root/radiance/ray/src/cv/pabopto2bsdf.c
Revision: 2.38
Committed: Tue Feb 16 15:49:32 2021 UTC (4 years, 2 months ago) by greg
fix: correction to last feature add
2 static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.37 2021/02/15 23:20:22 greg Exp $";
5 * Load measured BSDF data in PAB-Opto format.
6 * Assumes that surface-normal (Z-axis) faces into room unless -t option given.
7 *
8 * G. Ward
9 */
10
11 #define _USE_MATH_DEFINES
12 #include <stdlib.h>
13 #include <ctype.h>
14 #include <math.h>
15 #include "rtio.h"
16 #include "platform.h"
17 #include "bsdfrep.h"
18 /* global argv[0] */
19 char *progname;
20
21 typedef struct {
22 const char *fname; /* input file path */
23 double theta, phi; /* input angles (degrees) */
24 double up_phi; /* azimuth for "up" direction */
25 int igp[2]; /* input grid position */
26 int isDSF; /* data is DSF (rather than BSDF)? */
27 int nspec; /* number of spectral samples */
28 long dstart; /* data start offset in file */
29 } PGINPUT;
30
31 PGINPUT *inpfile; /* input files sorted by incidence */
32
33 int rev_orient = 0; /* shall we reverse surface orientation? */
34
35 /* Compare incident angles */
36 static int
37 cmp_indir(const void *p1, const void *p2)
38 {
39 const PGINPUT *inp1 = (const PGINPUT *)p1;
40 const PGINPUT *inp2 = (const PGINPUT *)p2;
41 int ydif = inp1->igp[1] - inp2->igp[1];
42
43 if (ydif)
44 return(ydif);
45
46 return(inp1->igp[0] - inp2->igp[0]);
47 }
48
49 /* Assign grid position from theta and phi */
50 static void
51 set_grid_pos(PGINPUT *pip)
52 {
53 FVECT dv;
54
55 if (pip->theta <= FTINY) {
56 pip->igp[0] = pip->igp[1] = grid_res/2 - 1;
57 return;
58 }
59 dv[2] = sin(M_PI/180.*pip->theta);
60 dv[0] = cos(M_PI/180.*pip->phi)*dv[2];
61 dv[1] = sin(M_PI/180.*pip->phi)*dv[2];
62 dv[2] = sqrt(1. - dv[2]*dv[2]);
63 pos_from_vec(pip->igp, dv);
64 }
65
66 /* Prepare a PAB-Opto input file by reading its header */
67 static int
68 init_pabopto_inp(const int i, const char *fname)
69 {
70 FILE *fp = fopen(fname, "r");
71 char buf[2048];
72 int c;
73
74 if (fp == NULL) {
75 fputs(fname, stderr);
76 fputs(": cannot open\n", stderr);
77 return(0);
78 }
79 inpfile[i].fname = fname;
80 inpfile[i].isDSF = -1;
81 inpfile[i].nspec = 0;
82 inpfile[i].up_phi = 0;
83 inpfile[i].theta = inpfile[i].phi = -10001.;
84 /* read header information */
85 while ((c = getc(fp)) == '#' || c == EOF) {
86 char typ[64];
87 if (fgets(buf, sizeof(buf), fp) == NULL) {
88 fputs(fname, stderr);
89 fputs(": unexpected EOF\n", stderr);
90 fclose(fp);
91 return(0);
92 }
93 if (sscanf(buf, "sample_name \"%[^\"]\"", bsdf_name) == 1)
94 continue;
95 if (sscanf(buf, "colorimetry: %s", typ) == 1) {
96 if (!strcasecmp(typ, "CIE-XYZ"))
97 inpfile[i].nspec = 3;
98 else if (!strcasecmp(typ, "CIE-Y"))
99 inpfile[i].nspec = 1;
100 continue;
101 }
102 if (sscanf(buf, "format: theta phi %s", typ) == 1) {
103 if (!strcasecmp(typ, "DSF"))
104 inpfile[i].isDSF = 1;
105 else if (!strcasecmp(typ, "BSDF") ||
106 !strcasecmp(typ, "BRDF") ||
