1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.29 2016/02/02 00:42:11 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Combine PAB-Opto data files for color (CIE-XYZ) interpolation. |
6 |
7 |
* G. Ward |
8 |
9 |
10 |
#define _USE_MATH_DEFINES |
11 |
#include "rtio.h" |
12 |
#include <stdlib.h> |
13 |
#include <ctype.h> |
14 |
#include <math.h> |
15 |
#include "interp2d.h" |
16 |
17 |
/* #define DEBUG 1 */ |
18 |
19 |
#ifndef MAX_INPUTS |
20 |
#define MAX_INPUTS 512 /* can handle this many files per chan */ |
21 |
#endif |
22 |
23 |
#define ANGRES 256 /* resolution per 180 degrees */ |
24 |
25 |
/* Input file header information */ |
26 |
typedef struct { |
27 |
const char *fname; /* input file path */ |
28 |
double theta, phi; /* input angles (degrees) */ |
29 |
double up_phi; /* azimuth for "up" direction */ |
30 |
int igp[2]; /* input grid position */ |
31 |
int isDSF; /* data is DSF (rather than BSDF)? */ |
32 |
int ndata; /* number of data points (or 0) */ |
33 |
long dstart; /* data start offset in file */ |
34 |
} PGINPUT; |
35 |
36 |
/* 2-D interpolant for a particular incident direction */ |
37 |
typedef struct { |
38 |
INTERP2 *ip2; /* 2-D interpolatiing function */ |
39 |
float *va; /* corresponding value array */ |
40 |
} PGINTERP; |
41 |
42 |
extern void SDdisk2square(double sq[2], double diskx, double disky); |
43 |
44 |
char *progname; /* global argv[0] */ |
45 |
46 |
int nprocs = 1; /* number of processes to run */ |
47 |
48 |
int nchild = 0; /* number of children (-1 in child) */ |
49 |
50 |
char *basename = "pabopto_xyz"; |
51 |
52 |
/* color conversion matrix */ |
53 |
double sens2xyz[3][3] = { |
54 |
8.7539e-01, 3.5402e-02, 9.0381e-02, |
55 |
1.3463e+00, -3.9082e-01, 7.2721e-02, |
56 |
2.7306e-01, -2.1111e-01, 1.1014e+00, |
57 |
58 |
59 |
#if defined(_WIN32) || defined(_WIN64) |
60 |
61 |
#define await_children(n) (void)(n) |
62 |
#define run_subprocess() 0 |
63 |
#define end_subprocess() (void)0 |
64 |
65 |
#else /* ! _WIN32 */ |
66 |
67 |
#include <unistd.h> |
68 |
#include <sys/wait.h> |
69 |
70 |
/* Wait for the specified number of child processes to complete */ |
71 |
static void |
72 |
await_children(int n) |
73 |
74 |
int exit_status = 0; |
75 |
76 |
if (n > nchild) |
77 |
n = nchild; |
78 |
while (n-- > 0) { |
79 |
int status; |
80 |
if (wait(&status) < 0) { |
81 |
fprintf(stderr, "%s: missing child(ren)!\n", progname); |
82 |
nchild = 0; |
83 |
break; |
84 |
85 |
--nchild; |
86 |
if (status) { /* something wrong */ |
87 |
if ((status = WEXITSTATUS(status))) |
88 |
exit_status = status; |
89 |
else |
90 |
exit_status += !exit_status; |
91 |
fprintf(stderr, "%s: subprocess died\n", progname); |
92 |
n = nchild; /* wait for the rest */ |
93 |
94 |
95 |
if (exit_status) |
96 |
exit(exit_status); |
97 |
98 |
99 |
/* Start child process if multiprocessing selected */ |
100 |
static pid_t |
101 |
run_subprocess(void) |
102 |
103 |
int status; |
104 |
pid_t pid; |
105 |
106 |
if (nprocs <= 1) /* any children requested? */ |
107 |
return(0); |
108 |
