--- ray/src/cv/pabopto2bsdf.c 2014/03/20 16:54:23 2.20 +++ ray/src/cv/pabopto2bsdf.c 2014/10/03 21:57:06 2.27 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.20 2014/03/20 16:54:23 greg Exp $"; +static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.27 2014/10/03 21:57:06 greg Exp $"; #endif /* * Load measured BSDF data in PAB-Opto format. @@ -21,7 +21,8 @@ char *progname; typedef struct { const char *fname; /* input file path */ - double theta, phi; /* input angles */ + double theta, phi; /* input angles (degrees) */ + double up_phi; /* azimuth for "up" direction */ int igp[2]; /* input grid position */ int isDSF; /* data is DSF (rather than BSDF)? */ long dstart; /* data start offset in file */ @@ -60,6 +61,7 @@ init_pabopto_inp(const int i, const char *fname) } inpfile[i].fname = fname; inpfile[i].isDSF = -1; + inpfile[i].up_phi = 0; inpfile[i].theta = inpfile[i].phi = -10001.; /* read header information */ while ((c = getc(fp)) == '#' || c == EOF) { @@ -77,11 +79,15 @@ init_pabopto_inp(const int i, const char *fname) inpfile[i].isDSF = 1; continue; } - if (!strcasecmp(typ, "BSDF")) { + if (!strcasecmp(typ, "BSDF") || + !strcasecmp(typ, "BRDF") || + !strcasecmp(typ, "BTDF")) { inpfile[i].isDSF = 0; continue; } } + if (sscanf(buf, "upphi %lf", &inpfile[i].up_phi) == 1) + continue; if (sscanf(buf, "intheta %lf", &inpfile[i].theta) == 1) continue; if (sscanf(buf, "inphi %lf", &inpfile[i].phi) == 1) @@ -102,6 +108,8 @@ init_pabopto_inp(const int i, const char *fname) fputs(": unknown incident angle\n", stderr); return(0); } + /* convert to Y-up orientation */ + inpfile[i].phi += 90.-inpfile[i].up_phi; /* convert angle to grid position */ dv[2] = sin(M_PI/180.*inpfile[i].theta); dv[0] = cos(M_PI/180.*inpfile[i].phi)*dv[2]; @@ -129,7 +137,7 @@ add_pabopto_inp(const int i) if (i) /* process previous incidence */ make_rbfrep(); #ifdef DEBUG - fprintf(stderr, "New incident (theta,phi)=(%f,%f)\n", + fprintf(stderr, "New incident (theta,phi)=(%.1f,%.1f)\n", inpfile[i].theta, inpfile[i].phi); #endif new_bsdf_data(inpfile[i].theta, inpfile[i].phi); @@ -139,7 +147,8 @@ add_pabopto_inp(const int i) #endif /* read scattering data */ while (fscanf(fp, "%lf %lf %lf\n", &theta_out, &phi_out, &val) == 3) - add_bsdf_data(theta_out, phi_out, val, inpfile[i].isDSF); + add_bsdf_data(theta_out, phi_out+90.-inpfile[i].up_phi, + val, inpfile[i].isDSF); n = 0; while ((c = getc(fp)) != EOF) n += !isspace(c); @@ -184,7 +193,7 @@ main(int argc, char *argv[]) for (i = 0; i < ninpfiles; i++) if (!init_pabopto_inp(i, argv[i+1])) return(1); - qsort(inpfile, ninpfiles, sizeof(PGINPUT), &cmp_indir); + qsort(inpfile, ninpfiles, sizeof(PGINPUT), cmp_indir); /* compile measurements */ for (i = 0; i < ninpfiles; i++) if (!add_pabopto_inp(i)) @@ -210,8 +219,9 @@ main(int argc, char *argv[]) FVECT dir; int i, j, n; + progname = argv[0]; if (argc != 2) { - fprintf(stderr, "Usage: %s input.dat > output.rad\n", argv[0]); + fprintf(stderr, "Usage: %s input.dat > output.rad\n", progname); return(1); } ninpfiles = 1; @@ -219,7 +229,10 @@ main(int argc, char *argv[]) if (!init_pabopto_inp(0, argv[1]) || !add_pabopto_inp(0)) return(1); /* reduce data set */ - make_rbfrep(); + if (make_rbfrep() == NULL) { + fprintf(stderr, "%s: nothing to plot!\n", progname); + exit(1); + } #ifdef DEBUG fprintf(stderr, "Minimum BSDF = %.4f\n", bsdf_min); #endif @@ -232,7 +245,7 @@ main(int argc, char *argv[]) if (dsf_grid[i][j].sum.n > 0) { ovec_from_pos(dir, i, j); bsdf = dsf_grid[i][j].sum.v / - (dsf_grid[i][j].sum.n*output_orient*dir[2]); + ((double)dsf_grid[i][j].sum.n*output_orient*dir[2]); if (bsdf <= bsdf_min*.6) continue; bsdf = log(bsdf + 1e-5) - min_log; @@ -248,7 +261,7 @@ main(int argc, char *argv[]) for (n = 0; n < dsf_list->nrbf; n++) { RBFVAL *rbf = &dsf_list->rbfa[n]; ovec_from_pos(dir, rbf->gx, rbf->gy); - bsdf = eval_rbfrep(dsf_list, dir) / (output_orient*dir[2]); + bsdf = eval_rbfrep(dsf_list, dir); bsdf = log(bsdf + 1e-5) - min_log; printf("red sphere p%04d\n0\n0\n", ++n); printf("4 %.6g %.6g %.6g %.6g\n\n", @@ -262,13 +275,13 @@ main(int argc, char *argv[]) sprintf(buf, "gensurf tgreen bsdf - - - %d %d", GRIDRES-1, GRIDRES-1); pfp = popen(buf, "w"); if (pfp == NULL) { - fprintf(stderr, "%s: cannot open '| %s'\n", argv[0], buf); + fprintf(stderr, "%s: cannot open '| %s'\n", progname, buf); return(1); } for (i = 0; i < GRIDRES; i++) for (j = 0; j < GRIDRES; j++) { ovec_from_pos(dir, i, j); - bsdf = eval_rbfrep(dsf_list, dir) / (output_orient*dir[2]); + bsdf = eval_rbfrep(dsf_list, dir); bsdf = log(bsdf + 1e-5) - min_log; fprintf(pfp, "%.8e %.8e %.8e\n", dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf);
