case '#': /* comment */
162 if (fgets(buf, sizeof(buf), fp) != NULL)
163 printf("# %s", buf);
164 break;
165 case '!': /* inline command */
166 ungetc(c, fp);
167 fgetline(buf, sizeof(buf), fp);
168 rad2mgf(buf);
169 break;
170 default: /* Radiance primitive */
171 ungetc(c, fp);
172 if (fgetword(mod, sizeof(mod), fp) == NULL ||
173 fgetword(typ, sizeof(typ), fp) == NULL ||
174 fgetword(id, sizeof(id), fp) == NULL) {
175 fputs(inp, stderr);
176 fputs(": unexpected EOF\n", stderr);
177 exit(1);
178 }
179 unspace(mod);
180 unspace(id);
181 if (!strcmp(typ, "alias")) {
182 strcpy(alias, "EOF");
183 fgetword(alias, sizeof(alias), fp);
184 unspace(alias);
185 newmat(id, alias);
186 } else {
187 if (!readfargs(&fa, fp)) {
188 fprintf(stderr,
189 "%s: bad argument syntax for %s \"%s\"\n",
190 inp, typ, id);
191 exit(1);
192 }
193 cvtprim(inp, mod, typ, id, &fa);
194 freefargs(&fa);
195 }
196 break;
197 }
198 printf("# End conversion from: %s\n", inp);
199 if (inp[0] == '!')
200 pclose(fp);
201 else
202 fclose(fp);
203 }
204
205
206 void
207 unspace( /* replace spaces with underscores in s */
208 char *s
209 )
210 {
211 while (*s) {
212 if (isspace(*s))
213 *s = '_';
214 ++s;
215 }
216 }
217
218
219 void
220 cvtprim( /* process Radiance primitive */
221 char *inp,
222 char *mod,
223 char *typ,
224 char *id,
225 FUNARGS *fa
226 )
227 {
228 int (*df)();
229
230 df = (int (*)())lu_find(&rdispatch, typ)->data;
231 if (df != NULL) { /* convert */
232 if ((*df)(mod, typ, id, fa) < 0) {
233 fprintf(stderr, "%s: bad %s \"%s\"\n", "rad2mgf", typ, id);
234 exit(1);
235 }
236 } else { /* unsupported */
237 o_unsupported(mod, typ, id, fa);
238 if (lu_find(&rmats, mod)->data != NULL) /* make alias */
239 newmat(id, mod);
240 }
241 }
242
243
244 void
245 newmat( /* add a modifier to the alias list */
246 char *id,
247 char *alias
248 )
249 {
250 register LUENT *lp, *lpa;
251
252 if (alias != NULL) { /* look up alias */
253 if ((lpa = lu_find(&rmats, alias)) == NULL)
254 goto memerr;
255 if (lpa->data == NULL)
256 alias = NULL; /* doesn't exist! */
257 }
258 if ((lp = lu_find(&rmats, id)) == NULL) /* look up material */
259 goto memerr;
260 if (alias != NULL && lp->data == lpa->key)
261 return; /* alias set already */
262 if (lp->data == NULL) { /* allocate material */
263 if ((lp->key = (char *)malloc(strlen(id)+1)) == NULL)
264 goto memerr;
265 strcpy(lp->key, id);
266 }
267 if (alias == NULL) { /* set this material */
268 lp->data = lp->key;
269 printf("m %s =\n", id);
270 } else { /* set this alias */
271 lp->data = lpa->key;
272 printf("m %s = %s\n", id, alias);
273 }
274 strcpy(curmat, id);
275 return;
276 memerr:
277 fputs("Out of memory in newmat!\n", stderr);
278 exit(1);
279 }
280
281
282 void
283 setmat( /* set material to this one */
284 char *id
285 )
286 {
287 if (!strcmp(id, curmat)) /* already set? */
288 return;
289 if (!strcmp(id, VOIDID)) /* cannot set */
290 return;
291 printf("m %s\n", id);
292 strcpy(curmat, id);
293 }
294
295
296 void
297 setobj( /* set object name to this one */
298 char *id
299 )
300 {
301 register char *cp, *cp2;
302 char *end = NULL;
303 int diff = 0;
304 /* use all but final suffix */
305 for (cp = id; *cp; cp++)
306 if (*cp == '.')
