1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: pabopto2xml.c,v 2.10 2012/09/18 02:50:13 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Convert PAB-Opto measurements to XML format using tensor tree representation |
6 |
* Employs Bonneel et al. Earth Mover's Distance interpolant. |
7 |
8 |
* G.Ward |
9 |
10 |
11 |
#define _USE_MATH_DEFINES |
12 |
#include <stdio.h> |
13 |
#include <stdlib.h> |
14 |
#include <string.h> |
15 |
#include <ctype.h> |
16 |
#include <math.h> |
17 |
#include "bsdf.h" |
18 |
19 |
#define DEBUG 1 |
20 |
21 |
#ifndef GRIDRES |
22 |
#define GRIDRES 200 /* grid resolution per side */ |
23 |
#endif |
24 |
25 |
#define RSCA 2.7 /* radius scaling factor (empirical) */ |
26 |
27 |
/* convert to/from coded radians */ |
28 |
#define ANG2R(r) (int)((r)*((1<<16)/M_PI)) |
29 |
#define R2ANG(c) (((c)+.5)*(M_PI/(1<<16))) |
30 |
31 |
typedef struct { |
32 |
float vsum; /* DSF sum */ |
33 |
unsigned short nval; /* number of values in sum */ |
34 |
unsigned short crad; /* radius (coded angle) */ |
35 |
} GRIDVAL; /* grid value */ |
36 |
37 |
typedef struct { |
38 |
float peak; /* lobe value at peak */ |
39 |
40 |
unsigned char gx, gy; /* grid position */ |
41 |
} RBFVAL; /* radial basis function value */ |
42 |
43 |
struct s_rbfnode; /* forward declaration of RBF struct */ |
44 |
45 |
typedef struct s_migration { |
46 |
struct s_migration *next; /* next in global edge list */ |
47 |
struct s_rbfnode *rbfv[2]; /* from,to vertex */ |
48 |
struct s_migration *enxt[2]; /* next from,to sibling */ |
49 |
float mtx[1]; /* matrix (extends struct) */ |
50 |
} MIGRATION; /* migration link (winged edge structure) */ |
51 |
52 |
typedef struct s_rbfnode { |
53 |
struct s_rbfnode *next; /* next in global RBF list */ |
54 |
MIGRATION *ejl; /* edge list for this vertex */ |
55 |
FVECT invec; /* incident vector direction */ |
56 |
double vtotal; /* volume for normalization */ |
57 |
int nrbf; /* number of RBFs */ |
58 |
RBFVAL rbfa[1]; /* RBF array (extends struct) */ |
59 |
} RBFNODE; /* RBF representation of DSF @ 1 incidence */ |
60 |
61 |
/* our loaded grid for this incident angle */ |
62 |
static double theta_in_deg, phi_in_deg; |
63 |
static GRIDVAL dsf_grid[GRIDRES][GRIDRES]; |
64 |
65 |
/* all incident angles in-plane so far? */ |
66 |
static int single_plane_incident = -1; |
67 |
68 |
/* input/output orientations */ |
69 |
static int input_orient = 0; |
70 |
static int output_orient = 0; |
71 |
72 |
/* processed incident DSF measurements */ |
73 |
static RBFNODE *dsf_list = NULL; |
74 |
75 |
/* RBF-linking matrices (edges) */ |
76 |
static MIGRATION *mig_list = NULL; |
77 |
78 |
/* migration edges drawn in raster fashion */ |
79 |
static MIGRATION *mig_grid[GRIDRES][GRIDRES]; |
80 |
81 |
#define mtx_nrows(m) ((m)->rbfv[0]->nrbf) |
82 |
#define mtx_ncols(m) ((m)->rbfv[1]->nrbf) |
83 |
#define mtx_ndx(m,i,j) ((i)*mtx_ncols(m) + (j)) |
84 |
#define is_src(rbf,m) ((rbf) == (m)->rbfv[0]) |
85 |
#define is_dest(rbf,m) ((rbf) == (m)->rbfv[1]) |
86 |
#define nextedge(rbf,m) (m)->enxt[is_dest(rbf,m)] |
87 |
#define opp_rbf(rbf,m) (m)->rbfv[is_src(rbf,m)] |
88 |
89 |
#define round(v) (int)((v) + .5 - ((v) < -.5)) |
90 |
91 |
/* Compute volume associated with Gaussian lobe */ |
92 |
static double |
93 |
rbf_volume(const RBFVAL *rbfp) |
94 |
95 |
double rad = R2ANG(rbfp->crad); |
96 |
97 |
return((2.*M_PI) * rbfp->peak * rad*rad); |
98 |
99 |
100 |
/* Compute outgoing vector from grid position */ |
101 |
static void |
102 |
ovec_from_pos(FVECT vec, int xpos, int ypos) |
103 |
104 |
double uv[2]; |
105 |
double r2; |
106 |
107 |
SDsquare2disk(uv, (1./GRIDRES)*(xpos+.5), (1./GRIDRES)*(ypos+.5)); |
108 |
/* uniform hemispherical projection */ |
109 |
r2 = uv[0]*uv[0] + uv[1]*uv[1]; |
110 |
vec[0] = vec[1] = sqrt(2. - r2); |
111 |
vec[0] *= uv[0]; |
112 |
vec[1] *= uv[1]; |
113 |
vec[2] = output_orient*(1. - r2); |
114 |
115 |
116 |
/* Compute grid position from normalized input/output vector */ |
117 |
static void |
118 |
pos_from_vec(int pos[2], const FVECT vec) |
119 |
120 |
double sq[2]; /* uniform hemispherical projection */ |
121 |
double norm = 1./sqrt(1. + fabs(vec[2])); |
122 |
123 |
SDdisk2square(sq, vec[0]*norm, vec[1]*norm); |
124 |
125 |
pos[0] = (int)(sq[0]*GRIDRES); |
126 |
pos[1] = (int)(sq[1]*GRIDRES); |
127 |
128 |
129 |
/* Evaluate RBF for DSF at the given normalized outgoing direction */ |
130 |
static double |
131 |
eval_rbfrep(const RBFNODE *rp, const FVECT outvec) |
132 |
133 |
double res = .0; |
134 |
const RBFVAL *rbfp; |
135 |
FVECT odir; |
136 |
double sig2; |
137 |
int n; |
138 |
139 |
rbfp = rp->rbfa; |
140 |
for (n = rp->nrbf; n--; rbfp++) { |
141 |
ovec_from_pos(odir, rbfp->gx, rbfp->gy); |
142 |
sig2 = R2ANG(rbfp->crad); |
143 |
sig2 = (DOT(odir,outvec) - 1.) / (sig2*sig2); |
144 |
if (sig2 > -19.) |
145 |
res += rbfp->peak * exp(sig2); |
146 |
147 |
return(res); |
148 |
