1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: pabopto2xml.c,v 2.7 2012/09/02 15:33:15 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Convert PAB-Opto measurements to XML format using tensor tree representation |
6 |
* Employs Bonneel et al. Earth Mover's Distance interpolant. |
7 |
8 |
* G.Ward |
9 |
10 |
11 |
#define _USE_MATH_DEFINES |
12 |
#include <stdio.h> |
13 |
#include <stdlib.h> |
14 |
#include <string.h> |
15 |
#include <ctype.h> |
16 |
#include <math.h> |
17 |
#include "bsdf.h" |
18 |
19 |
#ifndef GRIDRES |
20 |
#define GRIDRES 200 /* max. grid resolution per side */ |
21 |
#endif |
22 |
23 |
#define RSCA 2.7 /* radius scaling factor (empirical) */ |
24 |
25 |
/* convert to/from coded radians */ |
26 |
#define ANG2R(r) (int)((r)*((1<<16)/M_PI)) |
27 |
#define R2ANG(c) (((c)+.5)*(M_PI/(1<<16))) |
28 |
29 |
typedef struct { |
30 |
float vsum; /* DSF sum */ |
31 |
unsigned short nval; /* number of values in sum */ |
32 |
unsigned short crad; /* radius (coded angle) */ |
33 |
} GRIDVAL; /* grid value */ |
34 |
35 |
typedef struct { |
36 |
float peak; /* lobe value at peak */ |
37 |
38 |
unsigned char gx, gy; /* grid position */ |
39 |
} RBFVAL; /* radial basis function value */ |
40 |
41 |
struct s_rbfnode; /* forward declaration of RBF struct */ |
42 |
43 |
typedef struct s_migration { |
44 |
struct s_migration *next; /* next in global edge list */ |
45 |
struct s_rbfnode *rbfv[2]; /* from,to vertex */ |
46 |
struct s_migration *enxt[2]; /* next from,to sibling */ |
47 |
float mtx[1]; /* matrix (extends struct) */ |
48 |
} MIGRATION; /* migration link (winged edge structure) */ |
49 |
50 |
typedef struct s_rbfnode { |
51 |
struct s_rbfnode *next; /* next in global RBF list */ |
52 |
MIGRATION *ejl; /* edge list for this vertex */ |
53 |
FVECT invec; /* incident vector direction */ |
54 |
double vtotal; /* volume for normalization */ |
55 |
int nrbf; /* number of RBFs */ |
56 |
RBFVAL rbfa[1]; /* RBF array (extends struct) */ |
57 |
} RBFLIST; /* RBF representation of DSF @ 1 incidence */ |
58 |
59 |
/* our loaded grid for this incident angle */ |
60 |
static double theta_in_deg, phi_in_deg; |
61 |
static GRIDVAL dsf_grid[GRIDRES][GRIDRES]; |
62 |
63 |
/* processed incident DSF measurements */ |
64 |
static RBFLIST *dsf_list = NULL; |
65 |
66 |
/* RBF-linking matrices (edges) */ |
67 |
static MIGRATION *mig_list = NULL; |
68 |
69 |
#define mtx_nrows(m) ((m)->rbfv[0]->nrbf) |
70 |
#define mtx_ncols(m) ((m)->rbfv[1]->nrbf) |
71 |
#define mtx_ndx(m,i,j) ((i)*mtx_ncols(m) + (j)) |
72 |
#define is_src(rbf,m) ((rbf) == (m)->rbfv[0]) |
73 |
#define is_dest(rbf,m) ((rbf) == (m)->rbfv[1]) |
74 |
#define nextedge(rbf,m) (m)->enxt[is_dest(rbf,m)] |
75 |
76 |
/* Compute volume associated with Gaussian lobe */ |
