root/radiance/ray/src/cv/pabopto2xml.c
Revision: 2.6
Committed: Sun Aug 26 19:40:02 2012 UTC (11 years, 9 months ago) by greg
Changes since 2.5: +26 -19 lines
Changed to adaptive iteration based on convergence
2 static const char RCSid[] = "$Id: pabopto2xml.c,v 2.5 2012/08/25 22:39:03 greg Exp $";
5 * Convert PAB-Opto measurements to XML format using tensor tree representation
6 * Employs Bonneel et al. Earth Mover's Distance interpolant.
7 *
8 * G.Ward
9 */
10
11 #define _USE_MATH_DEFINES
12 #include <stdio.h>
13 #include <stdlib.h>
14 #include <string.h>
15 #include <ctype.h>
16 #include <math.h>
17 #include "bsdf.h"
18
19 #ifndef GRIDRES
20 #define GRIDRES 200 /* max. grid resolution per side */
21 #endif
22
23 #define RSCA 2.7 /* radius scaling factor (empirical) */
24
25 /* convert to/from coded radians */
26 #define ANG2R(r) (int)((r)*((1<<16)/M_PI))
27 #define R2ANG(c) (((c)+.5)*(M_PI/(1<<16)))
28
29 typedef struct {
30 float vsum; /* DSF sum */
31 unsigned short nval; /* number of values in sum */
32 unsigned short crad; /* radius (coded angle) */
33 } GRIDVAL; /* grid value */
34
35 typedef struct {
36 float peak; /* lobe value at peak */
37 unsigned short crad; /* radius (coded angle) */
38 unsigned char gx, gy; /* grid position */
39 } RBFVAL; /* radial basis function value */
40
41 typedef struct s_rbflist {
42 struct s_rbflist *next; /* next in our RBF list */
43 FVECT invec; /* incident vector direction */
44 int nrbf; /* number of RBFs */
45 RBFVAL rbfa[1]; /* RBF array (extends struct) */
46 } RBFLIST; /* RBF representation of DSF @ 1 incidence */
47
48 /* our loaded grid for this incident angle */
49 static double theta_in_deg, phi_in_deg;
50 static GRIDVAL dsf_grid[GRIDRES][GRIDRES];
51
52 /* processed incident DSF measurements */
53 static RBFLIST *dsf_list = NULL;
54
55 /* Compute outgoing vector from grid position */
56 static void
57 vec_from_pos(FVECT vec, int xpos, int ypos)
58 {
59 double uv[2];
60 double r2;
61
62 SDsquare2disk(uv, (1./GRIDRES)*(xpos+.5), (1./GRIDRES)*(ypos+.5));
63 /* uniform hemispherical projection */
64 r2 = uv[0]*uv[0] + uv[1]*uv[1];
65 vec[0] = vec[1] = sqrt(2. - r2);
66 vec[0] *= uv[0];
67 vec[1] *= uv[1];
68 vec[2] = 1. - r2;
69 }
70
71 /* Compute grid position from normalized outgoing vector */
72 static void
73 pos_from_vec(int pos[2], const FVECT vec)
74 {
75 double sq[2]; /* uniform hemispherical projection */
76 double norm = 1./sqrt(1. + vec[2]);
77
78 SDdisk2square(sq, vec[0]*norm, vec[1]*norm);
79
80 pos[0] = (int)(sq[0]*GRIDRES);
81 pos[1] = (int)(sq[1]*GRIDRES);
82 }
83
84 /* Evaluate RBF for DSF at the given normalized outgoing direction */
85 static double
86 eval_rbfrep(const RBFLIST *rp, const FVECT outvec)
87 {
88 double res = .0;
89 const RBFVAL *rbfp;
90 FVECT odir;
91 double sig2;
92 int n;
93
94 rbfp = rp->rbfa;
95 for (n = rp->nrbf; n--; rbfp++) {
96 vec_from_pos(odir, rbfp->gx, rbfp->gy);
97 sig2 = R2ANG(rbfp->crad);
98 sig2 = (DOT(odir,outvec) - 1.) / (sig2*sig2);
99 if (sig2 > -19.)
