root/Development/ray/src/cv/pabopto2bsdf.c
Revision: 2.44
Committed: Sat Jun 7 05:09:45 2025 UTC (5 months ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.43: +1 -3 lines
2 static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.43 2025/06/03 21:31:51 greg Exp $";
5 * Load measured BSDF data in PAB-Opto format.
6 * Assumes that surface-normal (Z-axis) faces into room unless -t option given.
7 *
8 * G. Ward
9 */
10
11 #define _USE_MATH_DEFINES
12 #include <stdlib.h>
13 #include <ctype.h>
14 #include <math.h>
15 #include "rtio.h"
16 #include "bsdfrep.h"
17
18 typedef struct {
19 const char *fname; /* input file path */
20 double theta, phi; /* input angles (degrees) */
21 double up_phi; /* azimuth for "up" direction */
22 int igp[2]; /* input grid position */
23 int isDSF; /* data is DSF (rather than BSDF)? */
24 int nspec; /* number of spectral samples */
25 long dstart; /* data start offset in file */
26 } PGINPUT;
27
28 PGINPUT *inpfile; /* input files sorted by incidence */
29
30 int rev_orient = 0; /* shall we reverse surface orientation? */
31
32 double lim_graze = 0; /* limit scattering near grazing (deg above) */
33
34 /* Compare incident angles */
35 static int
36 cmp_indir(const void *p1, const void *p2)
37 {
38 const PGINPUT *inp1 = (const PGINPUT *)p1;
39 const PGINPUT *inp2 = (const PGINPUT *)p2;
40 int ydif = inp1->igp[1] - inp2->igp[1];
41
42 if (ydif)
43 return(ydif);
44
45 return(inp1->igp[0] - inp2->igp[0]);
46 }
47
48 /* Assign grid position from theta and phi */
49 static void
50 set_grid_pos(PGINPUT *pip)
51 {
52 FVECT dv;
53
54 if (pip->theta <= FTINY) {
55 pip->igp[0] = pip->igp[1] = grid_res/2 - 1;
56 return;
57 }
58 dv[2] = sin(M_PI/180.*pip->theta);
59 dv[0] = cos(M_PI/180.*pip->phi)*dv[2];
60 dv[1] = sin(M_PI/180.*pip->phi)*dv[2];
61 dv[2] = sqrt(1. - dv[2]*dv[2]);
62 pos_from_vec(pip->igp, dv);
63 }
64
65 /* Prepare a PAB-Opto input file by reading its header */
66 static int
67 init_pabopto_inp(const int i, const char *fname)
68 {
69 FILE *fp = fopen(fname, "r");
70 char buf[2048];
71 int c;
72
73 if (fp == NULL) {
74 fputs(fname, stderr);
75 fputs(": cannot open\n", stderr);
76 return(0);
77 }
78 inpfile[i].fname = fname;
79 inpfile[i].isDSF = -1;
80 inpfile[i].nspec = 0;
81 inpfile[i].up_phi = 0;
82 inpfile[i].theta = inpfile[i].phi = -10001.;
83 /* read header information */
84 while ((c = getc(fp)) == '#' || c == EOF) {
85 char typ[64];
86 if (fgets(buf, sizeof(buf), fp) == NULL) {
87 fputs(fname, stderr);
88 fputs(": unexpected EOF\n", stderr);
89 fclose(fp);
90 return(0);
91 }
92 if (sscanf(buf, "sample_name \"%[^\"]\"", bsdf_name) == 1)
93 continue;
94 if (sscanf(buf, "colorimetry: %s", typ) == 1) {
95 if (!strcasecmp(typ, "CIE-XYZ"))
96 inpfile[i].nspec = 3;
97 else if (!strcasecmp(typ, "CIE-Y"))
98 inpfile[i].nspec = 1;
99 continue;
100 }
101 if (sscanf(buf, "format: theta phi %s", typ) == 1) {
102 if (!strcasecmp(typ, "DSF"))
103 inpfile[i].isDSF = 1;
104 else if (!strcasecmp(typ, "BSDF") ||
105 !strcasecmp(typ, "BRDF") ||
106 !strcasecmp(typ, "BTDF"))
107 inpfile[i].isDSF = 0;
108 continue;
109 }
110 if (sscanf(buf, "upphi %lf", &inpfile[i].up_phi) == 1)
