root/radiance/ray/src/cv/pabopto2bsdf.c
Revision: 2.36
Committed: Fri Jul 19 17:37:56 2019 UTC (4 years, 10 months ago) by greg
2 static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.35 2019/04/23 23:48:33 greg Exp $";
5 * Load measured BSDF data in PAB-Opto format.
6 * Assumes that surface-normal (Z-axis) faces into room unless -t option given.
7 *
8 * G. Ward
9 */
10
11 #define _USE_MATH_DEFINES
12 #include <stdlib.h>
13 #include <ctype.h>
14 #include <math.h>
15 #include "rtio.h"
16 #include "platform.h"
17 #include "bsdfrep.h"
18 /* global argv[0] */
19 char *progname;
20
21 typedef struct {
22 const char *fname; /* input file path */
23 double theta, phi; /* input angles (degrees) */
24 double up_phi; /* azimuth for "up" direction */
25 int igp[2]; /* input grid position */
26 int isDSF; /* data is DSF (rather than BSDF)? */
27 int nspec; /* number of spectral samples */
28 long dstart; /* data start offset in file */
29 } PGINPUT;
30
31 PGINPUT *inpfile; /* input files sorted by incidence */
32 int ninpfiles; /* number of input files */
33
34 int rev_orient = 0; /* shall we reverse surface orientation? */
35
36 /* Compare incident angles */
37 static int
38 cmp_indir(const void *p1, const void *p2)
39 {
40 const PGINPUT *inp1 = (const PGINPUT *)p1;
41 const PGINPUT *inp2 = (const PGINPUT *)p2;
42 int ydif = inp1->igp[1] - inp2->igp[1];
43
44 if (ydif)
45 return(ydif);
46
47 return(inp1->igp[0] - inp2->igp[0]);
48 }
49
50 /* Prepare a PAB-Opto input file by reading its header */
51 static int
52 init_pabopto_inp(const int i, const char *fname)
53 {
54 FILE *fp = fopen(fname, "r");
55 FVECT dv;
56 char buf[2048];
57 int c;
58
59 if (fp == NULL) {
60 fputs(fname, stderr);
61 fputs(": cannot open\n", stderr);
62 return(0);
63 }
64 inpfile[i].fname = fname;
65 inpfile[i].isDSF = -1;
66 inpfile[i].nspec = 0;
67 inpfile[i].up_phi = 0;
68 inpfile[i].theta = inpfile[i].phi = -10001.;
69 /* read header information */
70 while ((c = getc(fp)) == '#' || c == EOF) {
71 char typ[64];
72 if (fgets(buf, sizeof(buf), fp) == NULL) {
73 fputs(fname, stderr);
74 fputs(": unexpected EOF\n", stderr);
75 fclose(fp);
76 return(0);
77 }
78 if (sscanf(buf, "sample_name \"%[^\"]\"", bsdf_name) == 1)
79 continue;
80 if (sscanf(buf, "colorimetry: %s", typ) == 1) {
81 if (!strcasecmp(typ, "CIE-XYZ"))
82 inpfile[i].nspec = 3;
83 else if (!strcasecmp(typ, "CIE-Y"))
84 inpfile[i].nspec = 1;
85 continue;
86 }
87 if (sscanf(buf, "format: theta phi %s", typ) == 1) {
88 if (!strcasecmp(typ, "DSF"))
89 inpfile[i].isDSF = 1;
90 else if (!strcasecmp(typ, "BSDF") ||
91 !strcasecmp(typ, "BRDF") ||
92 !strcasecmp(typ, "BTDF"))
93 inpfile[i].isDSF = 0;
94 continue;
95 }
96 if (sscanf(buf, "upphi %lf", &inpfile[i].up_phi) == 1)
97 continue;
98 if (sscanf(buf, "intheta %lf", &inpfile[i].theta) == 1)
99 continue;
