| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.20 2014/03/20 16:54:23 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Load measured BSDF data in PAB-Opto format.
| 6 |
| 7 |
* G. Ward
| 8 |
| 9 |
| 10 |
#define _USE_MATH_DEFINES
| 11 |
#include <stdio.h>
| 12 |
#include <stdlib.h>
| 13 |
#include <string.h>
| 14 |
#include <ctype.h>
| 15 |
#include <math.h>
| 16 |
#include "platform.h"
| 17 |
#include "bsdfrep.h"
| 18 |
#include "resolu.h"
| 19 |
/* global argv[0] */
| 20 |
char *progname;
| 21 |
| 22 |
typedef struct {
| 23 |
const char *fname; /* input file path */
| 24 |
double theta, phi; /* input angles */
| 25 |
int igp[2]; /* input grid position */
| 26 |
int isDSF; /* data is DSF (rather than BSDF)? */
| 27 |
long dstart; /* data start offset in file */
| 28 |
} PGINPUT;
| 29 |
| 30 |
PGINPUT *inpfile; /* input files sorted by incidence */
| 31 |
int ninpfiles; /* number of input files */
| 32 |
| 33 |
/* Compare incident angles */
| 34 |
static int
| 35 |
cmp_indir(const void *p1, const void *p2)
| 36 |
| 37 |
const PGINPUT *inp1 = (const PGINPUT *)p1;
| 38 |
const PGINPUT *inp2 = (const PGINPUT *)p2;
| 39 |
int ydif = inp1->igp[1] - inp2->igp[1];
| 40 |
| 41 |
if (ydif)
| 42 |
return(ydif);
| 43 |
| 44 |
return(inp1->igp[0] - inp2->igp[0]);
| 45 |
| 46 |
| 47 |
/* Prepare a PAB-Opto input file by reading its header */
| 48 |
static int
| 49 |
init_pabopto_inp(const int i, const char *fname)
| 50 |
| 51 |
FILE *fp = fopen(fname, "r");
| 52 |
FVECT dv;
| 53 |
char buf[2048];
| 54 |
int c;
| 55 |
| 56 |
if (fp == NULL) {
| 57 |
fputs(fname, stderr);
| 58 |
fputs(": cannot open\n", stderr);
| 59 |
return(0);
| 60 |
| 61 |
inpfile[i].fname = fname;
| 62 |
inpfile[i].isDSF = -1;
| 63 |
inpfile[i].theta = inpfile[i].phi = -10001.;
| 64 |
/* read header information */
| 65 |
while ((c = getc(fp)) == '#' || c == EOF) {
| 66 |
char typ[32];
| 67 |
if (fgets(buf, sizeof(buf), fp) == NULL) {
| 68 |
| 69 |
fputs(": unexpected EOF\n", stderr);
| 70 |
fclose(fp);
| 71 |
return(0);
| 72 |
| 73 |
if (sscanf(buf, "sample_name \"%[^\"]\"", bsdf_name) == 1)
| 74 |
continue;
| 75 |
if (sscanf(buf, "format: theta phi %s", typ) == 1) {
| 76 |
if (!strcasecmp(typ, "DSF")) {
| 77 |
inpfile[i].isDSF = 1;
| 78 |
continue;
| 79 |
| 80 |
if (!strcasecmp(typ, "BSDF")) {
| 81 |
inpfile[i].isDSF = 0;
| 82 |
continue;
| 83 |
| 84 |
| 85 |
if (sscanf(buf, "intheta %lf", &inpfile[i].theta) == 1)
| 86 |
continue;
| 87 |
if (sscanf(buf, "inphi %lf", &inpfile[i].phi) == 1)
| 88 |
continue;
| 89 |
if (sscanf(buf, "incident_angle %lf %lf",
| 90 |
&inpfile[i].theta, &inpfile[i].phi) == 2)
| 91 |
continue;
| 92 |
| 93 |
inpfile[i].dstart = ftell(fp) - 1;
| 94 |
fclose(fp);
| 95 |
if (inpfile[i].isDSF < 0) {
| 96 |
| 97 |
fputs(": unknown format\n", stderr);
| 98 |
return(0);
| 99 |
| 100 |
if ((inpfile[i].theta < -10000.) | (inpfile[i].phi < -10000.)) {
