root/radiance/ray/src/cv/pabopto2bsdf.c
Revision: 2.30
Committed: Tue May 16 20:41:03 2017 UTC (7 years, 11 months ago) by greg
CVS Tags: rad5R2, rad5R1
Changes since 2.29: +5 -2 lines
Fixed issue with theta=0 inputs
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.30 static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.29 2016/02/02 00:42:11 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Load measured BSDF data in PAB-Opto format.
6 greg 2.29 * Assumes that surface-normal (Z-axis) faces into room unless -t option given.
7 greg 2.1 *
8     * G. Ward
9     */
10
11 greg 2.20 #define _USE_MATH_DEFINES
12 greg 2.1 #include <stdio.h>
13 greg 2.2 #include <stdlib.h>
14 greg 2.1 #include <string.h>
15     #include <ctype.h>
16 greg 2.6 #include <math.h>
17 greg 2.1 #include "platform.h"
18     #include "bsdfrep.h"
19 greg 2.15 #include "resolu.h"
20 greg 2.1 /* global argv[0] */
21     char *progname;
22
23 greg 2.2 typedef struct {
24     const char *fname; /* input file path */
25 greg 2.27 double theta, phi; /* input angles (degrees) */
26     double up_phi; /* azimuth for "up" direction */
27 greg 2.20 int igp[2]; /* input grid position */
28 greg 2.2 int isDSF; /* data is DSF (rather than BSDF)? */
29 greg 2.28 int nspec; /* number of spectral samples */
30 greg 2.2 long dstart; /* data start offset in file */
31     } PGINPUT;
32
33     PGINPUT *inpfile; /* input files sorted by incidence */
34     int ninpfiles; /* number of input files */
35
36 greg 2.29 int rev_orient = 0; /* shall we reverse surface orientation? */
37
38 greg 2.2 /* Compare incident angles */
39     static int
40 greg 2.20 cmp_indir(const void *p1, const void *p2)
41 greg 2.2 {
42     const PGINPUT *inp1 = (const PGINPUT *)p1;
43     const PGINPUT *inp2 = (const PGINPUT *)p2;
44 greg 2.20 int ydif = inp1->igp[1] - inp2->igp[1];
45 greg 2.2
46 greg 2.20 if (ydif)
47     return(ydif);
48
49     return(inp1->igp[0] - inp2->igp[0]);
50 greg 2.2 }
51
52     /* Prepare a PAB-Opto input file by reading its header */
53 greg 2.1 static int
54 greg 2.2 init_pabopto_inp(const int i, const char *fname)
55 greg 2.1 {
56     FILE *fp = fopen(fname, "r");
57 greg 2.20 FVECT dv;
58 greg 2.1 char buf[2048];
59 greg 2.2 int c;
60 greg 2.1
61     if (fp == NULL) {
62     fputs(fname, stderr);
63     fputs(": cannot open\n", stderr);
64     return(0);
65     }
66 greg 2.2 inpfile[i].fname = fname;
67     inpfile[i].isDSF = -1;
68 greg 2.28 inpfile[i].nspec = 0;
69 greg 2.27 inpfile[i].up_phi = 0;
70 greg 2.2 inpfile[i].theta = inpfile[i].phi = -10001.;
71 greg 2.1 /* read header information */
72     while ((c = getc(fp)) == '#' || c == EOF) {
73 greg 2.28 char typ[64];
74 greg 2.1 if (fgets(buf, sizeof(buf), fp) == NULL) {
75     fputs(fname, stderr);
76     fputs(": unexpected EOF\n", stderr);
77     fclose(fp);
78     return(0);
79     }
80 greg 2.10 if (sscanf(buf, "sample_name \"%[^\"]\"", bsdf_name) == 1)
81     continue;