149 |
150 |
/* Insert a new directional scattering function in our global list */ |
151 |
static void |
152 |
insert_dsf(RBFNODE *newrbf) |
153 |
154 |
RBFNODE *rbf, *rbf_last; |
155 |
156 |
/* keep in ascending theta order */ |
157 |
for (rbf_last = NULL, rbf = dsf_list; |
158 |
single_plane_incident & (rbf != NULL); |
159 |
rbf_last = rbf, rbf = rbf->next) |
160 |
if (input_orient*rbf->invec[2] < input_orient*newrbf->invec[2]) |
161 |
break; |
162 |
if (rbf_last == NULL) { |
163 |
newrbf->next = dsf_list; |
164 |
dsf_list = newrbf; |
165 |
return; |
166 |
167 |
newrbf->next = rbf; |
168 |
rbf_last->next = newrbf; |
169 |
170 |
171 |
/* Count up filled nodes and build RBF representation from current grid */ |
172 |
static RBFNODE * |
173 |
make_rbfrep(void) |
174 |
175 |
int niter = 16; |
176 |
double lastVar, thisVar = 100.; |
177 |
int nn; |
178 |
RBFNODE *newnode; |
179 |
int i, j; |
180 |
181 |
nn = 0; /* count selected bins */ |
182 |
for (i = 0; i < GRIDRES; i++) |
183 |
for (j = 0; j < GRIDRES; j++) |
184 |
nn += dsf_grid[i][j].nval; |
185 |
/* allocate RBF array */ |
186 |
newnode = (RBFNODE *)malloc(sizeof(RBFNODE) + sizeof(RBFVAL)*(nn-1)); |
187 |
if (newnode == NULL) { |
188 |
fputs("Out of memory in make_rbfrep()\n", stderr); |
189 |
exit(1); |
190 |
191 |
newnode->next = NULL; |
192 |
newnode->ejl = NULL; |
193 |
newnode->invec[2] = sin(M_PI/180.*theta_in_deg); |
194 |
newnode->invec[0] = cos(M_PI/180.*phi_in_deg)*newnode->invec[2]; |
195 |
newnode->invec[1] = sin(M_PI/180.*phi_in_deg)*newnode->invec[2]; |
196 |
newnode->invec[2] = input_orient*sqrt(1. - newnode->invec[2]*newnode->invec[2]); |
197 |
newnode->vtotal = 0; |
198 |
newnode->nrbf = nn; |
199 |
nn = 0; /* fill RBF array */ |
200 |
201 |
202 |
if (dsf_grid[i][j].nval) { |
203 |
newnode->rbfa[nn].peak = dsf_grid[i][j].vsum; |
204 |
newnode->rbfa[nn].crad = RSCA*dsf_grid[i][j].crad + .5; |
205 |
newnode->rbfa[nn].gx = i; |
206 |
newnode->rbfa[nn].gy = j; |
207 |
++nn; |
208 |
209 |
/* iterate to improve interpolation accuracy */ |
210 |
do { |
211 |
double dsum = .0, dsum2 = .0; |
212 |
nn = 0; |
213 |
214 |
215 |
216 |
FVECT odir; |
217 |
double corr; |
218 |
ovec_from_pos(odir, i, j); |
219 |
newnode->rbfa[nn++].peak *= corr = |
220 |
dsf_grid[i][j].vsum / |
221 |
eval_rbfrep(newnode, odir); |
222 |
dsum += corr - 1.; |
223 |
dsum2 += (corr-1.)*(corr-1.); |
224 |
225 |
lastVar = thisVar; |
226 |
thisVar = dsum2/(double)nn; |
227 |
#ifdef DEBUG |
228 |
fprintf(stderr, "Avg., RMS error: %.1f%% %.1f%%\n", |
229 |
100.*dsum/(double)nn, |
230 |
100.*sqrt(thisVar)); |
231 |
#endif |
232 |
} while (--niter > 0 && lastVar-thisVar > 0.02*lastVar); |
233 |
234 |
nn = 0; /* compute sum for normalization */ |
235 |
while (nn < newnode->nrbf) |
236 |
newnode->vtotal += rbf_volume(&newnode->rbfa[nn++]); |
237 |
238 |
insert_dsf(newnode); |
239 |
return(newnode); |
240 |
241 |
242 |
/* Load a set of measurements corresponding to a particular incident angle */ |
243 |
static int |
244 |
load_pabopto_meas(const char *fname) |
245 |
246 |
FILE *fp = fopen(fname, "r"); |
247 |
int inp_is_DSF = -1; |
248 |
double new_phi, theta_out, phi_out, val; |
249 |
char buf[2048]; |
250 |
int n, c; |
251 |
252 |
if (fp == NULL) { |
253 |
fputs(fname, stderr); |
254 |
fputs(": cannot open\n", stderr); |
255 |
return(0); |
256 |
257 |
memset(dsf_grid, 0, sizeof(dsf_grid)); |
258 |
#ifdef DEBUG |
259 |
fprintf(stderr, "Loading measurement file '%s'...\n", fname); |
260 |
#endif |
261 |
/* read header information */ |
262 |
while ((c = getc(fp)) == '#' || c == EOF) { |
263 |
if (fgets(buf, sizeof(buf), fp) == NULL) { |
264 |
265 |
fputs(": unexpected EOF\n", stderr); |
266 |
fclose(fp); |
267 |
return(0); |
268 |
269 |
if (!strcmp(buf, "format: theta phi DSF\n")) { |
270 |
inp_is_DSF = 1; |
271 |
continue; |
272 |
273 |
if (!strcmp(buf, "format: theta phi BSDF\n")) { |
274 |
inp_is_DSF = 0; |
275 |
continue; |
276 |
277 |
if (sscanf(buf, "intheta %lf", &theta_in_deg) == 1) |
278 |
continue; |
279 |
if (sscanf(buf, "inphi %lf", &new_phi) == 1) |
280 |
continue; |
281 |
if (sscanf(buf, "incident_angle %lf %lf", |
282 |
&theta_in_deg, &new_phi) == 2) |
283 |
continue; |
284 |
285 |
if (inp_is_DSF < 0) { |
286 |
287 |
fputs(": unknown format\n", stderr); |
288 |
fclose(fp); |
289 |
return(0); |
290 |
291 |
if (!input_orient) /* check input orientation */ |
292 |
input_orient = 1 - 2*(theta_in_deg > 90.); |
293 |
else if (input_orient > 0 ^ theta_in_deg < 90.) { |
294 |
fputs("Cannot handle input angles on both sides of surface\n", |
295 |
stderr); |
296 |
exit(1); |
297 |
298 |
if (single_plane_incident > 0) /* check if still in plane */ |
299 |
single_plane_incident = (round(new_phi) == round(phi_in_deg)); |
300 |
else if (single_plane_incident < 0) |
301 |
single_plane_incident = 1; |
302 |
phi_in_deg = new_phi; |
303 |
ungetc(c, fp); /* read actual data */ |