100 if (sscanf(buf, "inphi %lf", &inpfile[i].phi) == 1)
101 continue;
102 if (sscanf(buf, "incident_angle %lf %lf",
103 &inpfile[i].theta, &inpfile[i].phi) == 2)
104 continue;
105 }
106 inpfile[i].dstart = ftell(fp) - 1;
107 fclose(fp);
108 if (inpfile[i].isDSF < 0) {
109 fputs(fname, stderr);
110 fputs(": unknown format\n", stderr);
111 return(0);
112 }
113 if ((inpfile[i].theta < -10000.) | (inpfile[i].phi < -10000.)) {
114 fputs(fname, stderr);
115 fputs(": unknown incident angle\n", stderr);
116 return(0);
117 }
118 if (rev_orient) { /* reverse Z-axis to face outside */
119 inpfile[i].theta = 180. - inpfile[i].theta;
120 inpfile[i].phi = 360. - inpfile[i].phi;
121 }
122 /* convert to Y-up orientation */
123 inpfile[i].phi += 90.-inpfile[i].up_phi;
124 /* convert angle to grid position */
125 dv[2] = sin(M_PI/180.*inpfile[i].theta);
126 dv[0] = cos(M_PI/180.*inpfile[i].phi)*dv[2];
127 dv[1] = sin(M_PI/180.*inpfile[i].phi)*dv[2];
128 dv[2] = sqrt(1. - dv[2]*dv[2]);
129 if (inpfile[i].theta <= FTINY)
130 inpfile[i].igp[0] = inpfile[i].igp[1] = grid_res/2 - 1;
131 else
132 pos_from_vec(inpfile[i].igp, dv);
133 return(1);
134 }
135
136 /* Load a set of measurements corresponding to a particular incident angle */
137 static int
138 add_pabopto_inp(const int i)
139 {
140 FILE *fp = fopen(inpfile[i].fname, "r");
141 double theta_out, phi_out, val[3];
142 int n, c;
143
144 if (fp == NULL || fseek(fp, inpfile[i].dstart, 0) == EOF) {
145 fputs(inpfile[i].fname, stderr);
146 fputs(": cannot open\n", stderr);
147 return(0);
148 }
149 /* prepare input grid */
150 if (!i || cmp_indir(&inpfile[i-1], &inpfile[i])) {
151 if (i) /* process previous incidence */
152 make_rbfrep();
153 #ifdef DEBUG
154 fprintf(stderr, "New incident (theta,phi)=(%.1f,%.1f)\n",
155 inpfile[i].theta, inpfile[i].phi);
156 #endif
157 if (inpfile[i].nspec)
158 set_spectral_samples(inpfile[i].nspec);
159 new_bsdf_data(inpfile[i].theta, inpfile[i].phi);
160 }
161 #ifdef DEBUG
162 fprintf(stderr, "Loading measurements from '%s'...\n", inpfile[i].fname);
163 #endif
164 /* read scattering data */
165 while (fscanf(fp, "%lf %lf %lf", &theta_out, &phi_out, val) == 3) {
166 for (n = 1; n < inpfile[i].nspec; n++)
167 if (fscanf(fp, "%lf", val+n) != 1) {
168 fprintf(stderr, "%s: warning: unexpected EOF\n",
169 inpfile[i].fname);
170 fclose(fp);
171 return(1);
172 }
173 if (rev_orient) { /* reverse Z-axis to face outside */
174 theta_out = 180. - theta_out;
175 phi_out = 360. - phi_out;
176 }
177 add_bsdf_data(theta_out, phi_out+90.-inpfile[i].up_phi,
178 val, inpfile[i].isDSF);
179 }
180 n = 0;
181 while ((c = getc(fp)) != EOF)
182 n += !isspace(c);
183 if (n)
184 fprintf(stderr,
185 "%s: warning: %d unexpected characters past EOD\n",
186 inpfile[i].fname, n);
187 fclose(fp);
188 return(1);
189 }
190
191 #ifndef TEST_MAIN
192
193 #define SYM_ILL '?' /* illegal symmetry value */
