| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: pabopto2xml.c,v 2.19 2012/10/18 04:28:20 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Convert PAB-Opto measurements to XML format using tensor tree representation
| 6 |
* Employs Bonneel et al. Earth Mover's Distance interpolant.
| 7 |
| 8 |
* G.Ward
| 9 |
| 10 |
| 11 |
#ifndef _WIN32
| 12 |
#include <unistd.h>
| 13 |
#include <sys/wait.h>
| 14 |
#include <sys/mman.h>
| 15 |
#endif
| 16 |
#define _USE_MATH_DEFINES
| 17 |
#include <stdio.h>
| 18 |
#include <stdlib.h>
| 19 |
#include <string.h>
| 20 |
#include <ctype.h>
| 21 |
#include <math.h>
| 22 |
#include "bsdf.h"
| 23 |
| 24 |
#define DEBUG 1
| 25 |
| 26 |
#ifndef GRIDRES
| 27 |
#define GRIDRES 200 /* grid resolution per side */
| 28 |
#endif
| 29 |
| 30 |
#define MAXSAMPORD 7 /* don't sample finer than this */
| 31 |
| 32 |
#define RSCA 2.7 /* radius scaling factor (empirical) */
| 33 |
| 34 |
/* convert to/from coded radians */
| 35 |
#define ANG2R(r) (int)((r)*((1<<16)/M_PI))
| 36 |
#define R2ANG(c) (((c)+.5)*(M_PI/(1<<16)))
| 37 |
| 38 |
typedef struct {
| 39 |
float vsum; /* DSF sum */
| 40 |
unsigned short nval; /* number of values in sum */
| 41 |
unsigned short crad; /* radius (coded angle) */
| 42 |
} GRIDVAL; /* grid value */
| 43 |
| 44 |
typedef struct {
| 45 |
float peak; /* lobe value at peak */
| 46 |
| 47 |
unsigned char gx, gy; /* grid position */
| 48 |
} RBFVAL; /* radial basis function value */
| 49 |
| 50 |
struct s_rbfnode; /* forward declaration of RBF struct */
| 51 |
| 52 |
typedef struct s_migration {
| 53 |
struct s_migration *next; /* next in global edge list */
| 54 |
struct s_rbfnode *rbfv[2]; /* from,to vertex */
| 55 |
struct s_migration *enxt[2]; /* next from,to sibling */
| 56 |
float mtx[1]; /* matrix (extends struct) */
| 57 |
} MIGRATION; /* migration link (winged edge structure) */
| 58 |
| 59 |
typedef struct s_rbfnode {
| 60 |
struct s_rbfnode *next; /* next in global RBF list */
| 61 |
MIGRATION *ejl; /* edge list for this vertex */
| 62 |
FVECT invec; /* incident vector direction */
| 63 |
double vtotal; /* volume for normalization */
| 64 |
int nrbf; /* number of RBFs */
| 65 |
RBFVAL rbfa[1]; /* RBF array (extends struct) */
| 66 |
} RBFNODE; /* RBF representation of DSF @ 1 incidence */
| 67 |
| 68 |
/* our loaded grid for this incident angle */
| 69 |
static double theta_in_deg, phi_in_deg;
| 70 |
static GRIDVAL dsf_grid[GRIDRES][GRIDRES];
| 71 |
| 72 |
/* all incident angles in-plane so far? */
| 73 |
static int single_plane_incident = -1;
| 74 |
| 75 |
/* represented incident quadrants */
| 76 |
#define INP_QUAD1 1 /* 0-90 degree quadrant */
| 77 |
#define INP_QUAD2 2 /* 90-180 degree quadrant */
| 78 |
#define INP_QUAD3 4 /* 180-270 degree quadrant */
| 79 |
#define INP_QUAD4 8 /* 270-360 degree quadrant */
| 80 |
| 81 |
static int inp_coverage = 0;
| 82 |
| 83 |
/* symmetry operations */
| 84 |
#define MIRROR_X 1 /* mirror(ed) x-coordinate */
| 85 |
#define MIRROR_Y 2 /* mirror(ed) y-coordinate */
| 86 |
| 87 |
/* input/output orientations */
| 88 |
static int input_orient = 0;
| 89 |
static int output_orient = 0;
| 90 |
| 91 |
/* processed incident DSF measurements */
| 92 |
static RBFNODE *dsf_list = NULL;
| 93 |
| 94 |
/* RBF-linking matrices (edges) */
| 95 |
static MIGRATION *mig_list = NULL;
| 96 |
| 97 |
/* migration edges drawn in raster fashion */
| 98 |
static MIGRATION *mig_grid[GRIDRES][GRIDRES];
| 99 |
| 100 |
#define mtx_nrows(m) ((m)->rbfv[0]->nrbf)
| 101 |
#define mtx_ncols(m) ((m)->rbfv[1]->nrbf)
| 102 |
#define mtx_ndx(m,i,j) ((i)*mtx_ncols(m) + (j))
| 103 |
#define is_src(rbf,m) ((rbf) == (m)->rbfv[0])
| 104 |
#define is_dest(rbf,m) ((rbf) == (m)->rbfv[1])
| 105 |
#define nextedge(rbf,m) (m)->enxt[is_dest(rbf,m)]
| 106 |
#define opp_rbf(rbf,m) (m)->rbfv[is_src(rbf,m)]
| 107 |
| 108 |
#define round(v) (int)((v) + .5 - ((v) < -.5))
| 109 |
| 110 |
char *progname;
| 111 |
| 112 |
/* percentage to cull (<0 to turn off) */
| 113 |
int pctcull = 90;
| 114 |
/* number of processes to run */
| 115 |
int nprocs = 1;
| 116 |
| 117 |
/* number of children (-1 in child) */
| 118 |
int nchild = 0;
| 119 |
| 120 |
/* sampling order (set by data density) */
| 121 |
int samp_order = 0;
| 122 |
| 123 |
/* get phi value in degrees, [0,360) range */
| 124 |
#define get_phi360(v) ((180./M_PI)*atan2((v)[1],(v)[0]) + 180.)
| 125 |
| 126 |
/* Apply symmetry to the given vector based on distribution */
| 127 |
static int
| 128 |
use_symmetry(FVECT vec)
| 129 |
| 130 |
double phi = get_phi360(vec);
| 131 |
| 132 |
switch (inp_coverage) {
| 133 |
case INP_QUAD1|INP_QUAD2|INP_QUAD3|INP_QUAD4:
| 134 |
break;
| 135 |
case INP_QUAD1|INP_QUAD2:
| 136 |
if ((-FTINY > phi) | (phi > 180.+FTINY))
| 137 |
goto mir_y;
| 138 |
break;
| 139 |
case INP_QUAD2|INP_QUAD3:
| 140 |
if ((90.-FTINY > phi) | (phi > 270.+FTINY))
| 141 |
goto mir_x;
| 142 |
break;
| 143 |
case INP_QUAD3|INP_QUAD4:
| 144 |
if ((180.-FTINY > phi) | (phi > 360.+FTINY))
| 145 |
goto mir_y;
| 146 |
break;
| 147 |
case INP_QUAD4|INP_QUAD1:
| 148 |
if ((270.-FTINY > phi) & (phi > 90.+FTINY))
| 149 |
goto mir_x;
| 150 |
break;
| 151 |
case INP_QUAD1:
| 152 |
if ((-FTINY > phi) | (phi > 90.+FTINY))
| 153 |
switch ((int)(phi*(1./90.))) {
| 154 |
case 1: goto mir_x;
| 155 |
case 2: goto mir_xy;
| 156 |
case 3: goto mir_y;
| 157 |
| 158 |
break;
| 159 |
case INP_QUAD2:
| 160 |
if ((90.-FTINY > phi) | (phi > 180.+FTINY))
| 161 |
| 162 |
case 0: goto mir_x;
| 163 |
case 2: goto mir_y;
| 164 |
case 3: goto mir_xy;
| 165 |
| 166 |
break;
| 167 |
case INP_QUAD3:
| 168 |
if ((180.-FTINY > phi) | (phi > 270.+FTINY))
| 169 |
| 170 |
case 0: goto mir_xy;
| 171 |
case 1: goto mir_y;
| 172 |
case 3: goto mir_x;
| 173 |
| 174 |
break;
| 175 |
case INP_QUAD4:
| 176 |
if ((270.-FTINY > phi) | (phi > 360.+FTINY))
| 177 |
| 178 |
case 0: goto mir_y;
| 179 |
case 1: goto mir_xy;
| 180 |
case 2: goto mir_x;
| 181 |
| 182 |
break;
| 183 |
default:
| 184 |
fprintf(stderr, "%s: Illegal input coverage (%d)\n",
| 185 |
progname, inp_coverage);
| 186 |
exit(1);
| 187 |
| 188 |
return(0); /* in range */
| 189 |
mir_x:
| 190 |
vec[0] = -vec[0];
| 191 |
return(MIRROR_X);
| 192 |
mir_y:
| 193 |
vec[1] = -vec[1];
| 194 |
return(MIRROR_Y);
| 195 |
mir_xy:
| 196 |
vec[0] = -vec[0];
| 197 |
vec[1] = -vec[1];
| 198 |
return(MIRROR_X|MIRROR_Y);
| 199 |
| 200 |
| 201 |
/* Reverse symmetry based on what was done before */
| 202 |
static void
| 203 |
rev_symmetry(FVECT vec, int sym)
| 204 |
| 205 |
if (sym & MIRROR_X)
| 206 |
vec[0] = -vec[0];
| 207 |
if (sym & MIRROR_Y)
| 208 |
vec[1] = -vec[1];
| 209 |
| 210 |
| 211 |
/* Reverse symmetry for an RBF distribution */
| 212 |
static void
| 213 |
rev_rbf_symmetry(RBFNODE *rbf, int sym)
| 214 |
| 215 |
int n;
| 216 |
| 217 |
rev_symmetry(rbf->invec, sym);
| 218 |
if (sym & MIRROR_X)
| 219 |
for (n = rbf->nrbf; n-- > 0; )
| 220 |
rbf->rbfa[n].gx = GRIDRES-1 - rbf->rbfa[n].gx;
| 221 |
if (sym & MIRROR_Y)
| 222 |
| 223 |
rbf->rbfa[n].gy = GRIDRES-1 - rbf->rbfa[n].gy;
| 224 |
| 225 |
| 226 |
/* Compute volume associated with Gaussian lobe */
| 227 |
static double
| 228 |
rbf_volume(const RBFVAL *rbfp)
| 229 |
| 230 |
double rad = R2ANG(rbfp->crad);
| 231 |
| 232 |
return((2.*M_PI) * rbfp->peak * rad*rad);
| 233 |
| 234 |
| 235 |
/* Compute outgoing vector from grid position */
| 236 |
static void
| 237 |
ovec_from_pos(FVECT vec, int xpos, int ypos)
| 238 |
| 239 |
double uv[2];
| 240 |
double r2;
| 241 |
| 242 |
SDsquare2disk(uv, (1./GRIDRES)*(xpos+.5), (1./GRIDRES)*(ypos+.5));
| 243 |
/* uniform hemispherical projection */
| 244 |
r2 = uv[0]*uv[0] + uv[1]*uv[1];
| 245 |
vec[0] = vec[1] = sqrt(2. - r2);
| 246 |
vec[0] *= uv[0];
| 247 |
vec[1] *= uv[1];
| 248 |
vec[2] = output_orient*(1. - r2);
| 249 |
| 250 |
| 251 |
/* Compute grid position from normalized input/output vector */
| 252 |
static void
| 253 |
pos_from_vec(int pos[2], const FVECT vec)
| 254 |
| 255 |
double sq[2]; /* uniform hemispherical projection */
| 256 |
double norm = 1./sqrt(1. + fabs(vec[2]));
| 257 |
| 258 |
SDdisk2square(sq, vec[0]*norm, vec[1]*norm);
| 259 |
| 260 |
pos[0] = (int)(sq[0]*GRIDRES);
| 261 |
pos[1] = (int)(sq[1]*GRIDRES);
| 262 |
| 263 |
| 264 |
/* Evaluate RBF for DSF at the given normalized outgoing direction */
| 265 |
static double
| 266 |
eval_rbfrep(const RBFNODE *rp, const FVECT outvec)
| 267 |
| 268 |
double res = .0;
| 269 |
const RBFVAL *rbfp;
| 270 |
FVECT odir;
| 271 |
double sig2;
| 272 |
int n;
| 273 |
| 274 |
if (rp == NULL)
| 275 |
return(.0);
| 276 |
rbfp = rp->rbfa;
| 277 |
for (n = rp->nrbf; n--; rbfp++) {
| 278 |
ovec_from_pos(odir, rbfp->gx, rbfp->gy);
| 279 |
sig2 = R2ANG(rbfp->crad);
| 280 |
sig2 = (DOT(odir,outvec) - 1.) / (sig2*sig2);
| 281 |
if (sig2 > -19.)
