root/radiance/ray/src/cv/pabopto2bsdf.c
Revision: 2.16
Committed: Mon Mar 17 01:52:51 2014 UTC (11 years, 4 months ago) by greg
Fixed pabopto2rad for new grid union
2 static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.15 2014/03/08 01:05:00 greg Exp $";
5 * Load measured BSDF data in PAB-Opto format.
6 *
7 * G. Ward
8 */
9
10 #include <stdio.h>
11 #include <stdlib.h>
12 #include <string.h>
13 #include <ctype.h>
14 #include <math.h>
15 #include "platform.h"
16 #include "bsdfrep.h"
17 #include "resolu.h"
18 /* global argv[0] */
19 char *progname;
20
21 typedef struct {
22 const char *fname; /* input file path */
23 double theta, phi; /* incident angles (in degrees) */
24 int isDSF; /* data is DSF (rather than BSDF)? */
25 long dstart; /* data start offset in file */
26 } PGINPUT;
27
28 PGINPUT *inpfile; /* input files sorted by incidence */
29 int ninpfiles; /* number of input files */
30
31 /* Compare incident angles */
32 static int
33 cmp_inang(const void *p1, const void *p2)
34 {
35 const PGINPUT *inp1 = (const PGINPUT *)p1;
36 const PGINPUT *inp2 = (const PGINPUT *)p2;
37
38 if (inp1->theta > inp2->theta+FTINY)
39 return(1);
40 if (inp1->theta < inp2->theta-FTINY)
41 return(-1);
42 if (inp1->phi > inp2->phi+FTINY)
43 return(1);
44 if (inp1->phi < inp2->phi-FTINY)
45 return(-1);
46 return(0);
47 }
48
49 /* Prepare a PAB-Opto input file by reading its header */
50 static int
51 init_pabopto_inp(const int i, const char *fname)
52 {
53 FILE *fp = fopen(fname, "r");
54 char buf[2048];
55 int c;
56
57 if (fp == NULL) {
58 fputs(fname, stderr);
59 fputs(": cannot open\n", stderr);
60 return(0);
61 }
62 inpfile[i].fname = fname;
63 inpfile[i].isDSF = -1;
64 inpfile[i].theta = inpfile[i].phi = -10001.;
65 /* read header information */
66 while ((c = getc(fp)) == '#' || c == EOF) {
67 char typ[32];
68 if (fgets(buf, sizeof(buf), fp) == NULL) {
69 fputs(fname, stderr);
70 fputs(": unexpected EOF\n", stderr);
71 fclose(fp);
72 return(0);
73 }
74 if (sscanf(buf, "sample_name \"%[^\"]\"", bsdf_name) == 1)
75 continue;
76 if (sscanf(buf, "format: theta phi %s", typ) == 1) {
77 if (!strcasecmp(typ, "DSF")) {
78 inpfile[i].isDSF = 1;
79 continue;
80 }
81 if (!strcasecmp(typ, "BSDF")) {
82 inpfile[i].isDSF = 0;
83 continue;
84 }
85 }
86 if (sscanf(buf, "intheta %lf", &inpfile[i].theta) == 1)
87 continue;
88 if (sscanf(buf, "inphi %lf", &inpfile[i].phi) == 1)
89 continue;
90 if (sscanf(buf, "incident_angle %lf %lf",
91 &inpfile[i].theta, &inpfile[i].phi) == 2)
92 continue;
93 }
94 inpfile[i].dstart = ftell(fp) - 1;
95 fclose(fp);
96 if (inpfile[i].isDSF < 0) {
97 fputs(fname, stderr);
98 fputs(": unknown format\n", stderr);
99 return(0);
100 }
101 if ((inpfile[i].theta < -10000.) | (inpfile[i].phi < -10000.)) {
102 fputs(fname, stderr);
103 fputs(": unknown incident angle\n", stderr);
104 return(0);
105 }
106 while (inpfile[i].phi < 0) /* normalize phi direction */
107 inpfile[i].phi += 360.;
108 return(1);
109 }
110
111 /* Load a set of measurements corresponding to a particular incident angle */
112 static int
113 add_pabopto_inp(const int i)
114 {
115 FILE *fp = fopen(inpfile[i].fname, "r");
116 double theta_out, phi_out, val;
117 int n, c;
118
119 if (fp == NULL || fseek(fp, inpfile[i].dstart, 0) == EOF) {
120 fputs(inpfile[i].fname, stderr);
121 fputs(": cannot open\n", stderr);
122 return(0);
123 }
124 /* prepare input grid */
125 if (!i || cmp_inang(&inpfile[i-1], &inpfile[i])) {
126 if (i) /* need to process previous incidence */
127 make_rbfrep();
128 #ifdef DEBUG
129 fprintf(stderr, "New incident (theta,phi)=(%f,%f)\n",
130 inpfile[i].theta, inpfile[i].phi);
131 #endif
132 new_bsdf_data(inpfile[i].theta, inpfile[i].phi);
133 }
134 #ifdef DEBUG
135 fprintf(stderr, "Loading measurements from '%s'...\n", inpfile[i].fname);
136 #endif
137 /* read scattering data */
138 while (fscanf(fp, "%lf %lf %lf\n", &theta_out, &phi_out, &val) == 3)
139 add_bsdf_data(theta_out, phi_out, val, inpfile[i].isDSF);
140 n = 0;