77 |
static double |
78 |
rbf_volume(const RBFVAL *rbfp) |
79 |
80 |
double rad = R2ANG(rbfp->crad); |
81 |
82 |
return((2.*M_PI) * rbfp->peak * rad*rad); |
83 |
84 |
85 |
/* Compute outgoing vector from grid position */ |
86 |
static void |
87 |
vec_from_pos(FVECT vec, int xpos, int ypos) |
88 |
89 |
double uv[2]; |
90 |
double r2; |
91 |
92 |
SDsquare2disk(uv, (1./GRIDRES)*(xpos+.5), (1./GRIDRES)*(ypos+.5)); |
93 |
/* uniform hemispherical projection */ |
94 |
r2 = uv[0]*uv[0] + uv[1]*uv[1]; |
95 |
vec[0] = vec[1] = sqrt(2. - r2); |
96 |
vec[0] *= uv[0]; |
97 |
vec[1] *= uv[1]; |
98 |
vec[2] = 1. - r2; |
99 |
100 |
101 |
/* Compute grid position from normalized outgoing vector */ |
102 |
static void |
103 |
pos_from_vec(int pos[2], const FVECT vec) |
104 |
105 |
double sq[2]; /* uniform hemispherical projection */ |
106 |
double norm = 1./sqrt(1. + vec[2]); |
107 |
108 |
SDdisk2square(sq, vec[0]*norm, vec[1]*norm); |
109 |
110 |
pos[0] = (int)(sq[0]*GRIDRES); |
111 |
pos[1] = (int)(sq[1]*GRIDRES); |
112 |
113 |
114 |
/* Evaluate RBF for DSF at the given normalized outgoing direction */ |
115 |
static double |
116 |
eval_rbfrep(const RBFLIST *rp, const FVECT outvec) |
117 |
118 |
double res = .0; |
119 |
const RBFVAL *rbfp; |
120 |
FVECT odir; |
121 |
double sig2; |
122 |
int n; |
123 |
124 |
rbfp = rp->rbfa; |
125 |
for (n = rp->nrbf; n--; rbfp++) { |
126 |
vec_from_pos(odir, rbfp->gx, rbfp->gy); |
127 |
sig2 = R2ANG(rbfp->crad); |
128 |
sig2 = (DOT(odir,outvec) - 1.) / (sig2*sig2); |
129 |
if (sig2 > -19.) |
130 |
res += rbfp->peak * exp(sig2); |
131 |
132 |
return(res); |
133 |
134 |
135 |
/* Count up filled nodes and build RBF representation from current grid */ |
136 |
static RBFLIST * |
137 |
make_rbfrep(void) |
138 |
139 |
int niter = 16; |
140 |
double lastVar, thisVar = 100.; |
141 |
int nn; |
142 |
RBFLIST *newnode; |
143 |
int i, j; |
144 |
145 |
nn = 0; /* count selected bins */ |
146 |
for (i = 0; i < GRIDRES; i++) |
147 |
for (j = 0; j < GRIDRES; j++) |
148 |
nn += dsf_grid[i][j].nval; |
149 |
/* allocate RBF array */ |
150 |
newnode = (RBFLIST *)malloc(sizeof(RBFLIST) + sizeof(RBFVAL)*(nn-1)); |
151 |
if (newnode == NULL) { |
152 |
fputs("Out of memory in make_rbfrep()\n", stderr); |
153 |
exit(1); |
154 |
155 |
newnode->next = NULL; |
156 |
newnode->ejl = NULL; |
157 |
newnode->invec[2] = sin(M_PI/180.*theta_in_deg); |
158 |
newnode->invec[0] = cos(M_PI/180.*phi_in_deg)*newnode->invec[2]; |
159 |
newnode->invec[1] = sin(M_PI/180.*phi_in_deg)*newnode->invec[2]; |
160 |
newnode->invec[2] = sqrt(1. - newnode->invec[2]*newnode->invec[2]); |
161 |
newnode->vtotal = 0; |
162 |
newnode->nrbf = nn; |
163 |
nn = 0; /* fill RBF array */ |
164 |
165 |
166 |
if (dsf_grid[i][j].nval) { |
