root/radiance/ray/src/cv/pabopto2bsdf.c
Fri Oct 3 21:57:06 2014 UTC (9 years, 8 months ago) by greg
CVS Tags: rad4R2P2, rad5R0
Changes since 2.26: +10 -3 lines
Diff to previous 2.26 , to selected 2.18
Thu Aug 21 10:33:48 2014 UTC (9 years, 10 months ago) by greg
CVS Tags: rad4R2P1
Diff to previous 2.25 , to selected 2.18
Fri Jun 6 00:58:22 2014 UTC (10 years ago) by greg
CVS Tags: rad4R2
Diff to previous 2.24 , to selected 2.18
Removed redundant address operator
Mon Mar 24 02:31:02 2014 UTC (10 years, 3 months ago) by greg
Diff to previous 2.23 , to selected 2.18
Bug fix for BTDF sample point plotting in debug version (pabopto2rad)
Sun Mar 23 17:46:25 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.22: +4 -2 lines
Diff to previous 2.22 , to selected 2.18
Made more accepting of older Mountain formats
Fri Mar 21 23:11:44 2014 UTC (10 years, 3 months ago) by greg
Diff to previous 2.21 , to selected 2.18
Fixed format on debug statement
Fri Mar 21 01:04:42 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.20: +8 -4 lines
Diff to previous 2.20 , to selected 2.18
Changed behavior so bad incident directions are skipped rather than dying
Thu Mar 20 16:54:23 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.19: +20 -23 lines
Diff to previous 2.19 , to selected 2.18
Hopefully final change to angle collusion method
Wed Mar 19 19:48:57 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.18: +8 -6 lines
Diff to previous 2.18
Fixed potential bug due with closely-spaced incident angles
Revision 2.18 - (view) (download) (annotate) - [selected]
Wed Mar 19 00:19:11 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.17: +8 -6 lines
Diff to previous 2.17
Rejiggered epsilon tests so as not to confuse qsort()
Tue Mar 18 19:08:24 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.16: +7 -5 lines
Diff to previous 2.16 , to selected 2.18
Increased epsilon for incident angle equivalence test
Mon Mar 17 01:52:51 2014 UTC (10 years, 3 months ago) by greg
Diff to previous 2.15 , to selected 2.18
Fixed pabopto2rad for new grid union
Sat Mar 8 01:05:00 2014 UTC (10 years, 3 months ago) by greg
Diff to previous 2.14 , to selected 2.18
Fixed compiler warnings
Thu Feb 20 09:21:32 2014 UTC (10 years, 4 months ago) by greg
Diff to previous 2.13 , to selected 2.18
Mon Feb 17 21:56:22 2014 UTC (10 years, 4 months ago) by greg
Diff to previous 2.12 , to selected 2.18
Fri Jan 31 00:47:10 2014 UTC (10 years, 4 months ago) by greg
Diff to previous 2.11 , to selected 2.18
Moved misplaced assignment
Thu Jan 30 18:19:43 2014 UTC (10 years, 4 months ago) by greg
Changes since 2.10: +21 -4 lines
Diff to previous 2.10 , to selected 2.18
Added RBF peak locations to Radiance output (-DTEST_MAIN)
Sat Nov 9 05:47:49 2013 UTC (10 years, 7 months ago) by greg
Changes since 2.9: +3 -1 lines
Diff to previous 2.9 , to selected 2.18
Fri Nov 8 03:43:01 2013 UTC (10 years, 7 months ago) by greg
Diff to previous 2.8 , to selected 2.18
Added debugging output for pabopto2rad test module
Tue Oct 22 04:29:27 2013 UTC (10 years, 8 months ago) by greg
Changes since 2.7: +6 -6 lines
Diff to previous 2.7 , to selected 2.18
Mon Oct 21 18:33:15 2013 UTC (10 years, 8 months ago) by greg
Changes since 2.6: +7 -18 lines
Diff to previous 2.6 , to selected 2.18
Sat Oct 19 00:11:50 2013 UTC (10 years, 8 months ago) by greg
Changes since 2.5: +75 -1 lines
Diff to previous 2.5 , to selected 2.18
Thu Sep 12 16:09:31 2013 UTC (10 years, 9 months ago) by greg
Changes since 2.4: +11 -8 lines
Diff to previous 2.4 , to selected 2.18
Fixed brittle parser that was not recognizing format from different systems
Sun Jun 30 14:46:29 2013 UTC (10 years, 11 months ago) by greg
Diff to previous 2.3 , to selected 2.18
Added normalization step for azimuth angle
Sat Jun 29 22:38:25 2013 UTC (10 years, 11 months ago) by greg
Diff to previous 2.2 , to selected 2.18
Fixed debug output a bit
Sat Jun 29 22:35:15 2013 UTC (10 years, 11 months ago) by greg
Changes since 2.1: +94 -26 lines
Diff to previous 2.1 , to selected 2.18
Added handling of multiple input files with identical incident angles
Fri Oct 19 04:14:29 2012 UTC (11 years, 8 months ago) by greg
Diff to selected 2.18