141 while ((c = getc(fp)) != EOF)
142 n += !isspace(c);
143 if (n)
144 fprintf(stderr,
145 "%s: warning: %d unexpected characters past EOD\n",
146 inpfile[i].fname, n);
147 fclose(fp);
148 return(1);
149 }
150
151 #ifndef TEST_MAIN
152 /* Read in PAB-Opto BSDF files and output RBF interpolant */
153 int
154 main(int argc, char *argv[])
155 {
156 extern int nprocs;
157 int i;
158 /* start header */
159 SET_FILE_BINARY(stdout);
160 newheader("RADIANCE", stdout);
161 printargs(argc, argv, stdout);
162 fputnow(stdout);
163 progname = argv[0]; /* get options */
164 while (argc > 2 && argv[1][0] == '-') {
165 switch (argv[1][1]) {
166 case 'n':
167 nprocs = atoi(argv[2]);
168 break;
169 default:
170 goto userr;
171 }
172 argv += 2; argc -= 2;
173 }
174 /* initialize & sort inputs */
175 ninpfiles = argc - 1;
176 if (ninpfiles < 2)
177 goto userr;
178 inpfile = (PGINPUT *)malloc(sizeof(PGINPUT)*ninpfiles);
179 if (inpfile == NULL)
180 return(1);
181 for (i = 0; i < ninpfiles; i++)
182 if (!init_pabopto_inp(i, argv[i+1]))
183 return(1);
184 qsort(inpfile, ninpfiles, sizeof(PGINPUT), &cmp_inang);
185 /* compile measurements */
186 for (i = 0; i < ninpfiles; i++)
187 if (!add_pabopto_inp(i))
188 return(1);
189 make_rbfrep(); /* process last data set */
190 build_mesh(); /* create interpolation */
191 save_bsdf_rep(stdout); /* write it out */
192 return(0);
193 userr:
194 fprintf(stderr, "Usage: %s [-n nproc] meas1.dat meas2.dat .. > bsdf.sir\n",
195 progname);
196 return(1);
197 }
198 #else
199 /* Test main produces a Radiance model from the given input file */
200 int
201 main(int argc, char *argv[])
202 {
203 PGINPUT pginp;
204 char buf[128];
205 FILE *pfp;
206 double bsdf, min_log;
207 FVECT dir;
208 int i, j, n;
209
210 if (argc != 2) {
211 fprintf(stderr, "Usage: %s input.dat > output.rad\n", argv[0]);
212 return(1);
213 }
214 ninpfiles = 1;
215 inpfile = &pginp;
216 if (!init_pabopto_inp(0, argv[1]) || !add_pabopto_inp(0))
217 return(1);
218 /* reduce data set */
219 make_rbfrep();
220 #ifdef DEBUG
221 fprintf(stderr, "Minimum BSDF = %.4f\n", bsdf_min);
222 #endif
223 min_log = log(bsdf_min*.5 + 1e-5);
224 #if 1 /* produce spheres at meas. */
225 puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n");
226 n = 0;
227 for (i = 0; i < GRIDRES; i++)
228 for (j = 0; j < GRIDRES; j++)
229 if (dsf_grid[i][j].sum.n > 0) {
230 ovec_from_pos(dir, i, j);
231 bsdf = dsf_grid[i][j].sum.v /
232 (dsf_grid[i][j].sum.n*output_orient*dir[2]);
233 if (bsdf <= bsdf_min*.6)
234 continue;
235 bsdf = log(bsdf + 1e-5) - min_log;
236 ovec_from_pos(dir, i, j);
237 printf("yellow sphere s%04d\n0\n0\n", ++n);
238 printf("4 %.6g %.6g %.6g %.6g\n\n",
239 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
240 .007*bsdf);
241 }
242 #endif
243 #if 1 /* spheres at RBF peaks */
244 puts("void plastic red\n0\n0\n5 .8 .01 .01 .04 .08\n");
245 for (n = 0; n < dsf_list->nrbf; n++) {
246 RBFVAL *rbf = &dsf_list->rbfa[n];
247 ovec_from_pos(dir, rbf->gx, rbf->gy);
248 bsdf = eval_rbfrep(dsf_list, dir) / (output_orient*dir[2]);
249 bsdf = log(bsdf + 1e-5) - min_log;
250 printf("red sphere p%04d\n0\n0\n", ++n);
251 printf("4 %.6g %.6g %.6g %.6g\n\n",
252 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
253 .011*bsdf);
254 }
255 #endif
256 #if 1 /* output continuous surface */
257 puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 1\n");
258 fflush(stdout);
259 sprintf(buf, "gensurf tgreen bsdf - - - %d %d", GRIDRES-1, GRIDRES-1);
260 pfp = popen(buf, "w");
261 if (pfp == NULL) {
262 fprintf(stderr, "%s: cannot open '| %s'\n", argv[0], buf);
263 return(1);
264 }
265 for (i = 0; i < GRIDRES; i++)
266 for (j = 0; j < GRIDRES; j++) {
267 ovec_from_pos(dir, i, j);
268 bsdf = eval_rbfrep(dsf_list, dir) / (output_orient*dir[2]);
269 bsdf = log(bsdf + 1e-5) - min_log;
270 fprintf(pfp, "%.8e %.8e %.8e\n",
271 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf);
272 }
273 if (pclose(pfp) != 0)
274 return(1);
275 #endif
276 return(0);
277 }
278 #endif