await_children(nchild + 1 - nprocs); /* free up child process */ |
109 |
if ((pid = fork())) { |
110 |
if (pid < 0) { |
111 |
fprintf(stderr, "%s: cannot fork subprocess\n", |
112 |
progname); |
113 |
await_children(nchild); |
114 |
exit(1); |
115 |
116 |
++nchild; /* subprocess started */ |
117 |
return(pid); |
118 |
119 |
nchild = -1; |
120 |
return(0); /* put child to work */ |
121 |
122 |
123 |
/* If we are in subprocess, call exit */ |
124 |
#define end_subprocess() if (nchild < 0) _exit(0); else |
125 |
126 |
#endif /* ! _WIN32 */ |
127 |
128 |
/* Compute square location from normalized input/output vector */ |
129 |
static void |
130 |
sq_from_ang(double sq[2], double theta, double phi) |
131 |
132 |
double vec[3]; |
133 |
double norm; |
134 |
/* uniform hemispherical projection */ |
135 |
vec[2] = sin(M_PI/180.*theta); |
136 |
vec[0] = cos(M_PI/180.*phi)*vec[2]; |
137 |
vec[1] = sin(M_PI/180.*phi)*vec[2]; |
138 |
vec[2] = sqrt(1. - vec[2]*vec[2]); |
139 |
norm = 1./sqrt(1. + vec[2]); |
140 |
141 |
SDdisk2square(sq, vec[0]*norm, vec[1]*norm); |
142 |
143 |
144 |
/* Compute quantized grid position from normalized input/output vector */ |
145 |
static void |
146 |
pos_from_ang(int gp[2], double theta, double phi) |
147 |
148 |
double sq[2]; |
149 |
150 |
sq_from_ang(sq, theta, phi); |
151 |
gp[0] = (int)(sq[0]*ANGRES); |
152 |
gp[1] = (int)(sq[1]*ANGRES); |
153 |
154 |
155 |
/* Compare incident angles */ |
156 |
static int |
157 |
cmp_indir(const void *p1, const void *p2) |
158 |
159 |
const PGINPUT *inp1 = (const PGINPUT *)p1; |
160 |
const PGINPUT *inp2 = (const PGINPUT *)p2; |
161 |
int ydif; |
162 |
163 |
if (!inp1->dstart) /* put terminator last */ |
164 |
return(inp2->dstart > 0); |
165 |
if (!inp2->dstart) |
166 |
return(-1); |
167 |
168 |
ydif = inp1->igp[1] - inp2->igp[1]; |
169 |
if (ydif) |
170 |
return(ydif); |
171 |
172 |
return(inp1->igp[0] - inp2->igp[0]); |
173 |
174 |
175 |
/* Prepare a PAB-Opto input file by reading its header */ |
176 |
static int |
177 |
init_pabopto_inp(PGINPUT *pgi, const char *fname) |
178 |
179 |
FILE *fp = fopen(fname, "r"); |
180 |
char buf[2048]; |
181 |
int c; |
182 |
183 |
if (fp == NULL) { |
184 |
fputs(fname, stderr); |
185 |
fputs(": cannot open\n", stderr); |
186 |
return(0); |
187 |
188 |
pgi->fname = fname; |
189 |
pgi->isDSF = -1; |
190 |
pgi->ndata = 0; |
191 |
pgi->up_phi = 0; |
192 |
pgi->theta = pgi->phi = -10001.; |
193 |
/* read header information */ |
194 |
while ((c = getc(fp)) == '#' || c == EOF) { |
195 |
char typ[64]; |
196 |
if (fgets(buf, sizeof(buf), fp) == NULL) { |
197 |
198 |
fputs(": unexpected EOF\n", stderr); |
199 |
fclose(fp); |
200 |
return(0); |
201 |
202 |
if (sscanf(buf, "colorimetry: %s", typ) == 1) { |
203 |
if (!strcasecmp(typ, "CIE-XYZ")) { |
204 |
205 |
fputs(": already in XYZ color space!\n", stderr); |
206 |
return(0); |
207 |
208 |
continue; |
209 |
210 |
if (sscanf(buf, "datapoints_in_file:%d", &pgi->ndata) == 1) |
211 |
continue; |
212 |
if (sscanf(buf, "format: theta phi %s", typ) == 1) { |
213 |
if (!strcasecmp(typ, "DSF")) |