194 #define SYM_ISO 'I' /* isotropic */
195 #define SYM_QUAD 'Q' /* quadrilateral symmetry */
196 #define SYM_BILAT 'B' /* bilateral symmetry */
197 #define SYM_ANISO 'A' /* anisotropic */
198
199 static const char quadrant_rep[16][16] = {
200 "in-plane","0-90","90-180","0-180",
201 "180-270","0-90+180-270","90-270",
202 "0-270","270-360","270-90",
203 "90-180+270-360","270-180","180-360",
204 "180-90","90-360","0-360"
205 };
206 static const char quadrant_sym[16] = {
207 SYM_ISO, SYM_QUAD, SYM_QUAD, SYM_BILAT,
208 SYM_QUAD, SYM_ILL, SYM_BILAT, SYM_ILL,
209 SYM_QUAD, SYM_BILAT, SYM_ILL, SYM_ILL,
210 SYM_BILAT, SYM_ILL, SYM_ILL, SYM_ANISO
211 };
212
213 /* Read in PAB-Opto BSDF files and output RBF interpolant */
214 int
215 main(int argc, char *argv[])
216 {
217 extern int nprocs;
218 const char *symmetry = "U";
219 int i;
220 /* start header */
221 SET_FILE_BINARY(stdout);
222 newheader("RADIANCE", stdout);
223 printargs(argc, argv, stdout);
224 fputnow(stdout);
225 progname = argv[0]; /* get options */
226 while (argc > 2 && argv[1][0] == '-') {
227 switch (argv[1][1]) {
228 case 't':
229 rev_orient = !rev_orient;
230 break;
231 case 'n':
232 nprocs = atoi(argv[2]);
233 argv++; argc--;
234 break;
235 case 's':
236 symmetry = argv[2];
237 argv++; argc--;
238 break;
239 default:
240 goto userr;
241 }
242 argv++; argc--;
243 }
244 /* initialize & sort inputs */
245 ninpfiles = argc - 1;
246 if (ninpfiles < 2)
247 goto userr;
248 inpfile = (PGINPUT *)malloc(sizeof(PGINPUT)*ninpfiles);
249 if (inpfile == NULL)
250 return(1);
251 for (i = 0; i < ninpfiles; i++)
252 if (!init_pabopto_inp(i, argv[i+1]))
253 return(1);
254 qsort(inpfile, ninpfiles, sizeof(PGINPUT), cmp_indir);
255 /* compile measurements */
256 for (i = 0; i < ninpfiles; i++)
257 if (!add_pabopto_inp(i))
258 return(1);
259 make_rbfrep(); /* process last data set */
260 /* check input symmetry */
261 switch (toupper(symmetry[0])) {
262 case 'U': /* unspecified symmetry */
263 if (quadrant_sym[inp_coverage] != SYM_ILL)
264 break; /* anything legal goes */
265 fprintf(stderr, "%s: unsupported phi coverage (%s)\n",
266 progname, quadrant_rep[inp_coverage]);
267 return(1);
268 case SYM_ISO: /* legal symmetry types */
269 case SYM_QUAD:
270 case SYM_BILAT:
271 case SYM_ANISO:
272 if (quadrant_sym[inp_coverage] == toupper(symmetry[0]))
273 break; /* matches spec */
274 fprintf(stderr,
275 "%s: phi coverage (%s) does not match requested '%s' symmetry\n",
276 progname, quadrant_rep[inp_coverage], symmetry);
277 return(1);
278 default:
279 fprintf(stderr,
280 "%s: -s option must be Isotropic, Quadrilateral, Bilateral, or Anisotropic\n",
281 progname);
282 return(1);
283 }
284 #ifdef DEBUG
285 fprintf(stderr, "Input phi coverage (%s) has '%c' symmetry\n",
286 quadrant_rep[inp_coverage],
287 quadrant_sym[inp_coverage]);
288 #endif
