| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: pabopto2xyz.c,v 2.3 2016/08/22 21:03:00 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Combine PAB-Opto data files for color (CIE-XYZ) interpolation.
| 6 |
| 7 |
* G. Ward
| 8 |
| 9 |
| 10 |
#define _USE_MATH_DEFINES
| 11 |
#include "rtio.h"
| 12 |
#include <stdlib.h>
| 13 |
#include <ctype.h>
| 14 |
#include <math.h>
| 15 |
#include "interp2d.h"
| 16 |
| 17 |
/* #define DEBUG 1 */
| 18 |
| 19 |
#ifndef MAX_INPUTS
| 20 |
#define MAX_INPUTS 512 /* can handle this many files per chan */
| 21 |
#endif
| 22 |
| 23 |
#define ANGRES 256 /* resolution per 180 degrees */
| 24 |
| 25 |
/* Input file header information */
| 26 |
typedef struct {
| 27 |
const char *fname; /* input file path */
| 28 |
double theta, phi; /* input angles (degrees) */
| 29 |
double up_phi; /* azimuth for "up" direction */
| 30 |
int igp[2]; /* input grid position */
| 31 |
int isDSF; /* data is DSF (rather than BSDF)? */
| 32 |
int ndata; /* number of data points (or 0) */
| 33 |
long dstart; /* data start offset in file */
| 34 |
} PGINPUT;
| 35 |
| 36 |
/* 2-D interpolant for a particular incident direction */
| 37 |
typedef struct {
| 38 |
INTERP2 *ip2; /* 2-D interpolatiing function */
| 39 |
float *va; /* corresponding value array */
| 40 |
} PGINTERP;
| 41 |
| 42 |
extern void SDdisk2square(double sq[2], double diskx, double disky);
| 43 |
| 44 |
char *progname; /* global argv[0] */
| 45 |
| 46 |
int incident_side = 0; /* signum(intheta) */
| 47 |
int exiting_side = 0; /* signum(outtheta) */
| 48 |
| 49 |
int nprocs = 1; /* number of processes to run */
| 50 |
| 51 |
int nchild = 0; /* number of children (-1 in child) */
| 52 |
| 53 |
char *basename = "pabopto_xyz";
| 54 |
| 55 |
/* color conversion matrix */
| 56 |
double sens2xyz[3][3] = {
| 57 |
8.7539e-01, 3.5402e-02, 9.0381e-02,
| 58 |
1.3463e+00, -3.9082e-01, 7.2721e-02,
| 59 |
2.7306e-01, -2.1111e-01, 1.1014e+00,
| 60 |
| 61 |
| 62 |
#if defined(_WIN32) || defined(_WIN64)
| 63 |
| 64 |
#define await_children(n) (void)(n)
| 65 |
#define run_subprocess() 0
| 66 |
#define end_subprocess() (void)0
| 67 |
| 68 |
#else /* ! _WIN32 */
| 69 |
| 70 |
#include <unistd.h>
| 71 |
#include <sys/wait.h>
| 72 |
| 73 |
/* Wait for the specified number of child processes to complete */
| 74 |
static void
| 75 |
await_children(int n)
| 76 |
| 77 |
int exit_status = 0;
| 78 |
| 79 |
if (n > nchild)
| 80 |
n = nchild;
| 81 |
while (n-- > 0) {
| 82 |
int status;
| 83 |
if (wait(&status) < 0) {
| 84 |
fprintf(stderr, "%s: missing child(ren)!\n", progname);
| 85 |
nchild = 0;
| 86 |
break;
| 87 |
| 88 |
--nchild;
| 89 |
if (status) { /* something wrong */
| 90 |
