1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: pabopto2xml.c,v 2.18 2012/10/17 19:01:47 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Convert PAB-Opto measurements to XML format using tensor tree representation |
6 |
* Employs Bonneel et al. Earth Mover's Distance interpolant. |
7 |
8 |
* G.Ward |
9 |
10 |
11 |
#ifndef _WIN32 |
12 |
#include <unistd.h> |
13 |
#include <sys/wait.h> |
14 |
#include <sys/mman.h> |
15 |
#endif |
16 |
#define _USE_MATH_DEFINES |
17 |
#include <stdio.h> |
18 |
#include <stdlib.h> |
19 |
#include <string.h> |
20 |
#include <ctype.h> |
21 |
#include <math.h> |
22 |
#include "bsdf.h" |
23 |
24 |
#define DEBUG 1 |
25 |
26 |
#ifndef GRIDRES |
27 |
#define GRIDRES 200 /* grid resolution per side */ |
28 |
#endif |
29 |
30 |
#define MAXSAMPORD 7 /* don't sample finer than this */ |
31 |
32 |
#define RSCA 2.7 /* radius scaling factor (empirical) */ |
33 |
34 |
/* convert to/from coded radians */ |
35 |
#define ANG2R(r) (int)((r)*((1<<16)/M_PI)) |
36 |
#define R2ANG(c) (((c)+.5)*(M_PI/(1<<16))) |
37 |
38 |
typedef struct { |
39 |
float vsum; /* DSF sum */ |
40 |
unsigned short nval; /* number of values in sum */ |
41 |
unsigned short crad; /* radius (coded angle) */ |
42 |
} GRIDVAL; /* grid value */ |
43 |
44 |
typedef struct { |
45 |
float peak; /* lobe value at peak */ |
46 |
47 |
unsigned char gx, gy; /* grid position */ |
48 |
} RBFVAL; /* radial basis function value */ |
49 |
50 |
struct s_rbfnode; /* forward declaration of RBF struct */ |
51 |
52 |
typedef struct s_migration { |
53 |
struct s_migration *next; /* next in global edge list */ |
54 |
struct s_rbfnode *rbfv[2]; /* from,to vertex */ |
55 |
struct s_migration *enxt[2]; /* next from,to sibling */ |
56 |
float mtx[1]; /* matrix (extends struct) */ |
57 |
} MIGRATION; /* migration link (winged edge structure) */ |
58 |
59 |
typedef struct s_rbfnode { |
60 |
struct s_rbfnode *next; /* next in global RBF list */ |
61 |
MIGRATION *ejl; /* edge list for this vertex */ |
62 |
FVECT invec; /* incident vector direction */ |
63 |
double vtotal; /* volume for normalization */ |
64 |
int nrbf; /* number of RBFs */ |
65 |
RBFVAL rbfa[1]; /* RBF array (extends struct) */ |
66 |
} RBFNODE; /* RBF representation of DSF @ 1 incidence */ |
67 |
68 |
/* our loaded grid for this incident angle */ |
69 |
static double theta_in_deg, phi_in_deg; |
70 |
static GRIDVAL dsf_grid[GRIDRES][GRIDRES]; |
71 |
72 |
/* all incident angles in-plane so far? */ |
73 |
static int single_plane_incident = -1; |
74 |
75 |
/* represented incident quadrants */ |
76 |
#define INP_QUAD1 1 /* 0-90 degree quadrant */ |
77 |
#define INP_QUAD2 2 /* 90-180 degree quadrant */ |
78 |
#define INP_QUAD3 4 /* 180-270 degree quadrant */ |
79 |
#define INP_QUAD4 8 /* 270-360 degree quadrant */ |
80 |
81 |
static int inp_coverage = 0; |
82 |
83 |
/* symmetry operations */ |
84 |
#define MIRROR_X 1 /* mirror(ed) x-coordinate */ |
85 |
#define MIRROR_Y 2 /* mirror(ed) y-coordinate */ |
86 |
87 |
/* input/output orientations */ |
88 |
static int input_orient = 0; |
89 |
static int output_orient = 0; |
90 |
91 |
/* processed incident DSF measurements */ |
92 |
static RBFNODE *dsf_list = NULL; |
93 |
94 |
/* RBF-linking matrices (edges) */ |
95 |
static MIGRATION *mig_list = NULL; |
96 |
97 |
/* migration edges drawn in raster fashion */ |
98 |
static MIGRATION *mig_grid[GRIDRES][GRIDRES]; |
99 |
100 |
#define mtx_nrows(m) ((m)->rbfv[0]->nrbf) |
101 |
#define mtx_ncols(m) ((m)->rbfv[1]->nrbf) |
102 |
#define mtx_ndx(m,i,j) ((i)*mtx_ncols(m) + (j)) |
103 |
#define is_src(rbf,m) ((rbf) == (m)->rbfv[0]) |
104 |
#define is_dest(rbf,m) ((rbf) == (m)->rbfv[1]) |
105 |
#define nextedge(rbf,m) (m)->enxt[is_dest(rbf,m)] |
106 |
#define opp_rbf(rbf,m) (m)->rbfv[is_src(rbf,m)] |
107 |
108 |
#define round(v) (int)((v) + .5 - ((v) < -.5)) |
109 |
110 |
char *progname; |
111 |
112 |
/* percentage to cull (<0 to turn off) */ |
113 |
int pctcull = 90; |
114 |
/* number of processes to run */ |
115 |
int nprocs = 1; |
116 |
117 |
/* number of children (-1 in child) */ |
118 |
int nchild = 0; |
119 |
120 |
/* sampling order (set by data density) */ |
121 |
int samp_order = 0; |
122 |
123 |
/* get phi value in degrees, [0,360) range */ |
124 |
#define get_phi360(v) ((180./M_PI)*atan2((v)[1],(v)[0]) + 180.) |
125 |
126 |
/* Apply symmetry to the given vector based on distribution */ |
127 |
static int |
128 |
use_symmetry(FVECT vec) |
129 |
130 |
double phi = get_phi360(vec); |
131 |
132 |
switch (inp_coverage) { |
133 |
case INP_QUAD1|INP_QUAD2|INP_QUAD3|INP_QUAD4: |
134 |
break; |
135 |
case INP_QUAD1|INP_QUAD2: |
136 |
if ((-FTINY > phi) | (phi > 180.+FTINY)) |
137 |
goto mir_y; |
138 |
break; |
139 |
case INP_QUAD2|INP_QUAD3: |
140 |
if ((90.-FTINY > phi) | (phi > 270.+FTINY)) |
141 |
goto mir_x; |
142 |
break; |
143 |
case INP_QUAD3|INP_QUAD4: |
144 |
if ((180.-FTINY > phi) | (phi > 360.+FTINY)) |
145 |
goto mir_y; |
146 |
break; |
147 |
case INP_QUAD4|INP_QUAD1: |
148 |
if ((270.-FTINY > phi) & (phi > 90.+FTINY)) |
149 |
goto mir_x; |
150 |
break; |
151 |
case INP_QUAD1: |
152 |
if ((-FTINY > phi) | (phi > 90.+FTINY)) |
153 |
switch ((int)(phi*(1./90.))) { |
154 |
case 1: goto mir_x; |
155 |
case 2: goto mir_xy; |
156 |
case 3: goto mir_y; |
157 |
158 |
break; |
159 |
case INP_QUAD2: |
160 |
if ((90.-FTINY > phi) | (phi > 180.+FTINY)) |
161 |
162 |
case 0: goto mir_x; |
163 |
case 2: goto mir_y; |
164 |
case 3: goto mir_xy; |
165 |
166 |
break; |
167 |
case INP_QUAD3: |
168 |
if ((180.-FTINY > phi) | (phi > 270.+FTINY)) |
169 |
170 |
case 0: goto mir_xy; |
171 |
case 1: goto mir_y; |
172 |
case 3: goto mir_x; |
173 |
174 |
break; |
175 |
case INP_QUAD4: |
176 |
if ((270.-FTINY > phi) | (phi > 360.+FTINY)) |
177 |
178 |
case 0: goto mir_y; |
179 |
case 1: goto mir_xy; |
180 |
case 2: goto mir_x; |
181 |
182 |
break; |
183 |
default: |
184 |
fprintf(stderr, "%s: Illegal input coverage (%d)\n", |
185 |
progname, inp_coverage); |
186 |
exit(1); |
187 |
188 |
return(0); /* in range */ |
189 |
mir_x: |
190 |
vec[0] = -vec[0]; |
191 |
return(MIRROR_X); |
192 |
mir_y: |
193 |
vec[1] = -vec[1]; |
194 |
return(MIRROR_Y); |
195 |
mir_xy: |
196 |
vec[0] = -vec[0]; |
197 |
vec[1] = -vec[1]; |
198 |
return(MIRROR_X|MIRROR_Y); |
199 |
200 |
201 |
/* Reverse symmetry based on what was done before */ |
202 |
static void |
203 |
rev_symmetry(FVECT vec, int sym) |
204 |
205 |
if (sym & MIRROR_X) |
206 |
vec[0] = -vec[0]; |
207 |
if (sym & MIRROR_Y) |
208 |
vec[1] = -vec[1]; |
209 |
210 |
211 |
/* Reverse symmetry for an RBF distribution */ |
212 |
static void |
213 |
rev_rbf_symmetry(RBFNODE *rbf, int sym) |
214 |
215 |
int n; |
216 |
217 |
rev_symmetry(rbf->invec, sym); |
218 |
219 |
for (n = rbf->nrbf; n-- > 0; ) |
220 |
rbf->rbfa[n].gx = GRIDRES-1 - rbf->rbfa[n].gx; |
221 |
222 |
223 |
rbf->rbfa[n].gy = GRIDRES-1 - rbf->rbfa[n].gy; |
224 |
225 |
226 |
/* Compute volume associated with Gaussian lobe */ |
227 |
static double |
228 |
rbf_volume(const RBFVAL *rbfp) |
229 |
230 |
double rad = R2ANG(rbfp->crad); |
231 |
232 |
return((2.*M_PI) * rbfp->peak * rad*rad); |
233 |
234 |
235 |
/* Compute outgoing vector from grid position */ |
236 |
static void |
237 |
ovec_from_pos(FVECT vec, int xpos, int ypos) |
238 |
239 |