304 |
while (fscanf(fp, "%lf %lf %lf\n", &theta_out, &phi_out, &val) == 3) { |
305 |
FVECT ovec; |
306 |
int pos[2]; |
307 |
308 |
if (!output_orient) /* check output orientation */ |
309 |
output_orient = 1 - 2*(theta_out > 90.); |
310 |
else if (output_orient > 0 ^ theta_out < 90.) { |
311 |
fputs("Cannot handle output angles on both sides of surface\n", |
312 |
stderr); |
313 |
exit(1); |
314 |
315 |
ovec[2] = sin(M_PI/180.*theta_out); |
316 |
ovec[0] = cos(M_PI/180.*phi_out) * ovec[2]; |
317 |
ovec[1] = sin(M_PI/180.*phi_out) * ovec[2]; |
318 |
ovec[2] = sqrt(1. - ovec[2]*ovec[2]); |
319 |
320 |
if (!inp_is_DSF) |
321 |
val *= ovec[2]; /* convert from BSDF to DSF */ |
322 |
323 |
pos_from_vec(pos, ovec); |
324 |
325 |
dsf_grid[pos[0]][pos[1]].vsum += val; |
326 |
dsf_grid[pos[0]][pos[1]].nval++; |
327 |
328 |
n = 0; |
329 |
while ((c = getc(fp)) != EOF) |
330 |
n += !isspace(c); |
331 |
if (n) |
332 |
fprintf(stderr, |
333 |
"%s: warning: %d unexpected characters past EOD\n", |
334 |
fname, n); |
335 |
fclose(fp); |
336 |
return(1); |
337 |
338 |
339 |
/* Compute radii for non-empty bins */ |
340 |
/* (distance to furthest empty bin for which non-empty bin is the closest) */ |
341 |
static void |
342 |
compute_radii(void) |
343 |
344 |
unsigned int fill_grid[GRIDRES][GRIDRES]; |
345 |
unsigned short fill_cnt[GRIDRES][GRIDRES]; |
346 |
FVECT ovec0, ovec1; |
347 |
double ang2, lastang2; |
348 |
int r, i, j, jn, ii, jj, inear, jnear; |
349 |
350 |
r = GRIDRES/2; /* proceed in zig-zag */ |
351 |
352 |
for (jn = 0; jn < GRIDRES; jn++) { |
353 |
j = (i&1) ? jn : GRIDRES-1-jn; |
354 |
if (dsf_grid[i][j].nval) /* find empty grid pos. */ |
355 |
continue; |
356 |
ovec_from_pos(ovec0, i, j); |
357 |
inear = jnear = -1; /* find nearest non-empty */ |
358 |
lastang2 = M_PI*M_PI; |
359 |
for (ii = i-r; ii <= i+r; ii++) { |
360 |
if (ii < 0) continue; |
361 |
if (ii >= GRIDRES) break; |
362 |
for (jj = j-r; jj <= j+r; jj++) { |
363 |
if (jj < 0) continue; |
364 |
if (jj >= GRIDRES) break; |
365 |
if (!dsf_grid[ii][jj].nval) |
366 |
continue; |
367 |
ovec_from_pos(ovec1, ii, jj); |
368 |
ang2 = 2. - 2.*DOT(ovec0,ovec1); |
369 |
if (ang2 >= lastang2) |
370 |
continue; |
371 |
lastang2 = ang2; |
372 |
inear = ii; jnear = jj; |
373 |
374 |
375 |
if (inear < 0) { |
376 |
fputs("Could not find non-empty neighbor!\n", stderr); |
377 |
exit(1); |
378 |
379 |
ang2 = sqrt(lastang2); |
380 |
r = ANG2R(ang2); /* record if > previous */ |
381 |
if (r > dsf_grid[inear][jnear].crad) |
382 |
dsf_grid[inear][jnear].crad = r; |
383 |
/* next search radius */ |
384 |
r = ang2*(2.*GRIDRES/M_PI) + 3; |
385 |
386 |
/* blur radii over hemisphere */ |
387 |
memset(fill_grid, 0, sizeof(fill_grid)); |
388 |
memset(fill_cnt, 0, sizeof(fill_cnt)); |
389 |
390 |
for (j = 0; j < GRIDRES; j++) { |
391 |
if (!dsf_grid[i][j].crad) |
392 |
continue; /* missing distance */ |
393 |
r = R2ANG(dsf_grid[i][j].crad)*(2.*RSCA*GRIDRES/M_PI); |
394 |
395 |
396 |
397 |
398 |
399 |
400 |
if ((ii-i)*(ii-i) + (jj-j)*(jj-j) > r*r) |
401 |
continue; |
402 |
fill_grid[ii][jj] += dsf_grid[i][j].crad; |
403 |
fill_cnt[ii][jj]++; |
404 |
405 |
406 |
407 |
/* copy back blurred radii */ |
408 |
409 |
410 |
if (fill_cnt[i][j]) |
411 |
dsf_grid[i][j].crad = fill_grid[i][j]/fill_cnt[i][j]; |
412 |
413 |
414 |
/* Cull points for more uniform distribution, leave all nval 0 or 1 */ |
415 |
static void |
416 |
cull_values(void) |
417 |
418 |
419 |
double maxang, maxang2; |
420 |
int i, j, ii, jj, r; |
421 |
/* simple greedy algorithm */ |
422 |
423 |
424 |
if (!dsf_grid[i][j].nval) |
425 |
continue; |
426 |
427 |
continue; /* shouldn't happen */ |
428 |
429 |
maxang = 2.*R2ANG(dsf_grid[i][j].crad); |
430 |
if (maxang > ovec0[2]) /* clamp near horizon */ |
431 |
maxang = ovec0[2]; |
432 |
r = maxang*(2.*GRIDRES/M_PI) + 1; |
433 |
maxang2 = maxang*maxang; |
434 |
435 |
436 |
437 |
438 |
439 |
440 |
441 |
continue; |
442 |
if ((ii == i) & (jj == j)) |
443 |
continue; /* don't get self-absorbed */ |
444 |
445 |
if (2. - 2.*DOT(ovec0,ovec1) >= maxang2) |
446 |
continue; |
447 |
/* absorb sum */ |
448 |
dsf_grid[i][j].vsum += dsf_grid[ii][jj].vsum; |
449 |
dsf_grid[i][j].nval += dsf_grid[ii][jj].nval; |
450 |
/* keep value, though */ |
451 |
dsf_grid[ii][jj].vsum /= (float)dsf_grid[ii][jj].nval; |
452 |
dsf_grid[ii][jj].nval = 0; |
453 |
454 |
455 |
456 |
/* final averaging pass */ |
457 |
458 |
459 |
if (dsf_grid[i][j].nval > 1) { |
460 |
dsf_grid[i][j].vsum /= (float)dsf_grid[i][j].nval; |
461 |
dsf_grid[i][j].nval = 1; |
462 |
463 |
464 |
465 |
/* Compute (and allocate) migration price matrix for optimization */ |
466 |
static float * |
467 |
price_routes(const RBFNODE *from_rbf, const RBFNODE *to_rbf) |
468 |
469 |
float *pmtx = (float *)malloc(sizeof(float) * |
470 |
from_rbf->nrbf * to_rbf->nrbf); |
471 |
FVECT *vto = (FVECT *)malloc(sizeof(FVECT) * to_rbf->nrbf); |
472 |