if ((status = WEXITSTATUS(status)))
| 91 |
exit_status = status;
| 92 |
else
| 93 |
exit_status += !exit_status;
| 94 |
fprintf(stderr, "%s: subprocess died\n", progname);
| 95 |
n = nchild; /* wait for the rest */
| 96 |
| 97 |
| 98 |
if (exit_status)
| 99 |
exit(exit_status);
| 100 |
| 101 |
| 102 |
/* Start child process if multiprocessing selected */
| 103 |
static pid_t
| 104 |
run_subprocess(void)
| 105 |
| 106 |
int status;
| 107 |
pid_t pid;
| 108 |
| 109 |
if (nprocs <= 1) /* any children requested? */
| 110 |
return(0);
| 111 |
await_children(nchild + 1 - nprocs); /* free up child process */
| 112 |
if ((pid = fork())) {
| 113 |
if (pid < 0) {
| 114 |
fprintf(stderr, "%s: cannot fork subprocess\n",
| 115 |
progname);
| 116 |
await_children(nchild);
| 117 |
exit(1);
| 118 |
| 119 |
++nchild; /* subprocess started */
| 120 |
return(pid);
| 121 |
| 122 |
nchild = -1;
| 123 |
return(0); /* put child to work */
| 124 |
| 125 |
| 126 |
/* If we are in subprocess, call exit */
| 127 |
#define end_subprocess() if (nchild < 0) _exit(0); else
| 128 |
| 129 |
#endif /* ! _WIN32 */
| 130 |
| 131 |
/* Compute square location from normalized input/output vector */
| 132 |
static void
| 133 |
sq_from_ang(double sq[2], double theta, double phi)
| 134 |
| 135 |
double vec[3];
| 136 |
double norm;
| 137 |
/* uniform hemispherical projection */
| 138 |
vec[2] = sin(M_PI/180.*theta);
| 139 |
vec[0] = cos(M_PI/180.*phi)*vec[2];
| 140 |
vec[1] = sin(M_PI/180.*phi)*vec[2];
| 141 |
vec[2] = sqrt(1. - vec[2]*vec[2]);
| 142 |
norm = 1./sqrt(1. + vec[2]);
| 143 |
| 144 |
SDdisk2square(sq, vec[0]*norm, vec[1]*norm);
| 145 |
| 146 |
| 147 |
/* Compute quantized grid position from normalized input/output vector */
| 148 |
static void
| 149 |
pos_from_ang(int gp[2], double theta, double phi)
| 150 |
| 151 |
double sq[2];
| 152 |
| 153 |
sq_from_ang(sq, theta, phi);
| 154 |
gp[0] = (int)(sq[0]*ANGRES);
| 155 |
gp[1] = (int)(sq[1]*ANGRES);
| 156 |
| 157 |
| 158 |
/* Compare incident angles */
| 159 |
static int
| 160 |
cmp_indir(const void *p1, const void *p2)
| 161 |
| 162 |
const PGINPUT *inp1 = (const PGINPUT *)p1;
| 163 |
const PGINPUT *inp2 = (const PGINPUT *)p2;
| 164 |
int ydif;
| 165 |
| 166 |
if (!inp1->dstart) /* put terminator last */
| 167 |
return(inp2->dstart > 0);
| 168 |
if (!inp2->dstart)
| 169 |
return(-1);
| 170 |
| 171 |
ydif = inp1->igp[1] - inp2->igp[1];
| 172 |
if (ydif)
| 173 |
return(ydif);
| 174 |
| 175 |
return(inp1->igp[0] - inp2->igp[0]);
| 176 |
| 177 |
| 178 |
/* Prepare a PAB-Opto input file by reading its header */
| 179 |
static int
| 180 |
init_pabopto_inp(PGINPUT *pgi, const char *fname)
| 181 |
| 182 |
FILE *fp = fopen(fname, "r");
| 183 |
char buf[2048];