82 greg 2.28 if (sscanf(buf, "colorimetry: %s", typ) == 1) {
83     if (!strcasecmp(typ, "CIE-XYZ"))
84     inpfile[i].nspec = 3;
85     else if (!strcasecmp(typ, "CIE-Y"))
86     inpfile[i].nspec = 1;
87     continue;
88     }
89 greg 2.5 if (sscanf(buf, "format: theta phi %s", typ) == 1) {
90 greg 2.28 if (!strcasecmp(typ, "DSF"))
91 greg 2.5 inpfile[i].isDSF = 1;
92 greg 2.28 else if (!strcasecmp(typ, "BSDF") ||
93 greg 2.23 !strcasecmp(typ, "BRDF") ||
94 greg 2.28 !strcasecmp(typ, "BTDF"))
95 greg 2.5 inpfile[i].isDSF = 0;
96 greg 2.28 continue;
97 greg 2.1 }
98 greg 2.27 if (sscanf(buf, "upphi %lf", &inpfile[i].up_phi) == 1)
99     continue;
100 greg 2.2 if (sscanf(buf, "intheta %lf", &inpfile[i].theta) == 1)
101 greg 2.1 continue;
102 greg 2.2 if (sscanf(buf, "inphi %lf", &inpfile[i].phi) == 1)
103 greg 2.1 continue;
104     if (sscanf(buf, "incident_angle %lf %lf",
105 greg 2.2 &inpfile[i].theta, &inpfile[i].phi) == 2)
106 greg 2.1 continue;
107     }
108 greg 2.2 inpfile[i].dstart = ftell(fp) - 1;
109     fclose(fp);
110     if (inpfile[i].isDSF < 0) {
111 greg 2.1 fputs(fname, stderr);
112     fputs(": unknown format\n", stderr);
113     return(0);
114     }
115 greg 2.2 if ((inpfile[i].theta < -10000.) | (inpfile[i].phi < -10000.)) {
116     fputs(fname, stderr);
117     fputs(": unknown incident angle\n", stderr);
118     return(0);
119     }
120 greg 2.29 if (rev_orient) { /* reverse Z-axis to face outside */
121     inpfile[i].theta = 180. - inpfile[i].theta;
122     inpfile[i].phi = 360. - inpfile[i].phi;
123     }
124 greg 2.27 /* convert to Y-up orientation */
125     inpfile[i].phi += 90.-inpfile[i].up_phi;
126 greg 2.20 /* convert angle to grid position */
127     dv[2] = sin(M_PI/180.*inpfile[i].theta);
128     dv[0] = cos(M_PI/180.*inpfile[i].phi)*dv[2];
129     dv[1] = sin(M_PI/180.*inpfile[i].phi)*dv[2];
130     dv[2] = sqrt(1. - dv[2]*dv[2]);
131 greg 2.30 if (inpfile[i].theta <= FTINY)
132     inpfile[i].igp[0] = inpfile[i].igp[1] = grid_res/2 - 1;
133     else
134     pos_from_vec(inpfile[i].igp, dv);
135 greg 2.2 return(1);
136     }
137
138     /* Load a set of measurements corresponding to a particular incident angle */
139     static int
140     add_pabopto_inp(const int i)
141     {
142 greg 2.19 FILE *fp = fopen(inpfile[i].fname, "r");
143 greg 2.28 double theta_out, phi_out, val[3];
144 greg 2.19 int n, c;
145 greg 2.2
146     if (fp == NULL || fseek(fp, inpfile[i].dstart, 0) == EOF) {
147     fputs(inpfile[i].fname, stderr);
148     fputs(": cannot open\n", stderr);
149     return(0);
150     }
151 greg 2.1 /* prepare input grid */
152 greg 2.20 if (!i || cmp_indir(&inpfile[i-1], &inpfile[i])) {
153     if (i) /* process previous incidence */
154 greg 2.2 make_rbfrep();
155     #ifdef DEBUG
156 greg 2.22 fprintf(stderr, "New incident (theta,phi)=(%.1f,%.1f)\n",
157 greg 2.2 inpfile[i].theta, inpfile[i].phi);
158     #endif
159 greg 2.28 if (inpfile[i].nspec)