111 continue;
112 if (sscanf(buf, "intheta %lf", &inpfile[i].theta) == 1)
113 continue;
114 if (sscanf(buf, "inphi %lf", &inpfile[i].phi) == 1)
115 continue;
116 if (sscanf(buf, "incident_angle %lf %lf",
117 &inpfile[i].theta, &inpfile[i].phi) == 2)
118 continue;
119 }
120 inpfile[i].dstart = ftell(fp) - 1;
121 fclose(fp);
122 if (inpfile[i].isDSF < 0) {
123 fputs(fname, stderr);
124 fputs(": unknown format\n", stderr);
125 return(0);
126 }
127 if ((inpfile[i].theta < -10000.) | (inpfile[i].phi < -10000.)) {
128 fputs(fname, stderr);
129 fputs(": unknown incident angle\n", stderr);
130 return(0);
131 }
132 if (rev_orient) { /* reverse Z-axis to face outside */
133 inpfile[i].theta = 180. - inpfile[i].theta;
134 inpfile[i].phi = 360. - inpfile[i].phi;
135 }
136 /* convert to Y-up orientation */
137 inpfile[i].phi += 90.-inpfile[i].up_phi;
138 /* convert angle to grid position */
139 set_grid_pos(&inpfile[i]);
140 return(1);
141 }
142
143 /* Load a set of measurements corresponding to a particular incident angle */
144 static int
145 add_pabopto_inp(const int i)
146 {
147 FILE *fp = fopen(inpfile[i].fname, "r");
148 double theta_out, phi_out, val[3];
149 int n, c;
150
151 if (fp == NULL || fseek(fp, inpfile[i].dstart, 0) == EOF) {
152 fputs(inpfile[i].fname, stderr);
153 fputs(": cannot open\n", stderr);
154 return(0);
155 }
156 /* prepare input grid */
157 if (!i || cmp_indir(&inpfile[i-1], &inpfile[i])) {
158 if (i) /* process previous incidence */
159 make_rbfrep();
160 #ifdef DEBUG
161 fprintf(stderr, "New incident (theta,phi)=(%.1f,%.1f)\n",
162 inpfile[i].theta, inpfile[i].phi);
163 #endif
164 if (inpfile[i].nspec)
165 set_spectral_samples(inpfile[i].nspec);
166 new_bsdf_data(inpfile[i].theta, inpfile[i].phi);
167 }
168 #ifdef DEBUG
169 fprintf(stderr, "Loading measurements from '%s'...\n", inpfile[i].fname);
170 #endif
171 /* read scattering data */
172 while (fscanf(fp, "%lf %lf %lf", &theta_out, &phi_out, val) == 3) {
173 for (n = 1; n < inpfile[i].nspec; n++)
174 if (fscanf(fp, "%lf", val+n) != 1) {
175 fprintf(stderr, "%s: warning: unexpected EOF\n",
176 inpfile[i].fname);
177 fclose(fp);
178 return(1);
179 }
180 /* check if scatter angle is too low */
181 if (fabs(theta_out - 90.) < lim_graze-FTINY)
182 continue;
183 if (rev_orient) { /* reverse Z-axis to face outside? */
184 theta_out = 180. - theta_out;
185 phi_out = 360. - phi_out;
186 }
187 phi_out += 90.-inpfile[i].up_phi;
188 add_bsdf_data(theta_out, phi_out, val, inpfile[i].isDSF);
189 }
190 n = 0;
191 while ((c = getc(fp)) != EOF)
192 n += !isspace(c);
193 if (n)
194 fprintf(stderr,
195 "%s: warning: %d unexpected characters past EOD\n",
196 inpfile[i].fname, n);
197 fclose(fp);
198 return(1);
199 }
200
201 #ifndef TEST_MAIN
202
203 #define SYM_ILL '?' /* illegal symmetry value */
204 #define SYM_ISO 'I' /* isotropic */
205 #define SYM_QUAD 'Q' /* quadrilateral symmetry */
206 #define SYM_BILAT 'B' /* bilateral symmetry */
207 #define SYM_ANISO 'A' /* anisotropic */
208 #define SYM_UP 'U' /* "up-down" (180°) symmetry */
209
210 static const char quadrant_rep[16][16] = {
211 "in-plane","0-90","90-180","0-180",
212 "180-270","0-90+180-270","90-270",