int i, j; |
473 |
474 |
if ((pmtx == NULL) | (vto == NULL)) { |
475 |
fputs("Out of memory in migration_costs()\n", stderr); |
476 |
exit(1); |
477 |
478 |
for (j = to_rbf->nrbf; j--; ) /* save repetitive ops. */ |
479 |
ovec_from_pos(vto[j], to_rbf->rbfa[j].gx, to_rbf->rbfa[j].gy); |
480 |
481 |
for (i = from_rbf->nrbf; i--; ) { |
482 |
const double from_ang = R2ANG(from_rbf->rbfa[i].crad); |
483 |
FVECT vfrom; |
484 |
ovec_from_pos(vfrom, from_rbf->rbfa[i].gx, from_rbf->rbfa[i].gy); |
485 |
for (j = to_rbf->nrbf; j--; ) |
486 |
pmtx[i*to_rbf->nrbf + j] = acos(DOT(vfrom, vto[j])) + |
487 |
fabs(R2ANG(to_rbf->rbfa[j].crad) - from_ang); |
488 |
489 |
free(vto); |
490 |
return(pmtx); |
491 |
492 |
493 |
/* Comparison routine needed for sorting price row */ |
494 |
static const float *price_arr; |
495 |
static int |
496 |
msrt_cmp(const void *p1, const void *p2) |
497 |
498 |
float c1 = price_arr[*(const int *)p1]; |
499 |
float c2 = price_arr[*(const int *)p2]; |
500 |
501 |
if (c1 > c2) return(1); |
502 |
if (c1 < c2) return(-1); |
503 |
return(0); |
504 |
505 |
506 |
/* Compute minimum (optimistic) cost for moving the given source material */ |
507 |
static double |
508 |
min_cost(double amt2move, const double *avail, const float *price, int n) |
509 |
510 |
static int *price_sort = NULL; |
511 |
static int n_alloc = 0; |
512 |
double total_cost = 0; |
513 |
int i; |
514 |
515 |
if (amt2move <= FTINY) /* pre-emptive check */ |
516 |
return(0.); |
517 |
if (n > n_alloc) { /* (re)allocate sort array */ |
518 |
if (n_alloc) free(price_sort); |
519 |
price_sort = (int *)malloc(sizeof(int)*n); |
520 |
if (price_sort == NULL) { |
521 |
fputs("Out of memory in min_cost()\n", stderr); |
522 |
exit(1); |
523 |
524 |
n_alloc = n; |
525 |
526 |
for (i = n; i--; ) |
527 |
price_sort[i] = i; |
528 |
price_arr = price; |
529 |
qsort(price_sort, n, sizeof(int), &msrt_cmp); |
530 |
/* move cheapest first */ |
531 |
for (i = 0; i < n && amt2move > FTINY; i++) { |
532 |
int d = price_sort[i]; |
533 |
double amt = (amt2move < avail[d]) ? amt2move : avail[d]; |
534 |
535 |
total_cost += amt * price[d]; |
536 |
amt2move -= amt; |
537 |
538 |
return(total_cost); |
539 |
540 |
541 |
/* Take a step in migration by choosing optimal bucket to transfer */ |
542 |
static double |
543 |
migration_step(MIGRATION *mig, double *src_rem, double *dst_rem, const float *pmtx) |
544 |
545 |
static double *src_cost = NULL; |
546 |
int n_alloc = 0; |
547 |
const double maxamt = 2./(mtx_nrows(mig)*mtx_ncols(mig)); |
548 |
double amt = 0; |
549 |
struct { |
550 |
int s, d; /* source and destination */ |
551 |
double price; /* price estimate per amount moved */ |
552 |
double amt; /* amount we can move */ |
553 |
} cur, best; |
554 |
int i; |
555 |
556 |
if (mtx_nrows(mig) > n_alloc) { /* allocate cost array */ |
557 |
if (n_alloc) |
558 |
free(src_cost); |
559 |
src_cost = (double *)malloc(sizeof(double)*mtx_nrows(mig)); |
560 |
if (src_cost == NULL) { |
561 |
fputs("Out of memory in migration_step()\n", stderr); |
562 |
exit(1); |
563 |
564 |
n_alloc = mtx_nrows(mig); |
565 |
566 |
for (i = mtx_nrows(mig); i--; ) /* starting costs for diff. */ |
567 |
src_cost[i] = min_cost(src_rem[i], dst_rem, |
568 |
pmtx+i*mtx_ncols(mig), mtx_ncols(mig)); |
569 |
570 |
/* find best source & dest. */ |
571 |
best.s = best.d = -1; best.price = FHUGE; best.amt = 0; |
572 |
for (cur.s = mtx_nrows(mig); cur.s--; ) { |
573 |
const float *price = pmtx + cur.s*mtx_ncols(mig); |
574 |
double cost_others = 0; |
575 |
if (src_rem[cur.s] <= FTINY) |
576 |
continue; |
577 |
cur.d = -1; /* examine cheapest dest. */ |
578 |
for (i = mtx_ncols(mig); i--; ) |
579 |
if (dst_rem[i] > FTINY && |
580 |
(cur.d < 0 || price[i] < price[cur.d])) |
581 |
cur.d = i; |
582 |
if (cur.d < 0) |
583 |
return(.0); |
584 |
if ((cur.price = price[cur.d]) >= best.price) |
585 |
continue; /* no point checking further */ |
586 |
cur.amt = (src_rem[cur.s] < dst_rem[cur.d]) ? |
587 |
src_rem[cur.s] : dst_rem[cur.d]; |
588 |
if (cur.amt > maxamt) cur.amt = maxamt; |
589 |
dst_rem[cur.d] -= cur.amt; /* add up differential costs */ |
590 |
for (i = mtx_nrows(mig); i--; ) { |
591 |
if (i == cur.s) continue; |
592 |
cost_others += min_cost(src_rem[i], dst_rem, price, mtx_ncols(mig)) |
593 |
- src_cost[i]; |
594 |
595 |
dst_rem[cur.d] += cur.amt; /* undo trial move */ |
596 |
cur.price += cost_others/cur.amt; /* adjust effective price */ |
597 |
if (cur.price < best.price) /* are we better than best? */ |
598 |
best = cur; |
599 |
600 |
if ((best.s < 0) | (best.d < 0)) |
601 |
return(.0); |
602 |
/* make the actual move */ |
603 |
mig->mtx[mtx_ndx(mig,best.s,best.d)] += best.amt; |
604 |
src_rem[best.s] -= best.amt; |
605 |
dst_rem[best.d] -= best.amt; |
606 |
return(best.amt); |
607 |
608 |
609 |
/* Compute (and insert) migration along directed edge */ |
610 |
static MIGRATION * |
611 |