| 101 |
| 102 |
fputs(": unknown incident angle\n", stderr);
| 103 |
return(0);
| 104 |
| 105 |
/* convert angle to grid position */
| 106 |
dv[2] = sin(M_PI/180.*inpfile[i].theta);
| 107 |
dv[0] = cos(M_PI/180.*inpfile[i].phi)*dv[2];
| 108 |
dv[1] = sin(M_PI/180.*inpfile[i].phi)*dv[2];
| 109 |
dv[2] = sqrt(1. - dv[2]*dv[2]);
| 110 |
pos_from_vec(inpfile[i].igp, dv);
| 111 |
return(1);
| 112 |
| 113 |
| 114 |
/* Load a set of measurements corresponding to a particular incident angle */
| 115 |
static int
| 116 |
add_pabopto_inp(const int i)
| 117 |
| 118 |
FILE *fp = fopen(inpfile[i].fname, "r");
| 119 |
double theta_out, phi_out, val;
| 120 |
int n, c;
| 121 |
| 122 |
if (fp == NULL || fseek(fp, inpfile[i].dstart, 0) == EOF) {
| 123 |
fputs(inpfile[i].fname, stderr);
| 124 |
| 125 |
return(0);
| 126 |
| 127 |
/* prepare input grid */
| 128 |
if (!i || cmp_indir(&inpfile[i-1], &inpfile[i])) {
| 129 |
if (i) /* process previous incidence */
| 130 |
make_rbfrep();
| 131 |
#ifdef DEBUG
| 132 |
fprintf(stderr, "New incident (theta,phi)=(%f,%f)\n",
| 133 |
inpfile[i].theta, inpfile[i].phi);
| 134 |
#endif
| 135 |
new_bsdf_data(inpfile[i].theta, inpfile[i].phi);
| 136 |
| 137 |
#ifdef DEBUG
| 138 |
fprintf(stderr, "Loading measurements from '%s'...\n", inpfile[i].fname);
| 139 |
#endif
| 140 |
/* read scattering data */
| 141 |
while (fscanf(fp, "%lf %lf %lf\n", &theta_out, &phi_out, &val) == 3)
| 142 |
add_bsdf_data(theta_out, phi_out, val, inpfile[i].isDSF);
| 143 |
n = 0;
| 144 |
while ((c = getc(fp)) != EOF)
| 145 |
n += !isspace(c);
| 146 |
if (n)
| 147 |
fprintf(stderr,
| 148 |
"%s: warning: %d unexpected characters past EOD\n",
| 149 |
inpfile[i].fname, n);
| 150 |
fclose(fp);
| 151 |
return(1);
| 152 |
| 153 |
| 154 |
#ifndef TEST_MAIN
| 155 |
/* Read in PAB-Opto BSDF files and output RBF interpolant */
| 156 |
int
| 157 |
main(int argc, char *argv[])
| 158 |
| 159 |
extern int nprocs;
| 160 |
int i;
| 161 |
/* start header */
| 162 |
SET_FILE_BINARY(stdout);
| 163 |
newheader("RADIANCE", stdout);
| 164 |
printargs(argc, argv, stdout);
| 165 |
fputnow(stdout);
| 166 |
progname = argv[0]; /* get options */
| 167 |
while (argc > 2 && argv[1][0] == '-') {
| 168 |
switch (argv[1][1]) {
| 169 |
case 'n':
| 170 |
nprocs = atoi(argv[2]);
| 171 |
break;
| 172 |
default:
| 173 |
goto userr;
| 174 |
| 175 |
argv += 2; argc -= 2;
| 176 |
| 177 |
/* initialize & sort inputs */
| 178 |
ninpfiles = argc - 1;
| 179 |
if (ninpfiles < 2)
| 180 |
goto userr;
| 181 |
inpfile = (PGINPUT *)malloc(sizeof(PGINPUT)*ninpfiles);
| 182 |
if (inpfile == NULL)
| 183 |
return(1);
| 184 |
for (i = 0; i < ninpfiles; i++)
| 185 |
if (!init_pabopto_inp(i, argv[i+1]))
| 186 |
return(1);
| 187 |
qsort(inpfile, ninpfiles, sizeof(PGINPUT), &cmp_indir);
| 188 |
/* compile measurements */
| 189 |
| 190 |
if (!add_pabopto_inp(i))
| 191 |
return(1);
| 192 |