213 "0-270","270-360","270-90",
214 "90-180+270-360","270-180","180-360",
215 "180-90","90-360","0-360"
216 };
217 static const char quadrant_sym[16] = {
218 SYM_ISO, SYM_QUAD, SYM_QUAD, SYM_BILAT,
219 SYM_QUAD, SYM_ILL, SYM_BILAT, SYM_ILL,
220 SYM_QUAD, SYM_BILAT, SYM_ILL, SYM_ILL,
221 SYM_BILAT, SYM_ILL, SYM_ILL, SYM_ANISO
222 };
223
224 /* Read in PAB-Opto BSDF files and output RBF interpolant */
225 int
226 main(int argc, char *argv[])
227 {
228 extern int nprocs;
229 static char gval_buf[16];
230 char * auto_grazing = NULL;
231 const char *symmetry = "0";
232 int ninpfiles, totinc;
233 int a, i;
234 /* set global progname */
235 fixargv0(argv[0]);
236 /* get options */
237 for (a = 1; a < argc && argv[a][0] == '-'; a++)
238 switch (argv[a][1]) {
239 case 't':
240 rev_orient = !rev_orient;
241 break;
242 case 'n':
243 nprocs = atoi(argv[++a]);
244 break;
245 case 's':
246 symmetry = argv[++a];
247 break;
248 case 'g':
249 if (toupper(argv[a+1][0]) == 'A')
250 auto_grazing = argv[a+1] = gval_buf;
251 else
252 lim_graze = atof(argv[a+1]);
253 ++a;
254 break;
255 default:
256 goto userr;
257 }
258 totinc = ninpfiles = argc - a; /* initialize & sort inputs */
259 if (ninpfiles < 2)
260 goto userr;
261 if (toupper(symmetry[0]) == SYM_UP) /* special case for "up" symmetry */
262 totinc += ninpfiles;
263 inpfile = (PGINPUT *)malloc(sizeof(PGINPUT)*totinc);
264 if (inpfile == NULL)
265 return(1);
266 if (auto_grazing)
267 lim_graze = 90.;
268 for (i = 0; i < ninpfiles; i++) {
269 if (!init_pabopto_inp(i, argv[a+i]))
270 return(1);
271 if (auto_grazing && fabs(inpfile[i].theta - 90.) < lim_graze)
272 lim_graze = fabs(inpfile[i].theta - 90.);
273 }
274 if (auto_grazing)
275 sprintf(auto_grazing, "%.2f", lim_graze);
276 for (i = ninpfiles; i < totinc; i++) { /* copy for "up" symmetry */
277 inpfile[i] = inpfile[i-ninpfiles];
278 inpfile[i].phi += 180.; /* invert duplicate data */
279 inpfile[i].up_phi -= 180.;
280 set_grid_pos(&inpfile[i]); /* grid location for sorting */
281 }
282 qsort(inpfile, totinc, sizeof(PGINPUT), cmp_indir);
283 /* compile measurements */
284 for (i = 0; i < totinc; i++)
285 if (!add_pabopto_inp(i))
286 return(1);
287 make_rbfrep(); /* process last data set */
288 /* check input symmetry */
289 switch (toupper(symmetry[0])) {
290 case '0': /* unspecified symmetry */
291 if (quadrant_sym[inp_coverage] != SYM_ILL)
292 break; /* anything legal goes */
293 fprintf(stderr, "%s: unsupported phi coverage (%s)\n",
294 progname, quadrant_rep[inp_coverage]);
295 return(1);
296 case SYM_UP: /* faux "up" symmetry */
297 if (quadrant_sym[inp_coverage] == SYM_ANISO)
298 break;
299 /* fall through */
300 case SYM_ISO: /* usual symmetry types */
301 case SYM_QUAD:
302 case SYM_BILAT:
303 case SYM_ANISO:
304 if (quadrant_sym[inp_coverage] == toupper(symmetry[0]))
305 break; /* matches spec */
306 fprintf(stderr,
307 "%s: phi coverage (%s) does not match requested '%s' symmetry\n",
308 progname, quadrant_rep[inp_coverage], symmetry);
309 return(1);
310 default:
311 fprintf(stderr,
312 "%s: -s option must be Isotropic, Quadrilateral, Bilateral, Up, or Anisotropic\n",
313 progname);
314 return(1);
315 }