307 end = cp;
308 if (end == NULL)
309 end = cp;
310 /* copy to current object */
311 cp2 = curobj;
312 if (!isalpha(*id)) { /* start with letter */
313 diff = *cp2 != 'O';
314 *cp2++ = 'O';
315 }
316 for (cp = id; cp < end; *cp2++ = *cp++) {
317 if ((*cp < '!') | (*cp > '~')) /* limit to visible chars */
318 *cp = '?';
319 diff += *cp != *cp2;
320 }
321 if (!diff && !*cp2)
322 return;
323 *cp2 = '\0';
324 fputs("o\no ", stdout);
325 puts(curobj);
326 }
327
328
329 void
330 init(void) /* initialize dispatch table and output */
331 {
332 lu_init(&vertab, NVERTS);
333 lu_init(&rdispatch, 22);
334 add2dispatch("polygon", o_face);
335 add2dispatch("cone", o_cone);
336 add2dispatch("cup", o_cone);
337 add2dispatch("sphere", o_sphere);
338 add2dispatch("bubble", o_sphere);
339 add2dispatch("cylinder", o_cylinder);
340 add2dispatch("tube", o_cylinder);
341 add2dispatch("ring", o_ring);
342 add2dispatch("instance", o_instance);
343 add2dispatch("mesh", o_instance);
344 add2dispatch("plastic", o_plastic);
345 add2dispatch("plastic2", o_plastic);
346 add2dispatch("metal", o_metal);
347 add2dispatch("metal2", o_metal);
348 add2dispatch("glass", o_glass);
349 add2dispatch("dielectric", o_dielectric);
350 add2dispatch("trans", o_trans);
351 add2dispatch("trans2", o_trans);
352 add2dispatch("mirror", o_mirror);
353 add2dispatch("light", o_light);
354 add2dispatch("spotlight", o_light);
355 add2dispatch("glow", o_light);
356 add2dispatch("illum", o_illum);
357 puts("# The following was converted from RADIANCE scene input");
358 if (hasmult)
359 printf("xf -s %.4e\n", unit_mult);
360 printf("o %s\n", curobj);
361 }
362
363
364 void
365 uninit(void) /* mark end of MGF file */
366 {
367 puts("o");
368 if (hasmult)
369 puts("xf");
370 puts("# End of data converted from RADIANCE scene input");
371 lu_done(&rdispatch);
372 lu_done(&rmats);
373 lu_done(&vertab);
374 }
375
376
377 void
378 clrverts(void) /* clear vertex table */
379 {
380 register int i;
381
382 lu_done(&vertab);
383 for (i = 0; i < NVERTS; i++)
384 vert[i].lused = 0;
385 lu_init(&vertab, NVERTS);
386 }
387
388
389 void
390 add2dispatch( /* add function to dispatch table */
391 char *name,
392 int (*func)()
393 )
394 {
395 register LUENT *lp;
396
397 lp = lu_find(&rdispatch, name);
398 if (lp->key != NULL) {
399 fputs(name, stderr);
400 fputs(": duplicate dispatch entry!\n", stderr);
401 exit(1);
402 }
403 lp->key = name;
404 lp->data = (char *)func;
405 }
406
407
408 char *
409 getvertid( /* get/set vertex ID for this point */
410 char *vname,
411 FVECT vp
412 )
413 {
414 static char vkey[VKLEN];
415 register LUENT *lp;
416 register int i, vndx;
417
418 vclock++; /* increment counter */
419 mkvkey(vkey, vp);
420 if ((lp = lu_find(&vertab, vkey)) == NULL)
421 goto memerr;
422 if (lp->data == NULL) { /* allocate new vertex entry */
423 if (lp->key != NULL) /* reclaim deleted entry */
