root/radiance/ray/src/cv/pkgBSDF.c
Revision: 2.7
Committed: Tue Aug 18 15:23:38 2015 UTC (9 years, 9 months ago) by greg
CVS Tags: rad5R2, rad5R0, rad5R1
Allow .XML suffix in caps
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.7 static const char RCSid[] = "$Id: pkgBSDF.c,v 2.6 2013/08/11 00:54:12 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Take BSDF XML file and generate a referencing Radiance object
6     */
7
8 greg 2.2 #include "rtio.h"
9 greg 2.1 #include "paths.h"
10     #include "bsdf.h"
11
12     int do_stdout = 0; /* send Radiance object to stdout? */
13     int do_instance = 0; /* produce instance/octree pairs? */
14
15
16     /* Return appropriate suffix for Z offset */
17     static const char *
18     get_suffix(double zval)
19     {
20     return((zval > FTINY) ? "_f" : (zval < -FTINY) ? "_b" : "");
21     }
22
23
24     /* Produce a single rectangle corresponding to the given BSDF dimensions */
25     static void
26     faceBSDF(const SDData *bsp, double zval)
27     {
28     const char *sfx = get_suffix(zval);
29     /* output material */
30     printf("void BSDF m_%s%s\n", bsp->name, sfx);
31     printf("6 %g %s.xml 0 1 0 .\n", zval*1.00004, bsp->name);
32     printf("0\n0\n\n");
33     /* output surface */
34     zval *= (zval < 0) + 0.00002;
35     printf("m_%s%s polygon %s%s\n", bsp->name, sfx, bsp->name, sfx);
36     printf("0\n0\n12\n");
37     printf("\t%.6e\t%.6e\t%.6e\n",
38     -.5*bsp->dim[0], -.5*bsp->dim[1], zval);
39     printf("\t%.6e\t%.6e\t%.6e\n",
40     .5*bsp->dim[0], -.5*bsp->dim[1], zval);
41     printf("\t%.6e\t%.6e\t%.6e\n",
42     .5*bsp->dim[0], .5*bsp->dim[1], zval);
43     printf("\t%.6e\t%.6e\t%.6e\n\n",
44     -.5*bsp->dim[0], .5*bsp->dim[1], zval);
45     }
46
47
48     /* Convert BSDF (MGF) geometry to Radiance description */
49     static int
50     geomBSDF(const SDData *bsp)
51     {
52     char tmpfile[64];
53     char command[SDnameLn+64];
54     int fd;
55     /* write MGF to temp file */
56 greg 2.3 fd = open(mktemp(strcpy(tmpfile,TEMPLATE)), O_WRONLY|O_CREAT|O_EXCL, 0600);
57 greg 2.1 if (fd < 0) {
58     fprintf(stderr, "Cannot open temp file '%s'\n", tmpfile);
59     return(0);
60     }
61 greg 2.3 (void)write(fd, bsp->mgf, strlen(bsp->mgf));
62 greg 2.1 close(fd);
63     /* set up command */
64     if (do_instance) {
65     sprintf(command, "mgf2rad %s | oconv -f - > %s.oct",
66     tmpfile, bsp->name);
67     } else {
68     fflush(stdout);
69     sprintf(command, "mgf2rad %s", tmpfile);
70     }
71     if (system(command)) {
72     fprintf(stderr, "Error running: %s\n", command);
73     return(0);
74     }
75     unlink(tmpfile); /* remove temp file */
76     if (do_instance) { /* need to output instance? */
77     printf("void instance %s_g\n", bsp->name);
78     printf("1 %s.oct\n0\n0\n\n", bsp->name);
79     }
80     return(1);
81     }
82
83
84     /* Load a BSDF XML file and produce a corresponding Radiance object */
85     static int
86 greg 2.2 cvtBSDF(char *fname)
87 greg 2.1 {
88     int retOK;
89     SDData myBSDF;
90 greg 2.6 char *pname, *fnbeg;
91 greg 2.2 /* find and load the XML file */
92 greg 2.1 retOK = strlen(fname);
93 greg 2.7 if (retOK < 5 || strcasecmp(fname+retOK-4, ".xml")) {
94 greg 2.1 fprintf(stderr, "%s: input does not end in '.xml'\n", fname);
95     return(0);
96     }
97 greg 2.2 pname = getpath(fname, getrlibpath(), R_OK);
98     if (pname == NULL) {
99     fprintf(stderr, "%s: cannot find BSDF file\n", fname);
100     return(0);
101     }
102 greg 2.6 fnbeg = strrchr(fname, DIRSEP);
103     if (fnbeg != NULL) /* eliminate directory */
104     fname = fnbeg+1;
105 greg 2.1 SDclearBSDF(&myBSDF, fname);
106 greg 2.5 if (SDreportError(SDloadFile(&myBSDF, pname), stderr))
107 greg 2.1 return(0);
108     retOK = (myBSDF.dim[0] > FTINY) & (myBSDF.dim[1] > FTINY);
109     if (!retOK) {
110     fprintf(stderr, "%s: zero width or height\n", fname);
111     } else {
112     if (!do_stdout) {
113     char rname[SDnameLn+4];
114     strcpy(rname, myBSDF.name);
115     strcat(rname, ".rad");
116     retOK = (freopen(rname, "w", stdout) != NULL);
117     }
118     if (retOK) {
119 greg 2.4 if (myBSDF.matn[0] && myBSDF.makr[0])
120     printf("# Material '%s' by '%s'\n\n",
121     myBSDF.matn, myBSDF.makr);
122 greg 2.1 if (myBSDF.mgf == NULL) {
123     faceBSDF(&myBSDF, .0);
124     } else {
125     faceBSDF(&myBSDF, myBSDF.dim[2]);
126     if (myBSDF.rb != NULL)
127     faceBSDF(&myBSDF, -myBSDF.dim[2]);
128     retOK = geomBSDF(&myBSDF);
129     }
130     }
131     }
132     SDfreeBSDF(&myBSDF); /* clean up and return */
133     return(retOK);
134     }
135
136
137     /* Generate BSDF-referencing Radiance scenes, one per XML input */
138     int
139     main(int argc, char *argv[])
140     {
141     int status = 0;
142     int i;
143
144     for (i = 1; i < argc && argv[i][0] == '-'; i++)
145     switch (argv[i][1]) {
146     case 'i':
147     do_instance = 1;
148     break;
149     case 's':
150     do_stdout = 1;
151     break;
152     default:
153     goto userr;
154     }
155     if (i >= argc) {
156     fprintf(stderr, "%s: missing XML input\n", argv[0]);
157     goto userr;
158     }
159     if (i < argc-1 && do_stdout) {
160     fprintf(stderr, "%s: cannot send multiple BSDFs to stdout\n",
161     argv[0]);
162     return(1);
163     }
164     for ( ; i < argc; i++)
165     if (!cvtBSDF(argv[i])) {
166     fprintf(stderr, "%s: conversion of '%s' failed\n",
167     argv[0], argv[i]);
168     status = 1;
169     }
170     return(status);
171     userr:
172     fprintf(stderr, "Usage: %s [-i][-s] input.xml ..\n", argv[0]);
173     return(1);
174     }
