root/radiance/ray/src/cv/pabopto2bsdf.c
Revision: 2.18
Committed: Wed Mar 19 00:19:11 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.17: +8 -6 lines
Rejiggered epsilon tests so as not to confuse qsort()
2 static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.17 2014/03/18 19:08:24 greg Exp $";
5 * Load measured BSDF data in PAB-Opto format.
6 *
7 * G. Ward
8 */
9
10 #include <stdio.h>
11 #include <stdlib.h>
12 #include <string.h>
13 #include <ctype.h>
14 #include <math.h>
15 #include "platform.h"
16 #include "bsdfrep.h"
17 #include "resolu.h"
18 /* global argv[0] */
19 char *progname;
20
21 typedef struct {
22 const char *fname; /* input file path */
23 double theta, phi; /* incident angles (in degrees) */
24 int isDSF; /* data is DSF (rather than BSDF)? */
25 long dstart; /* data start offset in file */
26 } PGINPUT;
27
28 double angle_eps = 0; /* epsilon for angle comparisons */
29
30 PGINPUT *inpfile; /* input files sorted by incidence */
31 int ninpfiles; /* number of input files */
32
33 /* Compare incident angles */
34 static int
35 cmp_inang(const void *p1, const void *p2)
36 {
37 const PGINPUT *inp1 = (const PGINPUT *)p1;
38 const PGINPUT *inp2 = (const PGINPUT *)p2;
39
40 if (inp1->theta > inp2->theta+angle_eps)
41 return(1);
42 if (inp1->theta < inp2->theta-angle_eps)
43 return(-1);
44 if (inp1->phi > inp2->phi+angle_eps)
45 return(1);
46 if (inp1->phi < inp2->phi-angle_eps)
47 return(-1);
48 return(0);
49 }
50
51 /* Prepare a PAB-Opto input file by reading its header */
52 static int
53 init_pabopto_inp(const int i, const char *fname)
54 {
55 FILE *fp = fopen(fname, "r");
56 char buf[2048];
57 int c;
58
59 if (fp == NULL) {
60 fputs(fname, stderr);
61 fputs(": cannot open\n", stderr);
62 return(0);
63 }
64 inpfile[i].fname = fname;
65 inpfile[i].isDSF = -1;
66 inpfile[i].theta = inpfile[i].phi = -10001.;
67 /* read header information */
68 while ((c = getc(fp)) == '#' || c == EOF) {
69 char typ[32];
70 if (fgets(buf, sizeof(buf), fp) == NULL) {
71 fputs(fname, stderr);
72 fputs(": unexpected EOF\n", stderr);
73 fclose(fp);
74 return(0);
75 }
76 if (sscanf(buf, "sample_name \"%[^\"]\"", bsdf_name) == 1)
77 continue;
78 if (sscanf(buf, "format: theta phi %s", typ) == 1) {
79 if (!strcasecmp(typ, "DSF")) {
80 inpfile[i].isDSF = 1;
81 continue;
82 }
83 if (!strcasecmp(typ, "BSDF")) {
84 inpfile[i].isDSF = 0;
85 continue;
86 }
87 }
88 if (sscanf(buf, "intheta %lf", &inpfile[i].theta) == 1)
89 continue;
90 if (sscanf(buf, "inphi %lf", &inpfile[i].phi) == 1)
91 continue;
92 if (sscanf(buf, "incident_angle %lf %lf",
93 &inpfile[i].theta, &inpfile[i].phi) == 2)
94 continue;
95 }
96 inpfile[i].dstart = ftell(fp) - 1;
97 fclose(fp);
98 if (inpfile[i].isDSF < 0) {
99 fputs(fname, stderr);
100 fputs(": unknown format\n", stderr);
101 return(0);
102 }
103 if ((inpfile[i].theta < -10000.) | (inpfile[i].phi < -10000.)) {
104 fputs(fname, stderr);
105 fputs(": unknown incident angle\n", stderr);
106 return(0);
107 }
108 while (inpfile[i].phi < 0) /* normalize phi direction */
109 inpfile[i].phi += 360.;
110 return(1);
111 }
112
113 /* Load a set of measurements corresponding to a particular incident angle */
114 static int
115 add_pabopto_inp(const int i)
116 {
117 FILE *fp = fopen(inpfile[i].fname, "r");
118 double theta_out, phi_out, val;
119 int n, c;
120
121 if (fp == NULL || fseek(fp, inpfile[i].dstart, 0) == EOF) {
122 fputs(inpfile[i].fname, stderr);
123 fputs(": cannot open\n", stderr);
124 return(0);
125 }
126 /* prepare input grid */
127 angle_eps = 180./2./GRIDRES;
128 if (!i || cmp_inang(&inpfile[i-1], &inpfile[i])) {
129 if (i) /* need to process previous incidence */
130 make_rbfrep();
131 #ifdef DEBUG
132 fprintf(stderr, "New incident (theta,phi)=(%f,%f)\n",
133 inpfile[i].theta, inpfile[i].phi);
134 #endif
135 new_bsdf_data(inpfile[i].theta, inpfile[i].phi);
136 }
137 #ifdef DEBUG
138 fprintf(stderr, "Loading measurements from '%s'...\n", inpfile[i].fname);
139 #endif
140 /* read scattering data */
141 while (fscanf(fp, "%lf %lf %lf\n", &theta_out, &phi_out, &val) == 3)