double uv[2]; |
240 |
double r2; |
241 |
242 |
SDsquare2disk(uv, (1./GRIDRES)*(xpos+.5), (1./GRIDRES)*(ypos+.5)); |
243 |
/* uniform hemispherical projection */ |
244 |
r2 = uv[0]*uv[0] + uv[1]*uv[1]; |
245 |
vec[0] = vec[1] = sqrt(2. - r2); |
246 |
vec[0] *= uv[0]; |
247 |
vec[1] *= uv[1]; |
248 |
vec[2] = output_orient*(1. - r2); |
249 |
250 |
251 |
/* Compute grid position from normalized input/output vector */ |
252 |
static void |
253 |
pos_from_vec(int pos[2], const FVECT vec) |
254 |
255 |
double sq[2]; /* uniform hemispherical projection */ |
256 |
double norm = 1./sqrt(1. + fabs(vec[2])); |
257 |
258 |
SDdisk2square(sq, vec[0]*norm, vec[1]*norm); |
259 |
260 |
pos[0] = (int)(sq[0]*GRIDRES); |
261 |
pos[1] = (int)(sq[1]*GRIDRES); |
262 |
263 |
264 |
/* Evaluate RBF for DSF at the given normalized outgoing direction */ |
265 |
static double |
266 |
eval_rbfrep(const RBFNODE *rp, const FVECT outvec) |
267 |
268 |
double res = .0; |
269 |
const RBFVAL *rbfp; |
270 |
FVECT odir; |
271 |
double sig2; |
272 |
int n; |
273 |
274 |
if (rp == NULL) |
275 |
return(.0); |
276 |
rbfp = rp->rbfa; |
277 |
for (n = rp->nrbf; n--; rbfp++) { |
278 |
ovec_from_pos(odir, rbfp->gx, rbfp->gy); |
279 |
sig2 = R2ANG(rbfp->crad); |
280 |
sig2 = (DOT(odir,outvec) - 1.) / (sig2*sig2); |
281 |
if (sig2 > -19.) |
282 |
res += rbfp->peak * exp(sig2); |
283 |
284 |
return(res); |
285 |
286 |
287 |
/* Insert a new directional scattering function in our global list */ |
288 |
static void |
289 |
insert_dsf(RBFNODE *newrbf) |
290 |
291 |
RBFNODE *rbf, *rbf_last; |
292 |
/* check for redundant meas. */ |
293 |
for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) |
294 |
if (DOT(rbf->invec, newrbf->invec) >= 1.-FTINY) { |
295 |
fprintf(stderr, |
296 |
"%s: Duplicate incident measurement (ignored)\n", |
297 |
progname); |
298 |
free(newrbf); |
299 |
return; |
300 |
301 |
/* keep in ascending theta order */ |
302 |
for (rbf_last = NULL, rbf = dsf_list; |
303 |
single_plane_incident & (rbf != NULL); |
304 |
rbf_last = rbf, rbf = rbf->next) |
305 |
if (input_orient*rbf->invec[2] < input_orient*newrbf->invec[2]) |
306 |
break; |
307 |
if (rbf_last == NULL) { |
308 |
newrbf->next = dsf_list; |
309 |
dsf_list = newrbf; |
310 |
return; |
311 |
312 |
newrbf->next = rbf; |
313 |
rbf_last->next = newrbf; |
314 |
315 |
316 |
/* Count up filled nodes and build RBF representation from current grid */ |
317 |
static RBFNODE * |
318 |
make_rbfrep(void) |
319 |
320 |
int niter = 16; |
321 |
int minrad = ANG2R(pow(2., 1.-samp_order)); |
322 |
double lastVar, thisVar = 100.; |
323 |
int nn; |
324 |
RBFNODE *newnode; |
325 |
int i, j; |
326 |
327 |
nn = 0; /* count selected bins */ |
328 |
for (i = 0; i < GRIDRES; i++) |
329 |
for (j = 0; j < GRIDRES; j++) |
330 |
nn += dsf_grid[i][j].nval; |
331 |
/* allocate RBF array */ |
332 |
newnode = (RBFNODE *)malloc(sizeof(RBFNODE) + sizeof(RBFVAL)*(nn-1)); |
333 |
if (newnode == NULL) { |
334 |
fprintf(stderr, "%s: Out of memory in make_rbfrep()\n", progname); |
335 |
exit(1); |
336 |
337 |
newnode->next = NULL; |
338 |
newnode->ejl = NULL; |
339 |
newnode->invec[2] = sin(M_PI/180.*theta_in_deg); |
340 |
newnode->invec[0] = cos(M_PI/180.*phi_in_deg)*newnode->invec[2]; |
341 |
newnode->invec[1] = sin(M_PI/180.*phi_in_deg)*newnode->invec[2]; |
342 |
newnode->invec[2] = input_orient*sqrt(1. - newnode->invec[2]*newnode->invec[2]); |
343 |
newnode->vtotal = 0; |
344 |
newnode->nrbf = nn; |
345 |
nn = 0; /* fill RBF array */ |
346 |
347 |
348 |
if (dsf_grid[i][j].nval) { |
349 |
newnode->rbfa[nn].peak = dsf_grid[i][j].vsum; |
350 |
newnode->rbfa[nn].crad = RSCA*dsf_grid[i][j].crad + .5; |
351 |
newnode->rbfa[nn].gx = i; |
352 |
newnode->rbfa[nn].gy = j; |
353 |
if (newnode->rbfa[nn].crad < minrad) |
354 |
minrad = newnode->rbfa[nn].crad; |
355 |
++nn; |
356 |
357 |
/* iterate to improve interpolation accuracy */ |
358 |
do { |
359 |
double dsum = 0, dsum2 = 0; |
360 |
nn = 0; |
361 |
362 |
363 |
364 |
FVECT odir; |
365 |
double corr; |
366 |
ovec_from_pos(odir, i, j); |
367 |
newnode->rbfa[nn++].peak *= corr = |
368 |
dsf_grid[i][j].vsum / |
369 |
eval_rbfrep(newnode, odir); |
370 |
dsum += corr - 1.; |
371 |
dsum2 += (corr-1.)*(corr-1.); |
372 |
373 |
lastVar = thisVar; |
374 |
thisVar = dsum2/(double)nn; |
375 |
#ifdef DEBUG |
376 |
fprintf(stderr, "Avg., RMS error: %.1f%% %.1f%%\n", |
377 |
100.*dsum/(double)nn, |
378 |
100.*sqrt(thisVar)); |
379 |
#endif |
380 |
} while (--niter > 0 && lastVar-thisVar > 0.02*lastVar); |
381 |
382 |
nn = 0; /* compute sum for normalization */ |
383 |
while (nn < newnode->nrbf) |
384 |
newnode->vtotal += rbf_volume(&newnode->rbfa[nn++]); |
385 |
386 |
insert_dsf(newnode); |
387 |
/* adjust sampling resolution */ |
388 |
samp_order = log(2./R2ANG(minrad))/M_LN2 + .5; |
389 |
if (samp_order > MAXSAMPORD) |
390 |
samp_order = MAXSAMPORD; |
391 |
392 |
return(newnode); |
393 |
394 |
395 |
/* Load a set of measurements corresponding to a particular incident angle */ |
396 |
static int |
397 |
load_pabopto_meas(const char *fname) |
398 |
399 |
FILE *fp = fopen(fname, "r"); |
400 |
int inp_is_DSF = -1; |
401 |
double new_phi, theta_out, phi_out, val; |
402 |
char buf[2048]; |
403 |
int n, c; |
404 |
405 |
if (fp == NULL) { |
406 |
fputs(fname, stderr); |
407 |
fputs(": cannot open\n", stderr); |
408 |
return(0); |
409 |
410 |
memset(dsf_grid, 0, sizeof(dsf_grid)); |
411 |
#ifdef DEBUG |
412 |
fprintf(stderr, "Loading measurement file '%s'...\n", fname); |
413 |
#endif |
414 |
/* read header information */ |
415 |
while ((c = getc(fp)) == '#' || c == EOF) { |
416 |
if (fgets(buf, sizeof(buf), fp) == NULL) { |
417 |
418 |
fputs(": unexpected EOF\n", stderr); |
419 |
fclose(fp); |
420 |
return(0); |
421 |
422 |
if (!strcmp(buf, "format: theta phi DSF\n")) { |
423 |
inp_is_DSF = 1; |
424 |
continue; |
425 |
426 |
if (!strcmp(buf, "format: theta phi BSDF\n")) { |
427 |
inp_is_DSF = 0; |
428 |
continue; |
429 |
430 |
if (sscanf(buf, "intheta %lf", &theta_in_deg) == 1) |
431 |
continue; |
432 |
if (sscanf(buf, "inphi %lf", &new_phi) == 1) |
433 |
continue; |
434 |
if (sscanf(buf, "incident_angle %lf %lf", |
435 |
&theta_in_deg, &new_phi) == 2) |
436 |
continue; |
437 |
438 |
if (inp_is_DSF < 0) { |
439 |
440 |
fputs(": unknown format\n", stderr); |
441 |
fclose(fp); |
442 |
return(0); |
443 |
444 |
if (!input_orient) /* check input orientation */ |
445 |
input_orient = 1 - 2*(theta_in_deg > 90.); |
446 |
else if (input_orient > 0 ^ theta_in_deg < 90.) { |
447 |
fputs("Cannot handle input angles on both sides of surface\n", |
448 |
stderr); |
449 |
exit(1); |
450 |
451 |
if (single_plane_incident > 0) /* check input coverage */ |
452 |
single_plane_incident = (round(new_phi) == round(phi_in_deg)); |
453 |
else if (single_plane_incident < 0) |
454 |
single_plane_incident = 1; |
455 |
phi_in_deg = new_phi; |
456 |
new_phi += 360.*(new_phi < -FTINY); |
457 |
if ((1. < new_phi) & (new_phi < 89.)) |
458 |
inp_coverage |= INP_QUAD1; |
459 |
else if ((91. < new_phi) & (new_phi < 179.)) |
460 |
inp_coverage |= INP_QUAD2; |
461 |
else if ((181. < new_phi) & (new_phi < 269.)) |
462 |
inp_coverage |= INP_QUAD3; |
463 |
else if ((271. < new_phi) & (new_phi < 359.)) |
464 |
inp_coverage |= INP_QUAD4; |
465 |