214 |
pgi->isDSF = 1; |
215 |
else if (!strcasecmp(typ, "BSDF") || |
216 |
!strcasecmp(typ, "BRDF") || |
217 |
!strcasecmp(typ, "BTDF")) |
218 |
pgi->isDSF = 0; |
219 |
continue; |
220 |
221 |
if (sscanf(buf, "upphi %lf", &pgi->up_phi) == 1) |
222 |
continue; |
223 |
if (sscanf(buf, "intheta %lf", &pgi->theta) == 1) |
224 |
continue; |
225 |
if (sscanf(buf, "inphi %lf", &pgi->phi) == 1) |
226 |
continue; |
227 |
if (sscanf(buf, "incident_angle %lf %lf", |
228 |
&pgi->theta, &pgi->phi) == 2) |
229 |
continue; |
230 |
231 |
pgi->dstart = ftell(fp) - 1; |
232 |
fclose(fp); |
233 |
if (pgi->isDSF < 0) { |
234 |
235 |
fputs(": unknown format\n", stderr); |
236 |
return(0); |
237 |
238 |
if ((pgi->theta < -10000.) | (pgi->phi < -10000.)) { |
239 |
240 |
fputs(": unknown incident angle\n", stderr); |
241 |
return(0); |
242 |
243 |
/* convert angle to grid position */ |
244 |
pos_from_ang(pgi->igp, pgi->theta, pgi->phi); |
245 |
return(1); |
246 |
247 |
248 |
/* Load interpolating function for a particular incident direction */ |
249 |
static int |
250 |
load_interp(PGINTERP *pgint, const int igp[2], const PGINPUT *pginp) |
251 |
252 |
int nv = 0; |
253 |
int nread = 0; |
254 |
pgint->ip2 = NULL; |
255 |
pgint->va = NULL; |
256 |
/* load input file(s) */ |
257 |
while (pginp->dstart && (pginp->igp[0] == igp[0]) & |
258 |
(pginp->igp[1] == igp[1])) { |
259 |
FILE *fp = fopen(pginp->fname, "r"); |
260 |
double theta, phi; |
261 |
float val; |
262 |
263 |
if (fp == NULL || fseek(fp, pginp->dstart, SEEK_SET) < 0) { |
264 |
fputs(pginp->fname, stderr); |
265 |
fputs(": cannot re-open input file!\n", stderr); |
266 |
return(0); |
267 |
268 |
#ifdef DEBUG |
269 |
fprintf(stderr, "Loading channel from '%s'\n", pginp->fname); |
270 |
#endif |
271 |
while (fscanf(fp, "%lf %lf %f", &theta, &phi, &val) == 3) { |
272 |
double sq[2]; |
273 |
if (nread >= nv) { |
274 |
if (pginp->ndata > 0) |
275 |
nv += pginp->ndata; |
276 |
else |
277 |
nv += (nv>>1) + 1024; |
278 |
pgint->ip2 = interp2_realloc(pgint->ip2, nv); |
279 |
pgint->va = (float *)realloc(pgint->va, sizeof(float)*nv); |
280 |
if ((pgint->ip2 == NULL) | (pgint->va == NULL)) |
281 |
goto memerr; |
282 |
283 |
284 |
pgint->ip2->spt[nread][0] = sq[0]*ANGRES; |
285 |
pgint->ip2->spt[nread][1] = sq[1]*ANGRES; |
286 |
pgint->va[nread++] = val; |
287 |
288 |
fclose(fp); |
289 |
++pginp; /* advance to next input */ |
290 |
291 |
if (nv > nread) { /* fix array sizes */ |
292 |
pgint->ip2 = interp2_realloc(pgint->ip2, nread); |
293 |
pgint->va = (float *)realloc(pgint->va, nread); |
294 |
295 |
goto memerr; |
296 |
297 |
return(1); |
298 |
memerr: |
299 |
fputs(progname, stderr); |
300 |
fputs(": Out of memory in load_interp()!\n", stderr); |
301 |
return(0); |
302 |
303 |
304 |
/* Interpolate value at the given position */ |
305 |
static double |
306 |
interp2val(const PGINTERP *pgint, double px, double py) |
307 |
308 |
#define NSMP 12 |
309 |
float wt[NSMP]; |
310 |
int si[NSMP]; |
311 |
int n = interp2_topsamp(wt, si, NSMP, pgint->ip2, px, py); |
312 |