| 184 |
int c;
| 185 |
| 186 |
if (fp == NULL) {
| 187 |
fputs(fname, stderr);
| 188 |
fputs(": cannot open\n", stderr);
| 189 |
return(0);
| 190 |
| 191 |
pgi->fname = fname;
| 192 |
pgi->isDSF = -1;
| 193 |
pgi->ndata = 0;
| 194 |
pgi->up_phi = 0;
| 195 |
pgi->theta = pgi->phi = -10001.;
| 196 |
/* read header information */
| 197 |
while ((c = getc(fp)) == '#' || c == EOF) {
| 198 |
char typ[64];
| 199 |
if (fgets(buf, sizeof(buf), fp) == NULL) {
| 200 |
| 201 |
fputs(": unexpected EOF\n", stderr);
| 202 |
fclose(fp);
| 203 |
return(0);
| 204 |
| 205 |
if (sscanf(buf, "colorimetry: %s", typ) == 1) {
| 206 |
if (!strcasecmp(typ, "CIE-XYZ")) {
| 207 |
| 208 |
fputs(": already in XYZ color space!\n", stderr);
| 209 |
return(0);
| 210 |
| 211 |
continue;
| 212 |
| 213 |
if (sscanf(buf, "datapoints_in_file:%d", &pgi->ndata) == 1)
| 214 |
continue;
| 215 |
if (sscanf(buf, "format: theta phi %s", typ) == 1) {
| 216 |
if (!strcasecmp(typ, "DSF"))
| 217 |
pgi->isDSF = 1;
| 218 |
else if (!strcasecmp(typ, "BSDF") ||
| 219 |
!strcasecmp(typ, "BRDF") ||
| 220 |
!strcasecmp(typ, "BTDF"))
| 221 |
pgi->isDSF = 0;
| 222 |
continue;
| 223 |
| 224 |
if (sscanf(buf, "upphi %lf", &pgi->up_phi) == 1)
| 225 |
continue;
| 226 |
if (sscanf(buf, "intheta %lf", &pgi->theta) == 1)
| 227 |
continue;
| 228 |
if (sscanf(buf, "inphi %lf", &pgi->phi) == 1)
| 229 |
continue;
| 230 |
if (sscanf(buf, "incident_angle %lf %lf",
| 231 |
&pgi->theta, &pgi->phi) == 2)
| 232 |
continue;
| 233 |
| 234 |
pgi->dstart = ftell(fp) - 1;
| 235 |
fclose(fp);
| 236 |
if (pgi->isDSF < 0) {
| 237 |
| 238 |
fputs(": unknown format\n", stderr);
| 239 |
return(0);
| 240 |
| 241 |
if ((pgi->theta < -10000.) | (pgi->phi < -10000.)) {
| 242 |
| 243 |
fputs(": unknown incident angle\n", stderr);
| 244 |
return(0);
| 245 |
| 246 |
if (!incident_side) {
| 247 |
incident_side = (pgi->theta < 90.) ? 1 : -1;
| 248 |
} else if ((incident_side > 0) ^ (pgi->theta < 90.)) {
| 249 |
| 250 |
fputs(": incident on opposite side of surface\n", stderr);
| 251 |
return(0);
| 252 |
| 253 |
/* convert angle to grid position */
| 254 |
pos_from_ang(pgi->igp, pgi->theta, pgi->phi);
| 255 |
return(1);
| 256 |
| 257 |
| 258 |
/* Load interpolating function for a particular incident direction */
| 259 |
static int
| 260 |
load_interp(PGINTERP *pgint, const int igp[2], const PGINPUT *pginp)
| 261 |
| 262 |
int nv = 0;
| 263 |
int nread = 0;
| 264 |
pgint->ip2 = NULL;
| 265 |
pgint->va = NULL;
| 266 |
/* load input file(s) */
| 267 |
while (pginp->dstart && (pginp->igp[0] == igp[0]) &
| 268 |
(pginp->igp[1] == igp[1])) {
| 269 |
FILE *fp = fopen(pginp->fname, "r");
| 270 |
double theta, phi;
| 271 |
float val;
| 272 |
| 273 |