| 282 |
res += rbfp->peak * exp(sig2);
| 283 |
| 284 |
return(res);
| 285 |
| 286 |
| 287 |
/* Insert a new directional scattering function in our global list */
| 288 |
static void
| 289 |
insert_dsf(RBFNODE *newrbf)
| 290 |
| 291 |
RBFNODE *rbf, *rbf_last;
| 292 |
/* check for redundant meas. */
| 293 |
for (rbf = dsf_list; rbf != NULL; rbf = rbf->next)
| 294 |
if (DOT(rbf->invec, newrbf->invec) >= 1.-FTINY) {
| 295 |
fprintf(stderr,
| 296 |
"%s: Duplicate incident measurement (ignored)\n",
| 297 |
progname);
| 298 |
free(newrbf);
| 299 |
return;
| 300 |
| 301 |
/* keep in ascending theta order */
| 302 |
for (rbf_last = NULL, rbf = dsf_list;
| 303 |
single_plane_incident & (rbf != NULL);
| 304 |
rbf_last = rbf, rbf = rbf->next)
| 305 |
if (input_orient*rbf->invec[2] < input_orient*newrbf->invec[2])
| 306 |
break;
| 307 |
if (rbf_last == NULL) {
| 308 |
newrbf->next = dsf_list;
| 309 |
dsf_list = newrbf;
| 310 |
return;
| 311 |
| 312 |
newrbf->next = rbf;
| 313 |
rbf_last->next = newrbf;
| 314 |
| 315 |
| 316 |
/* Count up filled nodes and build RBF representation from current grid */
| 317 |
static RBFNODE *
| 318 |
make_rbfrep(void)
| 319 |
| 320 |
int niter = 16;
| 321 |
int minrad = ANG2R(pow(2., 1.-samp_order));
| 322 |
double lastVar, thisVar = 100.;
| 323 |
int nn;
| 324 |
RBFNODE *newnode;
| 325 |
int i, j;
| 326 |
| 327 |
nn = 0; /* count selected bins */
| 328 |
for (i = 0; i < GRIDRES; i++)
| 329 |
for (j = 0; j < GRIDRES; j++)
| 330 |
nn += dsf_grid[i][j].nval;
| 331 |
/* allocate RBF array */
| 332 |
newnode = (RBFNODE *)malloc(sizeof(RBFNODE) + sizeof(RBFVAL)*(nn-1));
| 333 |
if (newnode == NULL) {
| 334 |
fprintf(stderr, "%s: Out of memory in make_rbfrep()\n", progname);
| 335 |
exit(1);
| 336 |
| 337 |
newnode->next = NULL;
| 338 |
newnode->ejl = NULL;
| 339 |
newnode->invec[2] = sin(M_PI/180.*theta_in_deg);
| 340 |
newnode->invec[0] = cos(M_PI/180.*phi_in_deg)*newnode->invec[2];
| 341 |
newnode->invec[1] = sin(M_PI/180.*phi_in_deg)*newnode->invec[2];
| 342 |
newnode->invec[2] = input_orient*sqrt(1. - newnode->invec[2]*newnode->invec[2]);
| 343 |
newnode->vtotal = 0;
| 344 |
newnode->nrbf = nn;
| 345 |
nn = 0; /* fill RBF array */
| 346 |
| 347 |
| 348 |
if (dsf_grid[i][j].nval) {
| 349 |
newnode->rbfa[nn].peak = dsf_grid[i][j].vsum;
| 350 |
newnode->rbfa[nn].crad = RSCA*dsf_grid[i][j].crad + .5;
| 351 |
newnode->rbfa[nn].gx = i;
| 352 |
newnode->rbfa[nn].gy = j;
| 353 |
if (newnode->rbfa[nn].crad < minrad)
| 354 |
minrad = newnode->rbfa[nn].crad;
| 355 |
++nn;
| 356 |
| 357 |
/* iterate to improve interpolation accuracy */
| 358 |
do {
| 359 |
double dsum = 0, dsum2 = 0;
| 360 |
nn = 0;
| 361 |
| 362 |
| 363 |
| 364 |
FVECT odir;
| 365 |
double corr;
| 366 |
ovec_from_pos(odir, i, j);
| 367 |
newnode->rbfa[nn++].peak *= corr =
| 368 |
dsf_grid[i][j].vsum /
| 369 |
eval_rbfrep(newnode, odir);
| 370 |
dsum += corr - 1.;
| 371 |
dsum2 += (corr-1.)*(corr-1.);
| 372 |
| 373 |
lastVar = thisVar;
| 374 |
thisVar = dsum2/(double)nn;
| 375 |
#ifdef DEBUG
| 376 |
fprintf(stderr, "Avg., RMS error: %.1f%% %.1f%%\n",
| 377 |
100.*dsum/(double)nn,
| 378 |
100.*sqrt(thisVar));
| 379 |
#endif
| 380 |
} while (--niter > 0 && lastVar-thisVar > 0.02*lastVar);
| 381 |
| 382 |
nn = 0; /* compute sum for normalization */
| 383 |
while (nn < newnode->nrbf)
| 384 |
newnode->vtotal += rbf_volume(&newnode->rbfa[nn++]);
| 385 |
| 386 |
insert_dsf(newnode);
| 387 |
/* adjust sampling resolution */
| 388 |
samp_order = log(2./R2ANG(minrad))/M_LN2 + .5;
| 389 |
if (samp_order > MAXSAMPORD)
| 390 |
samp_order = MAXSAMPORD;
| 391 |
| 392 |
return(newnode);
| 393 |
| 394 |
| 395 |
/* Load a set of measurements corresponding to a particular incident angle */
| 396 |
static int
| 397 |
load_pabopto_meas(const char *fname)
| 398 |
| 399 |
FILE *fp = fopen(fname, "r");
| 400 |
int inp_is_DSF = -1;
| 401 |
double new_phi, theta_out, phi_out, val;
| 402 |
char buf[2048];
| 403 |
int n, c;
| 404 |
| 405 |
if (fp == NULL) {
| 406 |
fputs(fname, stderr);
| 407 |
fputs(": cannot open\n", stderr);
| 408 |
return(0);
| 409 |
| 410 |
memset(dsf_grid, 0, sizeof(dsf_grid));
| 411 |
#ifdef DEBUG
| 412 |
fprintf(stderr, "Loading measurement file '%s'...\n", fname);
| 413 |
#endif
| 414 |
/* read header information */
| 415 |
while ((c = getc(fp)) == '#' || c == EOF) {
| 416 |
if (fgets(buf, sizeof(buf), fp) == NULL) {
| 417 |
| 418 |
fputs(": unexpected EOF\n", stderr);
| 419 |
fclose(fp);
| 420 |
return(0);
| 421 |
| 422 |
if (!strcmp(buf, "format: theta phi DSF\n")) {
| 423 |
inp_is_DSF = 1;
| 424 |
continue;
| 425 |
| 426 |
if (!strcmp(buf, "format: theta phi BSDF\n")) {
| 427 |
inp_is_DSF = 0;
| 428 |
continue;
| 429 |
| 430 |
if (sscanf(buf, "intheta %lf", &theta_in_deg) == 1)
| 431 |
continue;
| 432 |
if (sscanf(buf, "inphi %lf", &new_phi) == 1)
| 433 |
continue;
| 434 |
if (sscanf(buf, "incident_angle %lf %lf",
| 435 |
&theta_in_deg, &new_phi) == 2)
| 436 |
continue;
| 437 |
| 438 |
if (inp_is_DSF < 0) {
| 439 |
| 440 |
fputs(": unknown format\n", stderr);
| 441 |
fclose(fp);
| 442 |
return(0);
| 443 |
| 444 |
if (!input_orient) /* check input orientation */
| 445 |
input_orient = 1 - 2*(theta_in_deg > 90.);
| 446 |
else if (input_orient > 0 ^ theta_in_deg < 90.) {
| 447 |
fputs("Cannot handle input angles on both sides of surface\n",
| 448 |
stderr);
| 449 |
exit(1);
| 450 |
| 451 |
if (single_plane_incident > 0) /* check input coverage */
| 452 |
single_plane_incident = (round(new_phi) == round(phi_in_deg));
| 453 |
else if (single_plane_incident < 0)
| 454 |
single_plane_incident = 1;
| 455 |
phi_in_deg = new_phi;
| 456 |
new_phi += 360.*(new_phi < -FTINY);
| 457 |
if ((1. < new_phi) & (new_phi < 89.))
| 458 |
inp_coverage |= INP_QUAD1;
| 459 |
else if ((91. < new_phi) & (new_phi < 179.))
| 460 |
inp_coverage |= INP_QUAD2;
| 461 |
else if ((181. < new_phi) & (new_phi < 269.))
| 462 |
inp_coverage |= INP_QUAD3;
| 463 |
else if ((271. < new_phi) & (new_phi < 359.))