160     set_spectral_samples(inpfile[i].nspec);
161 greg 2.2 new_bsdf_data(inpfile[i].theta, inpfile[i].phi);
162     }
163 greg 2.3 #ifdef DEBUG
164     fprintf(stderr, "Loading measurements from '%s'...\n", inpfile[i].fname);
165     #endif
166 greg 2.2 /* read scattering data */
167 greg 2.28 while (fscanf(fp, "%lf %lf %lf", &theta_out, &phi_out, val) == 3) {
168     for (n = 1; n < inpfile[i].nspec; n++)
169     if (fscanf(fp, "%lf", val+n) != 1) {
170     fprintf(stderr, "%s: warning: unexpected EOF\n",
171     inpfile[i].fname);
172     fclose(fp);
173     return(1);
174     }
175 greg 2.29 if (rev_orient) { /* reverse Z-axis to face outside */
176     theta_out = 180. - theta_out;
177     phi_out = 360. - phi_out;
178     }
179 greg 2.27 add_bsdf_data(theta_out, phi_out+90.-inpfile[i].up_phi,
180     val, inpfile[i].isDSF);
181 greg 2.28 }
182 greg 2.1 n = 0;
183     while ((c = getc(fp)) != EOF)
184     n += !isspace(c);
185     if (n)
186     fprintf(stderr,
187     "%s: warning: %d unexpected characters past EOD\n",
188 greg 2.2 inpfile[i].fname, n);
189 greg 2.1 fclose(fp);
190     return(1);
191     }
192
193 greg 2.8 #ifndef TEST_MAIN
194 greg 2.1 /* Read in PAB-Opto BSDF files and output RBF interpolant */
195     int
196     main(int argc, char *argv[])
197     {
198     extern int nprocs;
199     int i;
200     /* start header */
201     SET_FILE_BINARY(stdout);
202     newheader("RADIANCE", stdout);
203     printargs(argc, argv, stdout);
204     fputnow(stdout);
205     progname = argv[0]; /* get options */
206     while (argc > 2 && argv[1][0] == '-') {
207     switch (argv[1][1]) {
208 greg 2.29 case 't':
209     rev_orient = !rev_orient;
210     break;
211 greg 2.1 case 'n':
212     nprocs = atoi(argv[2]);
213 greg 2.29 argv++; argc--;
214 greg 2.1 break;
215     default:
216     goto userr;
217     }
218 greg 2.29 argv++; argc--;
219 greg 2.1 }
220 greg 2.2 /* initialize & sort inputs */
221     ninpfiles = argc - 1;
222     if (ninpfiles < 2)
223 greg 2.1 goto userr;
224 greg 2.2 inpfile = (PGINPUT *)malloc(sizeof(PGINPUT)*ninpfiles);
225     if (inpfile == NULL)
226     return(1);
227     for (i = 0; i < ninpfiles; i++)
228     if (!init_pabopto_inp(i, argv[i+1]))
229 greg 2.1 return(1);
230 greg 2.25 qsort(inpfile, ninpfiles, sizeof(PGINPUT), cmp_indir);
231 greg 2.2 /* compile measurements */
232     for (i = 0; i < ninpfiles; i++)
233     if (!add_pabopto_inp(i))
234     return(1);
235     make_rbfrep(); /* process last data set */
236 greg 2.1 build_mesh(); /* create interpolation */
237     save_bsdf_rep(stdout); /* write it out */
238     return(0);
239     userr:
240 greg 2.29 fprintf(stderr, "Usage: %s [-t][-n nproc] meas1.dat meas2.dat .. > bsdf.sir\n",
241 greg 2.1 progname);
242     return(1);
243     }
244 greg 2.6 #else
245     /* Test main produces a Radiance model from the given input file */
246     int
247     main(int argc, char *argv[])
248     {
249     PGINPUT pginp;
