root/radiance/ray/src/cv/pabopto2bsdf.c
Revision: 2.34
Committed: Tue Apr 23 17:18:18 2019 UTC (6 years, 1 month ago) by greg
Changes since 2.33: +7 -4 lines
Added checks for other illegal phi coverage flags
2 static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.33 2019/04/23 17:00:40 greg Exp $";
5 * Load measured BSDF data in PAB-Opto format.
6 * Assumes that surface-normal (Z-axis) faces into room unless -t option given.
7 *
8 * G. Ward
9 */
10
11 #define _USE_MATH_DEFINES
12 #include <stdio.h>
13 #include <stdlib.h>
14 #include <string.h>
15 #include <ctype.h>
16 #include <math.h>
17 #include "platform.h"
18 #include "bsdfrep.h"
19 #include "resolu.h"
20 /* global argv[0] */
21 char *progname;
22
23 typedef struct {
24 const char *fname; /* input file path */
25 double theta, phi; /* input angles (degrees) */
26 double up_phi; /* azimuth for "up" direction */
27 int igp[2]; /* input grid position */
28 int isDSF; /* data is DSF (rather than BSDF)? */
29 int nspec; /* number of spectral samples */
30 long dstart; /* data start offset in file */
31 } PGINPUT;
32
33 PGINPUT *inpfile; /* input files sorted by incidence */
34 int ninpfiles; /* number of input files */
35
36 int rev_orient = 0; /* shall we reverse surface orientation? */
37
38 /* Compare incident angles */
39 static int
40 cmp_indir(const void *p1, const void *p2)
41 {
42 const PGINPUT *inp1 = (const PGINPUT *)p1;
43 const PGINPUT *inp2 = (const PGINPUT *)p2;
44 int ydif = inp1->igp[1] - inp2->igp[1];
45
46 if (ydif)
47 return(ydif);
48
49 return(inp1->igp[0] - inp2->igp[0]);
50 }
51
52 /* Prepare a PAB-Opto input file by reading its header */
53 static int
54 init_pabopto_inp(const int i, const char *fname)
55 {
56 FILE *fp = fopen(fname, "r");
57 FVECT dv;
58 char buf[2048];
59 int c;
60
61 if (fp == NULL) {
62 fputs(fname, stderr);
63 fputs(": cannot open\n", stderr);
64 return(0);
65 }
66 inpfile[i].fname = fname;
67 inpfile[i].isDSF = -1;
68 inpfile[i].nspec = 0;
69 inpfile[i].up_phi = 0;
70 inpfile[i].theta = inpfile[i].phi = -10001.;
71 /* read header information */
72 while ((c = getc(fp)) == '#' || c == EOF) {
73 char typ[64];
74 if (fgets(buf, sizeof(buf), fp) == NULL) {
75 fputs(fname, stderr);
76 fputs(": unexpected EOF\n", stderr);
77 fclose(fp);
78 return(0);
79 }
80 if (sscanf(buf, "sample_name \"%[^\"]\"", bsdf_name) == 1)
81 continue;
82 if (sscanf(buf, "colorimetry: %s", typ) == 1) {
83 if (!strcasecmp(typ, "CIE-XYZ"))
84 inpfile[i].nspec = 3;
85 else if (!strcasecmp(typ, "CIE-Y"))
86 inpfile[i].nspec = 1;
87 continue;
88 }
89 if (sscanf(buf, "format: theta phi %s", typ) == 1) {
90 if (!strcasecmp(typ, "DSF"))
91 inpfile[i].isDSF = 1;
92 else if (!strcasecmp(typ, "BSDF") ||
93 !strcasecmp(typ, "BRDF") ||
94 !strcasecmp(typ, "BTDF"))
95 inpfile[i].isDSF = 0;
96 continue;
97 }
98 if (sscanf(buf, "upphi %lf", &inpfile[i].up_phi) == 1)
99 continue;
100 if (sscanf(buf, "intheta %lf", &inpfile[i].theta) == 1)