| 464 |
inp_coverage |= INP_QUAD4;
| 465 |
ungetc(c, fp); /* read actual data */
| 466 |
while (fscanf(fp, "%lf %lf %lf\n", &theta_out, &phi_out, &val) == 3) {
| 467 |
FVECT ovec;
| 468 |
int pos[2];
| 469 |
| 470 |
if (!output_orient) /* check output orientation */
| 471 |
output_orient = 1 - 2*(theta_out > 90.);
| 472 |
else if (output_orient > 0 ^ theta_out < 90.) {
| 473 |
fputs("Cannot handle output angles on both sides of surface\n",
| 474 |
stderr);
| 475 |
exit(1);
| 476 |
| 477 |
ovec[2] = sin(M_PI/180.*theta_out);
| 478 |
ovec[0] = cos(M_PI/180.*phi_out) * ovec[2];
| 479 |
ovec[1] = sin(M_PI/180.*phi_out) * ovec[2];
| 480 |
ovec[2] = sqrt(1. - ovec[2]*ovec[2]);
| 481 |
| 482 |
if (!inp_is_DSF)
| 483 |
val *= ovec[2]; /* convert from BSDF to DSF */
| 484 |
| 485 |
pos_from_vec(pos, ovec);
| 486 |
| 487 |
dsf_grid[pos[0]][pos[1]].vsum += val;
| 488 |
dsf_grid[pos[0]][pos[1]].nval++;
| 489 |
| 490 |
n = 0;
| 491 |
while ((c = getc(fp)) != EOF)
| 492 |
n += !isspace(c);
| 493 |
if (n)
| 494 |
fprintf(stderr,
| 495 |
"%s: warning: %d unexpected characters past EOD\n",
| 496 |
fname, n);
| 497 |
fclose(fp);
| 498 |
return(1);
| 499 |
| 500 |
| 501 |
/* Compute radii for non-empty bins */
| 502 |
/* (distance to furthest empty bin for which non-empty bin is the closest) */
| 503 |
static void
| 504 |
compute_radii(void)
| 505 |
| 506 |
unsigned int fill_grid[GRIDRES][GRIDRES];
| 507 |
unsigned short fill_cnt[GRIDRES][GRIDRES];
| 508 |
FVECT ovec0, ovec1;
| 509 |
double ang2, lastang2;
| 510 |
int r, i, j, jn, ii, jj, inear, jnear;
| 511 |
| 512 |
r = GRIDRES/2; /* proceed in zig-zag */
| 513 |
| 514 |
for (jn = 0; jn < GRIDRES; jn++) {
| 515 |
j = (i&1) ? jn : GRIDRES-1-jn;
| 516 |
if (dsf_grid[i][j].nval) /* find empty grid pos. */
| 517 |
continue;
| 518 |
ovec_from_pos(ovec0, i, j);
| 519 |
inear = jnear = -1; /* find nearest non-empty */
| 520 |
lastang2 = M_PI*M_PI;
| 521 |
for (ii = i-r; ii <= i+r; ii++) {
| 522 |
if (ii < 0) continue;
| 523 |
if (ii >= GRIDRES) break;
| 524 |
for (jj = j-r; jj <= j+r; jj++) {
| 525 |
if (jj < 0) continue;
| 526 |
if (jj >= GRIDRES) break;
| 527 |
if (!dsf_grid[ii][jj].nval)
| 528 |
continue;
| 529 |
ovec_from_pos(ovec1, ii, jj);
| 530 |
ang2 = 2. - 2.*DOT(ovec0,ovec1);
| 531 |
if (ang2 >= lastang2)
| 532 |
continue;
| 533 |
lastang2 = ang2;
| 534 |
inear = ii; jnear = jj;
| 535 |
| 536 |
| 537 |
if (inear < 0) {
| 538 |
fprintf(stderr,
| 539 |
"%s: Could not find non-empty neighbor!\n",
| 540 |
progname);
| 541 |
exit(1);
| 542 |
| 543 |
ang2 = sqrt(lastang2);
| 544 |
r = ANG2R(ang2); /* record if > previous */
| 545 |
if (r > dsf_grid[inear][jnear].crad)
| 546 |
dsf_grid[inear][jnear].crad = r;
| 547 |
/* next search radius */
| 548 |
r = ang2*(2.*GRIDRES/M_PI) + 3;
| 549 |
| 550 |
/* blur radii over hemisphere */
| 551 |
memset(fill_grid, 0, sizeof(fill_grid));
| 552 |
memset(fill_cnt, 0, sizeof(fill_cnt));
| 553 |
| 554 |
for (j = 0; j < GRIDRES; j++) {
| 555 |
if (!dsf_grid[i][j].crad)
| 556 |
continue; /* missing distance */
| 557 |
r = R2ANG(dsf_grid[i][j].crad)*(2.*RSCA*GRIDRES/M_PI);
| 558 |
| 559 |
| 560 |
| 561 |
| 562 |
| 563 |
| 564 |
if ((ii-i)*(ii-i) + (jj-j)*(jj-j) > r*r)
| 565 |
continue;
| 566 |
fill_grid[ii][jj] += dsf_grid[i][j].crad;
| 567 |
fill_cnt[ii][jj]++;
| 568 |
| 569 |
| 570 |
| 571 |
/* copy back blurred radii */
| 572 |
| 573 |
| 574 |
if (fill_cnt[i][j])
| 575 |
dsf_grid[i][j].crad = fill_grid[i][j]/fill_cnt[i][j];
| 576 |
| 577 |
| 578 |
/* Cull points for more uniform distribution, leave all nval 0 or 1 */
| 579 |
static void
| 580 |
cull_values(void)
| 581 |
| 582 |
FVECT ovec0, ovec1;
| 583 |
double maxang, maxang2;
| 584 |
int i, j, ii, jj, r;
| 585 |
/* simple greedy algorithm */
| 586 |
| 587 |
| 588 |
if (!dsf_grid[i][j].nval)
| 589 |
continue;
| 590 |
| 591 |
continue; /* shouldn't happen */
| 592 |
| 593 |
maxang = 2.*R2ANG(dsf_grid[i][j].crad);
| 594 |
if (maxang > ovec0[2]) /* clamp near horizon */
| 595 |
maxang = ovec0[2];
| 596 |
r = maxang*(2.*GRIDRES/M_PI) + 1;
| 597 |
maxang2 = maxang*maxang;
| 598 |
| 599 |
| 600 |
| 601 |
| 602 |
| 603 |
| 604 |
| 605 |
continue;
| 606 |
if ((ii == i) & (jj == j))
| 607 |
continue; /* don't get self-absorbed */
| 608 |
| 609 |
if (2. - 2.*DOT(ovec0,ovec1) >= maxang2)
| 610 |
continue;
| 611 |
/* absorb sum */
| 612 |
dsf_grid[i][j].vsum += dsf_grid[ii][jj].vsum;
| 613 |
dsf_grid[i][j].nval += dsf_grid[ii][jj].nval;
| 614 |
/* keep value, though */
| 615 |
dsf_grid[ii][jj].vsum /= (float)dsf_grid[ii][jj].nval;
| 616 |
dsf_grid[ii][jj].nval = 0;
| 617 |
| 618 |
| 619 |
| 620 |
/* final averaging pass */
| 621 |
| 622 |
| 623 |
if (dsf_grid[i][j].nval > 1) {
| 624 |
dsf_grid[i][j].vsum /= (float)dsf_grid[i][j].nval;
| 625 |
dsf_grid[i][j].nval = 1;
| 626 |
| 627 |
| 628 |
| 629 |
/* Compute (and allocate) migration price matrix for optimization */
| 630 |
static float *
| 631 |
price_routes(const RBFNODE *from_rbf, const RBFNODE *to_rbf)
| 632 |
| 633 |
float *pmtx = (float *)malloc(sizeof(float) *
| 634 |
from_rbf->nrbf * to_rbf->nrbf);
| 635 |
FVECT *vto = (FVECT *)malloc(sizeof(FVECT) * to_rbf->nrbf);
| 636 |
int i, j;
| 637 |
| 638 |
if ((pmtx == NULL) | (vto == NULL)) {
| 639 |
fprintf(stderr, "%s: Out of memory in migration_costs()\n",
| 640 |
progname);
| 641 |
exit(1);
| 642 |
| 643 |
for (j = to_rbf->nrbf; j--; ) /* save repetitive ops. */
| 644 |
ovec_from_pos(vto[j], to_rbf->rbfa[j].gx, to_rbf->rbfa[j].gy);
| 645 |
| 646 |
for (i = from_rbf->nrbf; i--; ) {
| 647 |
const double from_ang = R2ANG(from_rbf->rbfa[i].crad);
| 648 |
FVECT vfrom;
| 649 |
ovec_from_pos(vfrom, from_rbf->rbfa[i].gx, from_rbf->rbfa[i].gy);
| 650 |
| 651 |
pmtx[i*to_rbf->nrbf + j] = acos(DOT(vfrom, vto[j])) +
| 652 |
fabs(R2ANG(to_rbf->rbfa[j].crad) - from_ang);
| 653 |
| 654 |
free(vto);
| 655 |
return(pmtx);
| 656 |
| 657 |
| 658 |
/* Comparison routine needed for sorting price row */
| 659 |
static const float *price_arr;
| 660 |
static int
| 661 |
msrt_cmp(const void *p1, const void *p2)
| 662 |
| 663 |
float c1 = price_arr[*(const int *)p1];
| 664 |
float c2 = price_arr[*(const int *)p2];
| 665 |
| 666 |
if (c1 > c2) return(1);
| 667 |
if (c1 < c2) return(-1);
| 668 |
return(0);
| 669 |
| 670 |
| 671 |
/* Compute minimum (optimistic) cost for moving the given source material */
| 672 |
static double
| 673 |
min_cost(double amt2move, const double *avail, const float *price, int n)
| 674 |
| 675 |
static int *price_sort = NULL;
| 676 |
static int n_alloc = 0;
| 677 |
double total_cost = 0;
| 678 |
int i;
| 679 |
| 680 |
if (amt2move <= FTINY) /* pre-emptive check */
| 681 |
return(0.);
| 682 |
if (n > n_alloc) { /* (re)allocate sort array */
| 683 |
if (n_alloc) free(price_sort);
| 684 |
price_sort = (int *)malloc(sizeof(int)*n);
| 685 |
if (price_sort == NULL) {
| 686 |
fprintf(stderr, "%s: Out of memory in min_cost()\n",
| 687 |
progname);
| 688 |
exit(1);
| 689 |
| 690 |
n_alloc = n;
| 691 |
| 692 |
for (i = n; i--; )
| 693 |
price_sort[i] = i;
| 694 |
price_arr = price;
| 695 |
qsort(price_sort, n, sizeof(int), &msrt_cmp);
| 696 |
/* move cheapest first */
| 697 |
for (i = 0; i < n && amt2move > FTINY; i++) {
| 698 |
int d = price_sort[i];
| 699 |
double amt = (amt2move < avail[d]) ? amt2move : avail[d];
| 700 |
| 701 |
total_cost += amt * price[d];
| 702 |
amt2move -= amt;
| 703 |
| 704 |
return(total_cost);
| 705 |
| 706 |
| 707 |
/* Take a step in migration by choosing optimal bucket to transfer */
| 708 |
static double
| 709 |
migration_step(MIGRATION *mig, double *src_rem, double *dst_rem, const float *pmtx)
| 710 |
| 711 |
const double maxamt = .1;
| 712 |
const double minamt = maxamt*.0001;
| 713 |
static double *src_cost = NULL;
| 714 |
| 715 |
struct {
| 716 |
int s, d; /* source and destination */
| 717 |
double price; /* price estimate per amount moved */
| 718 |
double amt; /* amount we can move */
| 719 |
} cur, best;
| 720 |
int i;
| 721 |
| 722 |
if (mtx_nrows(mig) > n_alloc) { /* allocate cost array */
| 723 |
if (n_alloc)
| 724 |
free(src_cost);
| 725 |
src_cost = (double *)malloc(sizeof(double)*mtx_nrows(mig));
| 726 |
if (src_cost == NULL) {
| 727 |
fprintf(stderr, "%s: Out of memory in migration_step()\n",
| 728 |
progname);
| 729 |
exit(1);
| 730 |
| 731 |
n_alloc = mtx_nrows(mig);
| 732 |
| 733 |
for (i = mtx_nrows(mig); i--; ) /* starting costs for diff. */
| 734 |
src_cost[i] = min_cost(src_rem[i], dst_rem,
| 735 |
pmtx+i*mtx_ncols(mig), mtx_ncols(mig));
| 736 |
| 737 |
/* find best source & dest. */
| 738 |
best.s = best.d = -1; best.price = FHUGE; best.amt = 0;
| 739 |
for (cur.s = mtx_nrows(mig); cur.s--; ) {
| 740 |
const float *price = pmtx + cur.s*mtx_ncols(mig);
| 741 |
double cost_others = 0;
| 742 |
if (src_rem[cur.s] < minamt)
| 743 |
continue;
| 744 |
cur.d = -1; /* examine cheapest dest. */
| 745 |
for (i = mtx_ncols(mig); i--; )
| 746 |
if (dst_rem[i] > minamt &&
| 747 |
(cur.d < 0 || price[i] < price[cur.d]))
| 748 |
cur.d = i;
| 749 |
if (cur.d < 0)
| 750 |
return(.0);
| 751 |
if ((cur.price = price[cur.d]) >= best.price)
| 752 |
continue; /* no point checking further */
| 753 |
cur.amt = (src_rem[cur.s] < dst_rem[cur.d]) ?