250     char buf[128];
251     FILE *pfp;
252     double bsdf, min_log;
253     FVECT dir;
254     int i, j, n;
255
256 greg 2.21 progname = argv[0];
257 greg 2.6 if (argc != 2) {
258 greg 2.21 fprintf(stderr, "Usage: %s input.dat > output.rad\n", progname);
259 greg 2.6 return(1);
260     }
261     ninpfiles = 1;
262     inpfile = &pginp;
263     if (!init_pabopto_inp(0, argv[1]) || !add_pabopto_inp(0))
264     return(1);
265     /* reduce data set */
266 greg 2.21 if (make_rbfrep() == NULL) {
267     fprintf(stderr, "%s: nothing to plot!\n", progname);
268     exit(1);
269     }
270 greg 2.9 #ifdef DEBUG
271     fprintf(stderr, "Minimum BSDF = %.4f\n", bsdf_min);
272     #endif
273 greg 2.13 min_log = log(bsdf_min*.5 + 1e-5);
274 greg 2.11 #if 1 /* produce spheres at meas. */
275 greg 2.6 puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n");
276     n = 0;
277 greg 2.28 for (i = 0; i < grid_res; i++)
278     for (j = 0; j < grid_res; j++)
279 greg 2.16 if (dsf_grid[i][j].sum.n > 0) {
280 greg 2.6 ovec_from_pos(dir, i, j);
281 greg 2.16 bsdf = dsf_grid[i][j].sum.v /
282 greg 2.24 ((double)dsf_grid[i][j].sum.n*output_orient*dir[2]);
283 greg 2.6 if (bsdf <= bsdf_min*.6)
284     continue;
285 greg 2.14 bsdf = log(bsdf + 1e-5) - min_log;
286 greg 2.7 ovec_from_pos(dir, i, j);
287     printf("yellow sphere s%04d\n0\n0\n", ++n);
288     printf("4 %.6g %.6g %.6g %.6g\n\n",
289 greg 2.6 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
290 greg 2.7 .007*bsdf);
291 greg 2.6 }
292 greg 2.11 #endif
293     #if 1 /* spheres at RBF peaks */
294     puts("void plastic red\n0\n0\n5 .8 .01 .01 .04 .08\n");
295     for (n = 0; n < dsf_list->nrbf; n++) {
296     RBFVAL *rbf = &dsf_list->rbfa[n];
297     ovec_from_pos(dir, rbf->gx, rbf->gy);
298 greg 2.26 bsdf = eval_rbfrep(dsf_list, dir);
299 greg 2.14 bsdf = log(bsdf + 1e-5) - min_log;
300 greg 2.11 printf("red sphere p%04d\n0\n0\n", ++n);
301     printf("4 %.6g %.6g %.6g %.6g\n\n",
302     dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
303     .011*bsdf);
304     }
305     #endif
306     #if 1 /* output continuous surface */
307 greg 2.6 puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 1\n");
308     fflush(stdout);
309 greg 2.28 sprintf(buf, "gensurf tgreen bsdf - - - %d %d", grid_res-1, grid_res-1);
310 greg 2.6 pfp = popen(buf, "w");
311     if (pfp == NULL) {
312 greg 2.21 fprintf(stderr, "%s: cannot open '| %s'\n", progname, buf);
313 greg 2.6 return(1);
314     }
315 greg 2.28 for (i = 0; i < grid_res; i++)
316     for (j = 0; j < grid_res; j++) {
317 greg 2.6 ovec_from_pos(dir, i, j);
318 greg 2.26 bsdf = eval_rbfrep(dsf_list, dir);
319 greg 2.14 bsdf = log(bsdf + 1e-5) - min_log;
320 greg 2.6 fprintf(pfp, "%.8e %.8e %.8e\n",
321     dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf);
322     }
323 greg 2.11 if (pclose(pfp) != 0)
324     return(1);
325     #endif
326     return(0);
327 greg 2.6 }
328     #endif