107 !strcasecmp(typ, "BTDF"))
108 inpfile[i].isDSF = 0;
109 continue;
110 }
111 if (sscanf(buf, "upphi %lf", &inpfile[i].up_phi) == 1)
112 continue;
113 if (sscanf(buf, "intheta %lf", &inpfile[i].theta) == 1)
114 continue;
115 if (sscanf(buf, "inphi %lf", &inpfile[i].phi) == 1)
116 continue;
117 if (sscanf(buf, "incident_angle %lf %lf",
118 &inpfile[i].theta, &inpfile[i].phi) == 2)
119 continue;
120 }
121 inpfile[i].dstart = ftell(fp) - 1;
122 fclose(fp);
123 if (inpfile[i].isDSF < 0) {
124 fputs(fname, stderr);
125 fputs(": unknown format\n", stderr);
126 return(0);
127 }
128 if ((inpfile[i].theta < -10000.) | (inpfile[i].phi < -10000.)) {
129 fputs(fname, stderr);
130 fputs(": unknown incident angle\n", stderr);
131 return(0);
132 }
133 if (rev_orient) { /* reverse Z-axis to face outside */
134 inpfile[i].theta = 180. - inpfile[i].theta;
135 inpfile[i].phi = 360. - inpfile[i].phi;
136 }
137 /* convert to Y-up orientation */
138 inpfile[i].phi += 90.-inpfile[i].up_phi;
139 /* convert angle to grid position */
140 set_grid_pos(&inpfile[i]);
141 return(1);
142 }
143
144 /* Load a set of measurements corresponding to a particular incident angle */
145 static int
146 add_pabopto_inp(const int i)
147 {
148 FILE *fp = fopen(inpfile[i].fname, "r");
149 double theta_out, phi_out, val[3];
150 int n, c;
151
152 if (fp == NULL || fseek(fp, inpfile[i].dstart, 0) == EOF) {
153 fputs(inpfile[i].fname, stderr);
154 fputs(": cannot open\n", stderr);
155 return(0);
156 }
157 /* prepare input grid */
158 if (!i || cmp_indir(&inpfile[i-1], &inpfile[i])) {
159 if (i) /* process previous incidence */
160 make_rbfrep();
161 #ifdef DEBUG
162 fprintf(stderr, "New incident (theta,phi)=(%.1f,%.1f)\n",
163 inpfile[i].theta, inpfile[i].phi);
164 #endif
165 if (inpfile[i].nspec)
166 set_spectral_samples(inpfile[i].nspec);
167 new_bsdf_data(inpfile[i].theta, inpfile[i].phi);
168 }
169 #ifdef DEBUG
170 fprintf(stderr, "Loading measurements from '%s'...\n", inpfile[i].fname);
171 #endif
172 /* read scattering data */
173 while (fscanf(fp, "%lf %lf %lf", &theta_out, &phi_out, val) == 3) {
174 for (n = 1; n < inpfile[i].nspec; n++)
175 if (fscanf(fp, "%lf", val+n) != 1) {
176 fprintf(stderr, "%s: warning: unexpected EOF\n",
177 inpfile[i].fname);
178 fclose(fp);
179 return(1);
180 }
181 if (rev_orient) { /* reverse Z-axis to face outside */
182 theta_out = 180. - theta_out;
183 phi_out = 360. - phi_out;
184 }
185 phi_out += 90.-inpfile[i].up_phi;
186 add_bsdf_data(theta_out, phi_out, val, inpfile[i].isDSF);
187 }
188 n = 0;
189 while ((c = getc(fp)) != EOF)
190 n += !isspace(c);
191 if (n)
192 fprintf(stderr,
193 "%s: warning: %d unexpected characters past EOD\n",
194 inpfile[i].fname, n);
195 fclose(fp);
196 return(1);
197 }
198
199 #ifndef TEST_MAIN
200
201 #define SYM_ILL '?' /* illegal symmetry value */
202 #define SYM_ISO 'I' /* isotropic */
203 #define SYM_QUAD 'Q' /* quadrilateral symmetry */
204 #define SYM_BILAT 'B' /* bilateral symmetry */
205 #define SYM_ANISO 'A' /* anisotropic */