| 754 |
src_rem[cur.s] : dst_rem[cur.d];
| 755 |
if (cur.amt > maxamt) cur.amt = maxamt;
| 756 |
dst_rem[cur.d] -= cur.amt; /* add up differential costs */
| 757 |
| 758 |
if (i != cur.s)
| 759 |
cost_others += min_cost(src_rem[i], dst_rem,
| 760 |
price, mtx_ncols(mig))
| 761 |
- src_cost[i];
| 762 |
dst_rem[cur.d] += cur.amt; /* undo trial move */
| 763 |
cur.price += cost_others/cur.amt; /* adjust effective price */
| 764 |
if (cur.price < best.price) /* are we better than best? */
| 765 |
best = cur;
| 766 |
| 767 |
if ((best.s < 0) | (best.d < 0))
| 768 |
return(.0);
| 769 |
/* make the actual move */
| 770 |
mig->mtx[mtx_ndx(mig,best.s,best.d)] += best.amt;
| 771 |
src_rem[best.s] -= best.amt;
| 772 |
dst_rem[best.d] -= best.amt;
| 773 |
return(best.amt);
| 774 |
| 775 |
| 776 |
#ifdef DEBUG
| 777 |
static char *
| 778 |
thetaphi(const FVECT v)
| 779 |
| 780 |
static char buf[128];
| 781 |
double theta, phi;
| 782 |
| 783 |
theta = 180./M_PI*acos(v[2]);
| 784 |
phi = 180./M_PI*atan2(v[1],v[0]);
| 785 |
sprintf(buf, "(%.0f,%.0f)", theta, phi);
| 786 |
| 787 |
return(buf);
| 788 |
| 789 |
#endif
| 790 |
| 791 |
/* Create a new migration holder (sharing memory for multiprocessing) */
| 792 |
static MIGRATION *
| 793 |
new_migration(RBFNODE *from_rbf, RBFNODE *to_rbf)
| 794 |
| 795 |
size_t memlen = sizeof(MIGRATION) +
| 796 |
sizeof(float)*(from_rbf->nrbf*to_rbf->nrbf - 1);
| 797 |
MIGRATION *newmig;
| 798 |
#ifdef _WIN32
| 799 |
newmig = (MIGRATION *)malloc(memlen);
| 800 |
#else
| 801 |
if (nprocs <= 1) { /* single process? */
| 802 |
| 803 |
} else { /* else need to share memory */
| 804 |
newmig = (MIGRATION *)mmap(NULL, memlen, PROT_READ|PROT_WRITE,
| 805 |
MAP_ANON|MAP_SHARED, -1, 0);
| 806 |
if ((void *)newmig == MAP_FAILED)
| 807 |
newmig = NULL;
| 808 |
| 809 |
#endif
| 810 |
if (newmig == NULL) {
| 811 |
fprintf(stderr, "%s: cannot allocate new migration\n", progname);
| 812 |
exit(1);
| 813 |
| 814 |
newmig->rbfv[0] = from_rbf;
| 815 |
newmig->rbfv[1] = to_rbf;
| 816 |
/* insert in edge lists */
| 817 |
newmig->enxt[0] = from_rbf->ejl;
| 818 |
from_rbf->ejl = newmig;
| 819 |
newmig->enxt[1] = to_rbf->ejl;
| 820 |
to_rbf->ejl = newmig;
| 821 |
newmig->next = mig_list; /* push onto global list */
| 822 |
return(mig_list = newmig);
| 823 |
| 824 |
| 825 |
#ifdef _WIN32
| 826 |
#define await_children(n) (void)(n)
| 827 |
#define run_subprocess() 0
| 828 |
#define end_subprocess() (void)0
| 829 |
#else
| 830 |
| 831 |
/* Wait for the specified number of child processes to complete */
| 832 |
static void
| 833 |
await_children(int n)
| 834 |
| 835 |
int exit_status = 0;
| 836 |
| 837 |
if (n > nchild)
| 838 |
n = nchild;
| 839 |
while (n-- > 0) {
| 840 |
int status;
| 841 |
if (wait(&status) < 0) {
| 842 |
fprintf(stderr, "%s: missing child(ren)!\n", progname);
| 843 |
nchild = 0;
| 844 |
break;
| 845 |
| 846 |
--nchild;
| 847 |
if (status) { /* something wrong */
| 848 |
if ((status = WEXITSTATUS(status)))
| 849 |
exit_status = status;
| 850 |
else
| 851 |
exit_status += !exit_status;
| 852 |
fprintf(stderr, "%s: subprocess died\n", progname);
| 853 |
n = nchild; /* wait for the rest */
| 854 |
| 855 |
| 856 |
if (exit_status)
| 857 |
exit(exit_status);
| 858 |
| 859 |
| 860 |
/* Start child process if multiprocessing selected */
| 861 |
static pid_t
| 862 |
run_subprocess(void)
| 863 |
| 864 |
int status;
| 865 |
pid_t pid;
| 866 |
| 867 |
if (nprocs <= 1) /* any children requested? */
| 868 |
return(0);
| 869 |
await_children(nchild + 1 - nprocs); /* free up child process */
| 870 |
if ((pid = fork())) {
| 871 |
if (pid < 0) {
| 872 |
fprintf(stderr, "%s: cannot fork subprocess\n",
| 873 |
progname);
| 874 |
exit(1);
| 875 |
| 876 |
++nchild; /* subprocess started */
| 877 |
return(pid);
| 878 |
| 879 |
nchild = -1;
| 880 |
return(0); /* put child to work */
| 881 |
| 882 |
| 883 |
/* If we are in subprocess, call exit */
| 884 |
#define end_subprocess() if (nchild < 0) _exit(0); else
| 885 |
| 886 |
#endif /* ! _WIN32 */
| 887 |
| 888 |
/* Compute and insert migration along directed edge (may fork child) */
| 889 |
static MIGRATION *
| 890 |
create_migration(RBFNODE *from_rbf, RBFNODE *to_rbf)
| 891 |
| 892 |
const double end_thresh = 0.1/(from_rbf->nrbf*to_rbf->nrbf);
| 893 |
const double check_thresh = 0.01;
| 894 |
const double rel_thresh = 5e-6;
| 895 |
float *pmtx;
| 896 |
MIGRATION *newmig;
| 897 |
double *src_rem, *dst_rem;
| 898 |
double total_rem = 1., move_amt;
| 899 |
int i;
| 900 |
/* check if exists already */
| 901 |
for (newmig = from_rbf->ejl; newmig != NULL;
| 902 |
newmig = nextedge(from_rbf,newmig))
| 903 |
if (newmig->rbfv[1] == to_rbf)
| 904 |
return(NULL);
| 905 |
/* else allocate */
| 906 |
newmig = new_migration(from_rbf, to_rbf);
| 907 |
if (run_subprocess())
| 908 |
return(newmig); /* child continues */
| 909 |
pmtx = price_routes(from_rbf, to_rbf);
| 910 |
src_rem = (double *)malloc(sizeof(double)*from_rbf->nrbf);
| 911 |
dst_rem = (double *)malloc(sizeof(double)*to_rbf->nrbf);
| 912 |
if ((src_rem == NULL) | (dst_rem == NULL)) {
| 913 |
fprintf(stderr, "%s: Out of memory in create_migration()\n",
| 914 |
progname);
| 915 |
exit(1);
| 916 |
| 917 |
#ifdef DEBUG
| 918 |
fprintf(stderr, "Building path from (theta,phi) %s ",
| 919 |
thetaphi(from_rbf->invec));
| 920 |
fprintf(stderr, "to %s", thetaphi(to_rbf->invec));
| 921 |
/* if (nchild) */ fputc('\n', stderr);
| 922 |
#endif
| 923 |
/* starting quantities */
| 924 |
memset(newmig->mtx, 0, sizeof(float)*from_rbf->nrbf*to_rbf->nrbf);
| 925 |
| 926 |
src_rem[i] = rbf_volume(&from_rbf->rbfa[i]) / from_rbf->vtotal;
| 927 |
for (i = to_rbf->nrbf; i--; )
| 928 |
dst_rem[i] = rbf_volume(&to_rbf->rbfa[i]) / to_rbf->vtotal;
| 929 |
do { /* move a bit at a time */
| 930 |
move_amt = migration_step(newmig, src_rem, dst_rem, pmtx);
| 931 |
total_rem -= move_amt;
| 932 |
#ifdef DEBUG
| 933 |
if (!nchild)
| 934 |
/* fputc('.', stderr); */
| 935 |
fprintf(stderr, "%.9f remaining...\r", total_rem);
| 936 |
#endif
| 937 |
} while (total_rem > end_thresh && (total_rem > check_thresh) |
| 938 |
(move_amt > rel_thresh*total_rem));
| 939 |
#ifdef DEBUG
| 940 |
if (!nchild) fputs("\ndone.\n", stderr);
| 941 |
else fprintf(stderr, "finished with %.9f remaining\n", total_rem);
| 942 |
#endif
| 943 |
for (i = from_rbf->nrbf; i--; ) { /* normalize final matrix */
| 944 |
float nf = rbf_volume(&from_rbf->rbfa[i]);
| 945 |
int j;
| 946 |
if (nf <= FTINY) continue;
| 947 |
nf = from_rbf->vtotal / nf;
| 948 |
| 949 |
newmig->mtx[mtx_ndx(newmig,i,j)] *= nf;
| 950 |
| 951 |
end_subprocess(); /* exit here if subprocess */
| 952 |
free(pmtx); /* free working arrays */
| 953 |
free(src_rem);
| 954 |
free(dst_rem);
| 955 |
return(newmig);
| 956 |
| 957 |
| 958 |
/* Get triangle surface orientation (unnormalized) */
| 959 |
static void
| 960 |
tri_orient(FVECT vres, const FVECT v1, const FVECT v2, const FVECT v3)
| 961 |
| 962 |
FVECT v2minus1, v3minus2;
| 963 |
| 964 |
VSUB(v2minus1, v2, v1);
| 965 |
VSUB(v3minus2, v3, v2);
| 966 |
