root/Development/ray/src/cv/pkgBSDF.c
Revision: 2.10
Committed: Tue Jun 3 21:31:51 2025 UTC (3 months, 3 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.9: +2 -4 lines
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.10 static const char RCSid[] = "$Id: pkgBSDF.c,v 2.9 2024/12/08 18:33:23 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Take BSDF XML file and generate a referencing Radiance object
6     */
7
8 greg 2.2 #include "rtio.h"
9 greg 2.1 #include "paths.h"
10     #include "bsdf.h"
11
12     int do_stdout = 0; /* send Radiance object to stdout? */
13     int do_instance = 0; /* produce instance/octree pairs? */
14
15     /* Return appropriate suffix for Z offset */
16     static const char *
17     get_suffix(double zval)
18     {
19     return((zval > FTINY) ? "_f" : (zval < -FTINY) ? "_b" : "");
20     }
21
22
23     /* Produce a single rectangle corresponding to the given BSDF dimensions */
24     static void
25     faceBSDF(const SDData *bsp, double zval)
26     {
27     const char *sfx = get_suffix(zval);
28     /* output material */
29     printf("void BSDF m_%s%s\n", bsp->name, sfx);
30     printf("6 %g %s.xml 0 1 0 .\n", zval*1.00004, bsp->name);
31     printf("0\n0\n\n");
32     /* output surface */
33     zval *= (zval < 0) + 0.00002;
34     printf("m_%s%s polygon %s%s\n", bsp->name, sfx, bsp->name, sfx);
35     printf("0\n0\n12\n");
36     printf("\t%.6e\t%.6e\t%.6e\n",
37     -.5*bsp->dim[0], -.5*bsp->dim[1], zval);
38     printf("\t%.6e\t%.6e\t%.6e\n",
39     .5*bsp->dim[0], -.5*bsp->dim[1], zval);
40     printf("\t%.6e\t%.6e\t%.6e\n",
41     .5*bsp->dim[0], .5*bsp->dim[1], zval);
42     printf("\t%.6e\t%.6e\t%.6e\n\n",
43     -.5*bsp->dim[0], .5*bsp->dim[1], zval);
44     }
45
46
47     /* Convert BSDF (MGF) geometry to Radiance description */
48     static int
49     geomBSDF(const SDData *bsp)
50     {
51     char tmpfile[64];
52     char command[SDnameLn+64];
53     int fd;
54     /* write MGF to temp file */
55 greg 2.3 fd = open(mktemp(strcpy(tmpfile,TEMPLATE)), O_WRONLY|O_CREAT|O_EXCL, 0600);
56 greg 2.1 if (fd < 0) {
57     fprintf(stderr, "Cannot open temp file '%s'\n", tmpfile);
58     return(0);
59     }
60 greg 2.3 (void)write(fd, bsp->mgf, strlen(bsp->mgf));
61 greg 2.1 close(fd);
62     /* set up command */
63     if (do_instance) {
64 greg 2.9 sprintf(command, "mgf2rad -s %s | oconv -f - > %s.oct",
65 greg 2.1 tmpfile, bsp->name);
66     } else {
67     fflush(stdout);
68 greg 2.9 sprintf(command, "mgf2rad -s %s", tmpfile);
69 greg 2.1 }
70     if (system(command)) {
71     fprintf(stderr, "Error running: %s\n", command);
72     return(0);
73     }
74     unlink(tmpfile); /* remove temp file */
75     if (do_instance) { /* need to output instance? */
76     printf("void instance %s_g\n", bsp->name);
77     printf("1 %s.oct\n0\n0\n\n", bsp->name);
78     }
79     return(1);
80     }
81
82
83     /* Load a BSDF XML file and produce a corresponding Radiance object */
84     static int
85 greg 2.2 cvtBSDF(char *fname)
86 greg 2.1 {
87     int retOK;
88     SDData myBSDF;
89 greg 2.6 char *pname, *fnbeg;
90 greg 2.2 /* find and load the XML file */
91 greg 2.1 retOK = strlen(fname);
92 greg 2.7 if (retOK < 5 || strcasecmp(fname+retOK-4, ".xml")) {
93 greg 2.1 fprintf(stderr, "%s: input does not end in '.xml'\n", fname);
94     return(0);
95     }
96 greg 2.2 pname = getpath(fname, getrlibpath(), R_OK);
97     if (pname == NULL) {
98     fprintf(stderr, "%s: cannot find BSDF file\n", fname);
99     return(0);
100     }
101 greg 2.6 fnbeg = strrchr(fname, DIRSEP);
102     if (fnbeg != NULL) /* eliminate directory */
103     fname = fnbeg+1;
104 greg 2.1 SDclearBSDF(&myBSDF, fname);
105 greg 2.5 if (SDreportError(SDloadFile(&myBSDF, pname), stderr))
106 greg 2.1 return(0);
107     retOK = (myBSDF.dim[0] > FTINY) & (myBSDF.dim[1] > FTINY);
108     if (!retOK) {
109     fprintf(stderr, "%s: zero width or height\n", fname);
110     } else {
111     if (!do_stdout) {
112     char rname[SDnameLn+4];
113     strcpy(rname, myBSDF.name);
114     strcat(rname, ".rad");
115     retOK = (freopen(rname, "w", stdout) != NULL);
116     }
117     if (retOK) {
118 greg 2.8 printf("# Produced by: %s %s\n", progname, fname);
119 greg 2.4 if (myBSDF.matn[0] && myBSDF.makr[0])
120     printf("# Material '%s' by '%s'\n\n",
121     myBSDF.matn, myBSDF.makr);
122 greg 2.1 if (myBSDF.mgf == NULL) {
123     faceBSDF(&myBSDF, .0);
124     } else {
125     faceBSDF(&myBSDF, myBSDF.dim[2]);
126     if (myBSDF.rb != NULL)
127     faceBSDF(&myBSDF, -myBSDF.dim[2]);
128     retOK = geomBSDF(&myBSDF);
129     }
130     }
131     }
132     SDfreeBSDF(&myBSDF); /* clean up and return */
133     return(retOK);
134     }
135
136
137     /* Generate BSDF-referencing Radiance scenes, one per XML input */
138     int
139     main(int argc, char *argv[])
140     {
141     int status = 0;
142     int i;
143
144 greg 2.10 fixargv0(argv[0]); /* sets global progname */
145 greg 2.8
146 greg 2.1 for (i = 1; i < argc && argv[i][0] == '-'; i++)
147     switch (argv[i][1]) {
148     case 'i':
149     do_instance = 1;
150     break;
151     case 's':
152     do_stdout = 1;
153     break;
154     default:
155     goto userr;
156     }
157     if (i >= argc) {
158     fprintf(stderr, "%s: missing XML input\n", argv[0]);
159     goto userr;
160     }
161     if (i < argc-1 && do_stdout) {
162     fprintf(stderr, "%s: cannot send multiple BSDFs to stdout\n",
163     argv[0]);
164     return(1);
165     }
166     for ( ; i < argc; i++)
167     if (!cvtBSDF(argv[i])) {
168     fprintf(stderr, "%s: conversion of '%s' failed\n",
169     argv[0], argv[i]);
170     status = 1;
171     }
172     return(status);
173     userr:
174     fprintf(stderr, "Usage: %s [-i][-s] input.xml ..\n", argv[0]);
175     return(1);
176     }