424 vertab.ndel--;
425 else {
426 if ((lp->key = (char *)malloc(VKLEN)) == NULL)
427 goto memerr;
428 strcpy(lp->key, vkey);
429 }
430 vndx = 0; /* find oldest vertex */
431 for (i = 1; i < NVERTS; i++)
432 if (vert[i].lused < vert[vndx].lused)
433 vndx = i;
434 if (vert[vndx].lused) { /* free old entry first */
435 mkvkey(vkey, vert[vndx].p);
436 lu_delete(&vertab, vkey);
437 }
438 VCOPY(vert[vndx].p, vp); /* assign it */
439 printf("v v%d =\n\tp %.15g %.15g %.15g\n", /* print it */
440 vndx, vp[0], vp[1], vp[2]);
441 lp->data = (char *)&vert[vndx]; /* set it */
442 } else
443 vndx = (struct vert *)lp->data - vert;
444 vert[vndx].lused = vclock; /* record this use */
445 sprintf(vname, "v%d", vndx);
446 return(vname);
447 memerr:
448 fputs("Out of memory in getvertid!\n", stderr);
449 exit(1);
450 }
451
452
453 int
454 o_unsupported( /* mark unsupported primitive */
455 char *mod,
456 char *typ,
457 char *id,
458 FUNARGS *fa
459 )
460 {
461 register int i;
462
463 fputs("\n# Unsupported RADIANCE primitive:\n", stdout);
464 printf("# %s %s %s", mod, typ, id);
465 printf("\n# %d", fa->nsargs);
466 for (i = 0; i < fa->nsargs; i++)
467 printf(" %s", fa->sarg[i]);
468 #ifdef IARGS
469 printf("\n# %d", fa->niargs);
470 for (i = 0; i < fa->niargs; i++)
471 printf(" %ld", fa->iarg[i]);
472 #else
473 fputs("\n# 0", stdout);
474 #endif
475 printf("\n# %d", fa->nfargs);
476 for (i = 0; i < fa->nfargs; i++)
477 printf(" %g", fa->farg[i]);
478 fputs("\n\n", stdout);
479 return(0);
480 }
481
482
483 int
484 o_face( /* print out a polygon */
485 char *mod,
486 char *typ,
487 char *id,
488 FUNARGS *fa
489 )
490 {
491 char entbuf[2048], *linestart;
492 register char *cp;
493 register int i;
494
495 if ((fa->nfargs < 9) | (fa->nfargs % 3))
496 return(-1);
497 setmat(mod);
498 setobj(id);
499 cp = linestart = entbuf;
500 *cp++ = 'f';
501 for (i = 0; i < fa->nfargs; i += 3) {
502 *cp++ = ' ';
503 if (cp - linestart > 72) {
504 *cp++ = '\\'; *cp++ = '\n';
505 linestart = cp;
506 *cp++ = ' '; *cp++ = ' ';
507 }
508 getvertid(cp, fa->farg + i);
509 while (*cp)
510 cp++;
511 }
512 puts(entbuf);
513 return(0);
514 }
515
516
517 int
518 o_cone( /* print out a cone */
519 char *mod,
520 char *typ,
521 char *id,
522 register FUNARGS *fa
523 )
524 {
525 char v1[6], v2[6];
526
527 if (fa->nfargs != 8)
528 return(-1);
529 setmat(mod);
530 setobj(id);
531 getvertid(v1, fa->farg);
532 getvertid(v2, fa->farg + 3);
533 if (typ[1] == 'u') /* cup -> inverted cone */
534 printf("cone %s %.12g %s %.12g\n",
535 v1, -fa->farg[6], v2, -fa->farg[7]);
536 else
537 printf("cone %s %.12g %s %.12g\n",
538 v1, fa->farg[6], v2, fa->farg[7]);
539 return(0);
540 }
541
542
543 int
544 o_sphere( /* print out a sphere */
545 char *mod,
546 char *typ,
547 char *id,
548 register FUNARGS *fa
549 )
550 {
551 char cent[6];
552
553 if (fa->nfargs != 4)
554 return(-1);