VCROSS(vres, v2minus1, v3minus2);
| 967 |
| 968 |
| 969 |
/* Determine if vertex order is reversed (inward normal) */
| 970 |
static int
| 971 |
is_rev_tri(const FVECT v1, const FVECT v2, const FVECT v3)
| 972 |
| 973 |
FVECT tor;
| 974 |
| 975 |
tri_orient(tor, v1, v2, v3);
| 976 |
| 977 |
return(DOT(tor, v2) < 0.);
| 978 |
| 979 |
| 980 |
/* Find vertices completing triangles on either side of the given edge */
| 981 |
static int
| 982 |
get_triangles(RBFNODE *rbfv[2], const MIGRATION *mig)
| 983 |
| 984 |
const MIGRATION *ej, *ej2;
| 985 |
RBFNODE *tv;
| 986 |
| 987 |
rbfv[0] = rbfv[1] = NULL;
| 988 |
if (mig == NULL)
| 989 |
return(0);
| 990 |
for (ej = mig->rbfv[0]->ejl; ej != NULL;
| 991 |
ej = nextedge(mig->rbfv[0],ej)) {
| 992 |
if (ej == mig)
| 993 |
continue;
| 994 |
tv = opp_rbf(mig->rbfv[0],ej);
| 995 |
for (ej2 = tv->ejl; ej2 != NULL; ej2 = nextedge(tv,ej2))
| 996 |
if (opp_rbf(tv,ej2) == mig->rbfv[1]) {
| 997 |
rbfv[is_rev_tri(mig->rbfv[0]->invec,
| 998 |
mig->rbfv[1]->invec,
| 999 |
tv->invec)] = tv;
| 1000 |
break;
| 1001 |
| 1002 |
| 1003 |
return((rbfv[0] != NULL) + (rbfv[1] != NULL));
| 1004 |
| 1005 |
| 1006 |
/* Check if prospective vertex would create overlapping triangle */
| 1007 |
static int
| 1008 |
overlaps_tri(const RBFNODE *bv0, const RBFNODE *bv1, const RBFNODE *pv)
| 1009 |
| 1010 |
const MIGRATION *ej;
| 1011 |
RBFNODE *vother[2];
| 1012 |
int im_rev;
| 1013 |
/* find shared edge in mesh */
| 1014 |
for (ej = pv->ejl; ej != NULL; ej = nextedge(pv,ej)) {
| 1015 |
const RBFNODE *tv = opp_rbf(pv,ej);
| 1016 |
if (tv == bv0) {
| 1017 |
im_rev = is_rev_tri(ej->rbfv[0]->invec,
| 1018 |
ej->rbfv[1]->invec, bv1->invec);
| 1019 |
break;
| 1020 |
| 1021 |
if (tv == bv1) {
| 1022 |
| 1023 |
ej->rbfv[1]->invec, bv0->invec);
| 1024 |
break;
| 1025 |
| 1026 |
| 1027 |
if (!get_triangles(vother, ej)) /* triangle on same side? */
| 1028 |
return(0);
| 1029 |
return(vother[im_rev] != NULL);
| 1030 |
| 1031 |
| 1032 |
/* Find context hull vertex to complete triangle (oriented call) */
| 1033 |
static RBFNODE *
| 1034 |
find_chull_vert(const RBFNODE *rbf0, const RBFNODE *rbf1)
| 1035 |
| 1036 |
FVECT vmid, vejn, vp;
| 1037 |
RBFNODE *rbf, *rbfbest = NULL;
| 1038 |
double dprod, area2, bestarea2 = FHUGE, bestdprod = -.5;
| 1039 |
| 1040 |
VSUB(vejn, rbf1->invec, rbf0->invec);
| 1041 |
VADD(vmid, rbf0->invec, rbf1->invec);
| 1042 |
if (normalize(vejn) == 0 || normalize(vmid) == 0)
| 1043 |
return(NULL);
| 1044 |
/* XXX exhaustive search */
| 1045 |
/* Find triangle with minimum rotation from perpendicular */
| 1046 |
for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) {
| 1047 |
if ((rbf == rbf0) | (rbf == rbf1))
| 1048 |
continue;
| 1049 |
tri_orient(vp, rbf0->invec, rbf1->invec, rbf->invec);
| 1050 |
if (DOT(vp, vmid) <= FTINY)
| 1051 |
continue; /* wrong orientation */
| 1052 |
area2 = .25*DOT(vp,vp);
| 1053 |
VSUB(vp, rbf->invec, rbf0->invec);
| 1054 |
dprod = -DOT(vp, vejn);
| 1055 |
VSUM(vp, vp, vejn, dprod); /* above guarantees non-zero */
| 1056 |
dprod = DOT(vp, vmid) / VLEN(vp);
| 1057 |
if (dprod <= bestdprod + FTINY*(1 - 2*(area2 < bestarea2)))
| 1058 |
continue; /* found better already */
| 1059 |
if (overlaps_tri(rbf0, rbf1, rbf))
| 1060 |
continue; /* overlaps another triangle */
| 1061 |
rbfbest = rbf;
| 1062 |
bestdprod = dprod; /* new one to beat */
| 1063 |
bestarea2 = area2;
| 1064 |
| 1065 |
return(rbfbest);
| 1066 |
| 1067 |
| 1068 |
/* Create new migration edge and grow mesh recursively around it */
| 1069 |
static void
| 1070 |
mesh_from_edge(MIGRATION *edge)
| 1071 |
| 1072 |
MIGRATION *ej0, *ej1;
| 1073 |
RBFNODE *tvert[2];
| 1074 |
| 1075 |
if (edge == NULL)
| 1076 |
return;
| 1077 |
/* triangle on either side? */
| 1078 |
get_triangles(tvert, edge);
| 1079 |
if (tvert[0] == NULL) { /* grow mesh on right */
| 1080 |
tvert[0] = find_chull_vert(edge->rbfv[0], edge->rbfv[1]);
| 1081 |
if (tvert[0] != NULL) {
| 1082 |
if (tvert[0] > edge->rbfv[0])
| 1083 |
ej0 = create_migration(edge->rbfv[0], tvert[0]);
| 1084 |
else
| 1085 |
ej0 = create_migration(tvert[0], edge->rbfv[0]);
| 1086 |
if (tvert[0] > edge->rbfv[1])
| 1087 |
ej1 = create_migration(edge->rbfv[1], tvert[0]);
| 1088 |
else
| 1089 |
ej1 = create_migration(tvert[0], edge->rbfv[1]);
| 1090 |
mesh_from_edge(ej0);
| 1091 |
mesh_from_edge(ej1);
| 1092 |
| 1093 |
} else if (tvert[1] == NULL) { /* grow mesh on left */
| 1094 |
tvert[1] = find_chull_vert(edge->rbfv[1], edge->rbfv[0]);
| 1095 |
if (tvert[1] != NULL) {
| 1096 |
if (tvert[1] > edge->rbfv[0])
| 1097 |
ej0 = create_migration(edge->rbfv[0], tvert[1]);
| 1098 |
else
| 1099 |
ej0 = create_migration(tvert[1], edge->rbfv[0]);
| 1100 |
if (tvert[1] > edge->rbfv[1])
| 1101 |
ej1 = create_migration(edge->rbfv[1], tvert[1]);
| 1102 |
else
| 1103 |
ej1 = create_migration(tvert[1], edge->rbfv[1]);
| 1104 |
| 1105 |
| 1106 |
| 1107 |
| 1108 |
| 1109 |
| 1110 |
#ifdef DEBUG
| 1111 |
#include "random.h"
| 1112 |
#include "bmpfile.h"
| 1113 |
/* Hash pointer to byte value (must return 0 for NULL) */
| 1114 |
static int
| 1115 |
byte_hash(const void *p)
| 1116 |
| 1117 |
size_t h = (size_t)p;
| 1118 |
h ^= (size_t)p >> 8;
| 1119 |
h ^= (size_t)p >> 16;
| 1120 |
h ^= (size_t)p >> 24;
| 1121 |
return(h & 0xff);
| 1122 |
| 1123 |
/* Write out BMP image showing edges */
| 1124 |
static void
| 1125 |
write_edge_image(const char *fname)
| 1126 |
| 1127 |
BMPHeader *hdr = BMPmappedHeader(GRIDRES, GRIDRES, 0, 256);
| 1128 |
BMPWriter *wtr;
| 1129 |
int i, j;
| 1130 |
| 1131 |
fprintf(stderr, "Writing incident mesh drawing to '%s'\n", fname);
| 1132 |
hdr->compr = BI_RLE8;
| 1133 |
for (i = 256; --i; ) { /* assign random color map */
| 1134 |
hdr->palette[i].r = random() & 0xff;
| 1135 |
hdr->palette[i].g = random() & 0xff;
| 1136 |
hdr->palette[i].b = random() & 0xff;
| 1137 |
/* reject dark colors */
| 1138 |
i += (hdr->palette[i].r + hdr->palette[i].g +
| 1139 |
hdr->palette[i].b < 128);
| 1140 |
| 1141 |
hdr->palette[0].r = hdr->palette[0].g = hdr->palette[0].b = 0;
| 1142 |
/* open output */
| 1143 |
wtr = BMPopenOutputFile(fname, hdr);
| 1144 |
if (wtr == NULL) {
| 1145 |
free(hdr);
| 1146 |
return;
| 1147 |
| 1148 |
for (i = 0; i < GRIDRES; i++) { /* write scanlines */
| 1149 |
| 1150 |
wtr->scanline[j] = byte_hash(mig_grid[i][j]);
| 1151 |
if (BMPwriteScanline(wtr) != BIR_OK)
| 1152 |
break;
| 1153 |
| 1154 |
BMPcloseOutput(wtr); /* close & clean up */
| 1155 |
| 1156 |
#endif
| 1157 |
| 1158 |
/* Draw edge list into mig_grid array */
| 1159 |
static void
| 1160 |
draw_edges()
| 1161 |
| 1162 |
int nnull = 0, ntot = 0;
| 1163 |
MIGRATION *ej;
| 1164 |
int p0[2], p1[2];
| 1165 |
| 1166 |
/* memset(mig_grid, 0, sizeof(mig_grid)); */
| 1167 |
for (ej = mig_list; ej != NULL; ej = ej->next) {
| 1168 |
++ntot;
| 1169 |
pos_from_vec(p0, ej->rbfv[0]->invec);
| 1170 |
pos_from_vec(p1, ej->rbfv[1]->invec);
| 1171 |
if ((p0[0] == p1[0]) & (p0[1] == p1[1])) {
| 1172 |
++nnull;
| 1173 |
mig_grid[p0[0]][p0[1]] = ej;
| 1174 |
continue;
| 1175 |
| 1176 |
if (abs(p1[0]-p0[0]) > abs(p1[1]-p0[1])) {