167 |
newnode->rbfa[nn].peak = dsf_grid[i][j].vsum; |
168 |
newnode->rbfa[nn].crad = RSCA*dsf_grid[i][j].crad + .5; |
169 |
newnode->rbfa[nn].gx = i; |
170 |
newnode->rbfa[nn].gy = j; |
171 |
++nn; |
172 |
173 |
/* iterate to improve interpolation accuracy */ |
174 |
do { |
175 |
double dsum = .0, dsum2 = .0; |
176 |
nn = 0; |
177 |
178 |
179 |
180 |
FVECT odir; |
181 |
double corr; |
182 |
vec_from_pos(odir, i, j); |
183 |
newnode->rbfa[nn++].peak *= corr = |
184 |
dsf_grid[i][j].vsum / |
185 |
eval_rbfrep(newnode, odir); |
186 |
dsum += corr - 1.; |
187 |
dsum2 += (corr-1.)*(corr-1.); |
188 |
189 |
lastVar = thisVar; |
190 |
thisVar = dsum2/(double)nn; |
191 |
192 |
fprintf(stderr, "Avg., RMS error: %.1f%% %.1f%%\n", |
193 |
100.*dsum/(double)nn, |
194 |
100.*sqrt(thisVar)); |
195 |
196 |
} while (--niter > 0 && lastVar-thisVar > 0.02*lastVar); |
197 |
198 |
nn = 0; /* compute sum for normalization */ |
199 |
while (nn < newnode->nrbf) |
200 |
newnode->vtotal += rbf_volume(&newnode->rbfa[nn++]); |
201 |
202 |
newnode->next = dsf_list; |
203 |
return(dsf_list = newnode); |
204 |
205 |
206 |
/* Load a set of measurements corresponding to a particular incident angle */ |
207 |
static int |
208 |
load_bsdf_meas(const char *fname) |
209 |
210 |
FILE *fp = fopen(fname, "r"); |
211 |
int inp_is_DSF = -1; |
212 |
double theta_out, phi_out, val; |
213 |
char buf[2048]; |
214 |
int n, c; |
215 |
216 |
if (fp == NULL) { |
217 |
fputs(fname, stderr); |
218 |
fputs(": cannot open\n", stderr); |
219 |
return(0); |
220 |
221 |
memset(dsf_grid, 0, sizeof(dsf_grid)); |
222 |
/* read header information */ |
223 |
while ((c = getc(fp)) == '#' || c == EOF) { |
224 |
if (fgets(buf, sizeof(buf), fp) == NULL) { |
225 |
226 |
fputs(": unexpected EOF\n", stderr); |
227 |
fclose(fp); |
228 |
return(0); |
229 |
230 |
if (!strcmp(buf, "format: theta phi DSF\n")) { |
231 |
inp_is_DSF = 1; |
232 |
continue; |
233 |
234 |
if (!strcmp(buf, "format: theta phi BSDF\n")) { |
235 |
inp_is_DSF = 0; |
236 |
continue; |
237 |
238 |
if (sscanf(buf, "intheta %lf", &theta_in_deg) == 1) |
239 |
continue; |
240 |
if (sscanf(buf, "inphi %lf", &phi_in_deg) == 1) |
241 |
continue; |
242 |
if (sscanf(buf, "incident_angle %lf %lf", |
243 |
&theta_in_deg, &phi_in_deg) == 2) |
244 |
continue; |
245 |
246 |
if (inp_is_DSF < 0) { |
247 |
248 |
fputs(": unknown format\n", stderr); |
249 |
fclose(fp); |
250 |
return(0); |
251 |
252 |
ungetc(c, fp); /* read actual data */ |
253 |
while (fscanf(fp, "%lf %lf %lf\n", &theta_out, &phi_out, &val) == 3) { |
254 |
FVECT ovec; |
255 |
int pos[2]; |
256 |
257 |
ovec[2] = sin(M_PI/180.*theta_out); |
258 |
ovec[0] = cos(M_PI/180.*phi_out) * ovec[2]; |
259 |
ovec[1] = sin(M_PI/180.*phi_out) * ovec[2]; |
260 |