555 setmat(mod);
556 setobj(id);
557 printf("sph %s %.12g\n", getvertid(cent, fa->farg),
558 typ[0]=='b' ? -fa->farg[3] : fa->farg[3]);
559 return(0);
560 }
561
562
563 int
564 o_cylinder( /* print out a cylinder */
565 char *mod,
566 char *typ,
567 char *id,
568 register FUNARGS *fa
569 )
570 {
571 char v1[6], v2[6];
572
573 if (fa->nfargs != 7)
574 return(-1);
575 setmat(mod);
576 setobj(id);
577 getvertid(v1, fa->farg);
578 getvertid(v2, fa->farg + 3);
579 printf("cyl %s %.12g %s\n", v1,
580 typ[0]=='t' ? -fa->farg[6] : fa->farg[6], v2);
581 return(0);
582 }
583
584
585 int
586 o_ring( /* print out a ring */
587 char *mod,
588 char *typ,
589 char *id,
590 register FUNARGS *fa
591 )
592 {
593 if (fa->nfargs != 8)
594 return(-1);
595 setmat(mod);
596 setobj(id);
597 printf("v cent =\n\tp %.12g %.12g %.12g\n",
598 fa->farg[0], fa->farg[1], fa->farg[2]);
599 printf("\tn %.12g %.12g %.12g\n",
600 fa->farg[3], fa->farg[4], fa->farg[5]);
601 if (fa->farg[6] < fa->farg[7])
602 printf("ring cent %.12g %.12g\n",
603 fa->farg[6], fa->farg[7]);
604 else
605 printf("ring cent %.12g %.12g\n",
606 fa->farg[7], fa->farg[6]);
607 return(0);
608 }
609
610
611 int
612 o_instance( /* convert an instance (or mesh) */
613 char *mod,
614 char *typ,
615 char *id,
616 FUNARGS *fa
617 )
618 {
619 register int i;
620 register char *cp;
621 char *start = NULL, *end = NULL;
622 /*
623 * We don't really know how to do this, so we just create
624 * a reference to an undefined MGF file and it's the user's
625 * responsibility to create this file and put the appropriate
626 * stuff into it.
627 */
628 if (fa->nsargs < 1)
629 return(-1);
630 setmat(mod); /* only works if surfaces are void */
631 setobj(id);
632 for (cp = fa->sarg[0]; *cp; cp++) /* construct MGF file name */
633 if (*cp == '/')
634 start = cp+1;
635 else if (*cp == '.')
636 end = cp;
637 if (start == NULL)
638 start = fa->sarg[0];
639 if (end == NULL || start >= end)
640 end = cp;
641 fputs("i ", stdout); /* print include entity */
642 for (cp = start; cp < end; cp++)
643 putchar(*cp);
644 fputs(".mgf", stdout); /* add MGF suffix */
645 for (i = 1; i < fa->nsargs; i++) { /* add transform */
646 putchar(' ');
647 fputs(fa->sarg[i], stdout);
648 }
649 putchar('\n');
650 clrverts(); /* vertex id's no longer reliable */
651 return(0);
652 }
653
654
655 int
656 o_illum( /* convert an illum material */
657 char *mod,
658 char *typ,
659 char *id,
660 FUNARGS *fa
661 )
662 {
663 if (fa->nsargs == 1 && strcmp(fa->sarg[0], VOIDID)) {
664 newmat(id, fa->sarg[0]); /* just create alias */
665 return(0);
666 }
667 /* else create invisible material */
668 newmat(id, NULL);
669 puts("\tts 1 0");
670 return(0);
671 }
672
673
674 int
675 o_plastic( /* convert a plastic material */
676 char *mod,
677 char *typ,
678 char *id,
679 register FUNARGS *fa
680 )
681 {
682 COLOR cxyz, rrgb;
683 double d;
684