ungetc(c, fp); /* read actual data */ |
466 |
while (fscanf(fp, "%lf %lf %lf\n", &theta_out, &phi_out, &val) == 3) { |
467 |
FVECT ovec; |
468 |
int pos[2]; |
469 |
470 |
if (!output_orient) /* check output orientation */ |
471 |
output_orient = 1 - 2*(theta_out > 90.); |
472 |
else if (output_orient > 0 ^ theta_out < 90.) { |
473 |
fputs("Cannot handle output angles on both sides of surface\n", |
474 |
stderr); |
475 |
exit(1); |
476 |
477 |
ovec[2] = sin(M_PI/180.*theta_out); |
478 |
ovec[0] = cos(M_PI/180.*phi_out) * ovec[2]; |
479 |
ovec[1] = sin(M_PI/180.*phi_out) * ovec[2]; |
480 |
ovec[2] = sqrt(1. - ovec[2]*ovec[2]); |
481 |
482 |
if (!inp_is_DSF) |
483 |
val *= ovec[2]; /* convert from BSDF to DSF */ |
484 |
485 |
pos_from_vec(pos, ovec); |
486 |
487 |
dsf_grid[pos[0]][pos[1]].vsum += val; |
488 |
dsf_grid[pos[0]][pos[1]].nval++; |
489 |
490 |
n = 0; |
491 |
while ((c = getc(fp)) != EOF) |
492 |
n += !isspace(c); |
493 |
if (n) |
494 |
fprintf(stderr, |
495 |
"%s: warning: %d unexpected characters past EOD\n", |
496 |
fname, n); |
497 |
fclose(fp); |
498 |
return(1); |
499 |
500 |
501 |
/* Compute radii for non-empty bins */ |
502 |
/* (distance to furthest empty bin for which non-empty bin is the closest) */ |
503 |
static void |
504 |
compute_radii(void) |
505 |
506 |
unsigned int fill_grid[GRIDRES][GRIDRES]; |
507 |
unsigned short fill_cnt[GRIDRES][GRIDRES]; |
508 |
FVECT ovec0, ovec1; |
509 |
double ang2, lastang2; |
510 |
int r, i, j, jn, ii, jj, inear, jnear; |
511 |
512 |
r = GRIDRES/2; /* proceed in zig-zag */ |
513 |
514 |
for (jn = 0; jn < GRIDRES; jn++) { |
515 |
j = (i&1) ? jn : GRIDRES-1-jn; |
516 |
if (dsf_grid[i][j].nval) /* find empty grid pos. */ |
517 |
continue; |
518 |
ovec_from_pos(ovec0, i, j); |
519 |
inear = jnear = -1; /* find nearest non-empty */ |
520 |
lastang2 = M_PI*M_PI; |
521 |
for (ii = i-r; ii <= i+r; ii++) { |
522 |
if (ii < 0) continue; |
523 |
if (ii >= GRIDRES) break; |
524 |
for (jj = j-r; jj <= j+r; jj++) { |
525 |
if (jj < 0) continue; |
526 |
if (jj >= GRIDRES) break; |
527 |
if (!dsf_grid[ii][jj].nval) |
528 |
continue; |
529 |
ovec_from_pos(ovec1, ii, jj); |
530 |
ang2 = 2. - 2.*DOT(ovec0,ovec1); |
531 |
if (ang2 >= lastang2) |
532 |
continue; |
533 |
lastang2 = ang2; |
534 |
inear = ii; jnear = jj; |
535 |
536 |
537 |
if (inear < 0) { |
538 |
fprintf(stderr, |
539 |
"%s: Could not find non-empty neighbor!\n", |
540 |
progname); |
541 |
exit(1); |
542 |
543 |
ang2 = sqrt(lastang2); |
544 |
r = ANG2R(ang2); /* record if > previous */ |
545 |
if (r > dsf_grid[inear][jnear].crad) |
546 |
dsf_grid[inear][jnear].crad = r; |
547 |
/* next search radius */ |
548 |
r = ang2*(2.*GRIDRES/M_PI) + 3; |
549 |
550 |
/* blur radii over hemisphere */ |
551 |
memset(fill_grid, 0, sizeof(fill_grid)); |
552 |
memset(fill_cnt, 0, sizeof(fill_cnt)); |
553 |
554 |
for (j = 0; j < GRIDRES; j++) { |
555 |
if (!dsf_grid[i][j].crad) |
556 |
continue; /* missing distance */ |
557 |
r = R2ANG(dsf_grid[i][j].crad)*(2.*RSCA*GRIDRES/M_PI); |
558 |
559 |
560 |
561 |
562 |
563 |
564 |
if ((ii-i)*(ii-i) + (jj-j)*(jj-j) > r*r) |
565 |
continue; |
566 |
fill_grid[ii][jj] += dsf_grid[i][j].crad; |
567 |
fill_cnt[ii][jj]++; |
568 |
569 |
570 |
571 |
/* copy back blurred radii */ |
572 |
573 |
574 |
if (fill_cnt[i][j]) |
575 |
dsf_grid[i][j].crad = fill_grid[i][j]/fill_cnt[i][j]; |
576 |
577 |
578 |
/* Cull points for more uniform distribution, leave all nval 0 or 1 */ |
579 |
static void |
580 |
cull_values(void) |
581 |
582 |
583 |
double maxang, maxang2; |
584 |
int i, j, ii, jj, r; |
585 |
/* simple greedy algorithm */ |
586 |
587 |
588 |
if (!dsf_grid[i][j].nval) |
589 |
continue; |
590 |
591 |
continue; /* shouldn't happen */ |
592 |
593 |
maxang = 2.*R2ANG(dsf_grid[i][j].crad); |
594 |
if (maxang > ovec0[2]) /* clamp near horizon */ |
595 |
maxang = ovec0[2]; |
596 |
r = maxang*(2.*GRIDRES/M_PI) + 1; |
597 |
maxang2 = maxang*maxang; |
598 |
599 |
600 |
601 |
602 |
603 |
604 |
605 |
continue; |
606 |
if ((ii == i) & (jj == j)) |
607 |
continue; /* don't get self-absorbed */ |
608 |
609 |
if (2. - 2.*DOT(ovec0,ovec1) >= maxang2) |
610 |
continue; |
611 |
/* absorb sum */ |
612 |
dsf_grid[i][j].vsum += dsf_grid[ii][jj].vsum; |
613 |
dsf_grid[i][j].nval += dsf_grid[ii][jj].nval; |
614 |
/* keep value, though */ |
615 |
dsf_grid[ii][jj].vsum /= (float)dsf_grid[ii][jj].nval; |
616 |
dsf_grid[ii][jj].nval = 0; |
617 |
618 |
619 |
620 |
/* final averaging pass */ |
621 |
622 |
623 |
if (dsf_grid[i][j].nval > 1) { |
624 |
dsf_grid[i][j].vsum /= (float)dsf_grid[i][j].nval; |
625 |
dsf_grid[i][j].nval = 1; |
626 |
627 |
628 |
629 |
/* Compute (and allocate) migration price matrix for optimization */ |
630 |
static float * |
631 |
price_routes(const RBFNODE *from_rbf, const RBFNODE *to_rbf) |
632 |
633 |
float *pmtx = (float *)malloc(sizeof(float) * |
634 |
from_rbf->nrbf * to_rbf->nrbf); |
635 |
FVECT *vto = (FVECT *)malloc(sizeof(FVECT) * to_rbf->nrbf); |
636 |
int i, j; |
637 |
638 |
if ((pmtx == NULL) | (vto == NULL)) { |
639 |
fprintf(stderr, "%s: Out of memory in migration_costs()\n", |
640 |
progname); |
641 |
exit(1); |
642 |
643 |
for (j = to_rbf->nrbf; j--; ) /* save repetitive ops. */ |
644 |
ovec_from_pos(vto[j], to_rbf->rbfa[j].gx, to_rbf->rbfa[j].gy); |
645 |
646 |
for (i = from_rbf->nrbf; i--; ) { |
647 |
const double from_ang = R2ANG(from_rbf->rbfa[i].crad); |
648 |
FVECT vfrom; |
649 |
ovec_from_pos(vfrom, from_rbf->rbfa[i].gx, from_rbf->rbfa[i].gy); |
650 |
for (j = to_rbf->nrbf; j--; ) |
651 |
pmtx[i*to_rbf->nrbf + j] = acos(DOT(vfrom, vto[j])) + |
652 |
fabs(R2ANG(to_rbf->rbfa[j].crad) - from_ang); |
653 |
654 |
free(vto); |
655 |
return(pmtx); |
656 |
657 |
658 |
/* Comparison routine needed for sorting price row */ |
659 |
static const float *price_arr; |
660 |
static int |
661 |
msrt_cmp(const void *p1, const void *p2) |
662 |
663 |
float c1 = price_arr[*(const int *)p1]; |
664 |
float c2 = price_arr[*(const int *)p2]; |
665 |
666 |
if (c1 > c2) return(1); |
667 |
if (c1 < c2) return(-1); |
668 |
return(0); |
669 |
670 |
671 |
/* Compute minimum (optimistic) cost for moving the given source material */ |
672 |
static double |
673 |
min_cost(double amt2move, const double *avail, const float *price, int n) |
674 |
675 |
static int *price_sort = NULL; |
676 |
static int n_alloc = 0; |
677 |
double total_cost = 0; |
678 |
int i; |
679 |
680 |
if (amt2move <= FTINY) /* pre-emptive check */ |
681 |
return(0.); |
682 |
if (n > n_alloc) { /* (re)allocate sort array */ |
683 |
if (n_alloc) free(price_sort); |
684 |
price_sort = (int *)malloc(sizeof(int)*n); |
685 |
if (price_sort == NULL) { |
686 |
fprintf(stderr, "%s: Out of memory in min_cost()\n", |
687 |
progname); |
688 |
exit(1); |
689 |
690 |
n_alloc = n; |
691 |
692 |
for (i = n; i--; ) |
693 |
price_sort[i] = i; |
694 |
price_arr = price; |
695 |
qsort(price_sort, n, sizeof(int), &msrt_cmp); |
696 |
/* move cheapest first */ |
697 |
for (i = 0; i < n && amt2move > FTINY; i++) { |
698 |
int d = price_sort[i]; |
699 |
double amt = (amt2move < avail[d]) ? amt2move : avail[d]; |
700 |
701 |
total_cost += amt * price[d]; |
702 |
amt2move -= amt; |
703 |
704 |
return(total_cost); |
705 |
706 |
707 |
/* Take a step in migration by choosing optimal bucket to transfer */ |