ovec[2] = sqrt(1. - ovec[2]*ovec[2]); |
261 |
262 |
if (!inp_is_DSF) |
263 |
val *= ovec[2]; /* convert from BSDF to DSF */ |
264 |
265 |
pos_from_vec(pos, ovec); |
266 |
267 |
dsf_grid[pos[0]][pos[1]].vsum += val; |
268 |
dsf_grid[pos[0]][pos[1]].nval++; |
269 |
270 |
n = 0; |
271 |
while ((c = getc(fp)) != EOF) |
272 |
n += !isspace(c); |
273 |
if (n) |
274 |
fprintf(stderr, |
275 |
"%s: warning: %d unexpected characters past EOD\n", |
276 |
fname, n); |
277 |
fclose(fp); |
278 |
return(1); |
279 |
280 |
281 |
/* Compute radii for non-empty bins */ |
282 |
/* (distance to furthest empty bin for which non-empty bin is the closest) */ |
283 |
static void |
284 |
compute_radii(void) |
285 |
286 |
unsigned int fill_grid[GRIDRES][GRIDRES]; |
287 |
unsigned short fill_cnt[GRIDRES][GRIDRES]; |
288 |
FVECT ovec0, ovec1; |
289 |
double ang2, lastang2; |
290 |
int r, i, j, jn, ii, jj, inear, jnear; |
291 |
292 |
r = GRIDRES/2; /* proceed in zig-zag */ |
293 |
294 |
for (jn = 0; jn < GRIDRES; jn++) { |
295 |
j = (i&1) ? jn : GRIDRES-1-jn; |
296 |
if (dsf_grid[i][j].nval) /* find empty grid pos. */ |
297 |
continue; |
298 |
vec_from_pos(ovec0, i, j); |
299 |
inear = jnear = -1; /* find nearest non-empty */ |
300 |
lastang2 = M_PI*M_PI; |
301 |
for (ii = i-r; ii <= i+r; ii++) { |
302 |
if (ii < 0) continue; |
303 |
if (ii >= GRIDRES) break; |
304 |
for (jj = j-r; jj <= j+r; jj++) { |
305 |
if (jj < 0) continue; |
306 |
if (jj >= GRIDRES) break; |
307 |
if (!dsf_grid[ii][jj].nval) |
308 |
continue; |
309 |
vec_from_pos(ovec1, ii, jj); |
310 |
ang2 = 2. - 2.*DOT(ovec0,ovec1); |
311 |
if (ang2 >= lastang2) |
312 |
continue; |
313 |
lastang2 = ang2; |
314 |
inear = ii; jnear = jj; |
315 |
316 |
317 |
if (inear < 0) { |
318 |
fputs("Could not find non-empty neighbor!\n", stderr); |
319 |
exit(1); |
320 |
321 |
ang2 = sqrt(lastang2); |
322 |
r = ANG2R(ang2); /* record if > previous */ |
323 |
if (r > dsf_grid[inear][jnear].crad) |
324 |
dsf_grid[inear][jnear].crad = r; |
325 |
/* next search radius */ |
326 |
r = ang2*(2.*GRIDRES/M_PI) + 1; |
327 |
328 |
/* blur radii over hemisphere */ |
329 |
memset(fill_grid, 0, sizeof(fill_grid)); |
330 |
memset(fill_cnt, 0, sizeof(fill_cnt)); |
331 |
332 |
for (j = 0; j < GRIDRES; j++) { |
333 |
if (!dsf_grid[i][j].crad) |
334 |
continue; /* missing distance */ |
335 |
r = R2ANG(dsf_grid[i][j].crad)*(2.*RSCA*GRIDRES/M_PI); |
336 |
337 |
338 |
339 |
340 |
341 |
342 |
if ((ii-i)*(ii-i) + (jj-j)*(jj-j) > r*r) |
343 |
continue; |
344 |
fill_grid[ii][jj] += dsf_grid[i][j].crad; |
345 |
fill_cnt[ii][jj]++; |
346 |
347 |
348 |
349 |
/* copy back blurred radii */ |
350 |
351 |
352 |
if (fill_cnt[i][j]) |
353 |
dsf_grid[i][j].crad = fill_grid[i][j]/fill_cnt[i][j]; |
354 |
355 |
356 |