if (fp == NULL || fseek(fp, pginp->dstart, SEEK_SET) < 0) {
| 274 |
fputs(pginp->fname, stderr);
| 275 |
fputs(": cannot re-open input file!\n", stderr);
| 276 |
return(0);
| 277 |
| 278 |
#ifdef DEBUG
| 279 |
fprintf(stderr, "Loading channel from '%s'\n", pginp->fname);
| 280 |
#endif
| 281 |
while (fscanf(fp, "%lf %lf %f", &theta, &phi, &val) == 3) {
| 282 |
double sq[2];
| 283 |
if (nread >= nv) {
| 284 |
if (pginp->ndata > 0)
| 285 |
nv += pginp->ndata;
| 286 |
else
| 287 |
nv += (nv>>1) + 1024;
| 288 |
pgint->ip2 = interp2_realloc(pgint->ip2, nv);
| 289 |
pgint->va = (float *)realloc(pgint->va, sizeof(float)*nv);
| 290 |
if ((pgint->ip2 == NULL) | (pgint->va == NULL))
| 291 |
goto memerr;
| 292 |
| 293 |
if (!exiting_side) {
| 294 |
exiting_side = (theta < 90.) ? 1 : -1;
| 295 |
} else if ((exiting_side > 0) ^ (theta < 90.)) {
| 296 |
| 297 |
fputs(": exiting measurement on wrong side\n", stderr);
| 298 |
return(0);
| 299 |
| 300 |
| 301 |
pgint->ip2->spt[nread][0] = sq[0]*ANGRES;
| 302 |
pgint->ip2->spt[nread][1] = sq[1]*ANGRES;
| 303 |
pgint->va[nread++] = val;
| 304 |
| 305 |
fclose(fp);
| 306 |
++pginp; /* advance to next input */
| 307 |
| 308 |
if (nv > nread) { /* fix array sizes */
| 309 |
pgint->ip2 = interp2_realloc(pgint->ip2, nread);
| 310 |
pgint->va = (float *)realloc(pgint->va, nread);
| 311 |
| 312 |
goto memerr;
| 313 |
| 314 |
return(1);
| 315 |
memerr:
| 316 |
fputs(progname, stderr);
| 317 |
fputs(": Out of memory in load_interp()!\n", stderr);
| 318 |
return(0);
| 319 |
| 320 |
| 321 |
/* Interpolate value at the given position */
| 322 |
static double
| 323 |
interp2val(const PGINTERP *pgint, double px, double py)
| 324 |
| 325 |
#define NSMP 36
| 326 |
float wt[NSMP];
| 327 |
int si[NSMP];
| 328 |
int n = interp2_topsamp(wt, si, NSMP, pgint->ip2, px, py);
| 329 |
double v = .0;
| 330 |
| 331 |
while (n-- > 0)
| 332 |
v += wt[n]*pgint->va[si[n]];
| 333 |
| 334 |
return(v);
| 335 |
#undef NSMP
| 336 |
| 337 |
| 338 |
static void
| 339 |
free_interp(PGINTERP *pgint)
| 340 |
| 341 |
interp2_free(pgint->ip2);
| 342 |
pgint->ip2 = NULL;
| 343 |
free(pgint->va);
| 344 |
pgint->va = NULL;
| 345 |
| 346 |
| 347 |
/* Interpolate the given incident direction to an output file */
| 348 |
static int
| 349 |
interp_xyz(const PGINPUT *inp0, int nf, const PGINTERP *int1, const PGINTERP *int2)
| 350 |
| 351 |
int dtotal = 0;
| 352 |
char outfname[256];
| 353 |
FILE *ofp;
| 354 |
int i;
| 355 |
| 356 |
if (nf <= 0)
| 357 |
return(0);
| 358 |
/* create output file & write header */
| 359 |
sprintf(outfname, "%s_t%03.0fp%03.0f.txt", basename, inp0->theta, inp0->phi);
| 360 |
if ((ofp = fopen(outfname, "w")) == NULL) {
| 361 |
fputs(outfname, stderr);