708 |
static double |
709 |
migration_step(MIGRATION *mig, double *src_rem, double *dst_rem, const float *pmtx) |
710 |
711 |
const double maxamt = .1; |
712 |
const double minamt = maxamt*.0001; |
713 |
static double *src_cost = NULL; |
714 |
715 |
struct { |
716 |
int s, d; /* source and destination */ |
717 |
double price; /* price estimate per amount moved */ |
718 |
double amt; /* amount we can move */ |
719 |
} cur, best; |
720 |
int i; |
721 |
722 |
if (mtx_nrows(mig) > n_alloc) { /* allocate cost array */ |
723 |
if (n_alloc) |
724 |
free(src_cost); |
725 |
src_cost = (double *)malloc(sizeof(double)*mtx_nrows(mig)); |
726 |
if (src_cost == NULL) { |
727 |
fprintf(stderr, "%s: Out of memory in migration_step()\n", |
728 |
progname); |
729 |
exit(1); |
730 |
731 |
n_alloc = mtx_nrows(mig); |
732 |
733 |
for (i = mtx_nrows(mig); i--; ) /* starting costs for diff. */ |
734 |
src_cost[i] = min_cost(src_rem[i], dst_rem, |
735 |
pmtx+i*mtx_ncols(mig), mtx_ncols(mig)); |
736 |
737 |
/* find best source & dest. */ |
738 |
best.s = best.d = -1; best.price = FHUGE; best.amt = 0; |
739 |
for (cur.s = mtx_nrows(mig); cur.s--; ) { |
740 |
const float *price = pmtx + cur.s*mtx_ncols(mig); |
741 |
double cost_others = 0; |
742 |
if (src_rem[cur.s] < minamt) |
743 |
continue; |
744 |
cur.d = -1; /* examine cheapest dest. */ |
745 |
for (i = mtx_ncols(mig); i--; ) |
746 |
if (dst_rem[i] > minamt && |
747 |
(cur.d < 0 || price[i] < price[cur.d])) |
748 |
cur.d = i; |
749 |
if (cur.d < 0) |
750 |
return(.0); |
751 |
if ((cur.price = price[cur.d]) >= best.price) |
752 |
continue; /* no point checking further */ |
753 |
cur.amt = (src_rem[cur.s] < dst_rem[cur.d]) ? |
754 |
src_rem[cur.s] : dst_rem[cur.d]; |
755 |
if (cur.amt > maxamt) cur.amt = maxamt; |
756 |
dst_rem[cur.d] -= cur.amt; /* add up differential costs */ |
757 |
for (i = mtx_nrows(mig); i--; ) |
758 |
if (i != cur.s) |
759 |
cost_others += min_cost(src_rem[i], dst_rem, |
760 |
price, mtx_ncols(mig)) |
761 |
- src_cost[i]; |
762 |
dst_rem[cur.d] += cur.amt; /* undo trial move */ |
763 |
cur.price += cost_others/cur.amt; /* adjust effective price */ |
764 |
if (cur.price < best.price) /* are we better than best? */ |
765 |
best = cur; |
766 |
767 |
if ((best.s < 0) | (best.d < 0)) |
768 |
return(.0); |
769 |
/* make the actual move */ |
770 |
mig->mtx[mtx_ndx(mig,best.s,best.d)] += best.amt; |
771 |
src_rem[best.s] -= best.amt; |
772 |
dst_rem[best.d] -= best.amt; |
773 |
return(best.amt); |
774 |
775 |
776 |
#ifdef DEBUG |
777 |
static char * |
778 |
thetaphi(const FVECT v) |
779 |
780 |
static char buf[128]; |
781 |
double theta, phi; |
782 |
783 |
theta = 180./M_PI*acos(v[2]); |
784 |
phi = 180./M_PI*atan2(v[1],v[0]); |
785 |
sprintf(buf, "(%.0f,%.0f)", theta, phi); |
786 |
787 |
return(buf); |
788 |
789 |
#endif |
790 |
791 |
/* Create a new migration holder (sharing memory for multiprocessing) */ |
792 |
static MIGRATION * |
793 |
new_migration(RBFNODE *from_rbf, RBFNODE *to_rbf) |
794 |
795 |
size_t memlen = sizeof(MIGRATION) + |
796 |
sizeof(float)*(from_rbf->nrbf*to_rbf->nrbf - 1); |
797 |
MIGRATION *newmig; |
798 |
#ifdef _WIN32 |
799 |
newmig = (MIGRATION *)malloc(memlen); |
800 |
#else |
801 |
if (nprocs <= 1) { /* single process? */ |
802 |
803 |
} else { /* else need to share memory */ |
804 |
newmig = (MIGRATION *)mmap(NULL, memlen, PROT_READ|PROT_WRITE, |
805 |
MAP_ANON|MAP_SHARED, -1, 0); |
806 |
if ((void *)newmig == MAP_FAILED) |
807 |
newmig = NULL; |
808 |
809 |
#endif |
810 |
if (newmig == NULL) { |
811 |
fprintf(stderr, "%s: cannot allocate new migration\n", progname); |
812 |
exit(1); |
813 |
814 |
newmig->rbfv[0] = from_rbf; |
815 |
newmig->rbfv[1] = to_rbf; |
816 |
/* insert in edge lists */ |
817 |
newmig->enxt[0] = from_rbf->ejl; |
818 |
from_rbf->ejl = newmig; |
819 |
newmig->enxt[1] = to_rbf->ejl; |
820 |
to_rbf->ejl = newmig; |
821 |
newmig->next = mig_list; /* push onto global list */ |
822 |
return(mig_list = newmig); |
823 |
824 |
825 |
#ifdef _WIN32 |
826 |
#define await_children(n) (void)(n) |
827 |
#define run_subprocess() 0 |
828 |
#define end_subprocess() (void)0 |
829 |
#else |
830 |
831 |
/* Wait for the specified number of child processes to complete */ |
832 |
static void |
833 |
await_children(int n) |
834 |
835 |
int exit_status = 0; |
836 |
837 |
if (n > nchild) |
838 |
n = nchild; |
839 |
while (n-- > 0) { |
840 |
int status; |
841 |
if (wait(&status) < 0) { |
842 |
fprintf(stderr, "%s: missing child(ren)!\n", progname); |
843 |
nchild = 0; |
844 |
break; |
845 |
846 |
--nchild; |
847 |
if (status) { /* something wrong */ |
848 |
if ((status = WEXITSTATUS(status))) |
849 |
exit_status = status; |
850 |
else |
851 |
exit_status += !exit_status; |
852 |
fprintf(stderr, "%s: subprocess died\n", progname); |
853 |
n = nchild; /* wait for the rest */ |
854 |
855 |
856 |
if (exit_status) |
857 |
exit(exit_status); |
858 |
859 |
860 |
/* Start child process if multiprocessing selected */ |
861 |
static pid_t |
862 |
run_subprocess(void) |
863 |
864 |
int status; |
865 |
pid_t pid; |
866 |
867 |
if (nprocs <= 1) /* any children requested? */ |
868 |
return(0); |
869 |
await_children(nchild + 1 - nprocs); /* free up child process */ |
870 |
if ((pid = fork())) { |
871 |
if (pid < 0) { |
872 |
fprintf(stderr, "%s: cannot fork subprocess\n", |
873 |
progname); |
874 |
exit(1); |
875 |
876 |
++nchild; /* subprocess started */ |
877 |
return(pid); |
878 |
879 |
nchild = -1; |
880 |
return(0); /* put child to work */ |
881 |
882 |
883 |
/* If we are in subprocess, call exit */ |
884 |
#define end_subprocess() if (nchild < 0) _exit(0); else |
885 |
886 |
#endif /* ! _WIN32 */ |
887 |
888 |
/* Compute and insert migration along directed edge (may fork child) */ |
889 |
890 |
create_migration(RBFNODE *from_rbf, RBFNODE *to_rbf) |
891 |
892 |
const double end_thresh = 0.1/(from_rbf->nrbf*to_rbf->nrbf); |
893 |
const double check_thresh = 0.01; |
894 |
const double rel_thresh = 5e-6; |
895 |
float *pmtx; |
896 |
897 |
double *src_rem, *dst_rem; |
898 |
double total_rem = 1., move_amt; |
899 |
int i; |
900 |
/* check if exists already */ |
901 |
for (newmig = from_rbf->ejl; newmig != NULL; |
902 |
newmig = nextedge(from_rbf,newmig)) |
903 |
if (newmig->rbfv[1] == to_rbf) |
904 |
return(NULL); |
905 |
/* else allocate */ |
906 |
newmig = new_migration(from_rbf, to_rbf); |
907 |
if (run_subprocess()) |
908 |
return(newmig); /* child continues */ |
909 |
pmtx = price_routes(from_rbf, to_rbf); |
910 |
src_rem = (double *)malloc(sizeof(double)*from_rbf->nrbf); |
911 |
dst_rem = (double *)malloc(sizeof(double)*to_rbf->nrbf); |
912 |
if ((src_rem == NULL) | (dst_rem == NULL)) { |
913 |
fprintf(stderr, "%s: Out of memory in create_migration()\n", |
914 |
progname); |
915 |
exit(1); |
916 |
917 |
#ifdef DEBUG |
918 |
fprintf(stderr, "Building path from (theta,phi) %s ", |
919 |
thetaphi(from_rbf->invec)); |
920 |
fprintf(stderr, "to %s", thetaphi(to_rbf->invec)); |
921 |
/* if (nchild) */ fputc('\n', stderr); |
922 |
#endif |
923 |
/* starting quantities */ |
924 |
memset(newmig->mtx, 0, sizeof(float)*from_rbf->nrbf*to_rbf->nrbf); |
925 |
for (i = from_rbf->nrbf; i--; ) |
926 |
src_rem[i] = rbf_volume(&from_rbf->rbfa[i]) / from_rbf->vtotal; |
927 |