double v = .0; |
313 |
314 |
while (n-- > 0) |
315 |
v += wt[n]*pgint->va[si[n]]; |
316 |
317 |
return(v); |
318 |
#undef NSMP |
319 |
320 |
321 |
static void |
322 |
free_interp(PGINTERP *pgint) |
323 |
324 |
interp2_free(pgint->ip2); |
325 |
326 |
free(pgint->va); |
327 |
pgint->va = NULL; |
328 |
329 |
330 |
/* Interpolate the given incident direction to an output file */ |
331 |
static int |
332 |
interp_xyz(const PGINPUT *inp0, int nf, const PGINTERP *int1, const PGINTERP *int2) |
333 |
334 |
int dtotal = 0; |
335 |
char outfname[256]; |
336 |
FILE *ofp; |
337 |
int i; |
338 |
339 |
if (nf <= 0) |
340 |
return(0); |
341 |
/* create output file & write header */ |
342 |
sprintf(outfname, "%s_t%03.0fp%03.0f.txt", basename, inp0->theta, inp0->phi); |
343 |
if ((ofp = fopen(outfname, "w")) == NULL) { |
344 |
fputs(outfname, stderr); |
345 |
fputs(": cannot open for writing\n", stderr); |
346 |
return(0); |
347 |
348 |
fprintf(ofp, "#data written using %s\n", progname); |
349 |
fprintf(ofp, "#incident_angle %g %g\n", inp0->theta, inp0->phi); |
350 |
fprintf(ofp, "#intheta %g\n", inp0->theta); |
351 |
fprintf(ofp, "#inphi %g\n", inp0->phi); |
352 |
fprintf(ofp, "#upphi %g\n", inp0->up_phi); |
353 |
fprintf(ofp, "#colorimetry: CIE-XYZ\n"); |
354 |
for (i = nf; i--; ) |
355 |
dtotal += inp0[i].ndata; |
356 |
if (dtotal > 0) |
357 |
fprintf(ofp, "#datapoints_in_file: %d\n", dtotal); |
358 |
fprintf(ofp, "#format: theta phi %s\n", inp0->isDSF ? "DSF" : "BSDF"); |
359 |
dtotal = 0; |
360 |
while (nf-- > 0) { /* load channel 1 file(s) */ |
361 |
FILE *ifp = fopen(inp0->fname, "r"); |
362 |
double theta, phi, val[3], sq[2]; |
363 |
364 |
if (ifp == NULL || fseek(ifp, inp0->dstart, SEEK_SET) < 0) { |
365 |
fputs(inp0->fname, stderr); |
366 |
367 |
return(0); |
368 |
369 |
#ifdef DEBUG |
370 |
fprintf(stderr, "Adding points from '%s' to '%s'\n", |
371 |
inp0->fname, outfname); |
372 |
#endif |
373 |
while (fscanf(ifp, "%lf %lf %lf", &theta, &phi, &val[0]) == 3) { |
374 |
375 |
val[1] = interp2val(int1, sq[0]*ANGRES, sq[1]*ANGRES); |
376 |
val[2] = interp2val(int2, sq[0]*ANGRES, sq[1]*ANGRES); |
377 |
fprintf(ofp, "%.3f %.3f", theta, phi); |
378 |
for (i = 0; i < 3; i++) |
379 |
fprintf(ofp, " %.4f", |
380 |
sens2xyz[i][0]*val[0] + |
381 |
sens2xyz[i][1]*val[1] + |
382 |
sens2xyz[i][2]*val[2]); |
383 |
fputc('\n', ofp); |
384 |
++dtotal; |
385 |
386 |
fclose(ifp); |
387 |
++inp0; /* advance to next input file */ |
388 |
389 |
#ifdef DEBUG |
390 |
fprintf(stderr, "Wrote %d values to '%s'\n", dtotal, outfname); |
391 |
#endif |
392 |
return(fclose(ofp) == 0); |
393 |
394 |
395 |
/* Do next incident direction and advance counters */ |
396 |
static int |
397 |
advance_incidence(PGINPUT *slist[3], int ndx[3]) |
398 |
399 |
const int i0 = ndx[0]; |
400 |
PGINTERP pgi1, pgi2; |
401 |
int c; |
402 |
/* match up directions */ |
403 |
while ((c = cmp_indir(slist[1]+ndx[1], slist[0]+ndx[0])) < 0) |
404 |
ndx[1]++; |
405 |
if (c) { |
406 |
fputs(slist[0][ndx[0]].fname, stderr); |
407 |
fputs(": warning - missing channel 2 at this incidence\n", stderr); |