make_rbfrep(); /* process last data set */
| 193 |
build_mesh(); /* create interpolation */
| 194 |
save_bsdf_rep(stdout); /* write it out */
| 195 |
return(0);
| 196 |
userr:
| 197 |
fprintf(stderr, "Usage: %s [-n nproc] meas1.dat meas2.dat .. > bsdf.sir\n",
| 198 |
progname);
| 199 |
return(1);
| 200 |
| 201 |
#else
| 202 |
/* Test main produces a Radiance model from the given input file */
| 203 |
int
| 204 |
| 205 |
| 206 |
PGINPUT pginp;
| 207 |
char buf[128];
| 208 |
FILE *pfp;
| 209 |
double bsdf, min_log;
| 210 |
FVECT dir;
| 211 |
int i, j, n;
| 212 |
| 213 |
progname = argv[0];
| 214 |
if (argc != 2) {
| 215 |
fprintf(stderr, "Usage: %s input.dat > output.rad\n", progname);
| 216 |
return(1);
| 217 |
| 218 |
ninpfiles = 1;
| 219 |
inpfile = &pginp;
| 220 |
if (!init_pabopto_inp(0, argv[1]) || !add_pabopto_inp(0))
| 221 |
return(1);
| 222 |
/* reduce data set */
| 223 |
if (make_rbfrep() == NULL) {
| 224 |
fprintf(stderr, "%s: nothing to plot!\n", progname);
| 225 |
exit(1);
| 226 |
| 227 |
#ifdef DEBUG
| 228 |
fprintf(stderr, "Minimum BSDF = %.4f\n", bsdf_min);
| 229 |
#endif
| 230 |
min_log = log(bsdf_min*.5 + 1e-5);
| 231 |
#if 1 /* produce spheres at meas. */
| 232 |
puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n");
| 233 |
n = 0;
| 234 |
for (i = 0; i < GRIDRES; i++)
| 235 |
for (j = 0; j < GRIDRES; j++)
| 236 |
if (dsf_grid[i][j].sum.n > 0) {
| 237 |
ovec_from_pos(dir, i, j);
| 238 |
bsdf = dsf_grid[i][j].sum.v /
| 239 |
(dsf_grid[i][j].sum.n*output_orient*dir[2]);
| 240 |
if (bsdf <= bsdf_min*.6)
| 241 |
continue;
| 242 |
bsdf = log(bsdf + 1e-5) - min_log;
| 243 |
| 244 |
printf("yellow sphere s%04d\n0\n0\n", ++n);
| 245 |
printf("4 %.6g %.6g %.6g %.6g\n\n",
| 246 |
dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
| 247 |
.007*bsdf);
| 248 |
| 249 |
#endif
| 250 |
#if 1 /* spheres at RBF peaks */
| 251 |
puts("void plastic red\n0\n0\n5 .8 .01 .01 .04 .08\n");
| 252 |
for (n = 0; n < dsf_list->nrbf; n++) {
| 253 |
RBFVAL *rbf = &dsf_list->rbfa[n];
| 254 |
ovec_from_pos(dir, rbf->gx, rbf->gy);
| 255 |
bsdf = eval_rbfrep(dsf_list, dir) / (output_orient*dir[2]);
| 256 |
| 257 |
printf("red sphere p%04d\n0\n0\n", ++n);
| 258 |
| 259 |
| 260 |
.011*bsdf);
| 261 |
| 262 |
#endif
| 263 |
#if 1 /* output continuous surface */
| 264 |
puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 1\n");
| 265 |
fflush(stdout);
| 266 |
sprintf(buf, "gensurf tgreen bsdf - - - %d %d", GRIDRES-1, GRIDRES-1);
| 267 |
pfp = popen(buf, "w");
| 268 |
if (pfp == NULL) {
| 269 |
fprintf(stderr, "%s: cannot open '| %s'\n", progname, buf);
| 270 |
return(1);
| 271 |
| 272 |
| 273 |
for (j = 0; j < GRIDRES; j++) {
| 274 |
| 275 |
| 276 |
| 277 |
fprintf(pfp, "%.8e %.8e %.8e\n",
| 278 |
dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf);
| 279 |
| 280 |
if (pclose(pfp) != 0)
| 281 |
return(1);
| 282 |
#endif
| 283 |
return(0);
| 284 |
| 285 |
#endif