100 res += rbfp->peak * exp(sig2);
101 }
102 return(res);
103 }
104
105 /* Count up filled nodes and build RBF representation from current grid */
106 static RBFLIST *
107 make_rbfrep(void)
108 {
109 int niter = 16;
110 double lastVar, thisVar = 100.;
111 int nn;
112 RBFLIST *newnode;
113 int i, j;
114
115 nn = 0; /* count selected bins */
116 for (i = 0; i < GRIDRES; i++)
117 for (j = 0; j < GRIDRES; j++)
118 nn += dsf_grid[i][j].nval;
119 /* allocate RBF array */
120 newnode = (RBFLIST *)malloc(sizeof(RBFLIST) + sizeof(RBFVAL)*(nn-1));
121 if (newnode == NULL) {
122 fputs("Out of memory in make_rbfrep\n", stderr);
123 exit(1);
124 }
125 newnode->next = NULL;
126 newnode->invec[2] = sin(M_PI/180.*theta_in_deg);
127 newnode->invec[0] = cos(M_PI/180.*phi_in_deg)*newnode->invec[2];
128 newnode->invec[1] = sin(M_PI/180.*phi_in_deg)*newnode->invec[2];
129 newnode->invec[2] = sqrt(1. - newnode->invec[2]*newnode->invec[2]);
130 newnode->nrbf = nn;
131 nn = 0; /* fill RBF array */
132 for (i = 0; i < GRIDRES; i++)
133 for (j = 0; j < GRIDRES; j++)
134 if (dsf_grid[i][j].nval) {
135 newnode->rbfa[nn].peak = dsf_grid[i][j].vsum;
136 newnode->rbfa[nn].crad = RSCA*dsf_grid[i][j].crad + .5;
137 newnode->rbfa[nn].gx = i;
138 newnode->rbfa[nn].gy = j;
139 ++nn;
140 }
141 /* iterate to improve interpolation accuracy */
142 do {
143 double dsum = .0, dsum2 = .0;
144 nn = 0;
145 for (i = 0; i < GRIDRES; i++)
146 for (j = 0; j < GRIDRES; j++)
147 if (dsf_grid[i][j].nval) {
148 FVECT odir;
149 double corr;
150 vec_from_pos(odir, i, j);
151 newnode->rbfa[nn++].peak *= corr =
152 dsf_grid[i][j].vsum /
153 eval_rbfrep(newnode, odir);
154 dsum += corr - 1.;
155 dsum2 += (corr-1.)*(corr-1.);
156 }
157 lastVar = thisVar;
158 thisVar = dsum2/(double)nn;
159 /*
160 fprintf(stderr, "Avg., RMS error: %.1f%% %.1f%%\n",
161 100.*dsum/(double)nn,
162 100.*sqrt(thisVar));
163 */
164 } while (--niter > 0 && lastVar-thisVar > 0.02*lastVar);
165
166 newnode->next = dsf_list;
167 return(dsf_list = newnode);
168 }
169
170 /* Load a set of measurements corresponding to a particular incident angle */
171 static int
172 load_bsdf_meas(const char *fname)
173 {
174 FILE *fp = fopen(fname, "r");
175 int inp_is_DSF = -1;
176 double theta_out, phi_out, val;
177 char buf[2048];
178 int n, c;
179
180 if (fp == NULL) {
181 fputs(fname, stderr);
182 fputs(": cannot open\n", stderr);
183 return(0);
184 }
185 memset(dsf_grid, 0, sizeof(dsf_grid));
186 /* read header information */
187 while ((c = getc(fp)) == '#' || c == EOF) {
188 if (fgets(buf, sizeof(buf), fp) == NULL) {
189 fputs(fname, stderr);
190 fputs(": unexpected EOF\n", stderr);
191 fclose(fp);
192 return(0);
193 }
194 if (!strcmp(buf, "format: theta phi DSF\n")) {
195 inp_is_DSF = 1;
196 continue;
197 }
198 if (!strcmp(buf, "format: theta phi BSDF\n")) {
199 inp_is_DSF = 0;
200 continue;
201 }
202 if (sscanf(buf, "intheta %lf", &theta_in_deg) == 1)
203 continue;
204 if (sscanf(buf, "inphi %lf", &phi_in_deg) == 1)
205 continue;
206 if (sscanf(buf, "incident_angle %lf %lf",
207 &theta_in_deg, &phi_in_deg) == 2)
208 continue;
209 }
210 if (inp_is_DSF < 0) {
211 fputs(fname, stderr);
212 fputs(": unknown format\n", stderr);
213 fclose(fp);
214 return(0);
215 }