206 #define SYM_UP 'U' /* "up-down" (180°) symmetry */
207
208 static const char quadrant_rep[16][16] = {
209 "in-plane","0-90","90-180","0-180",
210 "180-270","0-90+180-270","90-270",
211 "0-270","270-360","270-90",
212 "90-180+270-360","270-180","180-360",
213 "180-90","90-360","0-360"
214 };
215 static const char quadrant_sym[16] = {
216 SYM_ISO, SYM_QUAD, SYM_QUAD, SYM_BILAT,
217 SYM_QUAD, SYM_ILL, SYM_BILAT, SYM_ILL,
218 SYM_QUAD, SYM_BILAT, SYM_ILL, SYM_ILL,
219 SYM_BILAT, SYM_ILL, SYM_ILL, SYM_ANISO
220 };
221
222 /* Read in PAB-Opto BSDF files and output RBF interpolant */
223 int
224 main(int argc, char *argv[])
225 {
226 extern int nprocs;
227 const char *symmetry = "0";
228 int ninpfiles, totinc;
229 int a, i;
230 /* start header */
231 SET_FILE_BINARY(stdout);
232 newheader("RADIANCE", stdout);
233 printargs(argc, argv, stdout);
234 fputnow(stdout);
235 progname = argv[0]; /* get options */
236 for (a = 1; a < argc && argv[a][0] == '-'; a++)
237 switch (argv[a][1]) {
238 case 't':
239 rev_orient = !rev_orient;
240 break;
241 case 'n':
242 nprocs = atoi(argv[++a]);
243 break;
244 case 's':
245 symmetry = argv[++a];
246 break;
247 default:
248 goto userr;
249 }
250 totinc = ninpfiles = argc - a; /* initialize & sort inputs */
251 if (ninpfiles < 2)
252 goto userr;
253 if (toupper(symmetry[0]) == SYM_UP) /* special case for "up" symmetry */
254 totinc += ninpfiles;
255 inpfile = (PGINPUT *)malloc(sizeof(PGINPUT)*totinc);
256 if (inpfile == NULL)
257 return(1);
258 for (i = 0; i < ninpfiles; i++)
259 if (!init_pabopto_inp(i, argv[a+i]))
260 return(1);
261
262 for (i = ninpfiles; i < totinc; i++) { /* copy for "up" symmetry */
263 inpfile[i] = inpfile[i-ninpfiles];
264 inpfile[i].phi += 180.; /* invert duplicate data */
265 inpfile[i].up_phi -= 180.;
266 set_grid_pos(&inpfile[i]); /* grid location for sorting */
267 }
268 qsort(inpfile, totinc, sizeof(PGINPUT), cmp_indir);
269 /* compile measurements */
270 for (i = 0; i < totinc; i++)
271 if (!add_pabopto_inp(i))
272 return(1);
273 make_rbfrep(); /* process last data set */
274 /* check input symmetry */
275 switch (toupper(symmetry[0])) {
276 case '0': /* unspecified symmetry */
277 if (quadrant_sym[inp_coverage] != SYM_ILL)
278 break; /* anything legal goes */
279 fprintf(stderr, "%s: unsupported phi coverage (%s)\n",
280 progname, quadrant_rep[inp_coverage]);
281 return(1);
282 case SYM_UP: /* faux "up" symmetry */
283 if (quadrant_sym[inp_coverage] == SYM_ANISO)
284 break;
285 /* fall through */
286 case SYM_ISO: /* usual symmetry types */
287 case SYM_QUAD:
288 case SYM_BILAT:
289 case SYM_ANISO:
290 if (quadrant_sym[inp_coverage] == toupper(symmetry[0]))
291 break; /* matches spec */
292 fprintf(stderr,
293 "%s: phi coverage (%s) does not match requested '%s' symmetry\n",
294 progname, quadrant_rep[inp_coverage], symmetry);
295 return(1);
296 default:
297 fprintf(stderr,
298 "%s: -s option must be Isotropic, Quadrilateral, Bilateral, Up, or Anisotropic\n",
299 progname);
300 return(1);
301 }