/* Cull points for more uniform distribution, leave all nval 0 or 1 */ |
357 |
static void |
358 |
cull_values(void) |
359 |
360 |
361 |
double maxang, maxang2; |
362 |
int i, j, ii, jj, r; |
363 |
/* simple greedy algorithm */ |
364 |
365 |
366 |
if (!dsf_grid[i][j].nval) |
367 |
continue; |
368 |
369 |
continue; /* shouldn't happen */ |
370 |
371 |
maxang = 2.*R2ANG(dsf_grid[i][j].crad); |
372 |
if (maxang > ovec0[2]) /* clamp near horizon */ |
373 |
maxang = ovec0[2]; |
374 |
r = maxang*(2.*GRIDRES/M_PI) + 1; |
375 |
maxang2 = maxang*maxang; |
376 |
377 |
378 |
379 |
380 |
381 |
382 |
383 |
continue; |
384 |
if ((ii == i) & (jj == j)) |
385 |
continue; /* don't get self-absorbed */ |
386 |
387 |
if (2. - 2.*DOT(ovec0,ovec1) >= maxang2) |
388 |
continue; |
389 |
/* absorb sum */ |
390 |
dsf_grid[i][j].vsum += dsf_grid[ii][jj].vsum; |
391 |
dsf_grid[i][j].nval += dsf_grid[ii][jj].nval; |
392 |
/* keep value, though */ |
393 |
dsf_grid[ii][jj].vsum /= (float)dsf_grid[ii][jj].nval; |
394 |
dsf_grid[ii][jj].nval = 0; |
395 |
396 |
397 |
398 |
/* final averaging pass */ |
399 |
400 |
401 |
if (dsf_grid[i][j].nval > 1) { |
402 |
dsf_grid[i][j].vsum /= (float)dsf_grid[i][j].nval; |
403 |
dsf_grid[i][j].nval = 1; |
404 |
405 |
406 |
407 |
/* Compute (and allocate) migration price matrix for optimization */ |
408 |
static float * |
409 |
price_routes(const RBFLIST *from_rbf, const RBFLIST *to_rbf) |
410 |
411 |
float *pmtx = (float *)malloc(sizeof(float) * |
412 |
from_rbf->nrbf * to_rbf->nrbf); |
413 |
FVECT *vto = (FVECT *)malloc(sizeof(FVECT) * to_rbf->nrbf); |
414 |
int i, j; |
415 |
416 |
if ((pmtx == NULL) | (vto == NULL)) { |
417 |
fputs("Out of memory in migration_costs()\n", stderr); |
418 |
exit(1); |
419 |
420 |
for (j = to_rbf->nrbf; j--; ) /* save repetitive ops. */ |
421 |
vec_from_pos(vto[j], to_rbf->rbfa[j].gx, to_rbf->rbfa[j].gy); |
422 |
423 |
for (i = from_rbf->nrbf; i--; ) { |
424 |
const double from_ang = R2ANG(from_rbf->rbfa[i].crad); |
425 |
FVECT vfrom; |
426 |
vec_from_pos(vfrom, from_rbf->rbfa[i].gx, from_rbf->rbfa[i].gy); |
427 |
for (j = to_rbf->nrbf; j--; ) |
428 |
pmtx[i*to_rbf->nrbf + j] = acos(DOT(vfrom, vto[j])) + |
429 |
fabs(R2ANG(to_rbf->rbfa[j].crad) - from_ang); |
430 |
431 |
free(vto); |
432 |
return(pmtx); |
433 |
434 |
435 |
/* Comparison routine needed for sorting price row */ |
436 |
static const float *price_arr; |
437 |
static int |
438 |
msrt_cmp(const void *p1, const void *p2) |
439 |
440 |
float c1 = price_arr[*(const int *)p1]; |
441 |
float c2 = price_arr[*(const int *)p2]; |
442 |
443 |
if (c1 > c2) return(1); |
444 |
if (c1 < c2) return(-1); |
445 |
return(0); |
446 |
447 |
448 |
/* Compute minimum (optimistic) cost for moving the given source material */ |
449 |
static double |
450 |
