--- ray/src/cv/pabopto2bsdf.c 2016/01/29 16:21:56 2.28 +++ ray/src/cv/pabopto2bsdf.c 2016/02/02 00:42:11 2.29 @@ -1,8 +1,9 @@ #ifndef lint -static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.28 2016/01/29 16:21:56 greg Exp $"; +static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.29 2016/02/02 00:42:11 greg Exp $"; #endif /* * Load measured BSDF data in PAB-Opto format. + * Assumes that surface-normal (Z-axis) faces into room unless -t option given. * * G. Ward */ @@ -32,6 +33,8 @@ typedef struct { PGINPUT *inpfile; /* input files sorted by incidence */ int ninpfiles; /* number of input files */ +int rev_orient = 0; /* shall we reverse surface orientation? */ + /* Compare incident angles */ static int cmp_indir(const void *p1, const void *p2) @@ -114,6 +117,10 @@ init_pabopto_inp(const int i, const char *fname) fputs(": unknown incident angle\n", stderr); return(0); } + if (rev_orient) { /* reverse Z-axis to face outside */ + inpfile[i].theta = 180. - inpfile[i].theta; + inpfile[i].phi = 360. - inpfile[i].phi; + } /* convert to Y-up orientation */ inpfile[i].phi += 90.-inpfile[i].up_phi; /* convert angle to grid position */ @@ -162,6 +169,10 @@ add_pabopto_inp(const int i) fclose(fp); return(1); } + if (rev_orient) { /* reverse Z-axis to face outside */ + theta_out = 180. - theta_out; + phi_out = 360. - phi_out; + } add_bsdf_data(theta_out, phi_out+90.-inpfile[i].up_phi, val, inpfile[i].isDSF); } @@ -191,13 +202,17 @@ main(int argc, char *argv[]) progname = argv[0]; /* get options */ while (argc > 2 && argv[1][0] == '-') { switch (argv[1][1]) { + case 't': + rev_orient = !rev_orient; + break; case 'n': nprocs = atoi(argv[2]); + argv++; argc--; break; default: goto userr; } - argv += 2; argc -= 2; + argv++; argc--; } /* initialize & sort inputs */ ninpfiles = argc - 1; @@ -219,7 +234,7 @@ main(int argc, char *argv[]) save_bsdf_rep(stdout); /* write it out */ return(0); userr: - fprintf(stderr, "Usage: %s [-n nproc] meas1.dat meas2.dat .. > bsdf.sir\n", + fprintf(stderr, "Usage: %s [-t][-n nproc] meas1.dat meas2.dat .. > bsdf.sir\n", progname); return(1); }