216 ungetc(c, fp); /* read actual data */
217 while (fscanf(fp, "%lf %lf %lf\n", &theta_out, &phi_out, &val) == 3) {
218 FVECT ovec;
219 int pos[2];
220
221 ovec[2] = sin(M_PI/180.*theta_out);
222 ovec[0] = cos(M_PI/180.*phi_out) * ovec[2];
223 ovec[1] = sin(M_PI/180.*phi_out) * ovec[2];
224 ovec[2] = sqrt(1. - ovec[2]*ovec[2]);
225
226 if (!inp_is_DSF)
227 val *= ovec[2]; /* convert from BSDF to DSF */
228
229 pos_from_vec(pos, ovec);
230
231 dsf_grid[pos[0]][pos[1]].vsum += val;
232 dsf_grid[pos[0]][pos[1]].nval++;
233 }
234 n = 0;
235 while ((c = getc(fp)) != EOF)
236 n += !isspace(c);
237 if (n)
238 fprintf(stderr,
239 "%s: warning: %d unexpected characters past EOD\n",
240 fname, n);
241 fclose(fp);
242 return(1);
243 }
244
245 /* Compute radii for non-empty bins */
246 /* (distance to furthest empty bin for which non-empty bin is the closest) */
247 static void
248 compute_radii(void)
249 {
250 unsigned int fill_grid[GRIDRES][GRIDRES];
251 unsigned short fill_cnt[GRIDRES][GRIDRES];
252 FVECT ovec0, ovec1;
253 double ang2, lastang2;
254 int r, i, j, jn, ii, jj, inear, jnear;
255
256 r = GRIDRES/2; /* proceed in zig-zag */
257 for (i = 0; i < GRIDRES; i++)
258 for (jn = 0; jn < GRIDRES; jn++) {
259 j = (i&1) ? jn : GRIDRES-1-jn;
260 if (dsf_grid[i][j].nval) /* find empty grid pos. */
261 continue;
262 vec_from_pos(ovec0, i, j);
263 inear = jnear = -1; /* find nearest non-empty */
264 lastang2 = M_PI*M_PI;
265 for (ii = i-r; ii <= i+r; ii++) {
266 if (ii < 0) continue;
267 if (ii >= GRIDRES) break;
268 for (jj = j-r; jj <= j+r; jj++) {
269 if (jj < 0) continue;
270 if (jj >= GRIDRES) break;
271 if (!dsf_grid[ii][jj].nval)
272 continue;
273 vec_from_pos(ovec1, ii, jj);
274 ang2 = 2. - 2.*DOT(ovec0,ovec1);
275 if (ang2 >= lastang2)
276 continue;
277 lastang2 = ang2;
278 inear = ii; jnear = jj;
279 }
280 }
281 if (inear < 0) {
282 fputs("Could not find non-empty neighbor!\n", stderr);
283 exit(1);
284 }
285 ang2 = sqrt(lastang2);
286 r = ANG2R(ang2); /* record if > previous */
287 if (r > dsf_grid[inear][jnear].crad)
288 dsf_grid[inear][jnear].crad = r;
289 /* next search radius */
290 r = ang2*(2.*GRIDRES/M_PI) + 1;
291 }
292 /* blur radii over hemisphere */
293 memset(fill_grid, 0, sizeof(fill_grid));
294 memset(fill_cnt, 0, sizeof(fill_cnt));
295 for (i = 0; i < GRIDRES; i++)
296 for (j = 0; j < GRIDRES; j++) {
297 if (!dsf_grid[i][j].crad)
298 continue; /* missing distance */
299 r = R2ANG(dsf_grid[i][j].crad)*(2.*RSCA*GRIDRES/M_PI);
300 for (ii = i-r; ii <= i+r; ii++) {
301 if (ii < 0) continue;
302 if (ii >= GRIDRES) break;
303 for (jj = j-r; jj <= j+r; jj++) {
304 if (jj < 0) continue;
305 if (jj >= GRIDRES) break;
306 if ((ii-i)*(ii-i) + (jj-j)*(jj-j) > r*r)
307 continue;
308 fill_grid[ii][jj] += dsf_grid[i][j].crad;
309 fill_cnt[ii][jj]++;
310 }
311 }
312 }
313 /* copy back blurred radii */
314 for (i = 0; i < GRIDRES; i++)
315 for (j = 0; j < GRIDRES; j++)
316 if (fill_cnt[i][j])
317 dsf_grid[i][j].crad = fill_grid[i][j]/fill_cnt[i][j];
318 }
319
320 /* Cull points for more uniform distribution, leave all nval 0 or 1 */
321 static void
322 cull_values(void)
323 {
324 FVECT ovec0, ovec1;
325 double maxang, maxang2;
326 int i, j, ii, jj, r;
327 /* simple greedy algorithm */