142 add_bsdf_data(theta_out, phi_out, val, inpfile[i].isDSF);
143 n = 0;
144 while ((c = getc(fp)) != EOF)
145 n += !isspace(c);
146 if (n)
147 fprintf(stderr,
148 "%s: warning: %d unexpected characters past EOD\n",
149 inpfile[i].fname, n);
150 fclose(fp);
151 return(1);
152 }
153
154 #ifndef TEST_MAIN
155 /* Read in PAB-Opto BSDF files and output RBF interpolant */
156 int
157 main(int argc, char *argv[])
158 {
159 extern int nprocs;
160 int i;
161 /* start header */
162 SET_FILE_BINARY(stdout);
163 newheader("RADIANCE", stdout);
164 printargs(argc, argv, stdout);
165 fputnow(stdout);
166 progname = argv[0]; /* get options */
167 while (argc > 2 && argv[1][0] == '-') {
168 switch (argv[1][1]) {
169 case 'n':
170 nprocs = atoi(argv[2]);
171 break;
172 default:
173 goto userr;
174 }
175 argv += 2; argc -= 2;
176 }
177 /* initialize & sort inputs */
178 ninpfiles = argc - 1;
179 if (ninpfiles < 2)
180 goto userr;
181 inpfile = (PGINPUT *)malloc(sizeof(PGINPUT)*ninpfiles);
182 if (inpfile == NULL)
183 return(1);
184 for (i = 0; i < ninpfiles; i++)
185 if (!init_pabopto_inp(i, argv[i+1]))
186 return(1);
187 angle_eps = 0;
188 qsort(inpfile, ninpfiles, sizeof(PGINPUT), &cmp_inang);
189 /* compile measurements */
190 for (i = 0; i < ninpfiles; i++)
191 if (!add_pabopto_inp(i))
192 return(1);
193 make_rbfrep(); /* process last data set */
194 build_mesh(); /* create interpolation */
195 save_bsdf_rep(stdout); /* write it out */
196 return(0);
197 userr:
198 fprintf(stderr, "Usage: %s [-n nproc] meas1.dat meas2.dat .. > bsdf.sir\n",
199 progname);
200 return(1);
201 }
202 #else
203 /* Test main produces a Radiance model from the given input file */
204 int
205 main(int argc, char *argv[])
206 {
207 PGINPUT pginp;
208 char buf[128];
209 FILE *pfp;
210 double bsdf, min_log;
211 FVECT dir;
212 int i, j, n;
213
214 if (argc != 2) {
215 fprintf(stderr, "Usage: %s input.dat > output.rad\n", argv[0]);
216 return(1);
217 }
218 ninpfiles = 1;
219 inpfile = &pginp;
220 if (!init_pabopto_inp(0, argv[1]) || !add_pabopto_inp(0))
221 return(1);
222 /* reduce data set */
223 make_rbfrep();
224 #ifdef DEBUG
225 fprintf(stderr, "Minimum BSDF = %.4f\n", bsdf_min);
226 #endif
227 min_log = log(bsdf_min*.5 + 1e-5);
228 #if 1 /* produce spheres at meas. */
229 puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n");
230 n = 0;
231 for (i = 0; i < GRIDRES; i++)
232 for (j = 0; j < GRIDRES; j++)
233 if (dsf_grid[i][j].sum.n > 0) {
234 ovec_from_pos(dir, i, j);
235 bsdf = dsf_grid[i][j].sum.v /
236 (dsf_grid[i][j].sum.n*output_orient*dir[2]);
237 if (bsdf <= bsdf_min*.6)
238 continue;
239 bsdf = log(bsdf + 1e-5) - min_log;
240 ovec_from_pos(dir, i, j);
241 printf("yellow sphere s%04d\n0\n0\n", ++n);
242 printf("4 %.6g %.6g %.6g %.6g\n\n",
243 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
244 .007*bsdf);
245 }
246 #endif
247 #if 1 /* spheres at RBF peaks */
248 puts("void plastic red\n0\n0\n5 .8 .01 .01 .04 .08\n");
249 for (n = 0; n < dsf_list->nrbf; n++) {
250 RBFVAL *rbf = &dsf_list->rbfa[n];
251 ovec_from_pos(dir, rbf->gx, rbf->gy);
252 bsdf = eval_rbfrep(dsf_list, dir) / (output_orient*dir[2]);
253 bsdf = log(bsdf + 1e-5) - min_log;
254 printf("red sphere p%04d\n0\n0\n", ++n);
255 printf("4 %.6g %.6g %.6g %.6g\n\n",
256 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
257 .011*bsdf);
258 }
259 #endif
260 #if 1 /* output continuous surface */
261 puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 1\n");
262 fflush(stdout);
263 sprintf(buf, "gensurf tgreen bsdf - - - %d %d", GRIDRES-1, GRIDRES-1);
264 pfp = popen(buf, "w");
265 if (pfp == NULL) {
266 fprintf(stderr, "%s: cannot open '| %s'\n", argv[0], buf);
267 return(1);
268 }
269 for (i = 0; i < GRIDRES; i++)
270 for (j = 0; j < GRIDRES; j++) {
271 ovec_from_pos(dir, i, j);
272 bsdf = eval_rbfrep(dsf_list, dir) / (output_orient*dir[2]);
273 bsdf = log(bsdf + 1e-5) - min_log;
274 fprintf(pfp, "%.8e %.8e %.8e\n",
275 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf);
276 }
277 if (pclose(pfp) != 0)
278 return(1);
279 #endif
280 return(0);
281 }
282 #endif
