root/radiance/ray/src/cv/pkgBSDF.c
Revision: 2.9
Committed: Sun Dec 8 18:33:23 2024 UTC (5 months ago) by greg
Error occurred while calculating annotation data.
feat(pkgBSDF): Added spectral conversion for MGF materials
2 static const char RCSid[] = "$Id: pkgBSDF.c,v 2.8 2018/12/01 19:45:43 greg Exp $";
5 * Take BSDF XML file and generate a referencing Radiance object
6 */
7
8 #include "rtio.h"
9 #include "paths.h"
10 #include "bsdf.h"
11
12 int do_stdout = 0; /* send Radiance object to stdout? */
13 int do_instance = 0; /* produce instance/octree pairs? */
14
15 char *progname; /* global argv[0] */
16
17 /* Return appropriate suffix for Z offset */
18 static const char *
19 get_suffix(double zval)
20 {
21 return((zval > FTINY) ? "_f" : (zval < -FTINY) ? "_b" : "");
22 }
23
24
25 /* Produce a single rectangle corresponding to the given BSDF dimensions */
26 static void
27 faceBSDF(const SDData *bsp, double zval)
28 {
29 const char *sfx = get_suffix(zval);
30 /* output material */
31 printf("void BSDF m_%s%s\n", bsp->name, sfx);
32 printf("6 %g %s.xml 0 1 0 .\n", zval*1.00004, bsp->name);
33 printf("0\n0\n\n");
34 /* output surface */
35 zval *= (zval < 0) + 0.00002;
36 printf("m_%s%s polygon %s%s\n", bsp->name, sfx, bsp->name, sfx);
37 printf("0\n0\n12\n");
38 printf("\t%.6e\t%.6e\t%.6e\n",
39 -.5*bsp->dim[0], -.5*bsp->dim[1], zval);
40 printf("\t%.6e\t%.6e\t%.6e\n",
41 .5*bsp->dim[0], -.5*bsp->dim[1], zval);
42 printf("\t%.6e\t%.6e\t%.6e\n",
43 .5*bsp->dim[0], .5*bsp->dim[1], zval);
44 printf("\t%.6e\t%.6e\t%.6e\n\n",
45 -.5*bsp->dim[0], .5*bsp->dim[1], zval);
46 }
47
48
49 /* Convert BSDF (MGF) geometry to Radiance description */
50 static int
51 geomBSDF(const SDData *bsp)
52 {
53 char tmpfile[64];
54 char command[SDnameLn+64];
55 int fd;
56 /* write MGF to temp file */
57 fd = open(mktemp(strcpy(tmpfile,TEMPLATE)), O_WRONLY|O_CREAT|O_EXCL, 0600);
58 if (fd < 0) {
59 fprintf(stderr, "Cannot open temp file '%s'\n", tmpfile);
60 return(0);
61 }
62 (void)write(fd, bsp->mgf, strlen(bsp->mgf));
63 close(fd);
64 /* set up command */
65 if (do_instance) {
66 sprintf(command, "mgf2rad -s %s | oconv -f - > %s.oct",
67 tmpfile, bsp->name);
68 } else {
69 fflush(stdout);
70 sprintf(command, "mgf2rad -s %s", tmpfile);
71 }
72 if (system(command)) {
73 fprintf(stderr, "Error running: %s\n", command);
74 return(0);
75 }
76 unlink(tmpfile); /* remove temp file */
77 if (do_instance) { /* need to output instance? */
78 printf("void instance %s_g\n", bsp->name);
79 printf("1 %s.oct\n0\n0\n\n", bsp->name);
80 }
81 return(1);
82 }
83
84
85 /* Load a BSDF XML file and produce a corresponding Radiance object */
86 static int
87 cvtBSDF(char *fname)
88 {
89 int retOK;
90 SDData myBSDF;
91 char *pname, *fnbeg;
92 /* find and load the XML file */
93 retOK = strlen(fname);
94 if (retOK < 5 || strcasecmp(fname+retOK-4, ".xml")) {
95 fprintf(stderr, "%s: input does not end in '.xml'\n", fname);
96 return(0);
97 }
98 pname = getpath(fname, getrlibpath(), R_OK);
99 if (pname == NULL) {
100 fprintf(stderr, "%s: cannot find BSDF file\n", fname);
101 return(0);
102 }
103 fnbeg = strrchr(fname, DIRSEP);
104 if (fnbeg != NULL) /* eliminate directory */
105 fname = fnbeg+1;
106 SDclearBSDF(&myBSDF, fname);
107 if (SDreportError(SDloadFile(&myBSDF, pname), stderr))
108 return(0);
109 retOK = (myBSDF.dim[0] > FTINY) & (myBSDF.dim[1] > FTINY);
110 if (!retOK) {
111 fprintf(stderr, "%s: zero width or height\n", fname);
112 } else {
113 if (!do_stdout) {
114 char rname[SDnameLn+4];
115 strcpy(rname, myBSDF.name);
116 strcat(rname, ".rad");
117 retOK = (freopen(rname, "w", stdout) != NULL);
118 }
119 if (retOK) {
120 printf("# Produced by: %s %s\n", progname, fname);
121 if (myBSDF.matn[0] && myBSDF.makr[0])
122 printf("# Material '%s' by '%s'\n\n",
123 myBSDF.matn, myBSDF.makr);
124 if (myBSDF.mgf == NULL) {
125 faceBSDF(&myBSDF, .0);
126 } else {
127 faceBSDF(&myBSDF, myBSDF.dim[2]);
128 if (myBSDF.rb != NULL)
129 faceBSDF(&myBSDF, -myBSDF.dim[2]);
130 retOK = geomBSDF(&myBSDF);
131 }
132 }
133 }
134 SDfreeBSDF(&myBSDF); /* clean up and return */
135 return(retOK);
136 }
137
138
139 /* Generate BSDF-referencing Radiance scenes, one per XML input */
140 int
141 main(int argc, char *argv[])
142 {
143 int status = 0;
144 int i;
145
146 progname = argv[0];
147
148 for (i = 1; i < argc && argv[i][0] == '-'; i++)
149 switch (argv[i][1]) {
150 case 'i':
151 do_instance = 1;
152 break;
153 case 's':
154 do_stdout = 1;
155 break;
156 default:
157 goto userr;
158 }
159 if (i >= argc) {
160 fprintf(stderr, "%s: missing XML input\n", argv[0]);
161 goto userr;
162 }
163 if (i < argc-1 && do_stdout) {
164 fprintf(stderr, "%s: cannot send multiple BSDFs to stdout\n",
165 argv[0]);
166 return(1);
167 }
168 for ( ; i < argc; i++)
169 if (!cvtBSDF(argv[i])) {
170 fprintf(stderr, "%s: conversion of '%s' failed\n",
171 argv[0], argv[i]);
172 status = 1;
173 }
174 return(status);
175 userr:
176 fprintf(stderr, "Usage: %s [-i][-s] input.xml ..\n", argv[0]);
177 return(1);
178 }