make_migration(RBFNODE *from_rbf, RBFNODE *to_rbf) |
612 |
613 |
const double end_thresh = 0.02/(from_rbf->nrbf*to_rbf->nrbf); |
614 |
float *pmtx = price_routes(from_rbf, to_rbf); |
615 |
MIGRATION *newmig = (MIGRATION *)malloc(sizeof(MIGRATION) + |
616 |
sizeof(float) * |
617 |
(from_rbf->nrbf*to_rbf->nrbf - 1)); |
618 |
double *src_rem = (double *)malloc(sizeof(double)*from_rbf->nrbf); |
619 |
double *dst_rem = (double *)malloc(sizeof(double)*to_rbf->nrbf); |
620 |
double total_rem = 1.; |
621 |
int i; |
622 |
623 |
if ((newmig == NULL) | (src_rem == NULL) | (dst_rem == NULL)) { |
624 |
fputs("Out of memory in make_migration()\n", stderr); |
625 |
exit(1); |
626 |
627 |
#ifdef DEBUG |
628 |
629 |
double theta, phi; |
630 |
theta = acos(from_rbf->invec[2])*(180./M_PI); |
631 |
phi = atan2(from_rbf->invec[1],from_rbf->invec[0])*(180./M_PI); |
632 |
fprintf(stderr, "Building path from (theta,phi) (%d,%d) to ", |
633 |
round(theta), round(phi)); |
634 |
theta = acos(to_rbf->invec[2])*(180./M_PI); |
635 |
phi = atan2(to_rbf->invec[1],to_rbf->invec[0])*(180./M_PI); |
636 |
fprintf(stderr, "(%d,%d)\n", round(theta), round(phi)); |
637 |
638 |
#endif |
639 |
newmig->next = NULL; |
640 |
newmig->rbfv[0] = from_rbf; |
641 |
newmig->rbfv[1] = to_rbf; |
642 |
newmig->enxt[0] = newmig->enxt[1] = NULL; |
643 |
memset(newmig->mtx, 0, sizeof(float)*from_rbf->nrbf*to_rbf->nrbf); |
644 |
/* starting quantities */ |
645 |
for (i = from_rbf->nrbf; i--; ) |
646 |
src_rem[i] = rbf_volume(&from_rbf->rbfa[i]) / from_rbf->vtotal; |
647 |
for (i = to_rbf->nrbf; i--; ) |
648 |
dst_rem[i] = rbf_volume(&to_rbf->rbfa[i]) / to_rbf->vtotal; |
649 |
/* move a bit at a time */ |
650 |
while (total_rem > end_thresh) |
651 |
total_rem -= migration_step(newmig, src_rem, dst_rem, pmtx); |
652 |
653 |
free(pmtx); /* free working arrays */ |
654 |
free(src_rem); |
655 |
free(dst_rem); |
656 |
for (i = from_rbf->nrbf; i--; ) { /* normalize final matrix */ |
657 |
float nf = rbf_volume(&from_rbf->rbfa[i]); |
658 |
int j; |
659 |
if (nf <= FTINY) continue; |
660 |
nf = from_rbf->vtotal / nf; |
661 |
662 |
newmig->mtx[mtx_ndx(newmig,i,j)] *= nf; |
663 |
664 |
/* insert in edge lists */ |
665 |
newmig->enxt[0] = from_rbf->ejl; |
666 |
from_rbf->ejl = newmig; |
667 |
newmig->enxt[1] = to_rbf->ejl; |
668 |
to_rbf->ejl = newmig; |
669 |
newmig->next = mig_list; |
670 |
return(mig_list = newmig); |
671 |
672 |
673 |
/* Get triangle surface orientation (unnormalized) */ |
674 |
static void |
675 |
tri_orient(FVECT vres, const FVECT v1, const FVECT v2, const FVECT v3) |
676 |
677 |
FVECT v2minus1, v3minus2; |
678 |
679 |
VSUB(v2minus1, v2, v1); |
680 |
VSUB(v3minus2, v3, v2); |
681 |
VCROSS(vres, v2minus1, v3minus2); |
682 |
683 |
684 |
/* Determine if vertex order is reversed (inward normal) */ |
685 |
static int |
686 |
is_rev_tri(const FVECT v1, const FVECT v2, const FVECT v3) |
687 |
688 |
FVECT tor; |
689 |
690 |
tri_orient(tor, v1, v2, v3); |
691 |
692 |
return(DOT(tor, v2) < 0.); |
693 |
694 |
695 |
/* Find vertices completing triangles on either side of the given edge */ |
696 |
static int |
697 |
get_triangles(RBFNODE *rbfv[2], const MIGRATION *mig) |
698 |
699 |
const MIGRATION *ej, *ej2; |
700 |
RBFNODE *tv; |
701 |
702 |
rbfv[0] = rbfv[1] = NULL; |
703 |
for (ej = mig->rbfv[0]->ejl; ej != NULL; |
704 |
ej = nextedge(mig->rbfv[0],ej)) { |
705 |
if (ej == mig) |
706 |
continue; |
707 |
tv = opp_rbf(mig->rbfv[0],ej); |
708 |
for (ej2 = tv->ejl; ej2 != NULL; ej2 = nextedge(tv,ej2)) |
709 |
if (opp_rbf(tv,ej2) == mig->rbfv[1]) { |
710 |
rbfv[is_rev_tri(mig->rbfv[0]->invec, |
711 |
mig->rbfv[1]->invec, |
712 |
tv->invec)] = tv; |
713 |
break; |
714 |
715 |
716 |
return((rbfv[0] != NULL) + (rbfv[1] != NULL)); |
717 |
718 |
719 |
/* Find context hull vertex to complete triangle (oriented call) */ |
720 |
static RBFNODE * |
721 |
find_chull_vert(const RBFNODE *rbf0, const RBFNODE *rbf1) |
722 |
723 |
FVECT vmid, vor; |
724 |
RBFNODE *rbf, *rbfbest = NULL; |
725 |
double dprod2, bestdprod2 = 0.5; |
726 |
727 |
VADD(vmid, rbf0->invec, rbf1->invec); |
728 |
if (normalize(vmid) == 0) |
729 |
return(NULL); |
730 |
/* XXX exhaustive search */ |
731 |
for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) { |
732 |
if ((rbf == rbf0) | (rbf == rbf1)) |
733 |
continue; |
734 |
tri_orient(vor, rbf0->invec, rbf1->invec, rbf->invec); |
735 |
dprod2 = DOT(vor, vmid); |
736 |
if (dprod2 <= FTINY) |
737 |
continue; /* wrong orientation */ |
738 |
dprod2 *= dprod2 / DOT(vor,vor); |
739 |
if (dprod2 > bestdprod2) { /* more convex than prev? */ |
740 |
rbfbest = rbf; |
741 |
bestdprod2 = dprod2; |
742 |
743 |
744 |
return(rbf); |
745 |
746 |
747 |
/* Create new migration edge and grow mesh recursively around it */ |
748 |
static void |
749 |
mesh_from_edge(RBFNODE *rbf0, RBFNODE *rbf1) |
750 |
751 |
MIGRATION *newej; |
752 |
RBFNODE *tvert[2]; |
753 |
754 |
