--- ray/src/cv/pabopto2bsdf.c 2014/03/18 19:08:24 2.17 +++ ray/src/cv/pabopto2bsdf.c 2014/03/19 00:19:11 2.18 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.17 2014/03/18 19:08:24 greg Exp $"; +static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.18 2014/03/19 00:19:11 greg Exp $"; #endif /* * Load measured BSDF data in PAB-Opto format. @@ -25,7 +25,7 @@ typedef struct { long dstart; /* data start offset in file */ } PGINPUT; -const double ANGLE_EPS = 180./2./GRIDRES; +double angle_eps = 0; /* epsilon for angle comparisons */ PGINPUT *inpfile; /* input files sorted by incidence */ int ninpfiles; /* number of input files */ @@ -37,13 +37,13 @@ cmp_inang(const void *p1, const void *p2) const PGINPUT *inp1 = (const PGINPUT *)p1; const PGINPUT *inp2 = (const PGINPUT *)p2; - if (inp1->theta > inp2->theta+ANGLE_EPS) + if (inp1->theta > inp2->theta+angle_eps) return(1); - if (inp1->theta < inp2->theta-ANGLE_EPS) + if (inp1->theta < inp2->theta-angle_eps) return(-1); - if (inp1->phi > inp2->phi+ANGLE_EPS) + if (inp1->phi > inp2->phi+angle_eps) return(1); - if (inp1->phi < inp2->phi-ANGLE_EPS) + if (inp1->phi < inp2->phi-angle_eps) return(-1); return(0); } @@ -124,6 +124,7 @@ add_pabopto_inp(const int i) return(0); } /* prepare input grid */ + angle_eps = 180./2./GRIDRES; if (!i || cmp_inang(&inpfile[i-1], &inpfile[i])) { if (i) /* need to process previous incidence */ make_rbfrep(); @@ -183,6 +184,7 @@ main(int argc, char *argv[]) for (i = 0; i < ninpfiles; i++) if (!init_pabopto_inp(i, argv[i+1])) return(1); + angle_eps = 0; qsort(inpfile, ninpfiles, sizeof(PGINPUT), &cmp_inang); /* compile measurements */ for (i = 0; i < ninpfiles; i++)
