root/radiance/ray/src/cv/pabopto2xml.c
Revision 2.20
Sat Oct 19 00:11:50 2013 UTC (10 years, 6 months ago) by greg
FILE REMOVED
Thu Oct 18 04:28:20 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.18: +179 -35 lines
Diff to previous 2.18
Added symmetry handling (still produces 0 output)
Wed Oct 17 19:01:47 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.17: +17 -17 lines
Diff to previous 2.17
Put upper limit on output resolution and other minor changes
Tue Oct 16 22:00:51 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.16: +19 -12 lines
Diff to previous 2.16
Fixed memory leak and termination issue
Sun Oct 14 22:31:20 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.15: +166 -49 lines
Diff to previous 2.15
Added multi-processing option
Sun Sep 23 16:45:20 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.14: +124 -69 lines
Diff to previous 2.14
Added checks for bad triangles in get_interp()
Sat Sep 22 23:10:24 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.13: +77 -48 lines
Diff to previous 2.13
Fixed most problems with Delaunay triangulation on sphere
Fri Sep 21 05:17:22 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.12: +159 -44 lines
Diff to previous 2.12
Numerous changes -- still debugging
Thu Sep 20 01:23:36 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.11: +176 -5 lines
Nearing completion -- needs prologue, epilogue and testing
Wed Sep 19 22:03:37 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.10: +126 -9 lines
Many additions, still untested
Tue Sep 18 02:50:13 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.9: +455 -53 lines
Further additions in preparation for actual interpolation
Thu Sep 6 00:07:43 2012 UTC (11 years, 8 months ago) by greg
Wed Sep 5 00:39:32 2012 UTC (11 years, 8 months ago) by greg
Changes since 2.7: +247 -5 lines
Added calculation of migration matrix
Sun Sep 2 15:33:15 2012 UTC (11 years, 8 months ago) by greg
Changes since 2.6: +21 -4 lines
Sun Aug 26 19:40:02 2012 UTC (11 years, 8 months ago) by greg
Changes since 2.5: +26 -19 lines
Changed to adaptive iteration based on convergence
Sat Aug 25 22:39:03 2012 UTC (11 years, 8 months ago) by greg
Changes since 2.4: +47 -47 lines
Switched from BSDF interpolation to DSF (BSDF*cos(theta_e)) interpolation
Sat Aug 25 02:53:06 2012 UTC (11 years, 8 months ago) by greg
Changes since 2.3: +28 -23 lines
Further improved initial estimate by blurring radii
Fri Aug 24 22:08:50 2012 UTC (11 years, 8 months ago) by greg
Changes since 2.2: +86 -76 lines
Added optimization for better fitting results
Fri Aug 24 20:55:28 2012 UTC (11 years, 8 months ago) by greg
Changes since 2.1: +64 -63 lines
Getting closer on initial estimate -- need to add optimization
Fri Aug 24 15:20:18 2012 UTC (11 years, 8 months ago) by greg
Introducing program for interpolating BSDF data
