| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: pkgBSDF.c,v 2.5 2013/04/21 22:56:14 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Take BSDF XML file and generate a referencing Radiance object
| 6 |
| 7 |
| 8 |
#include "rtio.h"
| 9 |
#include "paths.h"
| 10 |
#include "bsdf.h"
| 11 |
| 12 |
int do_stdout = 0; /* send Radiance object to stdout? */
| 13 |
int do_instance = 0; /* produce instance/octree pairs? */
| 14 |
| 15 |
| 16 |
/* Return appropriate suffix for Z offset */
| 17 |
static const char *
| 18 |
get_suffix(double zval)
| 19 |
| 20 |
return((zval > FTINY) ? "_f" : (zval < -FTINY) ? "_b" : "");
| 21 |
| 22 |
| 23 |
| 24 |
/* Produce a single rectangle corresponding to the given BSDF dimensions */
| 25 |
static void
| 26 |
faceBSDF(const SDData *bsp, double zval)
| 27 |
| 28 |
const char *sfx = get_suffix(zval);
| 29 |
/* output material */
| 30 |
printf("void BSDF m_%s%s\n", bsp->name, sfx);
| 31 |
printf("6 %g %s.xml 0 1 0 .\n", zval*1.00004, bsp->name);
| 32 |
printf("0\n0\n\n");
| 33 |
/* output surface */
| 34 |
zval *= (zval < 0) + 0.00002;
| 35 |
printf("m_%s%s polygon %s%s\n", bsp->name, sfx, bsp->name, sfx);
| 36 |
printf("0\n0\n12\n");
| 37 |
printf("\t%.6e\t%.6e\t%.6e\n",
| 38 |
-.5*bsp->dim[0], -.5*bsp->dim[1], zval);
| 39 |
| 40 |
| 41 |
| 42 |
.5*bsp->dim[0], .5*bsp->dim[1], zval);
| 43 |
printf("\t%.6e\t%.6e\t%.6e\n\n",
| 44 |
-.5*bsp->dim[0], .5*bsp->dim[1], zval);
| 45 |
| 46 |
| 47 |
| 48 |
/* Convert BSDF (MGF) geometry to Radiance description */
| 49 |
static int
| 50 |
geomBSDF(const SDData *bsp)
| 51 |
| 52 |
char tmpfile[64];
| 53 |
char command[SDnameLn+64];
| 54 |
int fd;
| 55 |
/* write MGF to temp file */
| 56 |
fd = open(mktemp(strcpy(tmpfile,TEMPLATE)), O_WRONLY|O_CREAT|O_EXCL, 0600);
| 57 |
if (fd < 0) {
| 58 |
fprintf(stderr, "Cannot open temp file '%s'\n", tmpfile);
| 59 |
return(0);
| 60 |
| 61 |
(void)write(fd, bsp->mgf, strlen(bsp->mgf));
| 62 |
close(fd);
| 63 |
/* set up command */
| 64 |
if (do_instance) {
| 65 |
sprintf(command, "mgf2rad %s | oconv -f - > %s.oct",
| 66 |
tmpfile, bsp->name);
| 67 |
} else {
| 68 |
fflush(stdout);
| 69 |
sprintf(command, "mgf2rad %s", tmpfile);
| 70 |
| 71 |
if (system(command)) {
| 72 |
fprintf(stderr, "Error running: %s\n", command);
| 73 |
return(0);
| 74 |
| 75 |
unlink(tmpfile); /* remove temp file */
| 76 |
if (do_instance) { /* need to output instance? */
| 77 |
printf("void instance %s_g\n", bsp->name);
| 78 |
printf("1 %s.oct\n0\n0\n\n", bsp->name);
| 79 |
| 80 |
return(1);
| 81 |
| 82 |
| 83 |
| 84 |
/* Load a BSDF XML file and produce a corresponding Radiance object */