328 for (i = 0; i < GRIDRES; i++)
329 for (j = 0; j < GRIDRES; j++) {
330 if (!dsf_grid[i][j].nval)
331 continue;
332 if (!dsf_grid[i][j].crad)
333 continue; /* shouldn't happen */
334 vec_from_pos(ovec0, i, j);
335 maxang = 2.*R2ANG(dsf_grid[i][j].crad);
336 if (maxang > ovec0[2]) /* clamp near horizon */
337 maxang = ovec0[2];
338 r = maxang*(2.*GRIDRES/M_PI) + 1;
339 maxang2 = maxang*maxang;
340 for (ii = i-r; ii <= i+r; ii++) {
341 if (ii < 0) continue;
342 if (ii >= GRIDRES) break;
343 for (jj = j-r; jj <= j+r; jj++) {
344 if (jj < 0) continue;
345 if (jj >= GRIDRES) break;
346 if (!dsf_grid[ii][jj].nval)
347 continue;
348 if ((ii == i) & (jj == j))
349 continue; /* don't get self-absorbed */
350 vec_from_pos(ovec1, ii, jj);
351 if (2. - 2.*DOT(ovec0,ovec1) >= maxang2)
352 continue;
353 /* absorb sum */
354 dsf_grid[i][j].vsum += dsf_grid[ii][jj].vsum;
355 dsf_grid[i][j].nval += dsf_grid[ii][jj].nval;
356 /* keep value, though */
357 dsf_grid[ii][jj].vsum /= (float)dsf_grid[ii][jj].nval;
358 dsf_grid[ii][jj].nval = 0;
359 }
360 }
361 }
362 /* final averaging pass */
363 for (i = 0; i < GRIDRES; i++)
364 for (j = 0; j < GRIDRES; j++)
365 if (dsf_grid[i][j].nval > 1) {
366 dsf_grid[i][j].vsum /= (float)dsf_grid[i][j].nval;
367 dsf_grid[i][j].nval = 1;
368 }
369 }
370
371
372 #if 1
373 /* Test main produces a Radiance model from the given input file */
374 int
375 main(int argc, char *argv[])
376 {
377 char buf[128];
378 FILE *pfp;
379 double bsdf;
380 FVECT dir;
381 int i, j, n;
382
383 if (argc != 2) {
384 fprintf(stderr, "Usage: %s input.dat > output.rad\n", argv[0]);
385 return(1);
386 }
387 if (!load_bsdf_meas(argv[1]))
388 return(1);
389
390 compute_radii();
391 cull_values();
392 make_rbfrep();
393 /* produce spheres at meas. */
394 puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n");
395 puts("void plastic pink\n0\n0\n5 .5 .05 .9 .04 .08\n");
396 n = 0;
397 for (i = 0; i < GRIDRES; i++)
398 for (j = 0; j < GRIDRES; j++)
399 if (dsf_grid[i][j].vsum > .0f) {
400 vec_from_pos(dir, i, j);
401 bsdf = dsf_grid[i][j].vsum / dir[2];
402 if (dsf_grid[i][j].nval) {
403 printf("pink cone c%04d\n0\n0\n8\n", ++n);
404 printf("\t%.6g %.6g %.6g\n",
405 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf);
406 printf("\t%.6g %.6g %.6g\n",
407 dir[0]*(bsdf+.005), dir[1]*(bsdf+.005),
408 dir[2]*(bsdf+.005));
409 puts("\t.003\t0\n");
410 } else {
411 vec_from_pos(dir, i, j);
412 printf("yellow sphere s%04d\n0\n0\n", ++n);
413 printf("4 %.6g %.6g %.6g .0015\n\n",
414 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf);
415 }
416 }
417 /* output continuous surface */
418 puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 .9\n");
419 fflush(stdout);
420 sprintf(buf, "gensurf tgreen bsdf - - - %d %d", GRIDRES-1, GRIDRES-1);
421 pfp = popen(buf, "w");
422 if (pfp == NULL) {
423 fputs(buf, stderr);
424 fputs(": cannot start command\n", stderr);
425 return(1);
426 }
427 for (i = 0; i < GRIDRES; i++)
428 for (j = 0; j < GRIDRES; j++) {
429 vec_from_pos(dir, i, j);
430 bsdf = eval_rbfrep(dsf_list, dir) / dir[2];
431 fprintf(pfp, "%.8e %.8e %.8e\n",
432 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf);
433 }
434 return(pclose(pfp)==0 ? 0 : 1);
435 }
436 #endif
