--- ray/src/cv/pabopto2bsdf.c 2014/03/08 01:05:00 2.15 +++ ray/src/cv/pabopto2bsdf.c 2019/03/19 20:27:33 2.31 @@ -1,12 +1,14 @@ #ifndef lint -static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.15 2014/03/08 01:05:00 greg Exp $"; +static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.31 2019/03/19 20:27:33 greg Exp $"; #endif /* * Load measured BSDF data in PAB-Opto format. + * Assumes that surface-normal (Z-axis) faces into room unless -t option given. * * G. Ward */ +#define _USE_MATH_DEFINES #include #include #include @@ -20,30 +22,31 @@ char *progname; typedef struct { const char *fname; /* input file path */ - double theta, phi; /* incident angles (in degrees) */ + double theta, phi; /* input angles (degrees) */ + double up_phi; /* azimuth for "up" direction */ + int igp[2]; /* input grid position */ int isDSF; /* data is DSF (rather than BSDF)? */ + int nspec; /* number of spectral samples */ long dstart; /* data start offset in file */ } PGINPUT; PGINPUT *inpfile; /* input files sorted by incidence */ int ninpfiles; /* number of input files */ +int rev_orient = 0; /* shall we reverse surface orientation? */ + /* Compare incident angles */ static int -cmp_inang(const void *p1, const void *p2) +cmp_indir(const void *p1, const void *p2) { const PGINPUT *inp1 = (const PGINPUT *)p1; const PGINPUT *inp2 = (const PGINPUT *)p2; + int ydif = inp1->igp[1] - inp2->igp[1]; - if (inp1->theta > inp2->theta+FTINY) - return(1); - if (inp1->theta < inp2->theta-FTINY) - return(-1); - if (inp1->phi > inp2->phi+FTINY) - return(1); - if (inp1->phi < inp2->phi-FTINY) - return(-1); - return(0); + if (ydif) + return(ydif); + + return(inp1->igp[0] - inp2->igp[0]); } /* Prepare a PAB-Opto input file by reading its header */ @@ -51,6 +54,7 @@ static int init_pabopto_inp(const int i, const char *fname) { FILE *fp = fopen(fname, "r"); + FVECT dv; char buf[2048]; int c; @@ -61,10 +65,12 @@ init_pabopto_inp(const int i, const char *fname) } inpfile[i].fname = fname; inpfile[i].isDSF = -1; + inpfile[i].nspec = 0; + inpfile[i].up_phi = 0; inpfile[i].theta = inpfile[i].phi = -10001.; /* read header information */ while ((c = getc(fp)) == '#' || c == EOF) { - char typ[32]; + char typ[64]; if (fgets(buf, sizeof(buf), fp) == NULL) { fputs(fname, stderr); fputs(": unexpected EOF\n", stderr); @@ -73,16 +79,24 @@ init_pabopto_inp(const int i, const char *fname) } if (sscanf(buf, "sample_name \"%[^\"]\"", bsdf_name) == 1) continue; + if (sscanf(buf, "colorimetry: %s", typ) == 1) { + if (!strcasecmp(typ, "CIE-XYZ")) + inpfile[i].nspec = 3; + else if (!strcasecmp(typ, "CIE-Y")) + inpfile[i].nspec = 1; + continue; + } if (sscanf(buf, "format: theta phi %s", typ) == 1) { - if (!strcasecmp(typ, "DSF")) { + if (!strcasecmp(typ, "DSF")) inpfile[i].isDSF = 1; - continue; - } - if (!strcasecmp(typ, "BSDF")) { + else if (!strcasecmp(typ, "BSDF") || + !strcasecmp(typ, "BRDF") || + !strcasecmp(typ, "BTDF")) inpfile[i].isDSF = 0; - continue; - } + continue; } + if (sscanf(buf, "upphi %lf", &inpfile[i].up_phi) == 1) + continue; if (sscanf(buf, "intheta %lf", &inpfile[i].theta) == 1) continue; if (sscanf(buf, "inphi %lf", &inpfile[i].phi) == 1) @@ -103,8 +117,21 @@ init_pabopto_inp(const int i, const char *fname) fputs(": unknown incident angle\n", stderr); return(0); } - while (inpfile[i].phi < 0) /* normalize phi direction */ - inpfile[i].phi += 360.; + if (rev_orient) { /* reverse Z-axis to face outside */ + inpfile[i].theta = 180. - inpfile[i].theta; + inpfile[i].phi = 360. - inpfile[i].phi; + } + /* convert to Y-up orientation */ + inpfile[i].phi += 90.-inpfile[i].up_phi; + /* convert angle to grid position */ + dv[2] = sin(M_PI/180.*inpfile[i].theta); + dv[0] = cos(M_PI/180.*inpfile[i].phi)*dv[2]; + dv[1] = sin(M_PI/180.*inpfile[i].phi)*dv[2]; + dv[2] = sqrt(1. - dv[2]*dv[2]); + if (inpfile[i].theta <= FTINY) + inpfile[i].igp[0] = inpfile[i].igp[1] = grid_res/2 - 1; + else + pos_from_vec(inpfile[i].igp, dv); return(1); } @@ -112,9 +139,9 @@ init_pabopto_inp(const int i, const char *fname) static int add_pabopto_inp(const int i) { - FILE *fp = fopen(inpfile[i].fname, "r"); - double theta_out, phi_out, val; - int n, c; + FILE *fp = fopen(inpfile[i].fname, "r"); + double theta_out, phi_out, val[3]; + int n, c; if (fp == NULL || fseek(fp, inpfile[i].dstart, 0) == EOF) { fputs(inpfile[i].fname, stderr); @@ -122,21 +149,36 @@ add_pabopto_inp(const int i) return(0); } /* prepare input grid */ - if (!i || cmp_inang(&inpfile[i-1], &inpfile[i])) { - if (i) /* need to process previous incidence */ + if (!i || cmp_indir(&inpfile[i-1], &inpfile[i])) { + if (i) /* process previous incidence */ make_rbfrep(); #ifdef DEBUG - fprintf(stderr, "New incident (theta,phi)=(%f,%f)\n", + fprintf(stderr, "New incident (theta,phi)=(%.1f,%.1f)\n", inpfile[i].theta, inpfile[i].phi); #endif + if (inpfile[i].nspec) + set_spectral_samples(inpfile[i].nspec); new_bsdf_data(inpfile[i].theta, inpfile[i].phi); } #ifdef DEBUG fprintf(stderr, "Loading measurements from '%s'...\n", inpfile[i].fname); #endif /* read scattering data */ - while (fscanf(fp, "%lf %lf %lf\n", &theta_out, &phi_out, &val) == 3) - add_bsdf_data(theta_out, phi_out, val, inpfile[i].isDSF); + while (fscanf(fp, "%lf %lf %lf", &theta_out, &phi_out, val) == 3) { + for (n = 1; n < inpfile[i].nspec; n++) + if (fscanf(fp, "%lf", val+n) != 1) { + fprintf(stderr, "%s: warning: unexpected EOF\n", + inpfile[i].fname); + fclose(fp); + return(1); + } + if (rev_orient) { /* reverse Z-axis to face outside */ + theta_out = 180. - theta_out; + phi_out = 360. - phi_out; + } + add_bsdf_data(theta_out, phi_out+90.-inpfile[i].up_phi, + val, inpfile[i].isDSF); + } n = 0; while ((c = getc(fp)) != EOF) n += !isspace(c); @@ -163,13 +205,17 @@ main(int argc, char *argv[]) progname = argv[0]; /* get options */ while (argc > 2 && argv[1][0] == '-') { switch (argv[1][1]) { + case 't': + rev_orient = !rev_orient; + break; case 'n': nprocs = atoi(argv[2]); + argv++; argc--; break; default: goto userr; } - argv += 2; argc -= 2; + argv++; argc--; } /* initialize & sort inputs */ ninpfiles = argc - 1; @@ -181,7 +227,7 @@ main(int argc, char *argv[]) for (i = 0; i < ninpfiles; i++) if (!init_pabopto_inp(i, argv[i+1])) return(1); - qsort(inpfile, ninpfiles, sizeof(PGINPUT), &cmp_inang); + qsort(inpfile, ninpfiles, sizeof(PGINPUT), cmp_indir); /* compile measurements */ for (i = 0; i < ninpfiles; i++) if (!add_pabopto_inp(i)) @@ -191,7 +237,7 @@ main(int argc, char *argv[]) save_bsdf_rep(stdout); /* write it out */ return(0); userr: - fprintf(stderr, "Usage: %s [-n nproc] meas1.dat meas2.dat .. > bsdf.sir\n", + fprintf(stderr, "Usage: %s [-t][-n nproc] meas1.dat meas2.dat .. > bsdf.sir\n", progname); return(1); } @@ -207,8 +253,9 @@ main(int argc, char *argv[]) FVECT dir; int i, j, n; + progname = argv[0]; if (argc != 2) { - fprintf(stderr, "Usage: %s input.dat > output.rad\n", argv[0]); + fprintf(stderr, "Usage: %s input.dat > output.rad\n", progname); return(1); } ninpfiles = 1; @@ -216,20 +263,24 @@ main(int argc, char *argv[]) if (!init_pabopto_inp(0, argv[1]) || !add_pabopto_inp(0)) return(1); /* reduce data set */ - make_rbfrep(); + if (make_rbfrep() == NULL) { + fprintf(stderr, "%s: nothing to plot!\n", progname); + exit(1); + } #ifdef DEBUG fprintf(stderr, "Minimum BSDF = %.4f\n", bsdf_min); + fprintf(stderr, "Integrated hemispherical value = %.4f\n", dsf_list->vtotal); #endif min_log = log(bsdf_min*.5 + 1e-5); #if 1 /* produce spheres at meas. */ puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n"); n = 0; - for (i = 0; i < GRIDRES; i++) - for (j = 0; j < GRIDRES; j++) - if (dsf_grid[i][j].nval > 0) { + for (i = 0; i < grid_res; i++) + for (j = 0; j < grid_res; j++) + if (dsf_grid[i][j].sum.n > 0) { ovec_from_pos(dir, i, j); - bsdf = dsf_grid[i][j].vsum / - (dsf_grid[i][j].nval*output_orient*dir[2]); + bsdf = dsf_grid[i][j].sum.v / + ((double)dsf_grid[i][j].sum.n*output_orient*dir[2]); if (bsdf <= bsdf_min*.6) continue; bsdf = log(bsdf + 1e-5) - min_log; @@ -245,7 +296,7 @@ main(int argc, char *argv[]) for (n = 0; n < dsf_list->nrbf; n++) { RBFVAL *rbf = &dsf_list->rbfa[n]; ovec_from_pos(dir, rbf->gx, rbf->gy); - bsdf = eval_rbfrep(dsf_list, dir) / (output_orient*dir[2]); + bsdf = eval_rbfrep(dsf_list, dir); bsdf = log(bsdf + 1e-5) - min_log; printf("red sphere p%04d\n0\n0\n", ++n); printf("4 %.6g %.6g %.6g %.6g\n\n", @@ -256,16 +307,16 @@ main(int argc, char *argv[]) #if 1 /* output continuous surface */ puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 1\n"); fflush(stdout); - sprintf(buf, "gensurf tgreen bsdf - - - %d %d", GRIDRES-1, GRIDRES-1); + sprintf(buf, "gensurf tgreen bsdf - - - %d %d", grid_res-1, grid_res-1); pfp = popen(buf, "w"); if (pfp == NULL) { - fprintf(stderr, "%s: cannot open '| %s'\n", argv[0], buf); + fprintf(stderr, "%s: cannot open '| %s'\n", progname, buf); return(1); } - for (i = 0; i < GRIDRES; i++) - for (j = 0; j < GRIDRES; j++) { + for (i = 0; i < grid_res; i++) + for (j = 0; j < grid_res; j++) { ovec_from_pos(dir, i, j); - bsdf = eval_rbfrep(dsf_list, dir) / (output_orient*dir[2]); + bsdf = eval_rbfrep(dsf_list, dir); bsdf = log(bsdf + 1e-5) - min_log; fprintf(pfp, "%.8e %.8e %.8e\n", dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf);