101 continue;
102 if (sscanf(buf, "inphi %lf", &inpfile[i].phi) == 1)
103 continue;
104 if (sscanf(buf, "incident_angle %lf %lf",
105 &inpfile[i].theta, &inpfile[i].phi) == 2)
106 continue;
107 }
108 inpfile[i].dstart = ftell(fp) - 1;
109 fclose(fp);
110 if (inpfile[i].isDSF < 0) {
111 fputs(fname, stderr);
112 fputs(": unknown format\n", stderr);
113 return(0);
114 }
115 if ((inpfile[i].theta < -10000.) | (inpfile[i].phi < -10000.)) {
116 fputs(fname, stderr);
117 fputs(": unknown incident angle\n", stderr);
118 return(0);
119 }
120 if (rev_orient) { /* reverse Z-axis to face outside */
121 inpfile[i].theta = 180. - inpfile[i].theta;
122 inpfile[i].phi = 360. - inpfile[i].phi;
123 }
124 /* convert to Y-up orientation */
125 inpfile[i].phi += 90.-inpfile[i].up_phi;
126 /* convert angle to grid position */
127 dv[2] = sin(M_PI/180.*inpfile[i].theta);
128 dv[0] = cos(M_PI/180.*inpfile[i].phi)*dv[2];
129 dv[1] = sin(M_PI/180.*inpfile[i].phi)*dv[2];
130 dv[2] = sqrt(1. - dv[2]*dv[2]);
131 if (inpfile[i].theta <= FTINY)
132 inpfile[i].igp[0] = inpfile[i].igp[1] = grid_res/2 - 1;
133 else
134 pos_from_vec(inpfile[i].igp, dv);
135 return(1);
136 }
137
138 /* Load a set of measurements corresponding to a particular incident angle */
139 static int
140 add_pabopto_inp(const int i)
141 {
142 FILE *fp = fopen(inpfile[i].fname, "r");
143 double theta_out, phi_out, val[3];
144 int n, c;
145
146 if (fp == NULL || fseek(fp, inpfile[i].dstart, 0) == EOF) {
147 fputs(inpfile[i].fname, stderr);
148 fputs(": cannot open\n", stderr);
149 return(0);
150 }
151 /* prepare input grid */
152 if (!i || cmp_indir(&inpfile[i-1], &inpfile[i])) {
153 if (i) /* process previous incidence */
154 make_rbfrep();
155 #ifdef DEBUG
156 fprintf(stderr, "New incident (theta,phi)=(%.1f,%.1f)\n",
157 inpfile[i].theta, inpfile[i].phi);
158 #endif
159 if (inpfile[i].nspec)
160 set_spectral_samples(inpfile[i].nspec);
161 new_bsdf_data(inpfile[i].theta, inpfile[i].phi);
162 }
163 #ifdef DEBUG
164 fprintf(stderr, "Loading measurements from '%s'...\n", inpfile[i].fname);
165 #endif
166 /* read scattering data */
167 while (fscanf(fp, "%lf %lf %lf", &theta_out, &phi_out, val) == 3) {
168 for (n = 1; n < inpfile[i].nspec; n++)
169 if (fscanf(fp, "%lf", val+n) != 1) {
170 fprintf(stderr, "%s: warning: unexpected EOF\n",
171 inpfile[i].fname);
172 fclose(fp);
173 return(1);
174 }
175 if (rev_orient) { /* reverse Z-axis to face outside */
176 theta_out = 180. - theta_out;
177 phi_out = 360. - phi_out;
178 }
179 add_bsdf_data(theta_out, phi_out+90.-inpfile[i].up_phi,
180 val, inpfile[i].isDSF);
181 }
182 n = 0;
183 while ((c = getc(fp)) != EOF)
184 n += !isspace(c);
185 if (n)
186 fprintf(stderr,
187 "%s: warning: %d unexpected characters past EOD\n",
188 inpfile[i].fname, n);
189 fclose(fp);
190 return(1);
191 }
192
193 #ifndef TEST_MAIN
194 /* Read in PAB-Opto BSDF files and output RBF interpolant */
195 int