for (i = to_rbf->nrbf; i--; ) |
928 |
dst_rem[i] = rbf_volume(&to_rbf->rbfa[i]) / to_rbf->vtotal; |
929 |
do { /* move a bit at a time */ |
930 |
move_amt = migration_step(newmig, src_rem, dst_rem, pmtx); |
931 |
total_rem -= move_amt; |
932 |
#ifdef DEBUG |
933 |
if (!nchild) |
934 |
/* fputc('.', stderr); */ |
935 |
fprintf(stderr, "%.9f remaining...\r", total_rem); |
936 |
#endif |
937 |
} while (total_rem > end_thresh && (total_rem > check_thresh) | |
938 |
(move_amt > rel_thresh*total_rem)); |
939 |
#ifdef DEBUG |
940 |
if (!nchild) fputs("\ndone.\n", stderr); |
941 |
else fprintf(stderr, "finished with %.9f remaining\n", total_rem); |
942 |
#endif |
943 |
for (i = from_rbf->nrbf; i--; ) { /* normalize final matrix */ |
944 |
float nf = rbf_volume(&from_rbf->rbfa[i]); |
945 |
int j; |
946 |
if (nf <= FTINY) continue; |
947 |
nf = from_rbf->vtotal / nf; |
948 |
949 |
newmig->mtx[mtx_ndx(newmig,i,j)] *= nf; |
950 |
951 |
end_subprocess(); /* exit here if subprocess */ |
952 |
free(pmtx); /* free working arrays */ |
953 |
free(src_rem); |
954 |
free(dst_rem); |
955 |
return(newmig); |
956 |
957 |
958 |
/* Get triangle surface orientation (unnormalized) */ |
959 |
static void |
960 |
tri_orient(FVECT vres, const FVECT v1, const FVECT v2, const FVECT v3) |
961 |
962 |
FVECT v2minus1, v3minus2; |
963 |
964 |
VSUB(v2minus1, v2, v1); |
965 |
VSUB(v3minus2, v3, v2); |
966 |
VCROSS(vres, v2minus1, v3minus2); |
967 |
968 |
969 |
/* Determine if vertex order is reversed (inward normal) */ |
970 |
static int |
971 |
is_rev_tri(const FVECT v1, const FVECT v2, const FVECT v3) |
972 |
973 |
FVECT tor; |
974 |
975 |
tri_orient(tor, v1, v2, v3); |
976 |
977 |
return(DOT(tor, v2) < 0.); |
978 |
979 |
980 |
/* Find vertices completing triangles on either side of the given edge */ |
981 |
static int |
982 |
get_triangles(RBFNODE *rbfv[2], const MIGRATION *mig) |
983 |
984 |
const MIGRATION *ej, *ej2; |
985 |
RBFNODE *tv; |
986 |
987 |
rbfv[0] = rbfv[1] = NULL; |
988 |
if (mig == NULL) |
989 |
return(0); |
990 |
for (ej = mig->rbfv[0]->ejl; ej != NULL; |
991 |
ej = nextedge(mig->rbfv[0],ej)) { |
992 |
if (ej == mig) |
993 |
continue; |
994 |
tv = opp_rbf(mig->rbfv[0],ej); |
995 |
for (ej2 = tv->ejl; ej2 != NULL; ej2 = nextedge(tv,ej2)) |
996 |
if (opp_rbf(tv,ej2) == mig->rbfv[1]) { |
997 |
rbfv[is_rev_tri(mig->rbfv[0]->invec, |
998 |
mig->rbfv[1]->invec, |
999 |
tv->invec)] = tv; |
1000 |
break; |
1001 |
1002 |
1003 |
return((rbfv[0] != NULL) + (rbfv[1] != NULL)); |
1004 |
1005 |
1006 |
/* Check if prospective vertex would create overlapping triangle */ |
1007 |
static int |
1008 |
overlaps_tri(const RBFNODE *bv0, const RBFNODE *bv1, const RBFNODE *pv) |
1009 |
1010 |
const MIGRATION *ej; |
1011 |
RBFNODE *vother[2]; |
1012 |
int im_rev; |
1013 |
/* find shared edge in mesh */ |
1014 |
for (ej = pv->ejl; ej != NULL; ej = nextedge(pv,ej)) { |
1015 |
const RBFNODE *tv = opp_rbf(pv,ej); |
1016 |
if (tv == bv0) { |
1017 |
im_rev = is_rev_tri(ej->rbfv[0]->invec, |
1018 |
ej->rbfv[1]->invec, bv1->invec); |
1019 |
break; |
1020 |
1021 |
if (tv == bv1) { |
1022 |
1023 |
ej->rbfv[1]->invec, bv0->invec); |
1024 |
break; |
1025 |
1026 |
1027 |
if (!get_triangles(vother, ej)) /* triangle on same side? */ |
1028 |
return(0); |
1029 |
return(vother[im_rev] != NULL); |
1030 |
1031 |
1032 |
/* Find context hull vertex to complete triangle (oriented call) */ |
1033 |
static RBFNODE * |
1034 |
find_chull_vert(const RBFNODE *rbf0, const RBFNODE *rbf1) |
1035 |
1036 |
FVECT vmid, vejn, vp; |
1037 |
RBFNODE *rbf, *rbfbest = NULL; |
1038 |
double dprod, area2, bestarea2 = FHUGE, bestdprod = -.5; |
1039 |
1040 |
VSUB(vejn, rbf1->invec, rbf0->invec); |
1041 |
VADD(vmid, rbf0->invec, rbf1->invec); |
1042 |
if (normalize(vejn) == 0 || normalize(vmid) == 0) |
1043 |
return(NULL); |
1044 |
/* XXX exhaustive search */ |
1045 |
/* Find triangle with minimum rotation from perpendicular */ |
1046 |
for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) { |
1047 |
if ((rbf == rbf0) | (rbf == rbf1)) |
1048 |
continue; |
1049 |
tri_orient(vp, rbf0->invec, rbf1->invec, rbf->invec); |
1050 |
if (DOT(vp, vmid) <= FTINY) |
1051 |
continue; /* wrong orientation */ |
1052 |
area2 = .25*DOT(vp,vp); |
1053 |
VSUB(vp, rbf->invec, rbf0->invec); |
1054 |
dprod = -DOT(vp, vejn); |
1055 |
VSUM(vp, vp, vejn, dprod); /* above guarantees non-zero */ |
1056 |
dprod = DOT(vp, vmid) / VLEN(vp); |
1057 |
if (dprod <= bestdprod + FTINY*(1 - 2*(area2 < bestarea2))) |
1058 |
continue; /* found better already */ |
1059 |
if (overlaps_tri(rbf0, rbf1, rbf)) |
1060 |
continue; /* overlaps another triangle */ |
1061 |
rbfbest = rbf; |
1062 |
bestdprod = dprod; /* new one to beat */ |
1063 |
bestarea2 = area2; |
1064 |
1065 |
return(rbfbest); |
1066 |
1067 |
1068 |
/* Create new migration edge and grow mesh recursively around it */ |
1069 |
static void |
1070 |
mesh_from_edge(MIGRATION *edge) |
1071 |
1072 |
MIGRATION *ej0, *ej1; |
1073 |
RBFNODE *tvert[2]; |
1074 |
1075 |
if (edge == NULL) |
1076 |
return; |
1077 |
/* triangle on either side? */ |
1078 |
get_triangles(tvert, edge); |
1079 |
if (tvert[0] == NULL) { /* grow mesh on right */ |
1080 |
tvert[0] = find_chull_vert(edge->rbfv[0], edge->rbfv[1]); |
1081 |
if (tvert[0] != NULL) { |
1082 |
if (tvert[0] > edge->rbfv[0]) |
1083 |
ej0 = create_migration(edge->rbfv[0], tvert[0]); |
1084 |
else |
1085 |
ej0 = create_migration(tvert[0], edge->rbfv[0]); |
1086 |
if (tvert[0] > edge->rbfv[1]) |
1087 |
ej1 = create_migration(edge->rbfv[1], tvert[0]); |
1088 |
else |
1089 |
ej1 = create_migration(tvert[0], edge->rbfv[1]); |
1090 |
mesh_from_edge(ej0); |
1091 |
mesh_from_edge(ej1); |
1092 |
1093 |
} else if (tvert[1] == NULL) { /* grow mesh on left */ |
1094 |
tvert[1] = find_chull_vert(edge->rbfv[1], edge->rbfv[0]); |
1095 |
if (tvert[1] != NULL) { |
1096 |
if (tvert[1] > edge->rbfv[0]) |
1097 |
ej0 = create_migration(edge->rbfv[0], tvert[1]); |
1098 |
else |
1099 |
ej0 = create_migration(tvert[1], edge->rbfv[0]); |
1100 |
if (tvert[1] > edge->rbfv[1]) |
1101 |
ej1 = create_migration(edge->rbfv[1], tvert[1]); |
1102 |
else |
1103 |
ej1 = create_migration(tvert[1], edge->rbfv[1]); |
1104 |
1105 |
1106 |
1107 |
1108 |
1109 |
1110 |
#ifdef DEBUG |
1111 |
#include "random.h" |
1112 |
#include "bmpfile.h" |
1113 |
/* Hash pointer to byte value (must return 0 for NULL) */ |
1114 |
static int |
1115 |
byte_hash(const void *p) |
1116 |
1117 |
size_t h = (size_t)p; |
1118 |
h ^= (size_t)p >> 8; |
1119 |
h ^= (size_t)p >> 16; |
1120 |
h ^= (size_t)p >> 24; |
1121 |
return(h & 0xff); |
1122 |
1123 |
/* Write out BMP image showing edges */ |
1124 |
static void |
1125 |
write_edge_image(const char *fname) |
1126 |
1127 |
BMPHeader *hdr = BMPmappedHeader(GRIDRES, GRIDRES, 0, 256); |
1128 |
BMPWriter *wtr; |
1129 |
int i, j; |
1130 |
1131 |
fprintf(stderr, "Writing incident mesh drawing to '%s'\n", fname); |
1132 |
hdr->compr = BI_RLE8; |
1133 |
for (i = 256; --i; ) { /* assign random color map */ |
1134 |
hdr->palette[i].r = random() & 0xff; |
1135 |
hdr->palette[i].g = random() & 0xff; |
1136 |
hdr->palette[i].b = random() & 0xff; |
1137 |
/* reject dark colors */ |
1138 |
i += (hdr->palette[i].r + hdr->palette[i].g + |
1139 |
hdr->palette[i].b < 128); |
1140 |
1141 |