| 362 |
fputs(": cannot open for writing\n", stderr);
| 363 |
return(0);
| 364 |
| 365 |
fprintf(ofp, "#data written using %s\n", progname);
| 366 |
fprintf(ofp, "#incident_angle %g %g\n", inp0->theta, inp0->phi);
| 367 |
fprintf(ofp, "#intheta %g\n", inp0->theta);
| 368 |
fprintf(ofp, "#inphi %g\n", inp0->phi);
| 369 |
fprintf(ofp, "#upphi %g\n", inp0->up_phi);
| 370 |
fprintf(ofp, "#colorimetry: CIE-XYZ\n");
| 371 |
for (i = nf; i--; )
| 372 |
dtotal += inp0[i].ndata;
| 373 |
if (dtotal > 0)
| 374 |
fprintf(ofp, "#datapoints_in_file: %d\n", dtotal);
| 375 |
fprintf(ofp, "#format: theta phi %s\n", inp0->isDSF ? "DSF" : "BSDF");
| 376 |
dtotal = 0;
| 377 |
while (nf-- > 0) { /* load channel 1 file(s) */
| 378 |
FILE *ifp = fopen(inp0->fname, "r");
| 379 |
double theta, phi, val[3], sq[2];
| 380 |
| 381 |
if (ifp == NULL || fseek(ifp, inp0->dstart, SEEK_SET) < 0) {
| 382 |
fputs(inp0->fname, stderr);
| 383 |
| 384 |
return(0);
| 385 |
| 386 |
#ifdef DEBUG
| 387 |
fprintf(stderr, "Adding points from '%s' to '%s'\n",
| 388 |
inp0->fname, outfname);
| 389 |
#endif
| 390 |
while (fscanf(ifp, "%lf %lf %lf", &theta, &phi, &val[0]) == 3) {
| 391 |
| 392 |
| 393 |
| 394 |
| 395 |
| 396 |
return(0);
| 397 |
| 398 |
| 399 |
val[1] = interp2val(int1, sq[0]*ANGRES, sq[1]*ANGRES);
| 400 |
val[2] = interp2val(int2, sq[0]*ANGRES, sq[1]*ANGRES);
| 401 |
fprintf(ofp, "%.3f %.3f", theta, phi);
| 402 |
for (i = 0; i < 3; i++)
| 403 |
fprintf(ofp, " %.4f",
| 404 |
sens2xyz[i][0]*val[0] +
| 405 |
sens2xyz[i][1]*val[1] +
| 406 |
sens2xyz[i][2]*val[2]);
| 407 |
fputc('\n', ofp);
| 408 |
++dtotal;
| 409 |
| 410 |
fclose(ifp);
| 411 |
++inp0; /* advance to next input file */
| 412 |
| 413 |
#ifdef DEBUG
| 414 |
fprintf(stderr, "Wrote %d values to '%s'\n", dtotal, outfname);
| 415 |
#endif
| 416 |
return(fclose(ofp) == 0);
| 417 |
| 418 |
| 419 |
/* Do next incident direction and advance counters */
| 420 |
static int
| 421 |
advance_incidence(PGINPUT *slist[3], int ndx[3])
| 422 |
| 423 |
const int i0 = ndx[0];
| 424 |
PGINTERP pgi1, pgi2;
| 425 |
int c;
| 426 |
/* match up directions */
| 427 |
while ((c = cmp_indir(slist[1]+ndx[1], slist[0]+ndx[0])) < 0)
| 428 |
ndx[1]++;
| 429 |
if (c) {
| 430 |
fputs(slist[0][ndx[0]].fname, stderr);
| 431 |
fputs(": warning - missing channel 2 at this incidence\n", stderr);
| 432 |
do
| 433 |
++ndx[0];
| 434 |
while (!cmp_indir(slist[0]+ndx[0], slist[0]+i0));
| 435 |
return(0);
| 436 |
| 437 |
while ((c = cmp_indir(slist[2]+ndx[2], slist[0]+ndx[0])) < 0)
| 438 |
ndx[2]++;
| 439 |
if (c) {
| 440 |
| 441 |
fputs(": warning - missing channel 3 at this incidence\n", stderr);
| 442 |
do
| 443 |
++ndx[0];
| 444 |
| 445 |
return(0);