196 main(int argc, char *argv[])
197 {
198 extern int nprocs;
199 static const char quadrant_rep[16][16] = {
200 "iso","0-90","90-180","0-180",
201 "180-270","0-90+180-270","90-270",
202 "0-270","270-360","270-90",
203 "90-180+270-360","270-180","180-360",
204 "0-90+180-360","90-360","0-360"
205 };
206 const char * symmetry = "Unknown";
207 int i;
208 /* start header */
209 SET_FILE_BINARY(stdout);
210 newheader("RADIANCE", stdout);
211 printargs(argc, argv, stdout);
212 fputnow(stdout);
213 progname = argv[0]; /* get options */
214 while (argc > 2 && argv[1][0] == '-') {
215 switch (argv[1][1]) {
216 case 't':
217 rev_orient = !rev_orient;
218 break;
219 case 'n':
220 nprocs = atoi(argv[2]);
221 argv++; argc--;
222 break;
223 case 's':
224 symmetry = argv[2];
225 argv++; argc--;
226 break;
227 default:
228 goto userr;
229 }
230 argv++; argc--;
231 }
232 /* initialize & sort inputs */
233 ninpfiles = argc - 1;
234 if (ninpfiles < 2)
235 goto userr;
236 inpfile = (PGINPUT *)malloc(sizeof(PGINPUT)*ninpfiles);
237 if (inpfile == NULL)
238 return(1);
239 for (i = 0; i < ninpfiles; i++)
240 if (!init_pabopto_inp(i, argv[i+1]))
241 return(1);
242 qsort(inpfile, ninpfiles, sizeof(PGINPUT), cmp_indir);
243 /* compile measurements */
244 for (i = 0; i < ninpfiles; i++)
245 if (!add_pabopto_inp(i))
246 return(1);
247 make_rbfrep(); /* process last data set */
248 /* check input symmetry */
249 switch (toupper(symmetry[0])) {
250 case 'U': /* unknown symmetry */
251 if ((inp_coverage == (INP_QUAD1|INP_QUAD3)) |
252 (inp_coverage == (INP_QUAD2|INP_QUAD4)) |
253 (inp_coverage == (INP_QUAD1|INP_QUAD2|INP_QUAD3)) |
254 (inp_coverage == (INP_QUAD2|INP_QUAD3|INP_QUAD4)) |
255 (inp_coverage == (INP_QUAD4|INP_QUAD1|INP_QUAD2)) |
256 (inp_coverage == (INP_QUAD1|INP_QUAD3|INP_QUAD4))) {
257 fprintf(stderr, "%s: unsupported phi coverage (%s)\n",
258 progname, quadrant_rep[inp_coverage]);
259 return(1);
260 }
261 break;
262 case 'I': /* isotropic */
263 if (inp_coverage)
264 goto badsymmetry;
265 break;
266 case 'Q': /* quadrilateral symmetry */
267 if ((inp_coverage != INP_QUAD1) &
268 (inp_coverage != INP_QUAD2) &
269 (inp_coverage != INP_QUAD3) &
270 (inp_coverage != INP_QUAD4))
271 goto badsymmetry;
272 break;
273 case 'B': /* bilateral symmetry */
274 if ((inp_coverage != (INP_QUAD1|INP_QUAD2)) &
275 (inp_coverage != (INP_QUAD2|INP_QUAD3)) &
276 (inp_coverage != (INP_QUAD3|INP_QUAD4)) &
277 (inp_coverage != (INP_QUAD4|INP_QUAD1)))
278 goto badsymmetry;
279 break;
280 case 'A': /* anisotropic */
281 if (inp_coverage != (INP_QUAD1|INP_QUAD2|INP_QUAD3|INP_QUAD4))
282 goto badsymmetry;
283 break;
284 default:
285 fprintf(stderr,
286 "%s: -s option must be Isotropic, Quadrilateral, Bilateral, or Anisotropic\n",
287 progname);
288 return(1);
289 }
290 #ifdef DEBUG
291 fprintf(stderr, "Input phi coverage: %s\n", quadrant_rep[inp_coverage]);
292 #endif
293 build_mesh(); /* create interpolation */