min_cost(double amt2move, const double *avail, const float *price, int n) |
451 |
452 |
static int *price_sort = NULL; |
453 |
static int n_alloc = 0; |
454 |
double total_cost = 0; |
455 |
int i; |
456 |
457 |
if (amt2move <= FTINY) /* pre-emptive check */ |
458 |
return(0.); |
459 |
if (n > n_alloc) { /* (re)allocate sort array */ |
460 |
if (n_alloc) free(price_sort); |
461 |
price_sort = (int *)malloc(sizeof(int)*n); |
462 |
if (price_sort == NULL) { |
463 |
fputs("Out of memory in min_cost()\n", stderr); |
464 |
exit(1); |
465 |
466 |
n_alloc = n; |
467 |
468 |
for (i = n; i--; ) |
469 |
price_sort[i] = i; |
470 |
price_arr = price; |
471 |
qsort(price_sort, n, sizeof(int), &msrt_cmp); |
472 |
/* move cheapest first */ |
473 |
for (i = 0; i < n && amt2move > FTINY; i++) { |
474 |
int d = price_sort[i]; |
475 |
double amt = (amt2move < avail[d]) ? amt2move : avail[d]; |
476 |
477 |
total_cost += amt * price[d]; |
478 |
amt2move -= amt; |
479 |
480 |
if (amt2move > 1e-5) fprintf(stderr, "%g leftover!\n", amt2move); |
481 |
return(total_cost); |
482 |
483 |
484 |
/* Take a step in migration by choosing optimal bucket to transfer */ |
485 |
static double |
486 |
migration_step(MIGRATION *mig, double *src_rem, double *dst_rem, const float *pmtx) |
487 |
488 |
static double *src_cost = NULL; |
489 |
int n_alloc = 0; |
490 |
const double maxamt = 0.5/(mtx_nrows(mig)*mtx_ncols(mig)); |
491 |
double amt = 0; |
492 |
struct { |
493 |
int s, d; /* source and destination */ |
494 |
double price; /* price estimate per amount moved */ |
495 |
double amt; /* amount we can move */ |
496 |
} cur, best; |
497 |
int i; |
498 |
499 |
if (mtx_nrows(mig) > n_alloc) { /* allocate cost array */ |
500 |
if (n_alloc) |
501 |
free(src_cost); |
502 |
src_cost = (double *)malloc(sizeof(double)*mtx_nrows(mig)); |
503 |
if (src_cost == NULL) { |
504 |
fputs("Out of memory in migration_step()\n", stderr); |
505 |
exit(1); |
506 |
507 |
n_alloc = mtx_nrows(mig); |
508 |
509 |
for (i = mtx_nrows(mig); i--; ) /* starting costs for diff. */ |
510 |
src_cost[i] = min_cost(src_rem[i], dst_rem, |
511 |
pmtx+i*mtx_ncols(mig), mtx_ncols(mig)); |
512 |
513 |
/* find best source & dest. */ |
514 |
best.s = best.d = -1; best.price = FHUGE; best.amt = 0; |
515 |
for (cur.s = mtx_nrows(mig); cur.s--; ) { |
516 |
const float *price = pmtx + cur.s*mtx_ncols(mig); |
517 |
double cost_others = 0; |
518 |
if (src_rem[cur.s] <= FTINY) |
519 |
continue; |
520 |
cur.d = -1; /* examine cheapest dest. */ |
521 |
for (i = mtx_ncols(mig); i--; ) |
522 |
if (dst_rem[i] > FTINY && |
523 |
(cur.d < 0 || price[i] < price[cur.d])) |
524 |
cur.d = i; |
525 |
if (cur.d < 0) |
526 |
return(.0); |
527 |
if ((cur.price = price[cur.d]) >= best.price) |
528 |