316 #ifdef DEBUG
317 fprintf(stderr, "Input phi coverage (%s) has '%c' symmetry\n",
318 quadrant_rep[inp_coverage],
319 quadrant_sym[inp_coverage]);
320 #endif
321 build_mesh(); /* create interpolation */
322 SET_FILE_BINARY(stdout); /* start header */
323 newheader("RADIANCE", stdout);
324 printargs(argc, argv, stdout);
325 fputnow(stdout);
326 save_bsdf_rep(stdout); /* complete header + data */
327 return(0);
328 userr:
329 fprintf(stderr, "Usage: %s [-t][-n nproc][-s symmetry][-g angle|'A'] meas1.dat meas2.dat .. > bsdf.sir\n",
330 progname);
331 return(1);
332 }
333
334 #else /* TEST_MAIN */
335
336 /* Test main produces a Radiance model from the given input file */
337 int
338 main(int argc, char *argv[])
339 {
340 PGINPUT pginp;
341 char buf[128];
342 FILE *pfp;
343 double bsdf, min_log;
344 FVECT dir;
345 int i, j, n;
346
347 progname = argv[0];
348 if (argc != 2) {
349 fprintf(stderr, "Usage: %s input.dat > output.rad\n", progname);
350 return(1);
351 }
352 inpfile = &pginp;
353 if (!init_pabopto_inp(0, argv[1]) || !add_pabopto_inp(0))
354 return(1);
355 /* reduce data set */
356 if (make_rbfrep() == NULL) {
357 fprintf(stderr, "%s: nothing to plot!\n", progname);
358 exit(1);
359 }
360 #ifdef DEBUG
361 fprintf(stderr, "Minimum BSDF = %.4f\n", bsdf_min);
362 #endif
363 min_log = log(bsdf_min*.5 + 1e-5);
364 #if 1 /* produce spheres at meas. */
365 puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n");
366 n = 0;
367 for (i = 0; i < grid_res; i++)
368 for (j = 0; j < grid_res; j++)
369 if (dsf_grid[i][j].sum.n > 0) {
370 ovec_from_pos(dir, i, j);
371 bsdf = dsf_grid[i][j].sum.v /
372 ((double)dsf_grid[i][j].sum.n*output_orient*dir[2]);
373 if (bsdf <= bsdf_min*.6)
374 continue;
375 bsdf = log(bsdf + 1e-5) - min_log;
376 ovec_from_pos(dir, i, j);
377 printf("yellow sphere s%04d\n0\n0\n", ++n);
378 printf("4 %.6g %.6g %.6g %.6g\n\n",
379 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
380 .007*bsdf);
381 }
382 #endif
383 #if 1 /* spheres at RBF peaks */
384 puts("void plastic red\n0\n0\n5 .8 .01 .01 .04 .08\n");
385 for (n = 0; n < dsf_list->nrbf; n++) {
386 RBFVAL *rbf = &dsf_list->rbfa[n];
387 ovec_from_pos(dir, rbf->gx, rbf->gy);
388 bsdf = eval_rbfrep(dsf_list, dir);
389 bsdf = log(bsdf + 1e-5) - min_log;
390 printf("red sphere p%04d\n0\n0\n", ++n);
391 printf("4 %.6g %.6g %.6g %.6g\n\n",
392 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
393 .011*bsdf);
394 }
395 #endif
396 #if 1 /* output continuous surface */
397 puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 1\n");
398 fflush(stdout);
399 sprintf(buf, "gensurf tgreen bsdf - - - %d %d", grid_res-1, grid_res-1);
400 pfp = popen(buf, "w");
401 if (pfp == NULL) {
402 fprintf(stderr, "%s: cannot open '| %s'\n", progname, buf);
403 return(1);
404 }
405 for (i = 0; i < grid_res; i++)
406 for (j = 0; j < grid_res; j++) {
407 ovec_from_pos(dir, i, j);
408 bsdf = eval_rbfrep(dsf_list, dir);
409 bsdf = log(bsdf + 1e-5) - min_log;
410 fprintf(pfp, "%.8e %.8e %.8e\n",
411 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf);
412 }
413 if (pclose(pfp) != 0)
414 return(1);
415 #endif
416 return(0);
417 }
418
419 #endif /* TEST_MAIN */
