root/radiance/ray/src/cv/pabopto2bsdf.c
Fri Jul 19 17:37:56 2019 UTC (4 years, 10 months ago) by greg
Diff to previous 2.35 , to selected 2.3
Tue Apr 23 23:48:33 2019 UTC (5 years, 1 month ago) by greg
Changes since 2.34: +49 -51 lines
Diff to previous 2.34 , to selected 2.3
Simplified and improved last change
Tue Apr 23 17:18:18 2019 UTC (5 years, 1 month ago) by greg
Changes since 2.33: +7 -4 lines
Diff to previous 2.33 , to selected 2.3
Added checks for other illegal phi coverage flags
Tue Apr 23 17:00:40 2019 UTC (5 years, 1 month ago) by greg
Changes since 2.32: +61 -4 lines
Diff to previous 2.32 , to selected 2.3
Added -s option to specify input symmetry
Tue Apr 9 22:15:51 2019 UTC (5 years, 2 months ago) by greg
Changes since 2.31: +1 -2 lines
Diff to previous 2.31 , to selected 2.3
Removed redundant debug output (already in bsdfrbf.c)
Tue Mar 19 20:27:33 2019 UTC (5 years, 2 months ago) by greg
Changes since 2.30: +2 -1 lines
Diff to previous 2.30 , to selected 2.3
Added debug output of integrated scattering to pabopto2rad
Tue May 16 20:41:03 2017 UTC (7 years ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.29: +5 -2 lines
Diff to previous 2.29 , to selected 2.3
Fixed issue with theta=0 inputs
Tue Feb 2 00:42:11 2016 UTC (8 years, 4 months ago) by greg
Changes since 2.28: +18 -3 lines
Diff to previous 2.28 , to selected 2.3
Added -t option to reverse coordinate orientation
Fri Jan 29 16:21:56 2016 UTC (8 years, 4 months ago) by greg
Changes since 2.27: +32 -16 lines
Diff to previous 2.27 , to selected 2.3
Fri Oct 3 21:57:06 2014 UTC (9 years, 8 months ago) by greg
CVS Tags: rad4R2P2, rad5R0
Changes since 2.26: +10 -3 lines
Diff to previous 2.26 , to selected 2.3
Thu Aug 21 10:33:48 2014 UTC (9 years, 9 months ago) by greg
CVS Tags: rad4R2P1
Diff to previous 2.25 , to selected 2.3
Fri Jun 6 00:58:22 2014 UTC (10 years ago) by greg
CVS Tags: rad4R2
Diff to previous 2.24 , to selected 2.3
Removed redundant address operator
Mon Mar 24 02:31:02 2014 UTC (10 years, 2 months ago) by greg
Diff to previous 2.23 , to selected 2.3
Bug fix for BTDF sample point plotting in debug version (pabopto2rad)
Sun Mar 23 17:46:25 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.22: +4 -2 lines
Diff to previous 2.22 , to selected 2.3
Made more accepting of older Mountain formats
Fri Mar 21 23:11:44 2014 UTC (10 years, 2 months ago) by greg
Diff to previous 2.21 , to selected 2.3
Fixed format on debug statement
Fri Mar 21 01:04:42 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.20: +8 -4 lines
Diff to previous 2.20 , to selected 2.3
Changed behavior so bad incident directions are skipped rather than dying
Thu Mar 20 16:54:23 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.19: +20 -23 lines
Diff to previous 2.19 , to selected 2.3
Hopefully final change to angle collusion method
Wed Mar 19 19:48:57 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.18: +8 -6 lines
Diff to previous 2.18 , to selected 2.3
Fixed potential bug due with closely-spaced incident angles
Wed Mar 19 00:19:11 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.17: +8 -6 lines
Diff to previous 2.17 , to selected 2.3
Rejiggered epsilon tests so as not to confuse qsort()
Tue Mar 18 19:08:24 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.16: +7 -5 lines
Diff to previous 2.16 , to selected 2.3
Increased epsilon for incident angle equivalence test
Mon Mar 17 01:52:51 2014 UTC (10 years, 2 months ago) by greg
Diff to previous 2.15 , to selected 2.3
Fixed pabopto2rad for new grid union
Sat Mar 8 01:05:00 2014 UTC (10 years, 3 months ago) by greg
Diff to previous 2.14 , to selected 2.3
Fixed compiler warnings
Thu Feb 20 09:21:32 2014 UTC (10 years, 3 months ago) by greg
Diff to previous 2.13 , to selected 2.3
Mon Feb 17 21:56:22 2014 UTC (10 years, 3 months ago) by greg
Diff to previous 2.12 , to selected 2.3
Fri Jan 31 00:47:10 2014 UTC (10 years, 4 months ago) by greg
Diff to previous 2.11 , to selected 2.3
Moved misplaced assignment
Thu Jan 30 18:19:43 2014 UTC (10 years, 4 months ago) by greg
Changes since 2.10: +21 -4 lines
Diff to previous 2.10 , to selected 2.3
Added RBF peak locations to Radiance output (-DTEST_MAIN)
Sat Nov 9 05:47:49 2013 UTC (10 years, 7 months ago) by greg
Changes since 2.9: +3 -1 lines
Diff to previous 2.9 , to selected 2.3
Fri Nov 8 03:43:01 2013 UTC (10 years, 7 months ago) by greg
Added debugging output for pabopto2rad test module
Tue Oct 22 04:29:27 2013 UTC (10 years, 7 months ago) by greg
Changes since 2.7: +6 -6 lines
Mon Oct 21 18:33:15 2013 UTC (10 years, 7 months ago) by greg
Changes since 2.6: +7 -18 lines
Sat Oct 19 00:11:50 2013 UTC (10 years, 7 months ago) by greg
Changes since 2.5: +75 -1 lines
Thu Sep 12 16:09:31 2013 UTC (10 years, 9 months ago) by greg
Changes since 2.4: +11 -8 lines
Fixed brittle parser that was not recognizing format from different systems
Sun Jun 30 14:46:29 2013 UTC (10 years, 11 months ago) by greg
Added normalization step for azimuth angle
Sat Jun 29 22:38:25 2013 UTC (10 years, 11 months ago) by greg
Fixed debug output a bit
Sat Jun 29 22:35:15 2013 UTC (10 years, 11 months ago) by greg
Changes since 2.1: +94 -26 lines
Added handling of multiple input files with identical incident angles
Fri Oct 19 04:14:29 2012 UTC (11 years, 7 months ago) by greg
Diff to selected 2.3