| 85 |
static int
| 86 |
cvtBSDF(char *fname)
| 87 |
| 88 |
int retOK;
| 89 |
SDData myBSDF;
| 90 |
char *pname, *fnbeg;
| 91 |
/* find and load the XML file */
| 92 |
retOK = strlen(fname);
| 93 |
if (retOK < 5 || strcmp(fname+retOK-4, ".xml")) {
| 94 |
fprintf(stderr, "%s: input does not end in '.xml'\n", fname);
| 95 |
return(0);
| 96 |
| 97 |
pname = getpath(fname, getrlibpath(), R_OK);
| 98 |
if (pname == NULL) {
| 99 |
fprintf(stderr, "%s: cannot find BSDF file\n", fname);
| 100 |
return(0);
| 101 |
| 102 |
fnbeg = strrchr(fname, DIRSEP);
| 103 |
if (fnbeg != NULL) /* eliminate directory */
| 104 |
fname = fnbeg+1;
| 105 |
SDclearBSDF(&myBSDF, fname);
| 106 |
if (SDreportError(SDloadFile(&myBSDF, pname), stderr))
| 107 |
return(0);
| 108 |
retOK = (myBSDF.dim[0] > FTINY) & (myBSDF.dim[1] > FTINY);
| 109 |
if (!retOK) {
| 110 |
fprintf(stderr, "%s: zero width or height\n", fname);
| 111 |
} else {
| 112 |
if (!do_stdout) {
| 113 |
char rname[SDnameLn+4];
| 114 |
strcpy(rname, myBSDF.name);
| 115 |
strcat(rname, ".rad");
| 116 |
retOK = (freopen(rname, "w", stdout) != NULL);
| 117 |
| 118 |
if (retOK) {
| 119 |
if (myBSDF.matn[0] && myBSDF.makr[0])
| 120 |
printf("# Material '%s' by '%s'\n\n",
| 121 |
myBSDF.matn, myBSDF.makr);
| 122 |
if (myBSDF.mgf == NULL) {
| 123 |
faceBSDF(&myBSDF, .0);
| 124 |
} else {
| 125 |
faceBSDF(&myBSDF, myBSDF.dim[2]);
| 126 |
if (myBSDF.rb != NULL)
| 127 |
faceBSDF(&myBSDF, -myBSDF.dim[2]);
| 128 |
retOK = geomBSDF(&myBSDF);
| 129 |
| 130 |
| 131 |
| 132 |
SDfreeBSDF(&myBSDF); /* clean up and return */
| 133 |
return(retOK);
| 134 |
| 135 |
| 136 |
| 137 |
/* Generate BSDF-referencing Radiance scenes, one per XML input */
| 138 |
int
| 139 |
main(int argc, char *argv[])
| 140 |
| 141 |
int status = 0;
| 142 |
int i;
| 143 |
| 144 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 145 |
switch (argv[i][1]) {
| 146 |
case 'i':
| 147 |
do_instance = 1;
| 148 |
break;
| 149 |
case 's':
| 150 |
do_stdout = 1;
| 151 |
break;
| 152 |
default:
| 153 |
goto userr;
| 154 |
| 155 |
if (i >= argc) {
| 156 |
fprintf(stderr, "%s: missing XML input\n", argv[0]);
| 157 |
goto userr;
| 158 |
| 159 |
if (i < argc-1 && do_stdout) {
| 160 |
fprintf(stderr, "%s: cannot send multiple BSDFs to stdout\n",
| 161 |
argv[0]);
| 162 |
return(1);
| 163 |
| 164 |
for ( ; i < argc; i++)
| 165 |
if (!cvtBSDF(argv[i])) {
| 166 |
fprintf(stderr, "%s: conversion of '%s' failed\n",
| 167 |
argv[0], argv[i]);
| 168 |
status = 1;
| 169 |
| 170 |
return(status);
| 171 |
userr:
| 172 |
fprintf(stderr, "Usage: %s [-i][-s] input.xml ..\n", argv[0]);
| 173 |
return(1);
| 174 |
