--- ray/src/cv/pabopto2bsdf.c 2014/03/18 19:08:24 2.17 +++ ray/src/cv/pabopto2bsdf.c 2014/03/20 16:54:23 2.20 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.17 2014/03/18 19:08:24 greg Exp $"; +static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.20 2014/03/20 16:54:23 greg Exp $"; #endif /* * Load measured BSDF data in PAB-Opto format. @@ -7,6 +7,7 @@ static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.1 * G. Ward */ +#define _USE_MATH_DEFINES #include #include #include @@ -20,32 +21,27 @@ char *progname; typedef struct { const char *fname; /* input file path */ - double theta, phi; /* incident angles (in degrees) */ + double theta, phi; /* input angles */ + int igp[2]; /* input grid position */ int isDSF; /* data is DSF (rather than BSDF)? */ long dstart; /* data start offset in file */ } PGINPUT; -const double ANGLE_EPS = 180./2./GRIDRES; - PGINPUT *inpfile; /* input files sorted by incidence */ int ninpfiles; /* number of input files */ /* Compare incident angles */ static int -cmp_inang(const void *p1, const void *p2) +cmp_indir(const void *p1, const void *p2) { const PGINPUT *inp1 = (const PGINPUT *)p1; const PGINPUT *inp2 = (const PGINPUT *)p2; + int ydif = inp1->igp[1] - inp2->igp[1]; - if (inp1->theta > inp2->theta+ANGLE_EPS) - return(1); - if (inp1->theta < inp2->theta-ANGLE_EPS) - return(-1); - if (inp1->phi > inp2->phi+ANGLE_EPS) - return(1); - if (inp1->phi < inp2->phi-ANGLE_EPS) - return(-1); - return(0); + if (ydif) + return(ydif); + + return(inp1->igp[0] - inp2->igp[0]); } /* Prepare a PAB-Opto input file by reading its header */ @@ -53,6 +49,7 @@ static int init_pabopto_inp(const int i, const char *fname) { FILE *fp = fopen(fname, "r"); + FVECT dv; char buf[2048]; int c; @@ -105,8 +102,12 @@ init_pabopto_inp(const int i, const char *fname) fputs(": unknown incident angle\n", stderr); return(0); } - while (inpfile[i].phi < 0) /* normalize phi direction */ - inpfile[i].phi += 360.; + /* convert angle to grid position */ + dv[2] = sin(M_PI/180.*inpfile[i].theta); + dv[0] = cos(M_PI/180.*inpfile[i].phi)*dv[2]; + dv[1] = sin(M_PI/180.*inpfile[i].phi)*dv[2]; + dv[2] = sqrt(1. - dv[2]*dv[2]); + pos_from_vec(inpfile[i].igp, dv); return(1); } @@ -114,9 +115,9 @@ init_pabopto_inp(const int i, const char *fname) static int add_pabopto_inp(const int i) { - FILE *fp = fopen(inpfile[i].fname, "r"); - double theta_out, phi_out, val; - int n, c; + FILE *fp = fopen(inpfile[i].fname, "r"); + double theta_out, phi_out, val; + int n, c; if (fp == NULL || fseek(fp, inpfile[i].dstart, 0) == EOF) { fputs(inpfile[i].fname, stderr); @@ -124,8 +125,8 @@ add_pabopto_inp(const int i) return(0); } /* prepare input grid */ - if (!i || cmp_inang(&inpfile[i-1], &inpfile[i])) { - if (i) /* need to process previous incidence */ + if (!i || cmp_indir(&inpfile[i-1], &inpfile[i])) { + if (i) /* process previous incidence */ make_rbfrep(); #ifdef DEBUG fprintf(stderr, "New incident (theta,phi)=(%f,%f)\n", @@ -183,7 +184,7 @@ main(int argc, char *argv[]) for (i = 0; i < ninpfiles; i++) if (!init_pabopto_inp(i, argv[i+1])) return(1); - qsort(inpfile, ninpfiles, sizeof(PGINPUT), &cmp_inang); + qsort(inpfile, ninpfiles, sizeof(PGINPUT), &cmp_indir); /* compile measurements */ for (i = 0; i < ninpfiles; i++) if (!add_pabopto_inp(i))