| 1177 |
const int xstep = 2*(p1[0] > p0[0]) - 1;
| 1178 |
const double ystep = (double)((p1[1]-p0[1])*xstep) /
| 1179 |
(double)(p1[0]-p0[0]);
| 1180 |
int x;
| 1181 |
double y;
| 1182 |
for (x = p0[0], y = p0[1]+.5; x != p1[0];
| 1183 |
x += xstep, y += ystep)
| 1184 |
mig_grid[x][(int)y] = ej;
| 1185 |
| 1186 |
} else {
| 1187 |
const int ystep = 2*(p1[1] > p0[1]) - 1;
| 1188 |
const double xstep = (double)((p1[0]-p0[0])*ystep) /
| 1189 |
(double)(p1[1]-p0[1]);
| 1190 |
int y;
| 1191 |
double x;
| 1192 |
for (y = p0[1], x = p0[0]+.5; y != p1[1];
| 1193 |
y += ystep, x += xstep)
| 1194 |
mig_grid[(int)x][y] = ej;
| 1195 |
| 1196 |
| 1197 |
| 1198 |
if (nnull)
| 1199 |
fprintf(stderr, "Warning: %d of %d edges are null\n",
| 1200 |
nnull, ntot);
| 1201 |
#ifdef DEBUG
| 1202 |
write_edge_image("bsdf_edges.bmp");
| 1203 |
#endif
| 1204 |
| 1205 |
| 1206 |
/* Build our triangle mesh from recorded RBFs */
| 1207 |
static void
| 1208 |
build_mesh()
| 1209 |
| 1210 |
double best2 = M_PI*M_PI;
| 1211 |
RBFNODE *shrt_edj[2];
| 1212 |
RBFNODE *rbf0, *rbf1;
| 1213 |
/* check if isotropic */
| 1214 |
if (single_plane_incident) {
| 1215 |
for (rbf0 = dsf_list; rbf0 != NULL; rbf0 = rbf0->next)
| 1216 |
if (rbf0->next != NULL)
| 1217 |
create_migration(rbf0, rbf0->next);
| 1218 |
await_children(nchild);
| 1219 |
return;
| 1220 |
| 1221 |
shrt_edj[0] = shrt_edj[1] = NULL; /* start w/ shortest edge */
| 1222 |
| 1223 |
for (rbf1 = rbf0->next; rbf1 != NULL; rbf1 = rbf1->next) {
| 1224 |
double dist2 = 2. - 2.*DOT(rbf0->invec,rbf1->invec);
| 1225 |
if (dist2 < best2) {
| 1226 |
shrt_edj[0] = rbf0;
| 1227 |
shrt_edj[1] = rbf1;
| 1228 |
best2 = dist2;
| 1229 |
| 1230 |
| 1231 |
if (shrt_edj[0] == NULL) {
| 1232 |
fprintf(stderr, "%s: Cannot find shortest edge\n", progname);
| 1233 |
exit(1);
| 1234 |
| 1235 |
/* build mesh from this edge */
| 1236 |
if (shrt_edj[0] < shrt_edj[1])
| 1237 |
mesh_from_edge(create_migration(shrt_edj[0], shrt_edj[1]));
| 1238 |
else
| 1239 |
mesh_from_edge(create_migration(shrt_edj[1], shrt_edj[0]));
| 1240 |
/* draw edge list into grid */
| 1241 |
draw_edges();
| 1242 |
/* complete migrations */
| 1243 |
| 1244 |
| 1245 |
| 1246 |
/* Identify enclosing triangle for this position (flood fill raster check) */
| 1247 |
static int
| 1248 |
identify_tri(MIGRATION *miga[3], unsigned char vmap[GRIDRES][(GRIDRES+7)/8],
| 1249 |
int px, int py)
| 1250 |
| 1251 |
const int btest = 1<<(py&07);
| 1252 |
| 1253 |
if (vmap[px][py>>3] & btest) /* already visited here? */
| 1254 |
return(1);
| 1255 |
/* else mark it */
| 1256 |
vmap[px][py>>3] |= btest;
| 1257 |
| 1258 |
if (mig_grid[px][py] != NULL) { /* are we on an edge? */
| 1259 |
int i;
| 1260 |
for (i = 0; i < 3; i++) {
| 1261 |
if (miga[i] == mig_grid[px][py])
| 1262 |
return(1);
| 1263 |
if (miga[i] != NULL)
| 1264 |
continue;
| 1265 |
miga[i] = mig_grid[px][py];
| 1266 |
return(1);
| 1267 |
| 1268 |
return(0); /* outside triangle! */
| 1269 |
| 1270 |
/* check neighbors (flood) */
| 1271 |
if (px > 0 && !identify_tri(miga, vmap, px-1, py))
| 1272 |
return(0);
| 1273 |
if (px < GRIDRES-1 && !identify_tri(miga, vmap, px+1, py))
| 1274 |
return(0);
| 1275 |
if (py > 0 && !identify_tri(miga, vmap, px, py-1))
| 1276 |
return(0);
| 1277 |
if (py < GRIDRES-1 && !identify_tri(miga, vmap, px, py+1))
| 1278 |
return(0);
| 1279 |
return(1); /* this neighborhood done */
| 1280 |
| 1281 |
| 1282 |
/* Insert vertex in ordered list */
| 1283 |
static void
| 1284 |
insert_vert(RBFNODE **vlist, RBFNODE *v)
| 1285 |
| 1286 |
int i, j;
| 1287 |
| 1288 |
for (i = 0; vlist[i] != NULL; i++) {
| 1289 |
if (v == vlist[i])
| 1290 |
return;
| 1291 |
if (v < vlist[i])
| 1292 |
break;
| 1293 |
| 1294 |
for (j = i; vlist[j] != NULL; j++)
| 1295 |
| 1296 |
while (j > i) {
| 1297 |
vlist[j] = vlist[j-1];
| 1298 |
--j;
| 1299 |
| 1300 |
vlist[i] = v;
| 1301 |
| 1302 |
| 1303 |
/* Sort triangle edges in standard order */
| 1304 |
static int
| 1305 |
order_triangle(MIGRATION *miga[3])
| 1306 |
| 1307 |
RBFNODE *vert[7];
| 1308 |
MIGRATION *ord[3];
| 1309 |
int i;
| 1310 |
/* order vertices, first */
| 1311 |
memset(vert, 0, sizeof(vert));
| 1312 |
for (i = 3; i--; ) {
| 1313 |
if (miga[i] == NULL)
| 1314 |
return(0);
| 1315 |
insert_vert(vert, miga[i]->rbfv[0]);
| 1316 |
insert_vert(vert, miga[i]->rbfv[1]);
| 1317 |
| 1318 |
/* should be just 3 vertices */
| 1319 |
if ((vert[3] == NULL) | (vert[4] != NULL))
| 1320 |
return(0);
| 1321 |
/* identify edge 0 */
| 1322 |
for (i = 3; i--; )
| 1323 |
if (miga[i]->rbfv[0] == vert[0] &&
| 1324 |
miga[i]->rbfv[1] == vert[1]) {
| 1325 |
ord[0] = miga[i];
| 1326 |
break;
| 1327 |
| 1328 |
if (i < 0)
| 1329 |
return(0);
| 1330 |
/* identify edge 1 */
| 1331 |
for (i = 3; i--; )
| 1332 |
if (miga[i]->rbfv[0] == vert[1] &&
| 1333 |
miga[i]->rbfv[1] == vert[2]) {
| 1334 |
ord[1] = miga[i];
| 1335 |
break;
| 1336 |
| 1337 |
if (i < 0)
| 1338 |
return(0);
| 1339 |
/* identify edge 2 */
| 1340 |
for (i = 3; i--; )
| 1341 |
| 1342 |
| 1343 |
ord[2] = miga[i];
| 1344 |
break;
| 1345 |
| 1346 |
if (i < 0)
| 1347 |
return(0);
| 1348 |
/* reassign order */
| 1349 |
miga[0] = ord[0]; miga[1] = ord[1]; miga[2] = ord[2];
| 1350 |
return(1);
| 1351 |
| 1352 |
| 1353 |
/* Find edge(s) for interpolating the given vector, applying symmetry */
| 1354 |
static int
| 1355 |
get_interp(MIGRATION *miga[3], FVECT invec)
| 1356 |
| 1357 |
miga[0] = miga[1] = miga[2] = NULL;
| 1358 |
if (single_plane_incident) { /* isotropic BSDF? */
| 1359 |
RBFNODE *rbf; /* find edge we're on */
| 1360 |
| 1361 |
if (input_orient*rbf->invec[2] < input_orient*invec[2])
| 1362 |
break;
| 1363 |
if (rbf->next != NULL &&
| 1364 |
input_orient*rbf->next->invec[2] <
| 1365 |
input_orient*invec[2]) {
| 1366 |
for (miga[0] = rbf->ejl; miga[0] != NULL;
| 1367 |
miga[0] = nextedge(rbf,miga[0]))
| 1368 |
if (opp_rbf(rbf,miga[0]) == rbf->next)
| 1369 |
return(0);
| 1370 |
break;
| 1371 |
| 1372 |
| 1373 |
return(-1); /* outside range! */
| 1374 |
| 1375 |
{ /* else use triangle mesh */
| 1376 |
const int sym = use_symmetry(invec);
| 1377 |
unsigned char floodmap[GRIDRES][(GRIDRES+7)/8];
| 1378 |
int pstart[2];
| 1379 |
RBFNODE *vother;
| 1380 |
MIGRATION *ej;
| 1381 |
int i;
| 1382 |
| 1383 |
pos_from_vec(pstart, invec);
| 1384 |
memset(floodmap, 0, sizeof(floodmap));
| 1385 |
/* call flooding function */
| 1386 |
if (!identify_tri(miga, floodmap, pstart[0], pstart[1]))
| 1387 |
return(-1); /* outside mesh */
| 1388 |
if ((miga[0] == NULL) | (miga[2] == NULL))
| 1389 |
return(-1); /* should never happen */
| 1390 |
if (miga[1] == NULL)
| 1391 |
return(sym); /* on edge */
| 1392 |
/* verify triangle */
| 1393 |
if (!order_triangle(miga)) {
| 1394 |
#ifdef DEBUG
| 1395 |
fputs("Munged triangle in get_interp()\n", stderr);
| 1396 |
#endif
| 1397 |
vother = NULL; /* find triangle from edge */
| 1398 |
| 1399 |
RBFNODE *tpair[2];
| 1400 |
if (get_triangles(tpair, miga[i]) &&
| 1401 |
(vother = tpair[ is_rev_tri(
| 1402 |
miga[i]->rbfv[0]->invec,
| 1403 |
miga[i]->rbfv[1]->invec,
| 1404 |
