--- ray/src/cv/pabopto2xml.c 2012/09/19 22:03:37 2.11 +++ ray/src/cv/pabopto2xml.c 2012/09/20 01:23:36 2.12 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: pabopto2xml.c,v 2.11 2012/09/19 22:03:37 greg Exp $"; +static const char RCSid[] = "$Id: pabopto2xml.c,v 2.12 2012/09/20 01:23:36 greg Exp $"; #endif /* * Convert PAB-Opto measurements to XML format using tensor tree representation @@ -88,6 +88,12 @@ static MIGRATION *mig_grid[GRIDRES][GRIDRES]; #define round(v) (int)((v) + .5 - ((v) < -.5)) +char *progname; + /* percentage to cull (<0 to turn off) */ +int pctcull = 90; + /* sampling order */ +int samp_order = 0; + /* Compute volume associated with Gaussian lobe */ static double rbf_volume(const RBFVAL *rbfp) @@ -136,6 +142,8 @@ eval_rbfrep(const RBFNODE *rp, const FVECT outvec) double sig2; int n; + if (rp == NULL) + return(.0); rbfp = rp->rbfa; for (n = rp->nrbf; n--; rbfp++) { ovec_from_pos(odir, rbfp->gx, rbfp->gy); @@ -173,6 +181,7 @@ static RBFNODE * make_rbfrep(void) { int niter = 16; + int minrad = ANG2R(pow(2., 1.-samp_order)); double lastVar, thisVar = 100.; int nn; RBFNODE *newnode; @@ -204,6 +213,8 @@ make_rbfrep(void) newnode->rbfa[nn].crad = RSCA*dsf_grid[i][j].crad + .5; newnode->rbfa[nn].gx = i; newnode->rbfa[nn].gy = j; + if (newnode->rbfa[nn].crad < minrad) + minrad = newnode->rbfa[nn].crad; ++nn; } /* iterate to improve interpolation accuracy */ @@ -236,6 +247,9 @@ make_rbfrep(void) newnode->vtotal += rbf_volume(&newnode->rbfa[nn++]); insert_dsf(newnode); + /* adjust sampling resolution */ + samp_order = log(2./R2ANG(minrad))/log(2.) + .5; + return(newnode); } @@ -909,7 +923,7 @@ get_interp(MIGRATION *miga[3], const FVECT invec) } return(0); /* outside range! */ } - { /* else use triagnle mesh */ + { /* else use triangle mesh */ unsigned char floodmap[GRIDRES][(GRIDRES+7)/8]; int pstart[2]; @@ -957,7 +971,10 @@ e_advect_rbf(const MIGRATION *mig, const FVECT invec) for (i = 0; i < mtx_nrows(mig); i++) for (j = 0; j < mtx_ncols(mig); j++) n += (mig->mtx[mtx_ndx(mig,i,j)] > FTINY); - +#ifdef DEBUG + fprintf(stderr, "Input RBFs have %d, %d nodes -> output has %d\n", + mig->rbfv[0]->nrbf, mig->rbfv[1]->nrbf, n); +#endif rbf = (RBFNODE *)malloc(sizeof(RBFNODE) + sizeof(RBFVAL)*(n-1)); if (rbf == NULL) goto memerr; @@ -1073,6 +1090,14 @@ advect_rbf(const FVECT invec) return(e_advect_rbf(miga[0], invec)); /* put in standard order */ order_triangle(miga); +#ifdef DEBUG + if (miga[0]->rbfv[0] != miga[2]->rbfv[0] | + miga[0]->rbfv[1] != miga[1]->rbfv[0] | + miga[1]->rbfv[1] != miga[2]->rbfv[1]) { + fputs("Triangle vertex screw-up!\n", stderr); + exit(1); + } +#endif /* figure out position */ fcross(v0, miga[2]->rbfv[0]->invec, miga[2]->rbfv[1]->invec); normalize(v0); @@ -1091,7 +1116,11 @@ advect_rbf(const FVECT invec) mtx_ncols(miga[2]); k--; ) n += (miga[2]->mtx[mtx_ndx(miga[2],i,k)] > FTINY && miga[1]->mtx[mtx_ndx(miga[1],j,k)] > FTINY); - +#ifdef DEBUG + fprintf(stderr, "Input RBFs have %d, %d, %d nodes -> output has %d\n", + miga[0]->rbfv[0]->nrbf, miga[0]->rbfv[1]->nrbf, + miga[2]->rbfv[1]->nrbf, n); +#endif rbf = (RBFNODE *)malloc(sizeof(RBFNODE) + sizeof(RBFVAL)*(n-1)); if (rbf == NULL) { fputs("Out of memory in advect_rbf()\n", stderr); @@ -1133,7 +1162,7 @@ advect_rbf(const FVECT invec) rbf2k = &miga[2]->rbfv[1]->rbfa[k]; rbf->rbfa[n].peak = w0i * ma * (mb*mbfact + mc*mcfact); rad2k = R2ANG(rbf2k->crad); - rbf->rbfa[n].crad = RAD2R(sqrt(srad2 + t*rad2k*rad2k)); + rbf->rbfa[n].crad = ANG2R(sqrt(srad2 + t*rad2k*rad2k)); ovec_from_pos(v2, rbf2k->gx, rbf2k->gy); geodesic(vout, v1, v2, t, GEOD_REL); pos_from_vec(pos, vout); @@ -1147,7 +1176,149 @@ advect_rbf(const FVECT invec) return(rbf); } +/* Interpolate and output isotropic BSDF data */ +static void +interp_isotropic() +{ + const int sqres = 1<= 0) { /* begin output */ + sprintf(cmd, "rttree_reduce -h -a -fd -r 3 -t %d -g %d", + pctcull, samp_order); + fflush(stdout); + ofp = popen(cmd, "w"); + if (ofp == NULL) { + fputs("Cannot create pipe for rttree_reduce\n", stderr); + exit(1); + } + } else + fputs("{\n", stdout); + /* run through directions */ + for (ix = 0; ix < sqres/2; ix++) { + RBFNODE *rbf; + SDsquare2disk(ivec, (ix+.5)/sqres, .5); + ivec[2] = input_orient * + sqrt(1. - ivec[0]*ivec[0] - ivec[1]*ivec[1]); + rbf = advect_rbf(ivec); + for (ox = 0; ox < sqres; ox++) + for (oy = 0; oy < sqres; oy++) { + SDsquare2disk(ovec, (ox+.5)/sqres, (oy+.5)/sqres); + ovec[2] = output_orient * + sqrt(1. - ovec[0]*ovec[0] - ovec[1]*ovec[1]); + bsdf = eval_rbfrep(rbf, ovec) / fabs(ovec[2]); + if (pctcull >= 0) + fwrite(&bsdf, sizeof(bsdf), 1, ofp); + else + printf("\t%.3e\n", bsdf); + } + free(rbf); + } + if (pctcull >= 0) { /* finish output */ + if (pclose(ofp)) { + fprintf(stderr, "Error running '%s'\n", cmd); + exit(1); + } + } else { + for (ix = sqres*sqres*sqres/2; ix--; ) + fputs("\t0\n", stdout); + fputs("}\n", stdout); + } +} + +/* Interpolate and output anisotropic BSDF data */ +static void +interp_anisotropic() +{ + const int sqres = 1<= 0) { /* begin output */ + sprintf(cmd, "rttree_reduce -h -a -fd -r 4 -t %d -g %d", + pctcull, samp_order); + fflush(stdout); + ofp = popen(cmd, "w"); + if (ofp == NULL) { + fputs("Cannot create pipe for rttree_reduce\n", stderr); + exit(1); + } + } else + fputs("{\n", stdout); + /* run through directions */ + for (ix = 0; ix < sqres; ix++) + for (iy = 0; iy < sqres; iy++) { + RBFNODE *rbf; + SDsquare2disk(ivec, (ix+.5)/sqres, (iy+.5)/sqres); + ivec[2] = input_orient * + sqrt(1. - ivec[0]*ivec[0] - ivec[1]*ivec[1]); + rbf = advect_rbf(ivec); + for (ox = 0; ox < sqres; ox++) + for (oy = 0; oy < sqres; oy++) { + SDsquare2disk(ovec, (ox+.5)/sqres, (oy+.5)/sqres); + ovec[2] = output_orient * + sqrt(1. - ovec[0]*ovec[0] - ovec[1]*ovec[1]); + bsdf = eval_rbfrep(rbf, ovec) / fabs(ovec[2]); + if (pctcull >= 0) + fwrite(&bsdf, sizeof(bsdf), 1, ofp); + else + printf("\t%.3e\n", bsdf); + } + free(rbf); + } + if (pctcull >= 0) { /* finish output */ + if (pclose(ofp)) { + fprintf(stderr, "Error running '%s'\n", cmd); + exit(1); + } + } else + fputs("}\n", stdout); +} + #if 1 +/* Read in BSDF files and interpolate as tensor tree representation */ +int +main(int argc, char *argv[]) +{ + RBFNODE *rbf; + double bsdf; + int i; + + progname = argv[0]; + if (argc > 2 && !strcmp(argv[1], "-t")) { + pctcull = atoi(argv[2]); + argv += 2; argc -= 2; + } + if (argc < 3) { + fprintf(stderr, + "Usage: %s [-t pctcull] meas1.dat meas2.dat .. > bsdf.xml\n", + progname); + return(1); + } + for (i = 1; i < argc; i++) { /* compile measurements */ + if (!load_pabopto_meas(argv[i])) + return(1); + compute_radii(); + cull_values(); + make_rbfrep(); + } + build_mesh(); /* create interpolation */ + /* xml_prologue(); /* start XML output */ + if (single_plane_incident) /* resample dist. */ + interp_isotropic(); + else + interp_anisotropic(); + /* xml_epilogue(); /* finish XML output */ + return(0); +} +#else /* Test main produces a Radiance model from the given input file */ int main(int argc, char *argv[])