289 build_mesh(); /* create interpolation */
290 save_bsdf_rep(stdout); /* write it out */
291 return(0);
292 userr:
293 fprintf(stderr, "Usage: %s [-t][-n nproc][-s symmetry] meas1.dat meas2.dat .. > bsdf.sir\n",
294 progname);
295 return(1);
296 }
297
298 #else /* TEST_MAIN */
299
300 /* Test main produces a Radiance model from the given input file */
301 int
302 main(int argc, char *argv[])
303 {
304 PGINPUT pginp;
305 char buf[128];
306 FILE *pfp;
307 double bsdf, min_log;
308 FVECT dir;
309 int i, j, n;
310
311 progname = argv[0];
312 if (argc != 2) {
313 fprintf(stderr, "Usage: %s input.dat > output.rad\n", progname);
314 return(1);
315 }
316 ninpfiles = 1;
317 inpfile = &pginp;
318 if (!init_pabopto_inp(0, argv[1]) || !add_pabopto_inp(0))
319 return(1);
320 /* reduce data set */
321 if (make_rbfrep() == NULL) {
322 fprintf(stderr, "%s: nothing to plot!\n", progname);
323 exit(1);
324 }
325 #ifdef DEBUG
326 fprintf(stderr, "Minimum BSDF = %.4f\n", bsdf_min);
327 #endif
328 min_log = log(bsdf_min*.5 + 1e-5);
329 #if 1 /* produce spheres at meas. */
330 puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n");
331 n = 0;
332 for (i = 0; i < grid_res; i++)
333 for (j = 0; j < grid_res; j++)
334 if (dsf_grid[i][j].sum.n > 0) {
335 ovec_from_pos(dir, i, j);
336 bsdf = dsf_grid[i][j].sum.v /
337 ((double)dsf_grid[i][j].sum.n*output_orient*dir[2]);
338 if (bsdf <= bsdf_min*.6)
339 continue;
340 bsdf = log(bsdf + 1e-5) - min_log;
341 ovec_from_pos(dir, i, j);
342 printf("yellow sphere s%04d\n0\n0\n", ++n);
343 printf("4 %.6g %.6g %.6g %.6g\n\n",
344 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
345 .007*bsdf);
346 }
347 #endif
348 #if 1 /* spheres at RBF peaks */
349 puts("void plastic red\n0\n0\n5 .8 .01 .01 .04 .08\n");
350 for (n = 0; n < dsf_list->nrbf; n++) {
351 RBFVAL *rbf = &dsf_list->rbfa[n];
352 ovec_from_pos(dir, rbf->gx, rbf->gy);
353 bsdf = eval_rbfrep(dsf_list, dir);
354 bsdf = log(bsdf + 1e-5) - min_log;
355 printf("red sphere p%04d\n0\n0\n", ++n);
356 printf("4 %.6g %.6g %.6g %.6g\n\n",
357 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
358 .011*bsdf);
359 }
360 #endif
361 #if 1 /* output continuous surface */
362 puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 1\n");
363 fflush(stdout);
364 sprintf(buf, "gensurf tgreen bsdf - - - %d %d", grid_res-1, grid_res-1);
365 pfp = popen(buf, "w");
366 if (pfp == NULL) {
367 fprintf(stderr, "%s: cannot open '| %s'\n", progname, buf);
368 return(1);
369 }
370 for (i = 0; i < grid_res; i++)
371 for (j = 0; j < grid_res; j++) {
372 ovec_from_pos(dir, i, j);
373 bsdf = eval_rbfrep(dsf_list, dir);
374 bsdf = log(bsdf + 1e-5) - min_log;
375 fprintf(pfp, "%.8e %.8e %.8e\n",
376 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf);
377 }
378 if (pclose(pfp) != 0)
379 return(1);
380 #endif
381 return(0);
382 }
383
384 #endif /* TEST_MAIN */