invec) ]) != NULL)
| 1405 |
break;
| 1406 |
| 1407 |
if (vother == NULL) { /* couldn't find 3rd vertex */
| 1408 |
#ifdef DEBUG
| 1409 |
fputs("No triangle in get_interp()\n", stderr);
| 1410 |
#endif
| 1411 |
return(-1);
| 1412 |
| 1413 |
/* reassign other two edges */
| 1414 |
for (ej = vother->ejl; ej != NULL;
| 1415 |
ej = nextedge(vother,ej)) {
| 1416 |
RBFNODE *vorig = opp_rbf(vother,ej);
| 1417 |
if (vorig == miga[i]->rbfv[0])
| 1418 |
miga[(i+1)%3] = ej;
| 1419 |
else if (vorig == miga[i]->rbfv[1])
| 1420 |
miga[(i+2)%3] = ej;
| 1421 |
| 1422 |
| 1423 |
#ifdef DEBUG
| 1424 |
fputs("Bad triangle in get_interp()\n", stderr);
| 1425 |
#endif
| 1426 |
return(-1);
| 1427 |
| 1428 |
| 1429 |
return(sym); /* return in standard order */
| 1430 |
| 1431 |
| 1432 |
| 1433 |
/* Advect and allocate new RBF along edge */
| 1434 |
static RBFNODE *
| 1435 |
e_advect_rbf(const MIGRATION *mig, const FVECT invec)
| 1436 |
| 1437 |
RBFNODE *rbf;
| 1438 |
int n, i, j;
| 1439 |
double t, full_dist;
| 1440 |
/* get relative position */
| 1441 |
t = acos(DOT(invec, mig->rbfv[0]->invec));
| 1442 |
if (t < M_PI/GRIDRES) { /* near first DSF */
| 1443 |
n = sizeof(RBFNODE) + sizeof(RBFVAL)*(mig->rbfv[0]->nrbf-1);
| 1444 |
rbf = (RBFNODE *)malloc(n);
| 1445 |
if (rbf == NULL)
| 1446 |
goto memerr;
| 1447 |
memcpy(rbf, mig->rbfv[0], n); /* just duplicate */
| 1448 |
return(rbf);
| 1449 |
| 1450 |
full_dist = acos(DOT(mig->rbfv[0]->invec, mig->rbfv[1]->invec));
| 1451 |
if (t > full_dist-M_PI/GRIDRES) { /* near second DSF */
| 1452 |
n = sizeof(RBFNODE) + sizeof(RBFVAL)*(mig->rbfv[1]->nrbf-1);
| 1453 |
| 1454 |
if (rbf == NULL)
| 1455 |
goto memerr;
| 1456 |
memcpy(rbf, mig->rbfv[1], n); /* just duplicate */
| 1457 |
return(rbf);
| 1458 |
| 1459 |
t /= full_dist;
| 1460 |
n = 0; /* count migrating particles */
| 1461 |
for (i = 0; i < mtx_nrows(mig); i++)
| 1462 |
for (j = 0; j < mtx_ncols(mig); j++)
| 1463 |
n += (mig->mtx[mtx_ndx(mig,i,j)] > FTINY);
| 1464 |
#ifdef DEBUG
| 1465 |
fprintf(stderr, "Input RBFs have %d, %d nodes -> output has %d\n",
| 1466 |
mig->rbfv[0]->nrbf, mig->rbfv[1]->nrbf, n);
| 1467 |
#endif
| 1468 |
rbf = (RBFNODE *)malloc(sizeof(RBFNODE) + sizeof(RBFVAL)*(n-1));
| 1469 |
if (rbf == NULL)
| 1470 |
goto memerr;
| 1471 |
rbf->next = NULL; rbf->ejl = NULL;
| 1472 |
VCOPY(rbf->invec, invec);
| 1473 |
rbf->nrbf = n;
| 1474 |
rbf->vtotal = 1.-t + t*mig->rbfv[1]->vtotal/mig->rbfv[0]->vtotal;
| 1475 |
n = 0; /* advect RBF lobes */
| 1476 |
for (i = 0; i < mtx_nrows(mig); i++) {
| 1477 |
const RBFVAL *rbf0i = &mig->rbfv[0]->rbfa[i];
| 1478 |
const float peak0 = rbf0i->peak;
| 1479 |
const double rad0 = R2ANG(rbf0i->crad);
| 1480 |
FVECT v0;
| 1481 |
float mv;
| 1482 |
ovec_from_pos(v0, rbf0i->gx, rbf0i->gy);
| 1483 |
| 1484 |
if ((mv = mig->mtx[mtx_ndx(mig,i,j)]) > FTINY) {
| 1485 |
const RBFVAL *rbf1j = &mig->rbfv[1]->rbfa[j];
| 1486 |
double rad1 = R2ANG(rbf1j->crad);
| 1487 |
FVECT v;
| 1488 |
int pos[2];
| 1489 |
rbf->rbfa[n].peak = peak0 * mv * rbf->vtotal;
| 1490 |
rbf->rbfa[n].crad = ANG2R(sqrt(rad0*rad0*(1.-t) +
| 1491 |
rad1*rad1*t));
| 1492 |
ovec_from_pos(v, rbf1j->gx, rbf1j->gy);
| 1493 |
geodesic(v, v0, v, t, GEOD_REL);
| 1494 |
pos_from_vec(pos, v);
| 1495 |
rbf->rbfa[n].gx = pos[0];
| 1496 |
rbf->rbfa[n].gy = pos[1];
| 1497 |
++n;
| 1498 |
| 1499 |
| 1500 |
rbf->vtotal *= mig->rbfv[0]->vtotal; /* turn ratio into actual */
| 1501 |
return(rbf);
| 1502 |
memerr:
| 1503 |
fprintf(stderr, "%s: Out of memory in e_advect_rbf()\n", progname);
| 1504 |
exit(1);
| 1505 |
return(NULL); /* pro forma return */
| 1506 |
| 1507 |
| 1508 |
/* Partially advect between recorded incident angles and allocate new RBF */
| 1509 |
static RBFNODE *
| 1510 |
advect_rbf(const FVECT invec)
| 1511 |
| 1512 |
FVECT sivec;
| 1513 |
MIGRATION *miga[3];
| 1514 |
RBFNODE *rbf;
| 1515 |
int sym;
| 1516 |
float mbfact, mcfact;
| 1517 |
int n, i, j, k;
| 1518 |
FVECT v0, v1, v2;
| 1519 |
double s, t;
| 1520 |
| 1521 |
VCOPY(sivec, invec); /* find triangle/edge */
| 1522 |
sym = get_interp(miga, sivec);
| 1523 |
if (sym < 0) /* can't interpolate? */
| 1524 |
return(NULL);
| 1525 |
if (miga[1] == NULL) { /* advect along edge? */
| 1526 |
rbf = e_advect_rbf(miga[0], sivec);
| 1527 |
rev_rbf_symmetry(rbf, sym);
| 1528 |
return(rbf);
| 1529 |
| 1530 |
#ifdef DEBUG
| 1531 |
if (miga[0]->rbfv[0] != miga[2]->rbfv[0] |
| 1532 |
miga[0]->rbfv[1] != miga[1]->rbfv[0] |
| 1533 |
miga[1]->rbfv[1] != miga[2]->rbfv[1]) {
| 1534 |
fprintf(stderr, "%s: Triangle vertex screw-up!\n", progname);
| 1535 |
exit(1);
| 1536 |
| 1537 |
#endif
| 1538 |
/* figure out position */
| 1539 |
fcross(v0, miga[2]->rbfv[0]->invec, miga[2]->rbfv[1]->invec);
| 1540 |
normalize(v0);
| 1541 |
fcross(v2, miga[1]->rbfv[0]->invec, miga[1]->rbfv[1]->invec);
| 1542 |
normalize(v2);
| 1543 |
fcross(v1, sivec, miga[1]->rbfv[1]->invec);
| 1544 |
normalize(v1);
| 1545 |
s = acos(DOT(v0,v1)) / acos(DOT(v0,v2));
| 1546 |
geodesic(v1, miga[0]->rbfv[0]->invec, miga[0]->rbfv[1]->invec,
| 1547 |
s, GEOD_REL);
| 1548 |
t = acos(DOT(v1,sivec)) / acos(DOT(v1,miga[1]->rbfv[1]->invec));
| 1549 |
| 1550 |
for (i = 0; i < mtx_nrows(miga[0]); i++)
| 1551 |
for (j = 0; j < mtx_ncols(miga[0]); j++)
| 1552 |
for (k = (miga[0]->mtx[mtx_ndx(miga[0],i,j)] > FTINY) *
| 1553 |
mtx_ncols(miga[2]); k--; )
| 1554 |
n += (miga[2]->mtx[mtx_ndx(miga[2],i,k)] > FTINY &&
| 1555 |
miga[1]->mtx[mtx_ndx(miga[1],j,k)] > FTINY);
| 1556 |
#ifdef DEBUG
| 1557 |
fprintf(stderr, "Input RBFs have %d, %d, %d nodes -> output has %d\n",
| 1558 |
miga[0]->rbfv[0]->nrbf, miga[0]->rbfv[1]->nrbf,
| 1559 |
miga[2]->rbfv[1]->nrbf, n);
| 1560 |
#endif
| 1561 |
| 1562 |
if (rbf == NULL) {
| 1563 |
fprintf(stderr, "%s: Out of memory in advect_rbf()\n", progname);
| 1564 |
exit(1);
| 1565 |
| 1566 |
| 1567 |
VCOPY(rbf->invec, sivec);
| 1568 |
rbf->nrbf = n;
| 1569 |
n = 0; /* compute RBF lobes */
| 1570 |
mbfact = s * miga[0]->rbfv[1]->vtotal/miga[0]->rbfv[0]->vtotal *
| 1571 |
(1.-t + t*miga[1]->rbfv[1]->vtotal/miga[1]->rbfv[0]->vtotal);
| 1572 |
mcfact = (1.-s) *
| 1573 |
(1.-t + t*miga[2]->rbfv[1]->vtotal/miga[2]->rbfv[0]->vtotal);
| 1574 |
for (i = 0; i < mtx_nrows(miga[0]); i++) {
| 1575 |
const RBFVAL *rbf0i = &miga[0]->rbfv[0]->rbfa[i];
| 1576 |
const float w0i = rbf0i->peak;
| 1577 |
const double rad0i = R2ANG(rbf0i->crad);
| 1578 |
| 1579 |
for (j = 0; j < mtx_ncols(miga[0]); j++) {
| 1580 |
const float ma = miga[0]->mtx[mtx_ndx(miga[0],i,j)];
| 1581 |
const RBFVAL *rbf1j;
| 1582 |
double rad1j, srad2;
| 1583 |
if (ma <= FTINY)
| 1584 |
continue;
| 1585 |
rbf1j = &miga[0]->rbfv[1]->rbfa[j];
| 1586 |
rad1j = R2ANG(rbf1j->crad);
| 1587 |
srad2 = (1.-s)*(1.-t)*rad0i*rad0i + s*(1.-t)*rad1j*rad1j;
| 1588 |
ovec_from_pos(v1, rbf1j->gx, rbf1j->gy);
| 1589 |
geodesic(v1, v0, v1, s, GEOD_REL);
| 1590 |
for (k = 0; k < mtx_ncols(miga[2]); k++) {
| 1591 |
float mb = miga[1]->mtx[mtx_ndx(miga[1],j,k)];
| 1592 |
float mc = miga[2]->mtx[mtx_ndx(miga[2],i,k)];
| 1593 |
const RBFVAL *rbf2k;
| 1594 |
double rad2k;
| 1595 |
FVECT vout;