408 |
do |
409 |
++ndx[0]; |
410 |
while (!cmp_indir(slist[0]+ndx[0], slist[0]+i0)); |
411 |
return(0); |
412 |
413 |
while ((c = cmp_indir(slist[2]+ndx[2], slist[0]+ndx[0])) < 0) |
414 |
ndx[2]++; |
415 |
if (c) { |
416 |
417 |
fputs(": warning - missing channel 3 at this incidence\n", stderr); |
418 |
do |
419 |
++ndx[0]; |
420 |
421 |
return(0); |
422 |
423 |
do /* advance first channel index */ |
424 |
++ndx[0]; |
425 |
426 |
427 |
if (run_subprocess()) /* fork here if multiprocessing */ |
428 |
return(1); |
429 |
/* interpolate channels 2 & 3 */ |
430 |
load_interp(&pgi1, slist[0][i0].igp, slist[1]+ndx[1]); |
431 |
load_interp(&pgi2, slist[0][i0].igp, slist[2]+ndx[2]); |
432 |
if (!interp_xyz(slist[0]+i0, ndx[0]-i0, &pgi1, &pgi2)) |
433 |
return(-1); |
434 |
end_subprocess(); |
435 |
free_interp(&pgi1); |
436 |
free_interp(&pgi2); |
437 |
return(1); |
438 |
439 |
440 |
/* Read in single-channel PAB-Opto BSDF files and output XYZ versions */ |
441 |
int |
442 |
main(int argc, char *argv[]) |
443 |
444 |
char *flist[MAX_INPUTS]; |
445 |
PGINPUT *slist[3]; |
446 |
int i, j; |
447 |
int ndx[3]; |
448 |
/* get options */ |
449 |
progname = argv[0]; |
450 |
for (i = 1; i < argc-3 && argv[i][0] == '-'; i++) |
451 |
switch (argv[i][1]) { |
452 |
case 'n': |
453 |
nprocs = atoi(argv[++i]); |
454 |
break; |
455 |
case 'm': |
456 |
if (i >= argc-(3+9)) |
457 |
goto userr; |
458 |
for (j = 0; j < 3; j++) { |
459 |
sens2xyz[j][0] = atof(argv[++i]); |
460 |
sens2xyz[j][1] = atof(argv[++i]); |
461 |
sens2xyz[j][2] = atof(argv[++i]); |
462 |
463 |
break; |
464 |
case 'o': |
465 |
basename = argv[++i]; |
466 |
break; |
467 |
default: |
468 |
goto userr; |
469 |
470 |
if (i > argc-3) |
471 |
goto userr; |
472 |
for (j = 0; j < 3; j++) { /* prep input channels */ |
473 |
int k, n; |
474 |
n = wordfile(flist, MAX_INPUTS, argv[i+j]); |
475 |
if (n <= 0) { |
476 |
fputs(argv[i+j], stderr); |
477 |
fputs(": cannot load input file names\n", stderr); |
478 |
return(1); |
479 |
480 |
slist[j] = (PGINPUT *)malloc(sizeof(PGINPUT)*(n+1)); |
481 |
if (slist[j] == NULL) { |
482 |
fputs(argv[0], stderr); |
483 |
fputs(": out of memory!\n", stderr); |
484 |
return(1); |
485 |
486 |
#ifdef DEBUG |
487 |
fprintf(stderr, "Checking %d files from '%s'\n", n, argv[i+j]); |
488 |
#endif |
489 |
for (k = 0; k < n; k++) |
490 |
if (!init_pabopto_inp(slist[j]+k, flist[k])) |
491 |
return(1); |
492 |
memset(slist[j]+n, 0, sizeof(PGINPUT)); |
493 |
/* sort by incident direction */ |
494 |
qsort(slist[j], n, sizeof(PGINPUT), cmp_indir); |
495 |
496 |
ndx[0]=ndx[1]=ndx[2]=0; /* compile measurements */ |
497 |
while (slist[0][ndx[0]].dstart) |
498 |
if (advance_incidence(slist, ndx) < 0) |
499 |
return(1); |
500 |
await_children(nchild); /* wait for all to finish */ |
501 |
return(0); |
502 |
userr: |
503 |
fputs("Usage: ", stderr); |
504 |
505 |
fputs(" [-m X1 X2 X3 Y1 Y2 Y3 Z1 Z2 Z3][-o basename][-n nprocs]", stderr); |
506 |
fputs(" s1files.txt s2files.txt s3files.txt\n", stderr); |
507 |
return(1); |
508 |