continue; /* no point checking further */ |
529 |
cur.amt = (src_rem[cur.s] < dst_rem[cur.d]) ? |
530 |
src_rem[cur.s] : dst_rem[cur.d]; |
531 |
if (cur.amt > maxamt) cur.amt = maxamt; |
532 |
dst_rem[cur.d] -= cur.amt; /* add up differential costs */ |
533 |
for (i = mtx_nrows(mig); i--; ) { |
534 |
if (i == cur.s) continue; |
535 |
cost_others += min_cost(src_rem[i], dst_rem, price, mtx_ncols(mig)) |
536 |
- src_cost[i]; |
537 |
538 |
dst_rem[cur.d] += cur.amt; /* undo trial move */ |
539 |
cur.price += cost_others/cur.amt; /* adjust effective price */ |
540 |
if (cur.price < best.price) /* are we better than best? */ |
541 |
best = cur; |
542 |
543 |
if ((best.s < 0) | (best.d < 0)) |
544 |
return(.0); |
545 |
/* make the actual move */ |
546 |
mig->mtx[mtx_ndx(mig,best.s,best.d)] += best.amt; |
547 |
src_rem[best.s] -= best.amt; |
548 |
dst_rem[best.d] -= best.amt; |
549 |
return(best.amt); |
550 |
551 |
552 |
/* Compute (and insert) migration along directed edge */ |
553 |
static MIGRATION * |
554 |
make_migration(RBFLIST *from_rbf, RBFLIST *to_rbf) |
555 |
556 |
const double end_thresh = 0.02/(from_rbf->nrbf*to_rbf->nrbf); |
557 |
float *pmtx = price_routes(from_rbf, to_rbf); |
558 |
MIGRATION *newmig = (MIGRATION *)malloc(sizeof(MIGRATION) + |
559 |
sizeof(float) * |
560 |
(from_rbf->nrbf*to_rbf->nrbf - 1)); |
561 |
double *src_rem = (double *)malloc(sizeof(double)*from_rbf->nrbf); |
562 |
double *dst_rem = (double *)malloc(sizeof(double)*to_rbf->nrbf); |
563 |
double total_rem = 1.; |
564 |
int i; |
565 |
566 |
if ((newmig == NULL) | (src_rem == NULL) | (dst_rem == NULL)) { |
567 |
fputs("Out of memory in make_migration()\n", stderr); |
568 |
exit(1); |
569 |
570 |
newmig->next = NULL; |
571 |
newmig->rbfv[0] = from_rbf; |
572 |
newmig->rbfv[1] = to_rbf; |
573 |
newmig->enxt[0] = newmig->enxt[1] = NULL; |
574 |
memset(newmig->mtx, 0, sizeof(float)*from_rbf->nrbf*to_rbf->nrbf); |
575 |
/* starting quantities */ |
576 |
for (i = from_rbf->nrbf; i--; ) |
577 |
src_rem[i] = rbf_volume(&from_rbf->rbfa[i]) / from_rbf->vtotal; |
578 |
for (i = to_rbf->nrbf; i--; ) |
579 |
dst_rem[i] = rbf_volume(&to_rbf->rbfa[i]) / to_rbf->vtotal; |
580 |
/* move a bit at a time */ |
581 |
while (total_rem > end_thresh) |
582 |
total_rem -= migration_step(newmig, src_rem, dst_rem, pmtx); |
583 |
584 |
free(pmtx); /* free working arrays */ |
585 |
free(src_rem); |
586 |
free(dst_rem); |
587 |
for (i = from_rbf->nrbf; i--; ) { /* normalize final matrix */ |
588 |
float nf = rbf_volume(&from_rbf->rbfa[i]); |
589 |
int j; |
590 |
if (nf <= FTINY) continue; |
591 |
nf = from_rbf->vtotal / nf; |
592 |
593 |
newmig->mtx[mtx_ndx(newmig,i,j)] *= nf; |
594 |
595 |
/* insert in edge lists */ |
596 |
newmig->enxt[0] = from_rbf->ejl; |
597 |
from_rbf->ejl = newmig; |