hdr->palette[0].r = hdr->palette[0].g = hdr->palette[0].b = 0; |
1142 |
/* open output */ |
1143 |
wtr = BMPopenOutputFile(fname, hdr); |
1144 |
if (wtr == NULL) { |
1145 |
free(hdr); |
1146 |
return; |
1147 |
1148 |
for (i = 0; i < GRIDRES; i++) { /* write scanlines */ |
1149 |
1150 |
wtr->scanline[j] = byte_hash(mig_grid[i][j]); |
1151 |
if (BMPwriteScanline(wtr) != BIR_OK) |
1152 |
break; |
1153 |
1154 |
BMPcloseOutput(wtr); /* close & clean up */ |
1155 |
1156 |
#endif |
1157 |
1158 |
/* Draw edge list into mig_grid array */ |
1159 |
static void |
1160 |
draw_edges() |
1161 |
1162 |
int nnull = 0, ntot = 0; |
1163 |
MIGRATION *ej; |
1164 |
int p0[2], p1[2]; |
1165 |
1166 |
/* memset(mig_grid, 0, sizeof(mig_grid)); */ |
1167 |
for (ej = mig_list; ej != NULL; ej = ej->next) { |
1168 |
++ntot; |
1169 |
pos_from_vec(p0, ej->rbfv[0]->invec); |
1170 |
pos_from_vec(p1, ej->rbfv[1]->invec); |
1171 |
if ((p0[0] == p1[0]) & (p0[1] == p1[1])) { |
1172 |
++nnull; |
1173 |
mig_grid[p0[0]][p0[1]] = ej; |
1174 |
continue; |
1175 |
1176 |
if (abs(p1[0]-p0[0]) > abs(p1[1]-p0[1])) { |
1177 |
const int xstep = 2*(p1[0] > p0[0]) - 1; |
1178 |
const double ystep = (double)((p1[1]-p0[1])*xstep) / |
1179 |
(double)(p1[0]-p0[0]); |
1180 |
int x; |
1181 |
double y; |
1182 |
for (x = p0[0], y = p0[1]+.5; x != p1[0]; |
1183 |
x += xstep, y += ystep) |
1184 |
mig_grid[x][(int)y] = ej; |
1185 |
1186 |
} else { |
1187 |
const int ystep = 2*(p1[1] > p0[1]) - 1; |
1188 |
const double xstep = (double)((p1[0]-p0[0])*ystep) / |
1189 |
(double)(p1[1]-p0[1]); |
1190 |
int y; |
1191 |
double x; |
1192 |
for (y = p0[1], x = p0[0]+.5; y != p1[1]; |
1193 |
y += ystep, x += xstep) |
1194 |
mig_grid[(int)x][y] = ej; |
1195 |
1196 |
1197 |
1198 |
if (nnull) |
1199 |
fprintf(stderr, "Warning: %d of %d edges are null\n", |
1200 |
nnull, ntot); |
1201 |
#ifdef DEBUG |
1202 |
write_edge_image("bsdf_edges.bmp"); |
1203 |
#endif |
1204 |
1205 |
1206 |
/* Build our triangle mesh from recorded RBFs */ |
1207 |
static void |
1208 |
build_mesh() |
1209 |
1210 |
double best2 = M_PI*M_PI; |
1211 |
RBFNODE *shrt_edj[2]; |
1212 |
RBFNODE *rbf0, *rbf1; |
1213 |
/* check if isotropic */ |
1214 |
if (single_plane_incident) { |
1215 |
for (rbf0 = dsf_list; rbf0 != NULL; rbf0 = rbf0->next) |
1216 |
if (rbf0->next != NULL) |
1217 |
create_migration(rbf0, rbf0->next); |
1218 |
await_children(nchild); |
1219 |
return; |
1220 |
1221 |
shrt_edj[0] = shrt_edj[1] = NULL; /* start w/ shortest edge */ |
1222 |
1223 |
for (rbf1 = rbf0->next; rbf1 != NULL; rbf1 = rbf1->next) { |
1224 |
double dist2 = 2. - 2.*DOT(rbf0->invec,rbf1->invec); |
1225 |
if (dist2 < best2) { |
1226 |
shrt_edj[0] = rbf0; |
1227 |
shrt_edj[1] = rbf1; |
1228 |
best2 = dist2; |
1229 |
1230 |
1231 |
if (shrt_edj[0] == NULL) { |
1232 |
fprintf(stderr, "%s: Cannot find shortest edge\n", progname); |
1233 |
exit(1); |
1234 |
1235 |
/* build mesh from this edge */ |
1236 |
if (shrt_edj[0] < shrt_edj[1]) |
1237 |
mesh_from_edge(create_migration(shrt_edj[0], shrt_edj[1])); |
1238 |
else |
1239 |
mesh_from_edge(create_migration(shrt_edj[1], shrt_edj[0])); |
1240 |
/* draw edge list into grid */ |
1241 |
draw_edges(); |
1242 |
/* complete migrations */ |
1243 |
1244 |
1245 |
1246 |
/* Identify enclosing triangle for this position (flood fill raster check) */ |
1247 |
static int |
1248 |
identify_tri(MIGRATION *miga[3], unsigned char vmap[GRIDRES][(GRIDRES+7)/8], |
1249 |
int px, int py) |
1250 |
1251 |
const int btest = 1<<(py&07); |
1252 |
1253 |
if (vmap[px][py>>3] & btest) /* already visited here? */ |
1254 |
return(1); |
1255 |
/* else mark it */ |
1256 |
vmap[px][py>>3] |= btest; |
1257 |
1258 |
if (mig_grid[px][py] != NULL) { /* are we on an edge? */ |
1259 |
int i; |
1260 |
for (i = 0; i < 3; i++) { |
1261 |
if (miga[i] == mig_grid[px][py]) |
1262 |
return(1); |
1263 |
if (miga[i] != NULL) |
1264 |
continue; |
1265 |
miga[i] = mig_grid[px][py]; |
1266 |
return(1); |
1267 |
1268 |
return(0); /* outside triangle! */ |
1269 |
1270 |
/* check neighbors (flood) */ |
1271 |
if (px > 0 && !identify_tri(miga, vmap, px-1, py)) |
1272 |
return(0); |
1273 |
if (px < GRIDRES-1 && !identify_tri(miga, vmap, px+1, py)) |
1274 |
return(0); |
1275 |
if (py > 0 && !identify_tri(miga, vmap, px, py-1)) |
1276 |
return(0); |
1277 |
if (py < GRIDRES-1 && !identify_tri(miga, vmap, px, py+1)) |
1278 |
return(0); |
1279 |
return(1); /* this neighborhood done */ |
1280 |
1281 |
1282 |
/* Insert vertex in ordered list */ |
1283 |
static void |
1284 |
insert_vert(RBFNODE **vlist, RBFNODE *v) |
1285 |
1286 |
int i, j; |
1287 |
1288 |
for (i = 0; vlist[i] != NULL; i++) { |
1289 |
if (v == vlist[i]) |
1290 |
return; |
1291 |
if (v < vlist[i]) |
1292 |
break; |
1293 |
1294 |
for (j = i; vlist[j] != NULL; j++) |
1295 |
1296 |
while (j > i) { |
1297 |
vlist[j] = vlist[j-1]; |
1298 |
--j; |
1299 |
1300 |
vlist[i] = v; |
1301 |
1302 |
1303 |
/* Sort triangle edges in standard order */ |
1304 |
static int |
1305 |
order_triangle(MIGRATION *miga[3]) |
1306 |
1307 |
RBFNODE *vert[7]; |
1308 |
MIGRATION *ord[3]; |
1309 |
int i; |
1310 |
/* order vertices, first */ |
1311 |
memset(vert, 0, sizeof(vert)); |
1312 |
for (i = 3; i--; ) { |
1313 |
if (miga[i] == NULL) |
1314 |
return(0); |
1315 |
insert_vert(vert, miga[i]->rbfv[0]); |
1316 |
insert_vert(vert, miga[i]->rbfv[1]); |
1317 |
1318 |
/* should be just 3 vertices */ |
1319 |
if ((vert[3] == NULL) | (vert[4] != NULL)) |
1320 |
return(0); |
1321 |
/* identify edge 0 */ |
1322 |
for (i = 3; i--; ) |
1323 |
if (miga[i]->rbfv[0] == vert[0] && |
1324 |
miga[i]->rbfv[1] == vert[1]) { |
1325 |
ord[0] = miga[i]; |
1326 |
break; |
1327 |
1328 |
if (i < 0) |
1329 |
return(0); |
1330 |
/* identify edge 1 */ |
1331 |
1332 |
if (miga[i]->rbfv[0] == vert[1] && |
1333 |
miga[i]->rbfv[1] == vert[2]) { |
1334 |
ord[1] = miga[i]; |
1335 |
break; |
1336 |
1337 |
if (i < 0) |
1338 |
return(0); |
1339 |
/* identify edge 2 */ |
1340 |
1341 |
1342 |
1343 |
ord[2] = miga[i]; |
1344 |
break; |
1345 |
1346 |
if (i < 0) |
1347 |
return(0); |
1348 |
/* reassign order */ |
1349 |
miga[0] = ord[0]; miga[1] = ord[1]; miga[2] = ord[2]; |
1350 |
return(1); |
1351 |
1352 |
1353 |
/* Find edge(s) for interpolating the given vector, applying symmetry */ |
1354 |
static int |
1355 |
get_interp(MIGRATION *miga[3], FVECT invec) |
1356 |
1357 |
miga[0] = miga[1] = miga[2] = NULL; |
1358 |
if (single_plane_incident) { /* isotropic BSDF? */ |
1359 |
RBFNODE *rbf; /* find edge we're on */ |
1360 |
1361 |
if (input_orient*rbf->invec[2] < input_orient*invec[2]) |
1362 |
break; |
1363 |
if (rbf->next != NULL && |
1364 |
input_orient*rbf->next->invec[2] < |
1365 |
input_orient*invec[2]) { |
1366 |
for (miga[0] = rbf->ejl; miga[0] != NULL; |
1367 |
miga[0] = nextedge(rbf,miga[0])) |
1368 |
if (opp_rbf(rbf,miga[0]) == rbf->next) |
1369 |
return(0); |
1370 |
break; |
1371 |
1372 |
1373 |
return(-1); /* outside range! */ |
1374 |
1375 |
{ /* else use triangle mesh */ |
1376 |
const int sym = use_symmetry(invec); |
1377 |
unsigned char floodmap[GRIDRES][(GRIDRES+7)/8]; |
1378 |
int pstart[2]; |
1379 |
RBFNODE *vother; |
1380 |
MIGRATION *ej; |
1381 |
int i; |
1382 |
1383 |
pos_from_vec(pstart, invec); |
1384 |
memset(floodmap, 0, sizeof(floodmap)); |
1385 |
/* call flooding function */ |