685 if (fa->nfargs != (typ[7]=='2' ? 6 : 5))
686 return(-1);
687 newmat(id, NULL);
688 rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2];
689 rgb_cie(cxyz, rrgb);
690 puts("\tc"); /* put diffuse component */
691 d = cxyz[0] + cxyz[1] + cxyz[2];
692 if (d > FTINY)
693 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
694 printf("\trd %.4f\n", cxyz[1]*(1. - fa->farg[3]));
695 if (fa->farg[3] > FTINY) { /* put specular component */
696 puts("\tc");
697 printf("\trs %.4f %.4f\n", fa->farg[3],
698 typ[7]=='2' ? .5*(fa->farg[4] + fa->farg[5]) :
699 fa->farg[4]);
700 }
701 return(0);
702 }
703
704
705 int
706 o_metal( /* convert a metal material */
707 char *mod,
708 char *typ,
709 char *id,
710 register FUNARGS *fa
711 )
712 {
713 COLOR cxyz, rrgb;
714 double d;
715
716 if (fa->nfargs != (typ[5]=='2' ? 6 : 5))
717 return(-1);
718 newmat(id, NULL);
719 rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2];
720 rgb_cie(cxyz, rrgb);
721 puts("\tc"); /* put diffuse component */
722 d = cxyz[0] + cxyz[1] + cxyz[2];
723 if (d > FTINY)
724 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
725 printf("\trd %.4f\n", cxyz[1]*(1. - fa->farg[3]));
726 /* put specular component */
727 printf("\trs %.4f %.4f\n", cxyz[1]*fa->farg[3],
728 typ[5]=='2' ? .5*(fa->farg[4] + fa->farg[5]) :
729 fa->farg[4]);
730 return(0);
731 }
732
733
734 int
735 o_glass( /* convert a glass material */
736 char *mod,
737 char *typ,
738 char *id,
739 register FUNARGS *fa
740 )
741 {
742 COLOR cxyz, rrgb, trgb;
743 double nrfr = 1.52, F, d;
744 register int i;
745
746 if (fa->nfargs != 3 && fa->nfargs != 4)
747 return(-1);
748 newmat(id, NULL);
749 if (fa->nfargs == 4)
750 nrfr = fa->farg[3];
751 printf("\tir %f 0\n", nrfr);
752 F = (1. - nrfr)/(1. + nrfr); /* use normal incidence */
753 F *= F;
754 for (i = 0; i < 3; i++) {
755 trgb[i] = fa->farg[i] * (1. - F)*(1. - F) /
756 (1. - F*F*fa->farg[i]*fa->farg[i]);
757 rrgb[i] = F * (1. + (1. - 2.*F)*fa->farg[i]) /
758 (1. - F*F*fa->farg[i]*fa->farg[i]);
759 }
760 rgb_cie(cxyz, rrgb); /* put reflected component */
761 puts("\tc");
762 d = cxyz[0] + cxyz[1] + cxyz[2];
763 if (d > FTINY)
764 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
765 printf("\trs %.4f 0\n", cxyz[1]);
766 rgb_cie(cxyz, trgb); /* put transmitted component */
767 puts("\tc");
768 d = cxyz[0] + cxyz[1] + cxyz[2];
769 if (d > FTINY)
770 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
771 printf("\tts %.4f 0\n", cxyz[1]);
772 return(0);
773 }
774
775
776 int
777 o_dielectric( /* convert a dielectric material */
778 char *mod,
779 char *typ,
780 char *id,
781 register FUNARGS *fa
782 )
783 {
784 COLOR cxyz, trgb;
785 double F, d;
786 register int i;
787
788 if (fa->nfargs != 5)
789 return(-1);
790 newmat(id, NULL);
791 F = (1. - fa->farg[3])/(1. + fa->farg[3]); /* normal incidence */
792 F *= F;
793 for (i = 0; i < 3; i++)