| 446 |
| 447 |
do /* advance first channel index */
| 448 |
++ndx[0];
| 449 |
| 450 |
| 451 |
if (run_subprocess()) /* fork here if multiprocessing */
| 452 |
return(1);
| 453 |
/* interpolate channels 2 & 3 */
| 454 |
load_interp(&pgi1, slist[0][i0].igp, slist[1]+ndx[1]);
| 455 |
load_interp(&pgi2, slist[0][i0].igp, slist[2]+ndx[2]);
| 456 |
if (!interp_xyz(slist[0]+i0, ndx[0]-i0, &pgi1, &pgi2))
| 457 |
return(-1);
| 458 |
end_subprocess();
| 459 |
free_interp(&pgi1);
| 460 |
free_interp(&pgi2);
| 461 |
return(1);
| 462 |
| 463 |
| 464 |
/* Read in single-channel PAB-Opto BSDF files and output XYZ versions */
| 465 |
int
| 466 |
main(int argc, char *argv[])
| 467 |
| 468 |
char *flist[MAX_INPUTS];
| 469 |
PGINPUT *slist[3];
| 470 |
int i, j;
| 471 |
int ndx[3];
| 472 |
/* get options */
| 473 |
progname = argv[0];
| 474 |
for (i = 1; i < argc-3 && argv[i][0] == '-'; i++)
| 475 |
switch (argv[i][1]) {
| 476 |
case 'n':
| 477 |
nprocs = atoi(argv[++i]);
| 478 |
break;
| 479 |
case 'm':
| 480 |
if (i >= argc-(3+9))
| 481 |
goto userr;
| 482 |
for (j = 0; j < 3; j++) {
| 483 |
sens2xyz[j][0] = atof(argv[++i]);
| 484 |
sens2xyz[j][1] = atof(argv[++i]);
| 485 |
sens2xyz[j][2] = atof(argv[++i]);
| 486 |
| 487 |
break;
| 488 |
case 'o':
| 489 |
basename = argv[++i];
| 490 |
break;
| 491 |
default:
| 492 |
goto userr;
| 493 |
| 494 |
if (i != argc-3)
| 495 |
goto userr;
| 496 |
for (j = 0; j < 3; j++) { /* prep input channels */
| 497 |
int k, n;
| 498 |
n = wordfile(flist, MAX_INPUTS, argv[i+j]);
| 499 |
if (n <= 0) {
| 500 |
fputs(argv[i+j], stderr);
| 501 |
fputs(": cannot load input file names\n", stderr);
| 502 |
return(1);
| 503 |
| 504 |
slist[j] = (PGINPUT *)malloc(sizeof(PGINPUT)*(n+1));
| 505 |
if (slist[j] == NULL) {
| 506 |
fputs(argv[0], stderr);
| 507 |
fputs(": out of memory!\n", stderr);
| 508 |
return(1);
| 509 |
| 510 |
#ifdef DEBUG
| 511 |
fprintf(stderr, "Checking %d files from '%s'\n", n, argv[i+j]);
| 512 |
#endif
| 513 |
for (k = 0; k < n; k++)
| 514 |
if (!init_pabopto_inp(slist[j]+k, flist[k]))
| 515 |
return(1);
| 516 |
memset(slist[j]+n, 0, sizeof(PGINPUT));
| 517 |
/* sort by incident direction */
| 518 |
qsort(slist[j], n, sizeof(PGINPUT), cmp_indir);
| 519 |
| 520 |
ndx[0]=ndx[1]=ndx[2]=0; /* compile measurements */
| 521 |
while (slist[0][ndx[0]].dstart)
| 522 |
if (advance_incidence(slist, ndx) < 0)
| 523 |
return(1);
| 524 |
await_children(nchild); /* wait for all to finish */
| 525 |
return(0);
| 526 |
userr:
| 527 |
fputs("Usage: ", stderr);
| 528 |
| 529 |
fputs(" [-m X1 X2 X3 Y1 Y2 Y3 Z1 Z2 Z3][-o basename][-n nprocs]", stderr);
| 530 |
fputs(" s1files.txt s2files.txt s3files.txt\n", stderr);
| 531 |
return(1);
| 532 |