if (rbf0 < rbf1) /* avoid migration loops */ |
755 |
newej = make_migration(rbf0, rbf1); |
756 |
else |
757 |
newej = make_migration(rbf1, rbf0); |
758 |
/* triangle on either side? */ |
759 |
get_triangles(tvert, newej); |
760 |
if (tvert[0] == NULL) { /* recurse on new right edge */ |
761 |
tvert[0] = find_chull_vert(newej->rbfv[0], newej->rbfv[1]); |
762 |
if (tvert[0] != NULL) { |
763 |
mesh_from_edge(rbf0, tvert[0]); |
764 |
mesh_from_edge(rbf1, tvert[0]); |
765 |
766 |
767 |
if (tvert[1] == NULL) { /* recurse on new left edge */ |
768 |
tvert[1] = find_chull_vert(newej->rbfv[1], newej->rbfv[0]); |
769 |
if (tvert[1] != NULL) { |
770 |
mesh_from_edge(rbf0, tvert[1]); |
771 |
mesh_from_edge(rbf1, tvert[1]); |
772 |
773 |
774 |
775 |
776 |
/* Draw edge list into mig_grid array */ |
777 |
static void |
778 |
draw_edges() |
779 |
780 |
int nnull = 0, ntot = 0; |
781 |
MIGRATION *ej; |
782 |
int p0[2], p1[2]; |
783 |
784 |
/* memset(mig_grid, 0, sizeof(mig_grid)); */ |
785 |
for (ej = mig_list; ej != NULL; ej = ej->next) { |
786 |
++ntot; |
787 |
pos_from_vec(p0, ej->rbfv[0]->invec); |
788 |
pos_from_vec(p1, ej->rbfv[1]->invec); |
789 |
if ((p0[0] == p1[0]) & (p0[1] == p1[1])) { |
790 |
++nnull; |
791 |
mig_grid[p0[0]][p0[1]] = ej; |
792 |
continue; |
793 |
794 |
if (abs(p1[0]-p0[0]) > abs(p1[1]-p0[1])) { |
795 |
const int xstep = 2*(p1[0] > p0[0]) - 1; |
796 |
const double ystep = (double)((p1[1]-p0[1])*xstep) / |
797 |
(double)(p1[0]-p0[0]); |
798 |
int x; |
799 |
double y; |
800 |
for (x = p0[0], y = p0[1]+.5; x != p1[0]; |
801 |
x += xstep, y += ystep) |
802 |
mig_grid[x][(int)y] = ej; |
803 |
804 |
} else { |
805 |
const int ystep = 2*(p1[1] > p0[1]) - 1; |
806 |
const double xstep = (double)((p1[0]-p0[0])*ystep) / |
807 |
(double)(p1[1]-p0[1]); |
808 |
int y; |
809 |
double x; |
810 |
for (y = p0[1], x = p0[0]+.5; y != p1[1]; |
811 |
y += ystep, x += xstep) |
812 |
mig_grid[(int)x][y] = ej; |
813 |
814 |
815 |
816 |
if (nnull) |
817 |
fprintf(stderr, "Warning: %d of %d edges are null\n", |
818 |
nnull, ntot); |
819 |
820 |
821 |
/* Build our triangle mesh from recorded RBFs */ |
822 |
static void |
823 |
build_mesh() |
824 |
825 |
double best2 = M_PI*M_PI; |
826 |
RBFNODE *rbf, *rbf_near = NULL; |
827 |
/* check if isotropic */ |
828 |
if (single_plane_incident) { |
829 |
for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) |
830 |
if (rbf->next != NULL) |
831 |
make_migration(rbf, rbf->next); |
832 |
return; |
833 |
834 |
/* find RBF nearest to head */ |
835 |
if (dsf_list == NULL) |
836 |
return; |
837 |
for (rbf = dsf_list->next; rbf != NULL; rbf = rbf->next) { |
838 |
double dist2 = 2. - 2.*DOT(dsf_list->invec,rbf->invec); |
839 |
if (dist2 < best2) { |
840 |
rbf_near = rbf; |
841 |
best2 = dist2; |
842 |
843 |
844 |
if (rbf_near == NULL) { |
845 |
fputs("Cannot find nearest point for first edge\n", stderr); |
846 |
exit(1); |
847 |
848 |
/* build mesh from this edge */ |
849 |
mesh_from_edge(dsf_list, rbf_near); |
850 |
/* draw edge list into grid */ |
851 |
draw_edges(); |
852 |
853 |
854 |
/* Identify enclosing triangle for this position (flood fill raster check) */ |
855 |
static int |
856 |
identify_tri(MIGRATION *miga[3], unsigned char vmap[GRIDRES][(GRIDRES+7)/8], |
857 |
int px, int py) |
858 |
859 |
const int btest = 1<<(py&07); |
860 |
861 |
if (vmap[px][py>>3] & btest) /* already visited here? */ |
862 |
return(1); |
863 |
/* else mark it */ |
864 |
vmap[px][py>>3] |= btest; |
865 |
866 |
if (mig_grid[px][py] != NULL) { /* are we on an edge? */ |
867 |
int i; |
868 |
for (i = 0; i < 3; i++) { |
869 |
if (miga[i] == mig_grid[px][py]) |
870 |
return(1); |
871 |
if (miga[i] != NULL) |
872 |
continue; |
873 |
miga[i] = mig_grid[px][py]; |
874 |
return(1); |
875 |
876 |
return(0); /* outside triangle! */ |
877 |
878 |
/* check neighbors (flood) */ |
879 |
if (px > 0 && !identify_tri(miga, vmap, px-1, py)) |
880 |
return(0); |
881 |
if (px < GRIDRES-1 && !identify_tri(miga, vmap, px+1, py)) |
882 |
return(0); |
883 |
if (py > 0 && !identify_tri(miga, vmap, px, py-1)) |
884 |
return(0); |
885 |
if (py < GRIDRES-1 && !identify_tri(miga, vmap, px, py+1)) |
886 |
return(0); |
887 |
return(1); /* this neighborhood done */ |
888 |
889 |
890 |
/* Find edge(s) for interpolating the given incident vector */ |
891 |
static int |
892 |
get_interp(MIGRATION *miga[3], const FVECT invec) |
893 |
894 |
miga[0] = miga[1] = miga[2] = NULL; |
895 |
if (single_plane_incident) { /* isotropic BSDF? */ |
896 |
RBFNODE *rbf; /* find edge we're on */ |
897 |
898 |
if (input_orient*rbf->invec[2] < input_orient*invec[2]) |
899 |
break; |
900 |
if (rbf->next != NULL && |
901 |
input_orient*rbf->next->invec[2] < |
902 |
input_orient*invec[2]) { |
903 |
for (miga[0] = rbf->ejl; miga[0] != NULL; |
904 |
miga[0] = nextedge(rbf,miga[0])) |
905 |
if (opp_rbf(rbf,miga[0]) == rbf->next) |
906 |
return(1); |
907 |
break; |