598 |
newmig->enxt[1] = to_rbf->ejl; |
599 |
to_rbf->ejl = newmig; |
600 |
newmig->next = mig_list; |
601 |
return(mig_list = newmig); |
602 |
603 |
604 |
#if 0 |
605 |
/* Partially advect between the given RBFs to a newly allocated one */ |
606 |
static RBFLIST * |
607 |
advect_rbf(const RBFLIST *from_rbf, const RBFLIST *to_rbf, |
608 |
const float *mtx, const FVECT invec) |
609 |
610 |
RBFLIST *rbf; |
611 |
612 |
if (from_rbf->nrbf > to_rbf->nrbf) { |
613 |
fputs("Internal error: source RBF won't fit destination\n", |
614 |
stderr); |
615 |
exit(1); |
616 |
617 |
rbf = (RBFLIST *)malloc(sizeof(RBFLIST) + sizeof(RBFVAL)*(to_rbf->nrbf-1)); |
618 |
if (rbf == NULL) { |
619 |
fputs("Out of memory in advect_rbf()\n", stderr); |
620 |
exit(1); |
621 |
622 |
rbf->next = NULL; rbf->ejl = NULL; |
623 |
VCOPY(rbf->invec, invec); |
624 |
rbf->vtotal = 0; |
625 |
rbf->nrbf = to_rbf->nrbf; |
626 |
627 |
return rbf; |
628 |
629 |
#endif |
630 |
631 |
#if 1 |
632 |
/* Test main produces a Radiance model from the given input file */ |
633 |
int |
634 |
main(int argc, char *argv[]) |
635 |
636 |
char buf[128]; |
637 |
FILE *pfp; |
638 |
double bsdf; |
639 |
FVECT dir; |
640 |
int i, j, n; |
641 |
642 |
if (argc != 2) { |
643 |
fprintf(stderr, "Usage: %s input.dat > output.rad\n", argv[0]); |
644 |
return(1); |
645 |
646 |
if (!load_bsdf_meas(argv[1])) |
647 |
return(1); |
648 |
649 |
compute_radii(); |
650 |
cull_values(); |
651 |
make_rbfrep(); |
652 |
/* produce spheres at meas. */ |
653 |
puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n"); |
654 |
puts("void plastic pink\n0\n0\n5 .5 .05 .9 .04 .08\n"); |
655 |
n = 0; |
656 |
657 |
658 |
if (dsf_grid[i][j].vsum > .0f) { |
659 |
vec_from_pos(dir, i, j); |
660 |
bsdf = dsf_grid[i][j].vsum / dir[2]; |
661 |
662 |
printf("pink cone c%04d\n0\n0\n8\n", ++n); |
663 |
printf("\t%.6g %.6g %.6g\n", |
664 |
dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf); |
665 |
666 |
dir[0]*(bsdf+.005), dir[1]*(bsdf+.005), |
667 |
dir[2]*(bsdf+.005)); |
668 |
puts("\t.003\t0\n"); |
669 |
} else { |
670 |
671 |
printf("yellow sphere s%04d\n0\n0\n", ++n); |
672 |
printf("4 %.6g %.6g %.6g .0015\n\n", |
673 |
674 |
675 |
676 |
/* output continuous surface */ |
677 |
puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 .9\n"); |
678 |
fflush(stdout); |
679 |
sprintf(buf, "gensurf tgreen bsdf - - - %d %d", GRIDRES-1, GRIDRES-1); |
680 |
pfp = popen(buf, "w"); |
681 |
if (pfp == NULL) { |
682 |
fputs(buf, stderr); |
683 |
fputs(": cannot start command\n", stderr); |
684 |
return(1); |
685 |
686 |
687 |
688 |
689 |
bsdf = eval_rbfrep(dsf_list, dir) / dir[2]; |
690 |
fprintf(pfp, "%.8e %.8e %.8e\n", |
691 |
692 |
693 |
return(pclose(pfp)==0 ? 0 : 1); |
694 |
695 |
#endif |