794 trgb[i] = (1. - F)*pow(fa->farg[i], C_1SIDEDTHICK/unit_mult);
795 printf("\tir %f 0\n", fa->farg[3]); /* put index of refraction */
796 printf("\tsides 1\n");
797 puts("\tc"); /* put reflected component */
798 printf("\trs %.4f 0\n", F);
799 rgb_cie(cxyz, trgb); /* put transmitted component */
800 puts("\tc");
801 d = cxyz[0] + cxyz[1] + cxyz[2];
802 if (d > FTINY)
803 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
804 printf("\tts %.4f 0\n", cxyz[1]);
805 return(0);
806 }
807
808
809 int
810 o_mirror( /* convert a mirror material */
811 char *mod,
812 char *typ,
813 char *id,
814 register FUNARGS *fa
815 )
816 {
817 COLOR cxyz, rrgb;
818 double d;
819
820 if (fa->nsargs == 1) { /* use alternate material */
821 newmat(id, fa->sarg[0]);
822 return(0);
823 }
824 if (fa->nfargs != 3)
825 return(-1);
826 newmat(id, NULL);
827 rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2];
828 rgb_cie(cxyz, rrgb);
829 puts("\tc"); /* put specular component */
830 d = cxyz[0] + cxyz[1] + cxyz[2];
831 if (d > FTINY)
832 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
833 printf("\trs %.4f 0\n", cxyz[1]);
834 return(0);
835 }
836
837
838 int
839 o_trans( /* convert a trans material */
840 char *mod,
841 char *typ,
842 char *id,
843 register FUNARGS *fa
844 )
845 {
846 COLOR cxyz, rrgb;
847 double rough, trans, tspec, d;
848
849 if (typ[4] == '2') { /* trans2 */
850 if (fa->nfargs != 8)
851 return(-1);
852 rough = .5*(fa->farg[4] + fa->farg[5]);
853 trans = fa->farg[6];
854 tspec = fa->farg[7];
855 } else { /* trans */
856 if (fa->nfargs != 7)
857 return(-1);
858 rough = fa->farg[4];
859 trans = fa->farg[5];
860 tspec = fa->farg[6];
861 }
862 newmat(id, NULL);
863 rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2];
864 rgb_cie(cxyz, rrgb);
865 puts("\tc"); /* put transmitted diffuse */
866 d = cxyz[0] + cxyz[1] + cxyz[2];
867 if (d > FTINY)
868 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
869 printf("\ttd %.4f\n", cxyz[1]*trans*(1. - fa->farg[3])*(1. - tspec));
870 /* put transmitted specular */
871 printf("\tts %.4f %.4f\n", cxyz[1]*trans*tspec*(1. - fa->farg[3]), rough);
872 /* put reflected diffuse */
873 printf("\trd %.4f\n", cxyz[1]*(1. - fa->farg[3])*(1. - trans));
874 puts("\tc"); /* put reflected specular */
875 printf("\trs %.4f %.4f\n", fa->farg[3], rough);
876 return(0);
877 }
878
879
880 int
881 o_light( /* convert a light type */
882 char *mod,
883 char *typ,
884 char *id,
885 register FUNARGS *fa
886 )
887 {
888 COLOR cxyz, rrgb;
889 double d;
890
891 if (fa->nfargs < 3)
892 return(-1);
893 newmat(id, NULL);
894 rrgb[0] = fa->farg[0]; rrgb[1] = fa->farg[1]; rrgb[2] = fa->farg[2];
895 rgb_cie(cxyz, rrgb);
896 d = cxyz[0] + cxyz[1] + cxyz[2];
897 puts("\tc");
898 if (d > FTINY)
899 printf("\t\tcxy %.4f %.4f\n", cxyz[0]/d, cxyz[1]/d);
900 printf("\ted %.4g\n", cxyz[1]*(PI*WHTEFFICACY));
901 return(0);
902 }