1386 |
if (!identify_tri(miga, floodmap, pstart[0], pstart[1])) |
1387 |
return(-1); /* outside mesh */ |
1388 |
if ((miga[0] == NULL) | (miga[2] == NULL)) |
1389 |
return(-1); /* should never happen */ |
1390 |
if (miga[1] == NULL) |
1391 |
return(sym); /* on edge */ |
1392 |
/* verify triangle */ |
1393 |
if (!order_triangle(miga)) { |
1394 |
#ifdef DEBUG |
1395 |
fputs("Munged triangle in get_interp()\n", stderr); |
1396 |
#endif |
1397 |
vother = NULL; /* find triangle from edge */ |
1398 |
1399 |
RBFNODE *tpair[2]; |
1400 |
if (get_triangles(tpair, miga[i]) && |
1401 |
(vother = tpair[ is_rev_tri( |
1402 |
miga[i]->rbfv[0]->invec, |
1403 |
miga[i]->rbfv[1]->invec, |
1404 |
invec) ]) != NULL) |
1405 |
break; |
1406 |
1407 |
if (vother == NULL) { /* couldn't find 3rd vertex */ |
1408 |
#ifdef DEBUG |
1409 |
fputs("No triangle in get_interp()\n", stderr); |
1410 |
#endif |
1411 |
return(-1); |
1412 |
1413 |
/* reassign other two edges */ |
1414 |
for (ej = vother->ejl; ej != NULL; |
1415 |
ej = nextedge(vother,ej)) { |
1416 |
RBFNODE *vorig = opp_rbf(vother,ej); |
1417 |
if (vorig == miga[i]->rbfv[0]) |
1418 |
miga[(i+1)%3] = ej; |
1419 |
else if (vorig == miga[i]->rbfv[1]) |
1420 |
miga[(i+2)%3] = ej; |
1421 |
1422 |
1423 |
#ifdef DEBUG |
1424 |
fputs("Bad triangle in get_interp()\n", stderr); |
1425 |
#endif |
1426 |
return(-1); |
1427 |
1428 |
1429 |
return(sym); /* return in standard order */ |
1430 |
1431 |
1432 |
1433 |
/* Advect and allocate new RBF along edge */ |
1434 |
static RBFNODE * |
1435 |
e_advect_rbf(const MIGRATION *mig, const FVECT invec) |
1436 |
1437 |
RBFNODE *rbf; |
1438 |
int n, i, j; |
1439 |
double t, full_dist; |
1440 |
/* get relative position */ |
1441 |
t = acos(DOT(invec, mig->rbfv[0]->invec)); |
1442 |
if (t < M_PI/GRIDRES) { /* near first DSF */ |
1443 |
n = sizeof(RBFNODE) + sizeof(RBFVAL)*(mig->rbfv[0]->nrbf-1); |
1444 |
rbf = (RBFNODE *)malloc(n); |
1445 |
if (rbf == NULL) |
1446 |
goto memerr; |
1447 |
memcpy(rbf, mig->rbfv[0], n); /* just duplicate */ |
1448 |
return(rbf); |
1449 |
1450 |
full_dist = acos(DOT(mig->rbfv[0]->invec, mig->rbfv[1]->invec)); |
1451 |
if (t > full_dist-M_PI/GRIDRES) { /* near second DSF */ |
1452 |
n = sizeof(RBFNODE) + sizeof(RBFVAL)*(mig->rbfv[1]->nrbf-1); |
1453 |
1454 |
if (rbf == NULL) |
1455 |
goto memerr; |
1456 |
memcpy(rbf, mig->rbfv[1], n); /* just duplicate */ |
1457 |
return(rbf); |
1458 |
1459 |
t /= full_dist; |
1460 |
n = 0; /* count migrating particles */ |
1461 |
for (i = 0; i < mtx_nrows(mig); i++) |
1462 |
for (j = 0; j < mtx_ncols(mig); j++) |
1463 |
n += (mig->mtx[mtx_ndx(mig,i,j)] > FTINY); |
1464 |
#ifdef DEBUG |
1465 |
fprintf(stderr, "Input RBFs have %d, %d nodes -> output has %d\n", |
1466 |
mig->rbfv[0]->nrbf, mig->rbfv[1]->nrbf, n); |
1467 |
#endif |
1468 |
rbf = (RBFNODE *)malloc(sizeof(RBFNODE) + sizeof(RBFVAL)*(n-1)); |
1469 |
if (rbf == NULL) |
1470 |
goto memerr; |
1471 |
rbf->next = NULL; rbf->ejl = NULL; |
1472 |
VCOPY(rbf->invec, invec); |
1473 |
rbf->nrbf = n; |
1474 |
rbf->vtotal = 1.-t + t*mig->rbfv[1]->vtotal/mig->rbfv[0]->vtotal; |
1475 |
n = 0; /* advect RBF lobes */ |
1476 |
for (i = 0; i < mtx_nrows(mig); i++) { |
1477 |
const RBFVAL *rbf0i = &mig->rbfv[0]->rbfa[i]; |
1478 |
const float peak0 = rbf0i->peak; |
1479 |
const double rad0 = R2ANG(rbf0i->crad); |
1480 |
FVECT v0; |
1481 |
float mv; |
1482 |
ovec_from_pos(v0, rbf0i->gx, rbf0i->gy); |
1483 |
1484 |
if ((mv = mig->mtx[mtx_ndx(mig,i,j)]) > FTINY) { |
1485 |
const RBFVAL *rbf1j = &mig->rbfv[1]->rbfa[j]; |
1486 |
double rad1 = R2ANG(rbf1j->crad); |
1487 |
FVECT v; |
1488 |
int pos[2]; |
1489 |
rbf->rbfa[n].peak = peak0 * mv * rbf->vtotal; |
1490 |
rbf->rbfa[n].crad = ANG2R(sqrt(rad0*rad0*(1.-t) + |
1491 |
rad1*rad1*t)); |
1492 |
ovec_from_pos(v, rbf1j->gx, rbf1j->gy); |
1493 |
geodesic(v, v0, v, t, GEOD_REL); |
1494 |
pos_from_vec(pos, v); |
1495 |
rbf->rbfa[n].gx = pos[0]; |
1496 |
rbf->rbfa[n].gy = pos[1]; |
1497 |
++n; |
1498 |
1499 |
1500 |
rbf->vtotal *= mig->rbfv[0]->vtotal; /* turn ratio into actual */ |
1501 |
return(rbf); |
1502 |
memerr: |
1503 |
fprintf(stderr, "%s: Out of memory in e_advect_rbf()\n", progname); |
1504 |
exit(1); |
1505 |
return(NULL); /* pro forma return */ |
1506 |
1507 |
1508 |
/* Partially advect between recorded incident angles and allocate new RBF */ |
1509 |
static RBFNODE * |
1510 |
advect_rbf(const FVECT invec) |
1511 |
1512 |
FVECT sivec; |
1513 |
MIGRATION *miga[3]; |
1514 |
RBFNODE *rbf; |
1515 |
int sym; |
1516 |
float mbfact, mcfact; |
1517 |
int n, i, j, k; |
1518 |
FVECT v0, v1, v2; |
1519 |
double s, t; |
1520 |
1521 |
VCOPY(sivec, invec); /* find triangle/edge */ |
1522 |
sym = get_interp(miga, sivec); |
1523 |
if (sym < 0) /* can't interpolate? */ |
1524 |
return(NULL); |
1525 |
if (miga[1] == NULL) { /* advect along edge? */ |
1526 |
rbf = e_advect_rbf(miga[0], sivec); |
1527 |
rev_rbf_symmetry(rbf, sym); |
1528 |
return(rbf); |
1529 |
1530 |
#ifdef DEBUG |
1531 |
if (miga[0]->rbfv[0] != miga[2]->rbfv[0] | |
1532 |
miga[0]->rbfv[1] != miga[1]->rbfv[0] | |
1533 |
miga[1]->rbfv[1] != miga[2]->rbfv[1]) { |
1534 |
fprintf(stderr, "%s: Triangle vertex screw-up!\n", progname); |
1535 |
exit(1); |
1536 |
1537 |
#endif |
1538 |
/* figure out position */ |
1539 |
fcross(v0, miga[2]->rbfv[0]->invec, miga[2]->rbfv[1]->invec); |
1540 |
normalize(v0); |
1541 |
fcross(v2, miga[1]->rbfv[0]->invec, miga[1]->rbfv[1]->invec); |
1542 |
normalize(v2); |
1543 |
fcross(v1, sivec, miga[1]->rbfv[1]->invec); |
1544 |
normalize(v1); |
1545 |
s = acos(DOT(v0,v1)) / acos(DOT(v0,v2)); |
1546 |
geodesic(v1, miga[0]->rbfv[0]->invec, miga[0]->rbfv[1]->invec, |
1547 |
s, GEOD_REL); |
1548 |
t = acos(DOT(v1,sivec)) / acos(DOT(v1,miga[1]->rbfv[1]->invec)); |
1549 |
1550 |
for (i = 0; i < mtx_nrows(miga[0]); i++) |
1551 |
for (j = 0; j < mtx_ncols(miga[0]); j++) |
1552 |
for (k = (miga[0]->mtx[mtx_ndx(miga[0],i,j)] > FTINY) * |
1553 |
mtx_ncols(miga[2]); k--; ) |
1554 |
n += (miga[2]->mtx[mtx_ndx(miga[2],i,k)] > FTINY && |
1555 |
miga[1]->mtx[mtx_ndx(miga[1],j,k)] > FTINY); |
1556 |
#ifdef DEBUG |
1557 |
fprintf(stderr, "Input RBFs have %d, %d, %d nodes -> output has %d\n", |
1558 |
miga[0]->rbfv[0]->nrbf, miga[0]->rbfv[1]->nrbf, |
1559 |
miga[2]->rbfv[1]->nrbf, n); |
1560 |
#endif |
1561 |
1562 |
if (rbf == NULL) { |
1563 |
fprintf(stderr, "%s: Out of memory in advect_rbf()\n", progname); |
1564 |
exit(1); |
1565 |
1566 |
1567 |
VCOPY(rbf->invec, sivec); |
1568 |
rbf->nrbf = n; |
1569 |
n = 0; /* compute RBF lobes */ |
1570 |
mbfact = s * miga[0]->rbfv[1]->vtotal/miga[0]->rbfv[0]->vtotal * |
1571 |
(1.-t + t*miga[1]->rbfv[1]->vtotal/miga[1]->rbfv[0]->vtotal); |
1572 |
mcfact = (1.-s) * |
1573 |
(1.-t + t*miga[2]->rbfv[1]->vtotal/miga[2]->rbfv[0]->vtotal); |
1574 |
for (i = 0; i < mtx_nrows(miga[0]); i++) { |
1575 |
const RBFVAL *rbf0i = &miga[0]->rbfv[0]->rbfa[i]; |
1576 |
const float w0i = rbf0i->peak; |
1577 |
const double rad0i = R2ANG(rbf0i->crad); |
1578 |
1579 |
for (j = 0; j < mtx_ncols(miga[0]); j++) { |
1580 |
const float ma = miga[0]->mtx[mtx_ndx(miga[0],i,j)]; |
1581 |
const RBFVAL *rbf1j; |
1582 |
double rad1j, srad2; |
1583 |
if (ma <= FTINY) |
1584 |
continue; |
1585 |
rbf1j = &miga[0]->rbfv[1]->rbfa[j]; |
1586 |