908 |
909 |
910 |
return(0); /* outside range! */ |
911 |
912 |
{ /* else use triagnle mesh */ |
913 |
unsigned char floodmap[GRIDRES][(GRIDRES+7)/8]; |
914 |
int pstart[2]; |
915 |
916 |
pos_from_vec(pstart, invec); |
917 |
memset(floodmap, 0, sizeof(floodmap)); |
918 |
/* call flooding function */ |
919 |
if (!identify_tri(miga, floodmap, pstart[0], pstart[1])) |
920 |
return(0); /* outside mesh */ |
921 |
if ((miga[0] == NULL) | (miga[2] == NULL)) |
922 |
return(0); /* should never happen */ |
923 |
if (miga[1] == NULL) |
924 |
return(1); /* on edge */ |
925 |
return(3); /* else in triangle */ |
926 |
927 |
928 |
929 |
/* Advect and allocate new RBF along edge */ |
930 |
static RBFNODE * |
931 |
e_advect_rbf(const MIGRATION *mig, const FVECT invec) |
932 |
933 |
RBFNODE *rbf; |
934 |
int n, i, j; |
935 |
double t, full_dist; |
936 |
/* get relative position */ |
937 |
t = acos(DOT(invec, mig->rbfv[0]->invec)); |
938 |
if (t < M_PI/GRIDRES) { /* near first DSF */ |
939 |
n = sizeof(RBFNODE) + sizeof(RBFVAL)*(mig->rbfv[0]->nrbf-1); |
940 |
rbf = (RBFNODE *)malloc(n); |
941 |
if (rbf == NULL) |
942 |
goto memerr; |
943 |
memcpy(rbf, mig->rbfv[0], n); /* just duplicate */ |
944 |
return(rbf); |
945 |
946 |
full_dist = acos(DOT(mig->rbfv[0]->invec, mig->rbfv[1]->invec)); |
947 |
if (t > full_dist-M_PI/GRIDRES) { /* near second DSF */ |
948 |
n = sizeof(RBFNODE) + sizeof(RBFVAL)*(mig->rbfv[1]->nrbf-1); |
949 |
950 |
if (rbf == NULL) |
951 |
goto memerr; |
952 |
memcpy(rbf, mig->rbfv[1], n); /* just duplicate */ |
953 |
return(rbf); |
954 |
955 |
t /= full_dist; |
956 |
n = 0; /* count migrating particles */ |
957 |
for (i = 0; i < mtx_nrows(mig); i++) |
958 |
for (j = 0; j < mtx_ncols(mig); j++) |
959 |
n += (mig->mtx[mtx_ndx(mig,i,j)] > FTINY); |
960 |
961 |
rbf = (RBFNODE *)malloc(sizeof(RBFNODE) + sizeof(RBFVAL)*(n-1)); |
962 |
if (rbf == NULL) |
963 |
goto memerr; |
964 |
rbf->next = NULL; rbf->ejl = NULL; |
965 |
VCOPY(rbf->invec, invec); |
966 |
rbf->nrbf = n; |
967 |
rbf->vtotal = 1.-t + t*mig->rbfv[1]->vtotal/mig->rbfv[0]->vtotal; |
968 |
n = 0; /* advect RBF lobes */ |
969 |
for (i = 0; i < mtx_nrows(mig); i++) { |
970 |
const RBFVAL *rbf0i = &mig->rbfv[0]->rbfa[i]; |
971 |
const float peak0 = rbf0i->peak; |
972 |
const double rad0 = R2ANG(rbf0i->crad); |
973 |
FVECT v0; |
974 |
float mv; |
975 |
ovec_from_pos(v0, rbf0i->gx, rbf0i->gy); |
976 |
977 |
if ((mv = mig->mtx[mtx_ndx(mig,i,j)]) > FTINY) { |
978 |
const RBFVAL *rbf1j = &mig->rbfv[1]->rbfa[j]; |
979 |
double rad1 = R2ANG(rbf1j->crad); |
980 |
FVECT v; |
981 |
int pos[2]; |
982 |
rbf->rbfa[n].peak = peak0 * mv * rbf->vtotal; |
983 |
rbf->rbfa[n].crad = ANG2R(sqrt(rad0*rad0*(1.-t) + |
984 |
rad1*rad1*t)); |
985 |
ovec_from_pos(v, rbf1j->gx, rbf1j->gy); |
986 |
geodesic(v, v0, v, t, GEOD_REL); |
987 |
pos_from_vec(pos, v); |
988 |
rbf->rbfa[n].gx = pos[0]; |
989 |
rbf->rbfa[n].gy = pos[1]; |
990 |
++n; |
991 |
992 |
993 |
rbf->vtotal *= mig->rbfv[0]->vtotal; /* turn ratio into actual */ |
994 |
return(rbf); |
995 |
memerr: |
996 |
fputs("Out of memory in e_advect_rbf()\n", stderr); |
997 |
exit(1); |
998 |
return(NULL); /* pro forma return */ |
999 |
1000 |
1001 |
/* Insert vertex in ordered list */ |
1002 |
static void |
1003 |
insert_vert(RBFNODE **vlist, RBFNODE *v) |
1004 |
1005 |
int i, j; |
1006 |
1007 |
for (i = 0; vlist[i] != NULL; i++) { |
1008 |
if (v == vlist[i]) |
1009 |
return; |
1010 |
if (v < vlist[i]) |
1011 |
break; |
1012 |
1013 |
for (j = i; vlist[j] != NULL; j++) |
1014 |
1015 |
while (j > i) { |
1016 |
vlist[j] = vlist[j-1]; |
1017 |
--j; |
1018 |
1019 |
vlist[i] = v; |
1020 |
1021 |
1022 |
/* Sort triangle edges in standard order */ |
1023 |
static void |
1024 |
order_triangle(MIGRATION *miga[3]) |
1025 |
1026 |
RBFNODE *vert[4]; |
1027 |
MIGRATION *ord[3]; |
1028 |
int i; |
1029 |
/* order vertices, first */ |
1030 |
memset(vert, 0, sizeof(vert)); |
1031 |
1032 |
insert_vert(vert, miga[i]->rbfv[0]); |
1033 |
insert_vert(vert, miga[i]->rbfv[1]); |
1034 |
1035 |
/* identify edge 0 */ |
1036 |
for (i = 0; i < 3; i++) |
1037 |
if (miga[i]->rbfv[0] == vert[0] && |
1038 |
miga[i]->rbfv[1] == vert[1]) { |
1039 |
ord[0] = miga[i]; |
1040 |
break; |
1041 |
1042 |
/* identify edge 1 */ |
1043 |
1044 |
if (miga[i]->rbfv[0] == vert[1] && |
1045 |
miga[i]->rbfv[1] == vert[2]) { |
1046 |
ord[1] = miga[i]; |
1047 |
break; |
1048 |
1049 |
/* identify edge 2 */ |
1050 |
1051 |
1052 |
1053 |
ord[2] = miga[i]; |
1054 |
break; |
1055 |
1056 |
miga[0] = ord[0]; miga[1] = ord[1]; miga[2] = ord[2]; |
1057 |
1058 |
1059 |
/* Partially advect between recorded incident angles and allocate new RBF */ |
1060 |
static RBFNODE * |
1061 |
advect_rbf(const FVECT invec) |
1062 |
1063 |
MIGRATION *miga[3]; |
1064 |
RBFNODE *rbf; |
1065 |
float mbfact, mcfact; |
1066 |
int n, i, j, k; |
1067 |
FVECT v0, v1, v2; |
1068 |
double s, t; |
1069 |
1070 |