| 1596 |
int pos[2];
| 1597 |
if ((mb <= FTINY) | (mc <= FTINY))
| 1598 |
continue;
| 1599 |
rbf2k = &miga[2]->rbfv[1]->rbfa[k];
| 1600 |
rbf->rbfa[n].peak = w0i * ma * (mb*mbfact + mc*mcfact);
| 1601 |
rad2k = R2ANG(rbf2k->crad);
| 1602 |
rbf->rbfa[n].crad = ANG2R(sqrt(srad2 + t*rad2k*rad2k));
| 1603 |
ovec_from_pos(v2, rbf2k->gx, rbf2k->gy);
| 1604 |
geodesic(vout, v1, v2, t, GEOD_REL);
| 1605 |
pos_from_vec(pos, vout);
| 1606 |
| 1607 |
| 1608 |
++n;
| 1609 |
| 1610 |
| 1611 |
| 1612 |
rbf->vtotal = miga[0]->rbfv[0]->vtotal * (mbfact + mcfact);
| 1613 |
| 1614 |
return(rbf);
| 1615 |
| 1616 |
| 1617 |
/* Interpolate and output isotropic BSDF data */
| 1618 |
static void
| 1619 |
interp_isotropic()
| 1620 |
| 1621 |
const int sqres = 1<<samp_order;
| 1622 |
FILE *ofp = NULL;
| 1623 |
char cmd[128];
| 1624 |
int ix, ox, oy;
| 1625 |
FVECT ivec, ovec;
| 1626 |
double bsdf;
| 1627 |
#if DEBUG
| 1628 |
fprintf(stderr, "Writing isotropic order %d ", samp_order);
| 1629 |
if (pctcull >= 0) fprintf(stderr, "data with %d%% culling\n", pctcull);
| 1630 |
else fputs("raw data\n", stderr);
| 1631 |
#endif
| 1632 |
if (pctcull >= 0) { /* begin output */
| 1633 |
sprintf(cmd, "rttree_reduce -h -a -fd -r 3 -t %d -g %d",
| 1634 |
pctcull, samp_order);
| 1635 |
fflush(stdout);
| 1636 |
ofp = popen(cmd, "w");
| 1637 |
if (ofp == NULL) {
| 1638 |
fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n",
| 1639 |
progname);
| 1640 |
exit(1);
| 1641 |
| 1642 |
} else
| 1643 |
fputs("{\n", stdout);
| 1644 |
/* run through directions */
| 1645 |
for (ix = 0; ix < sqres/2; ix++) {
| 1646 |
RBFNODE *rbf;
| 1647 |
SDsquare2disk(ivec, (ix+.5)/sqres, .5);
| 1648 |
ivec[2] = input_orient *
| 1649 |
sqrt(1. - ivec[0]*ivec[0] - ivec[1]*ivec[1]);
| 1650 |
rbf = advect_rbf(ivec);
| 1651 |
for (ox = 0; ox < sqres; ox++)
| 1652 |
for (oy = 0; oy < sqres; oy++) {
| 1653 |
SDsquare2disk(ovec, (ox+.5)/sqres, (oy+.5)/sqres);
| 1654 |
ovec[2] = output_orient *
| 1655 |
sqrt(1. - ovec[0]*ovec[0] - ovec[1]*ovec[1]);
| 1656 |
bsdf = eval_rbfrep(rbf, ovec) / fabs(ovec[2]);
| 1657 |
if (pctcull >= 0)
| 1658 |
fwrite(&bsdf, sizeof(bsdf), 1, ofp);
| 1659 |
else
| 1660 |
printf("\t%.3e\n", bsdf);
| 1661 |
| 1662 |
free(rbf);
| 1663 |
| 1664 |
if (pctcull >= 0) { /* finish output */
| 1665 |
if (pclose(ofp)) {
| 1666 |
fprintf(stderr, "%s: error running '%s'\n",
| 1667 |
progname, cmd);
| 1668 |
exit(1);
| 1669 |
| 1670 |
} else {
| 1671 |
for (ix = sqres*sqres*sqres/2; ix--; )
| 1672 |
fputs("\t0\n", stdout);
| 1673 |
fputs("}\n", stdout);
| 1674 |
| 1675 |
| 1676 |
| 1677 |
/* Interpolate and output anisotropic BSDF data */
| 1678 |
static void
| 1679 |
interp_anisotropic()
| 1680 |
| 1681 |
| 1682 |
FILE *ofp = NULL;
| 1683 |
char cmd[128];
| 1684 |
int ix, iy, ox, oy;
| 1685 |
FVECT ivec, ovec;
| 1686 |
double bsdf;
| 1687 |
#if DEBUG
| 1688 |
fprintf(stderr, "Writing anisotropic order %d ", samp_order);
| 1689 |
| 1690 |
| 1691 |
#endif
| 1692 |
| 1693 |
sprintf(cmd, "rttree_reduce -h -a -fd -r 4 -t %d -g %d",
| 1694 |
| 1695 |
fflush(stdout);
| 1696 |
| 1697 |
if (ofp == NULL) {
| 1698 |
| 1699 |
progname);
| 1700 |
exit(1);
| 1701 |
| 1702 |
} else
| 1703 |
| 1704 |
| 1705 |
for (ix = 0; ix < sqres; ix++)
| 1706 |
for (iy = 0; iy < sqres; iy++) {
| 1707 |
RBFNODE *rbf;
| 1708 |
SDsquare2disk(ivec, (ix+.5)/sqres, (iy+.5)/sqres);
| 1709 |
| 1710 |
| 1711 |
| 1712 |
| 1713 |
| 1714 |
| 1715 |
| 1716 |
| 1717 |
| 1718 |
if (pctcull >= 0)
| 1719 |
| 1720 |
else
| 1721 |
| 1722 |
| 1723 |
free(rbf);
| 1724 |
| 1725 |
| 1726 |
if (pclose(ofp)) {
| 1727 |
| 1728 |
progname, cmd);
| 1729 |
exit(1);
| 1730 |
| 1731 |
} else
| 1732 |
| 1733 |
| 1734 |
| 1735 |
#if 1
| 1736 |
/* Read in BSDF files and interpolate as tensor tree representation */
| 1737 |
int
| 1738 |
main(int argc, char *argv[])
| 1739 |
| 1740 |
RBFNODE *rbf;
| 1741 |
double bsdf;
| 1742 |
int i;
| 1743 |
| 1744 |
progname = argv[0]; /* get options */
| 1745 |
while (argc > 2 && argv[1][0] == '-') {
| 1746 |
switch (argv[1][1]) {
| 1747 |
case 'n':
| 1748 |
nprocs = atoi(argv[2]);
| 1749 |
break;
| 1750 |
case 't':
| 1751 |
pctcull = atoi(argv[2]);
| 1752 |
break;
| 1753 |
default:
| 1754 |
goto userr;
| 1755 |
| 1756 |
argv += 2; argc -= 2;
| 1757 |
| 1758 |
if (argc < 3)
| 1759 |
goto userr;
| 1760 |
#ifdef _WIN32
| 1761 |
if (nprocs > 1) {
| 1762 |
fprintf(stderr, "%s: multiprocessing not supported\n",
| 1763 |
progname);
| 1764 |
return(1);
| 1765 |
| 1766 |
#endif
| 1767 |
for (i = 1; i < argc; i++) { /* compile measurements */
| 1768 |
if (!load_pabopto_meas(argv[i]))
| 1769 |
return(1);
| 1770 |
compute_radii();
| 1771 |
cull_values();
| 1772 |
make_rbfrep();
| 1773 |
| 1774 |
build_mesh(); /* create interpolation */
| 1775 |
/* xml_prologue(); /* start XML output */
| 1776 |
if (single_plane_incident) /* resample dist. */
| 1777 |
interp_isotropic();
| 1778 |
else
| 1779 |
interp_anisotropic();
| 1780 |
/* xml_epilogue(); /* finish XML output */
| 1781 |
return(0);
| 1782 |
userr:
| 1783 |
fprintf(stderr,
| 1784 |
"Usage: %s [-n nprocs][-t pctcull] meas1.dat meas2.dat .. > bsdf.xml\n",
| 1785 |
progname);
| 1786 |
return(1);
| 1787 |
| 1788 |
#else
| 1789 |
/* Test main produces a Radiance model from the given input file */
| 1790 |
int
| 1791 |
| 1792 |
| 1793 |
char buf[128];
| 1794 |
FILE *pfp;
| 1795 |
double bsdf;
| 1796 |
FVECT dir;
| 1797 |
int i, j, n;
| 1798 |
| 1799 |
if (argc != 2) {
| 1800 |
fprintf(stderr, "Usage: %s input.dat > output.rad\n", argv[0]);
| 1801 |
return(1);
| 1802 |
| 1803 |
if (!load_pabopto_meas(argv[1]))
| 1804 |
return(1);
| 1805 |
| 1806 |
compute_radii();
| 1807 |
cull_values();
| 1808 |
make_rbfrep();
| 1809 |
/* produce spheres at meas. */
| 1810 |
puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n");
| 1811 |
puts("void plastic pink\n0\n0\n5 .5 .05 .9 .04 .08\n");
| 1812 |
n = 0;
| 1813 |
| 1814 |
| 1815 |
if (dsf_grid[i][j].vsum > .0f) {
| 1816 |
ovec_from_pos(dir, i, j);
| 1817 |
bsdf = dsf_grid[i][j].vsum / dir[2];
| 1818 |
| 1819 |
printf("pink cone c%04d\n0\n0\n8\n", ++n);
| 1820 |
printf("\t%.6g %.6g %.6g\n",
| 1821 |
dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf);
| 1822 |
| 1823 |
dir[0]*(bsdf+.005), dir[1]*(bsdf+.005),
| 1824 |
dir[2]*(bsdf+.005));
| 1825 |
puts("\t.003\t0\n");
| 1826 |
} else {
| 1827 |
| 1828 |
printf("yellow sphere s%04d\n0\n0\n", ++n);
| 1829 |
printf("4 %.6g %.6g %.6g .0015\n\n",
| 1830 |
| 1831 |
| 1832 |
| 1833 |
/* output continuous surface */
| 1834 |
puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 .9\n");
| 1835 |
fflush(stdout);
| 1836 |
sprintf(buf, "gensurf tgreen bsdf - - - %d %d", GRIDRES-1, GRIDRES-1);
| 1837 |
pfp = popen(buf, "w");
| 1838 |
if (pfp == NULL) {
| 1839 |
fputs(buf, stderr);
| 1840 |
fputs(": cannot start command\n", stderr);
| 1841 |
return(1);
| 1842 |
| 1843 |
| 1844 |
| 1845 |
| 1846 |
bsdf = eval_rbfrep(dsf_list, dir) / dir[2];
| 1847 |
fprintf(pfp, "%.8e %.8e %.8e\n",
| 1848 |
| 1849 |
| 1850 |
return(pclose(pfp)==0 ? 0 : 1);
| 1851 |
| 1852 |
#endif