rad1j = R2ANG(rbf1j->crad); |
1587 |
srad2 = (1.-s)*(1.-t)*rad0i*rad0i + s*(1.-t)*rad1j*rad1j; |
1588 |
ovec_from_pos(v1, rbf1j->gx, rbf1j->gy); |
1589 |
geodesic(v1, v0, v1, s, GEOD_REL); |
1590 |
for (k = 0; k < mtx_ncols(miga[2]); k++) { |
1591 |
float mb = miga[1]->mtx[mtx_ndx(miga[1],j,k)]; |
1592 |
float mc = miga[2]->mtx[mtx_ndx(miga[2],i,k)]; |
1593 |
const RBFVAL *rbf2k; |
1594 |
double rad2k; |
1595 |
FVECT vout; |
1596 |
int pos[2]; |
1597 |
if ((mb <= FTINY) | (mc <= FTINY)) |
1598 |
continue; |
1599 |
rbf2k = &miga[2]->rbfv[1]->rbfa[k]; |
1600 |
rbf->rbfa[n].peak = w0i * ma * (mb*mbfact + mc*mcfact); |
1601 |
rad2k = R2ANG(rbf2k->crad); |
1602 |
rbf->rbfa[n].crad = ANG2R(sqrt(srad2 + t*rad2k*rad2k)); |
1603 |
ovec_from_pos(v2, rbf2k->gx, rbf2k->gy); |
1604 |
geodesic(vout, v1, v2, t, GEOD_REL); |
1605 |
pos_from_vec(pos, vout); |
1606 |
1607 |
1608 |
++n; |
1609 |
1610 |
1611 |
1612 |
rbf->vtotal = miga[0]->rbfv[0]->vtotal * (mbfact + mcfact); |
1613 |
1614 |
return(rbf); |
1615 |
1616 |
1617 |
/* Interpolate and output isotropic BSDF data */ |
1618 |
static void |
1619 |
interp_isotropic() |
1620 |
1621 |
const int sqres = 1<<samp_order; |
1622 |
FILE *ofp = NULL; |
1623 |
char cmd[128]; |
1624 |
int ix, ox, oy; |
1625 |
FVECT ivec, ovec; |
1626 |
double bsdf; |
1627 |
#if DEBUG |
1628 |
fprintf(stderr, "Writing isotropic order %d ", samp_order); |
1629 |
if (pctcull >= 0) fprintf(stderr, "data with %d%% culling\n", pctcull); |
1630 |
else fputs("raw data\n", stderr); |
1631 |
#endif |
1632 |
if (pctcull >= 0) { /* begin output */ |
1633 |
sprintf(cmd, "rttree_reduce -h -a -fd -r 3 -t %d -g %d", |
1634 |
pctcull, samp_order); |
1635 |
fflush(stdout); |
1636 |
ofp = popen(cmd, "w"); |
1637 |
if (ofp == NULL) { |
1638 |
fprintf(stderr, "%s: cannot create pipe to rttree_reduce\n", |
1639 |
progname); |
1640 |
exit(1); |
1641 |
1642 |
} else |
1643 |
fputs("{\n", stdout); |
1644 |
/* run through directions */ |
1645 |
for (ix = 0; ix < sqres/2; ix++) { |
1646 |
RBFNODE *rbf; |
1647 |
SDsquare2disk(ivec, (ix+.5)/sqres, .5); |
1648 |
ivec[2] = input_orient * |
1649 |
sqrt(1. - ivec[0]*ivec[0] - ivec[1]*ivec[1]); |
1650 |
rbf = advect_rbf(ivec); |
1651 |
for (ox = 0; ox < sqres; ox++) |
1652 |
for (oy = 0; oy < sqres; oy++) { |
1653 |
SDsquare2disk(ovec, (ox+.5)/sqres, (oy+.5)/sqres); |
1654 |
ovec[2] = output_orient * |
1655 |
sqrt(1. - ovec[0]*ovec[0] - ovec[1]*ovec[1]); |
1656 |
bsdf = eval_rbfrep(rbf, ovec) / fabs(ovec[2]); |
1657 |
if (pctcull >= 0) |
1658 |
fwrite(&bsdf, sizeof(bsdf), 1, ofp); |
1659 |
else |
1660 |
printf("\t%.3e\n", bsdf); |
1661 |
1662 |
free(rbf); |
1663 |
1664 |
if (pctcull >= 0) { /* finish output */ |
1665 |
if (pclose(ofp)) { |
1666 |
fprintf(stderr, "%s: error running '%s'\n", |
1667 |
progname, cmd); |
1668 |
exit(1); |
1669 |
1670 |
} else { |
1671 |
for (ix = sqres*sqres*sqres/2; ix--; ) |
1672 |
fputs("\t0\n", stdout); |
1673 |
fputs("}\n", stdout); |
1674 |
1675 |
1676 |
1677 |
/* Interpolate and output anisotropic BSDF data */ |
1678 |
static void |
1679 |
interp_anisotropic() |
1680 |
1681 |
1682 |
FILE *ofp = NULL; |
1683 |
char cmd[128]; |
1684 |
int ix, iy, ox, oy; |
1685 |
FVECT ivec, ovec; |
1686 |
double bsdf; |
1687 |
#if DEBUG |
1688 |
fprintf(stderr, "Writing anisotropic order %d ", samp_order); |
1689 |
1690 |
1691 |
#endif |
1692 |
1693 |
sprintf(cmd, "rttree_reduce -h -a -fd -r 4 -t %d -g %d", |
1694 |
1695 |
fflush(stdout); |
1696 |
1697 |
1698 |
1699 |
progname); |
1700 |
exit(1); |
1701 |
1702 |
} else |
1703 |
1704 |
1705 |
for (ix = 0; ix < sqres; ix++) |
1706 |
for (iy = 0; iy < sqres; iy++) { |
1707 |
RBFNODE *rbf; |
1708 |
SDsquare2disk(ivec, (ix+.5)/sqres, (iy+.5)/sqres); |
1709 |
1710 |
1711 |
1712 |
1713 |
1714 |
1715 |
1716 |
1717 |
1718 |
if (pctcull >= 0) |
1719 |
1720 |
else |
1721 |
1722 |
1723 |
free(rbf); |
1724 |
1725 |
1726 |
1727 |
1728 |
progname, cmd); |
1729 |
exit(1); |
1730 |
1731 |
} else |
1732 |
1733 |
1734 |
1735 |
#if 1 |
1736 |
/* Read in BSDF files and interpolate as tensor tree representation */ |
1737 |
int |
1738 |
main(int argc, char *argv[]) |
1739 |
1740 |
RBFNODE *rbf; |
1741 |
double bsdf; |
1742 |
int i; |
1743 |
1744 |
progname = argv[0]; /* get options */ |
1745 |
while (argc > 2 && argv[1][0] == '-') { |
1746 |
switch (argv[1][1]) { |
1747 |
case 'n': |
1748 |
nprocs = atoi(argv[2]); |
1749 |
break; |
1750 |
case 't': |
1751 |
pctcull = atoi(argv[2]); |
1752 |
break; |
1753 |
default: |
1754 |
goto userr; |
1755 |
1756 |
argv += 2; argc -= 2; |
1757 |
1758 |
if (argc < 3) |
1759 |
goto userr; |
1760 |
#ifdef _WIN32 |
1761 |
if (nprocs > 1) { |
1762 |
fprintf(stderr, "%s: multiprocessing not supported\n", |
1763 |
progname); |
1764 |
return(1); |
1765 |
1766 |
#endif |
1767 |
for (i = 1; i < argc; i++) { /* compile measurements */ |
1768 |
if (!load_pabopto_meas(argv[i])) |
1769 |
return(1); |
1770 |
compute_radii(); |
1771 |
cull_values(); |
1772 |
make_rbfrep(); |
1773 |
1774 |
build_mesh(); /* create interpolation */ |
1775 |
/* xml_prologue(); /* start XML output */ |
1776 |
if (single_plane_incident) /* resample dist. */ |
1777 |
interp_isotropic(); |
1778 |
else |
1779 |
interp_anisotropic(); |
1780 |
/* xml_epilogue(); /* finish XML output */ |
1781 |
return(0); |
1782 |
userr: |
1783 |
fprintf(stderr, |
1784 |
"Usage: %s [-n nprocs][-t pctcull] meas1.dat meas2.dat .. > bsdf.xml\n", |
1785 |
progname); |
1786 |
return(1); |
1787 |
1788 |
#else |
1789 |
/* Test main produces a Radiance model from the given input file */ |
1790 |
int |
1791 |
1792 |
1793 |
char buf[128]; |
1794 |
FILE *pfp; |
1795 |
double bsdf; |
1796 |
FVECT dir; |
1797 |
int i, j, n; |
1798 |
1799 |
if (argc != 2) { |
1800 |
fprintf(stderr, "Usage: %s input.dat > output.rad\n", argv[0]); |
1801 |
return(1); |
1802 |
1803 |
if (!load_pabopto_meas(argv[1])) |
1804 |
return(1); |
1805 |
1806 |
compute_radii(); |
1807 |
cull_values(); |
1808 |
make_rbfrep(); |
1809 |
/* produce spheres at meas. */ |
1810 |
puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n"); |
1811 |
puts("void plastic pink\n0\n0\n5 .5 .05 .9 .04 .08\n"); |
1812 |
n = 0; |
1813 |
1814 |
1815 |
if (dsf_grid[i][j].vsum > .0f) { |
1816 |
ovec_from_pos(dir, i, j); |
1817 |
bsdf = dsf_grid[i][j].vsum / dir[2]; |
1818 |
1819 |
printf("pink cone c%04d\n0\n0\n8\n", ++n); |
1820 |
printf("\t%.6g %.6g %.6g\n", |
1821 |
dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf); |
1822 |
1823 |
dir[0]*(bsdf+.005), dir[1]*(bsdf+.005), |
1824 |
dir[2]*(bsdf+.005)); |
1825 |
puts("\t.003\t0\n"); |
1826 |
} else { |
1827 |
1828 |
printf("yellow sphere s%04d\n0\n0\n", ++n); |
1829 |
printf("4 %.6g %.6g %.6g .0015\n\n", |
1830 |
1831 |
1832 |
1833 |
/* output continuous surface */ |
1834 |
puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 .9\n"); |
1835 |
fflush(stdout); |
1836 |
sprintf(buf, "gensurf tgreen bsdf - - - %d %d", GRIDRES-1, GRIDRES-1); |
1837 |
pfp = popen(buf, "w"); |
1838 |
if (pfp == NULL) { |
1839 |
fputs(buf, stderr); |
1840 |
fputs(": cannot start command\n", stderr); |
1841 |
return(1); |
1842 |
1843 |
1844 |
1845 |
1846 |
bsdf = eval_rbfrep(dsf_list, dir) / dir[2]; |
1847 |
fprintf(pfp, "%.8e %.8e %.8e\n", |
1848 |
1849 |
1850 |
return(pclose(pfp)==0 ? 0 : 1); |
1851 |
1852 |
#endif |