294 save_bsdf_rep(stdout); /* write it out */
295 return(0);
296 badsymmetry:
297 fprintf(stderr, "%s: phi coverage (%s) does not match requested '%s' symmetry\n",
298 progname, quadrant_rep[inp_coverage], symmetry);
299 userr:
300 fprintf(stderr, "Usage: %s [-t][-n nproc][-s symmetry] meas1.dat meas2.dat .. > bsdf.sir\n",
301 progname);
302 return(1);
303 }
304 #else
305 /* Test main produces a Radiance model from the given input file */
306 int
307 main(int argc, char *argv[])
308 {
309 PGINPUT pginp;
310 char buf[128];
311 FILE *pfp;
312 double bsdf, min_log;
313 FVECT dir;
314 int i, j, n;
315
316 progname = argv[0];
317 if (argc != 2) {
318 fprintf(stderr, "Usage: %s input.dat > output.rad\n", progname);
319 return(1);
320 }
321 ninpfiles = 1;
322 inpfile = &pginp;
323 if (!init_pabopto_inp(0, argv[1]) || !add_pabopto_inp(0))
324 return(1);
325 /* reduce data set */
326 if (make_rbfrep() == NULL) {
327 fprintf(stderr, "%s: nothing to plot!\n", progname);
328 exit(1);
329 }
330 #ifdef DEBUG
331 fprintf(stderr, "Minimum BSDF = %.4f\n", bsdf_min);
332 #endif
333 min_log = log(bsdf_min*.5 + 1e-5);
334 #if 1 /* produce spheres at meas. */
335 puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n");
336 n = 0;
337 for (i = 0; i < grid_res; i++)
338 for (j = 0; j < grid_res; j++)
339 if (dsf_grid[i][j].sum.n > 0) {
340 ovec_from_pos(dir, i, j);
341 bsdf = dsf_grid[i][j].sum.v /
342 ((double)dsf_grid[i][j].sum.n*output_orient*dir[2]);
343 if (bsdf <= bsdf_min*.6)
344 continue;
345 bsdf = log(bsdf + 1e-5) - min_log;
346 ovec_from_pos(dir, i, j);
347 printf("yellow sphere s%04d\n0\n0\n", ++n);
348 printf("4 %.6g %.6g %.6g %.6g\n\n",
349 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
350 .007*bsdf);
351 }
352 #endif
353 #if 1 /* spheres at RBF peaks */
354 puts("void plastic red\n0\n0\n5 .8 .01 .01 .04 .08\n");
355 for (n = 0; n < dsf_list->nrbf; n++) {
356 RBFVAL *rbf = &dsf_list->rbfa[n];
357 ovec_from_pos(dir, rbf->gx, rbf->gy);
358 bsdf = eval_rbfrep(dsf_list, dir);
359 bsdf = log(bsdf + 1e-5) - min_log;
360 printf("red sphere p%04d\n0\n0\n", ++n);
361 printf("4 %.6g %.6g %.6g %.6g\n\n",
362 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
363 .011*bsdf);
364 }
365 #endif
366 #if 1 /* output continuous surface */
367 puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 1\n");
368 fflush(stdout);
369 sprintf(buf, "gensurf tgreen bsdf - - - %d %d", grid_res-1, grid_res-1);
370 pfp = popen(buf, "w");
371 if (pfp == NULL) {
372 fprintf(stderr, "%s: cannot open '| %s'\n", progname, buf);
373 return(1);
374 }
375 for (i = 0; i < grid_res; i++)
376 for (j = 0; j < grid_res; j++) {
377 ovec_from_pos(dir, i, j);
378 bsdf = eval_rbfrep(dsf_list, dir);
379 bsdf = log(bsdf + 1e-5) - min_log;
380 fprintf(pfp, "%.8e %.8e %.8e\n",
381 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf);
382 }
383 if (pclose(pfp) != 0)
384 return(1);
385 #endif
386 return(0);
387 }
388 #endif