if (!get_interp(miga, invec)) /* can't interpolate? */ |
1071 |
return(NULL); |
1072 |
if (miga[1] == NULL) /* along edge? */ |
1073 |
return(e_advect_rbf(miga[0], invec)); |
1074 |
/* put in standard order */ |
1075 |
order_triangle(miga); |
1076 |
/* figure out position */ |
1077 |
fcross(v0, miga[2]->rbfv[0]->invec, miga[2]->rbfv[1]->invec); |
1078 |
normalize(v0); |
1079 |
fcross(v2, miga[1]->rbfv[0]->invec, miga[1]->rbfv[1]->invec); |
1080 |
normalize(v2); |
1081 |
fcross(v1, invec, miga[1]->rbfv[1]->invec); |
1082 |
normalize(v1); |
1083 |
s = acos(DOT(v0,v1)) / acos(DOT(v0,v2)); |
1084 |
geodesic(v1, miga[0]->rbfv[0]->invec, miga[0]->rbfv[1]->invec, |
1085 |
s, GEOD_REL); |
1086 |
t = acos(DOT(v1,invec)) / acos(DOT(v1,miga[1]->rbfv[1]->invec)); |
1087 |
1088 |
for (i = 0; i < mtx_nrows(miga[0]); i++) |
1089 |
for (j = 0; j < mtx_ncols(miga[0]); j++) |
1090 |
for (k = (miga[0]->mtx[mtx_ndx(miga[0],i,j)] > FTINY) * |
1091 |
mtx_ncols(miga[2]); k--; ) |
1092 |
n += (miga[2]->mtx[mtx_ndx(miga[2],i,k)] > FTINY && |
1093 |
miga[1]->mtx[mtx_ndx(miga[1],j,k)] > FTINY); |
1094 |
1095 |
1096 |
if (rbf == NULL) { |
1097 |
fputs("Out of memory in advect_rbf()\n", stderr); |
1098 |
exit(1); |
1099 |
1100 |
1101 |
1102 |
rbf->nrbf = n; |
1103 |
n = 0; /* compute RBF lobes */ |
1104 |
mbfact = s * miga[0]->rbfv[1]->vtotal/miga[0]->rbfv[0]->vtotal * |
1105 |
(1.-t + t*miga[1]->rbfv[1]->vtotal/miga[1]->rbfv[0]->vtotal); |
1106 |
mcfact = (1.-s) * |
1107 |
(1.-t + t*miga[2]->rbfv[1]->vtotal/miga[2]->rbfv[0]->vtotal); |
1108 |
for (i = 0; i < mtx_nrows(miga[0]); i++) { |
1109 |
const RBFVAL *rbf0i = &miga[0]->rbfv[0]->rbfa[i]; |
1110 |
const float w0i = rbf0i->peak; |
1111 |
const double rad0i = R2ANG(rbf0i->crad); |
1112 |
1113 |
for (j = 0; j < mtx_ncols(miga[0]); j++) { |
1114 |
const float ma = miga[0]->mtx[mtx_ndx(miga[0],i,j)]; |
1115 |
const RBFVAL *rbf1j; |
1116 |
double rad1j, srad2; |
1117 |
if (ma <= FTINY) |
1118 |
continue; |
1119 |
rbf1j = &miga[0]->rbfv[1]->rbfa[j]; |
1120 |
rad1j = R2ANG(rbf1j->crad); |
1121 |
srad2 = (1.-s)*(1.-t)*rad0i*rad0i + s*(1.-t)*rad1j*rad1j; |
1122 |
ovec_from_pos(v1, rbf1j->gx, rbf1j->gy); |
1123 |
geodesic(v1, v0, v1, s, GEOD_REL); |
1124 |
for (k = 0; k < mtx_ncols(miga[2]); k++) { |
1125 |
float mb = miga[1]->mtx[mtx_ndx(miga[1],j,k)]; |
1126 |
float mc = miga[2]->mtx[mtx_ndx(miga[2],i,k)]; |
1127 |
const RBFVAL *rbf2k; |
1128 |
double rad2k; |
1129 |
FVECT vout; |
1130 |
int pos[2]; |
1131 |
if ((mb <= FTINY) | (mc <= FTINY)) |
1132 |
continue; |
1133 |
rbf2k = &miga[2]->rbfv[1]->rbfa[k]; |
1134 |
rbf->rbfa[n].peak = w0i * ma * (mb*mbfact + mc*mcfact); |
1135 |
rad2k = R2ANG(rbf2k->crad); |
1136 |
rbf->rbfa[n].crad = RAD2R(sqrt(srad2 + t*rad2k*rad2k)); |
1137 |
ovec_from_pos(v2, rbf2k->gx, rbf2k->gy); |
1138 |
geodesic(vout, v1, v2, t, GEOD_REL); |
1139 |
pos_from_vec(pos, vout); |
1140 |
1141 |
1142 |
++n; |
1143 |
1144 |
1145 |
1146 |
rbf->vtotal = miga[0]->rbfv[0]->vtotal * (mbfact + mcfact); |
1147 |
return(rbf); |
1148 |
1149 |
1150 |
#if 1 |
1151 |
/* Test main produces a Radiance model from the given input file */ |
1152 |
int |
1153 |
main(int argc, char *argv[]) |
1154 |
1155 |
char buf[128]; |
1156 |
FILE *pfp; |
1157 |
double bsdf; |
1158 |
FVECT dir; |
1159 |
int i, j, n; |
1160 |
1161 |
if (argc != 2) { |
1162 |
fprintf(stderr, "Usage: %s input.dat > output.rad\n", argv[0]); |
1163 |
return(1); |
1164 |
1165 |
if (!load_pabopto_meas(argv[1])) |
1166 |
return(1); |
1167 |
1168 |
compute_radii(); |
1169 |
cull_values(); |
1170 |
make_rbfrep(); |
1171 |
/* produce spheres at meas. */ |
1172 |
puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n"); |
1173 |
puts("void plastic pink\n0\n0\n5 .5 .05 .9 .04 .08\n"); |
1174 |
n = 0; |
1175 |
1176 |
1177 |
if (dsf_grid[i][j].vsum > .0f) { |
1178 |
ovec_from_pos(dir, i, j); |
1179 |
bsdf = dsf_grid[i][j].vsum / dir[2]; |
1180 |
1181 |
printf("pink cone c%04d\n0\n0\n8\n", ++n); |
1182 |
printf("\t%.6g %.6g %.6g\n", |
1183 |
dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf); |
1184 |
1185 |
dir[0]*(bsdf+.005), dir[1]*(bsdf+.005), |
1186 |
dir[2]*(bsdf+.005)); |
1187 |
puts("\t.003\t0\n"); |
1188 |
} else { |
1189 |
1190 |
printf("yellow sphere s%04d\n0\n0\n", ++n); |
1191 |
printf("4 %.6g %.6g %.6g .0015\n\n", |
1192 |
1193 |
1194 |
1195 |
/* output continuous surface */ |
1196 |
puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 .9\n"); |
1197 |
fflush(stdout); |
1198 |
sprintf(buf, "gensurf tgreen bsdf - - - %d %d", GRIDRES-1, GRIDRES-1); |
1199 |
pfp = popen(buf, "w"); |
1200 |
if (pfp == NULL) { |
1201 |
fputs(buf, stderr); |
1202 |
fputs(": cannot start command\n", stderr); |
1203 |
return(1); |
1204 |
1205 |
1206 |
1207 |
1208 |
bsdf = eval_rbfrep(dsf_list, dir) / dir[2]; |
1209 |
fprintf(pfp, "%.8e %.8e %.8e\n", |
1210 |
1211 |
1212 |
return(pclose(pfp)==0 ? 0 : 1); |
1213 |
1214 |
#endif |