302 #ifdef DEBUG
303 fprintf(stderr, "Input phi coverage (%s) has '%c' symmetry\n",
304 quadrant_rep[inp_coverage],
305 quadrant_sym[inp_coverage]);
306 #endif
307 build_mesh(); /* create interpolation */
308 save_bsdf_rep(stdout); /* write it out */
309 return(0);
310 userr:
311 fprintf(stderr, "Usage: %s [-t][-n nproc][-s symmetry] meas1.dat meas2.dat .. > bsdf.sir\n",
312 progname);
313 return(1);
314 }
315
316 #else /* TEST_MAIN */
317
318 /* Test main produces a Radiance model from the given input file */
319 int
320 main(int argc, char *argv[])
321 {
322 PGINPUT pginp;
323 char buf[128];
324 FILE *pfp;
325 double bsdf, min_log;
326 FVECT dir;
327 int i, j, n;
328
329 progname = argv[0];
330 if (argc != 2) {
331 fprintf(stderr, "Usage: %s input.dat > output.rad\n", progname);
332 return(1);
333 }
334 inpfile = &pginp;
335 if (!init_pabopto_inp(0, argv[1]) || !add_pabopto_inp(0))
336 return(1);
337 /* reduce data set */
338 if (make_rbfrep() == NULL) {
339 fprintf(stderr, "%s: nothing to plot!\n", progname);
340 exit(1);
341 }
342 #ifdef DEBUG
343 fprintf(stderr, "Minimum BSDF = %.4f\n", bsdf_min);
344 #endif
345 min_log = log(bsdf_min*.5 + 1e-5);
346 #if 1 /* produce spheres at meas. */
347 puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n");
348 n = 0;
349 for (i = 0; i < grid_res; i++)
350 for (j = 0; j < grid_res; j++)
351 if (dsf_grid[i][j].sum.n > 0) {
352 ovec_from_pos(dir, i, j);
353 bsdf = dsf_grid[i][j].sum.v /
354 ((double)dsf_grid[i][j].sum.n*output_orient*dir[2]);
355 if (bsdf <= bsdf_min*.6)
356 continue;
357 bsdf = log(bsdf + 1e-5) - min_log;
358 ovec_from_pos(dir, i, j);
359 printf("yellow sphere s%04d\n0\n0\n", ++n);
360 printf("4 %.6g %.6g %.6g %.6g\n\n",
361 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
362 .007*bsdf);
363 }
364 #endif
365 #if 1 /* spheres at RBF peaks */
366 puts("void plastic red\n0\n0\n5 .8 .01 .01 .04 .08\n");
367 for (n = 0; n < dsf_list->nrbf; n++) {
368 RBFVAL *rbf = &dsf_list->rbfa[n];
369 ovec_from_pos(dir, rbf->gx, rbf->gy);
370 bsdf = eval_rbfrep(dsf_list, dir);
371 bsdf = log(bsdf + 1e-5) - min_log;
372 printf("red sphere p%04d\n0\n0\n", ++n);
373 printf("4 %.6g %.6g %.6g %.6g\n\n",
374 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
375 .011*bsdf);
376 }
377 #endif
378 #if 1 /* output continuous surface */
379 puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 1\n");
380 fflush(stdout);
381 sprintf(buf, "gensurf tgreen bsdf - - - %d %d", grid_res-1, grid_res-1);
382 pfp = popen(buf, "w");
383 if (pfp == NULL) {
384 fprintf(stderr, "%s: cannot open '| %s'\n", progname, buf);
385 return(1);
386 }
387 for (i = 0; i < grid_res; i++)
388 for (j = 0; j < grid_res; j++) {
389 ovec_from_pos(dir, i, j);
390 bsdf = eval_rbfrep(dsf_list, dir);
391 bsdf = log(bsdf + 1e-5) - min_log;
392 fprintf(pfp, "%.8e %.8e %.8e\n",
393 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf);
394 }
395 if (pclose(pfp) != 0)
396 return(1);
397 #endif
398 return(0);
399 }
400
401 #endif /* TEST_MAIN */
